path: root/arch/arm/mach-ux500/cpu-db5500.c
2011-05-24mach-ux500: make PRCMU base address dynamicLinus Walleij
This makes the PRCMU base address be selected at runtime for U8500 and U5500 instead of being compiled-in. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-03-14mach-ux500: add MUSB to db5500 devicesMian Yousaf Kaukab
- DMA tx and rx maps for usb channels are set to be configured at runtime - MUSB is enabled with soc specific base address, irq and dma configurations Signed-off-by: Mian Yousaf Kaukab <mian-yousaf.kaukab@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-03-14mach-ux500: add DB5500 PMU resourcesLinus Walleij
This adds the PMU resources necessary to get perf working with the DB5500 ASIC. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-01-10ux500: dynamic SOC detectionRabin Vincent
Dynamically detect the DBx500 SOC an revision based on the ASIC ID. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2011-01-10ux500: remove build-time changing macrosRabin Vincent
To allow the possiblity of building U8500 and U5500 support in the same image. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> [Rebased to latest changes in Russells tree] Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-08ux500: rework gpio registrationRabin Vincent
Rework gpio registration to remove build-time changing macros. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-08ux500: Add DMA support for U5500Per Forlin
Add basic DMA configuration for u5500 supporting memcpy. Make way for SDI0 dma support by setting SDI0 to -1, indicating it will be configured in runtime. Signed-off-by: Per Forlin <per.forlin@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-08ux500: rework device registrationRabin Vincent
Change the Ux500 devices to be dynamically allocated and added by calling functions instead of referencing structures, thereby allowing 5500 and other derivatives' support to be added without having to duplicate structures, use fixup functions, or use compile-time macros. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-10-04ARM: 6413/1: ux500: resources for DB5500 mbox driver and modem irq handlerLinus Walleij
Platform resources found in the DB5500 for mailboxes and the modem IRQ controller. Signed-off-by: Stefan Nilsson XK <stefan.xk.nilsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-09ARM: 6184/2: ux500: use neutral PRCMU baseLinus Walleij
The MTU wallclock timing fix-up patch was hardwired to the DB8500 causing a regression. This makes it work on the DB5500 as well. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-04ARM: 6090/1: ux500: add U5500 supportRabin Vincent
Add basic support for the U5500 platform. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
