Rename pinmux-t2.h and pinmux-t2-tables.c to the new tegra naming. This file
will be reworked somewhat in the next patch to support multiple tegra SoC
types.
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Acked-by: Colin Cross <ccross@android.com>
Use ioremap to obtain access to registers instead of using static
mappings. This reduces the number of users of the static mappings, which
will eventually allow them to be removed.
Note that on Tegra30, the number of register "banks" will decrease to 2,
and the packing of specific bits into registers will change significantly.
That's why this change adds the "*_bank" fields to the pingroup tables,
rather than implementing some more hard-coded scheme.
Also, completely remove the implementation of suspend/resume; Tegra doesn't
yet support suspend/resume, and the implementation is complex for the
general pinmux driver:
* Not all registers are used within each bank, so we probably shouldn't
just iterate over every register in the bank, and save/restore it,
since that would mean touching undefined registers.
* Registers are shared between pingroups, so we can't simply iterate over
each pingroup, and save/restore the registers it uses.
It'd probably be best have probe() calculate a bitmask of actually-used
registers for each bank, and have suspend/resume iterate over those
bitmaps.
Oh, and Real Soon Now, I should be looking into converting this driver to
the new pinmux/pinctrl subsystem, so I didn't want to put too much work
into the current incarnation.
v2: s/space/bank/ to match comments on reg_* fields in pinmux.h.
Re-order bank/reg parameters to pg_readl/pg_writel.
Adds missing drive pingroups, saves all drive pingroups in
suspend, and restores the pinmux registers in the proper order.
Signed-off-by: Gary King <gking@nvidia.com>
Signed-off-by: Colin Cross <ccross@android.com>
- the reset values for some pin groups in the tegra pin mux can result in
functional errors due to conflicting with actively-configured pin groups
muxing from the same controller. this change adds a known safe, non-
conflicting mux for every pin group, which can be used on platforms
where the pin group is not routed to any peripheral
- also add each pin group's I/O voltage rail, to enable platform code to
map from the pin groups used by each interface to the regulators used
for dynamic voltage control
- add routines to individually configure the tristate, pin mux and pull-
ups for a pingroup_config array, so that it is possible to program
individual values at run-time without modifying other values.
this allows driver power-management code to reprogram individual
interfaces into lower power states during idle / suspend, or to
reprogram the pin mux to support multiple physical busses per
internal controller (e.g., sharing a single I2C or SPI controller
across multiple pin groups)
- move chip-specific data like pingroups and drive-pingroups
out of the common code and into chip-specific code
- fix debug output for group with no pullups
- add a TEGRA_MUX_SAFE function. Setting a pingroup to TEGRA_MUX_SAFE
will automatically select a mux setting that is guaranteed not to
conflict with any of the hardware blocks.
