Not exported and not used externally.
Fixes a lot of:
arch/arm/mach-tegra/timer.c:75:2: warning: cast removes address space of expression
arch/arm/mach-tegra/timer.c:75:2: warning: incorrect type in argument 1 (different base types)
arch/arm/mach-tegra/timer.c:75:2: expected void const volatile [noderef] <asn:2>*<noident>
arch/arm/mach-tegra/timer.c:75:2: got unsigned int
Convert ixp4xx, lpc32xx, mxc, netx, pxa, sa1100, tcc8k, tegra and u300
to use the generic mmio clocksource recently introduced.
Cc: Imre Kaloz <kaloz@openwrt.org>
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Acked-by: "Hans J. Koch" <hjk@hansjkoch.de>
Acked-by: Colin Cross <ccross@android.com>
Cc: Erik Gilling <konkers@android.com>
Cc: Olof Johansson <olof@lixom.net>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Enable the timer and rtc clocks to prevent them being
turned off by the bootloader clock disabling code.
Signed-off-by: Colin Cross <ccross@android.com>
Acked-by: Olof Johansson <olof@lixom.net>
Implement read_persistent_clock by reading the Tegra RTC
registers that stay running during suspend.
Save and restore the timer configuration register in
suspend.
Convert tegra to use the new sched_clock() infrastructure for extending
32bit counters to full 64-bit nanoseconds.
Tested-by: Olof Johansson <olof@lixom.net>
ftrace requires sched_clock() to be notrace. Ensure that all
implementations are so marked. Also make sure that they include
linux/sched.h
Also ensure OMAP clocksource read functions are marked notrace as
they're used for sched_clock() too.
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Will Deacon <will.deacon@arm.com>
Tested-by: Mikael Pettersson <mikpe@it.uu.se>
Tested-by: Eric Miao <eric.y.miao@gmail.com>
tegra_clocksource_read should not use cnt32_to_63, wrapping is
already handled in the clocksource code. Move the cnt32_to_63
into the sched_clock function, and replace the use of clocksource
mult and shift with a multiplication by 1000 to convert us to ns.
Acked-by: John Stultz <johnstul@us.ibm.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Signed-off-by: Zimny Lech <napohybelskurwysynom2010@gmail.com>
v2: fixes from Russell King:
- include linux/io.h instead of asm/io.h
fixes from Gary King:
- remove extra (and incorrect) irq definitions
- use timer 3 instead of timer 1 for compatibility with other drivers
- fix typo that disabled oneshot mode
v3:
- Implement sched_clock
- Fix checkpatch issues
- Fix incorrect cycles calculation
- Fix min_delta_ns assignment
fixes from Linus Walleij:
- use calc_mult_shift() instead of hard coding values
