path: root/arch/arm/mach-tegra/board-seaboard-pinmux.c
2012-03-22Make tegra_defconfig compileDan Willemsen
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
2012-01-06Merge branch 'tegra/soc' into next/boardsArnd Bergmann
Conflicts: arch/arm/mach-tegra/board-harmony-pcie.c To fix an internal merge conflict between the tegra/soc and tegra/boards branches. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-12-20arm/tegra: remove __initdata annotation from pinmux tablesOlof Johansson
Instead of reshuffling what functions in the pinmux paths should be __init and thus could keep references to __initdata, let's just remove the annotations for now -- the tables are moving to device tree in the next version anyway and the whole subsystem is being wired up. We will go back and re-annotate where appropriate once things settle down. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Stephen Warren <swarren@nvidia.com>
2011-12-19arm/tegra: Refactor board-*-pinmux.c to share codeStephen Warren
This moves the implementation of *_pinmux_init() into a single location. The board-specific pinmux data is left in each board's own file. This will allow future changes that set up the pinmux in a more complex fashion to do so without duplicating that code in each board's pinmux file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-12-19arm/tegra: Rework Seaboard-vs-Ventana pinmux tableStephen Warren
Rather than modifying seaboard_pinmux[] using ventana_pinmux[], split seaboard_pinmux[] into common_pinmux[] and seaboard_pinmux[], and then actually apply common_pinmux[] always, followed by the appopriate one of seaboard_pinmux[] or ventana_pinmux[]. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-12-19arm/tegra: Remove useless entries from ventana_pinmux[]Stephen Warren
Some of the entries in ventana_pinmux[] are identical to what's already in seaboard_pinmux[]. Remove the overrides from the Ventana table. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-12-19arm/tegra: Split Seaboard GPIO table to allow for VentanaStephen Warren
Seaboard and Ventana share some GPIOs, but others are different. Split the GPIO table into common, seaboard-specific, and ventana-specific tables, so that only the correct ones are enabled for each board. Add a few missing audio-related GPIOs for Ventana. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-12-17arm/tegra: rename tegra20 pinmux filesPeter De Schrijver
Rename pinmux-t2.h and pinmux-t2-tables.c to the new tegra naming. This file will be reworked somewhat in the next patch to support multiple tegra SoC types. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Colin Cross <ccross@android.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-11-09arm/tegra: enable headphone detection gpio on seaboardYufeng Shen
Enable the headphone detection gpio on tegra platform. Signed-off-by: Yufeng Shen <miletus@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-11-09arm/tegra: Don't create duplicate gpio and pinmux devicesStephen Warren
*_pinmux_init() register the GPIO and pinmux devices so that they're ready before any other device needs them. *_pinmux_init() are also called by board-dt.c in order to set up the GPIO and pinmux configurations. In this case, if we register the devices, they end up being probed once due to this registration, and a second time due to a device-tree node (or vice-versa). The second probe fails since the memory regions are already requested. Besides, we don't actually want the duplicated devices. To avoid this duplicate registration, modify *_pinmux_init() to check whether it's running on a DT machine. If not, register the pinmux devices. If so, don't register them. Finally, modify board-dt.c to call the *_pinmux_init() after all devices have been instantiated from device-tree. This allows the GPIO and pinmux devices to be instantiated and initialized before calling functions to configure the hardware. This has one disadvantage: The pinmux and GPIO initialization now happens after /all/ devices are instantiated, rather than after just gpio and pinmux but before anything else. So the correct HW configuration is not in place when e.g. the SD/MMC device is probed. Long-term, this should be solved by doing both: a) Initializing the HW state from DT nodes during GPIO and pinmux device probe. b) Using the deferred driver probe mechanism, so that drivers can defer their probe until after the gpio and pinmux drivers have probed. v2: s/int is_dt/bool is_dt/ v3: Use of_machine_is_compatible inside *_pinmux_init() rather than passing an explicit parameter into the function from outside. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-11-01Merge branch 'next/devel' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/devel' of git://git.linaro.org/people/arnd/arm-soc: (50 commits) ARM: tegra: update defconfig arm/tegra: Harmony: Configure PMC for low-level interrupts arm/tegra: device tree support for ventana board arm/tegra: add support for ventana pinmuxing arm/tegra: prepare Seaboard pinmux code for derived boards arm/tegra: pinmux: ioremap registers gpio/tegra: Convert to a platform device arm/tegra: Convert pinmux driver to a platform device arm/dt: Tegra: Add pinmux node to tegra20.dtsi arm/tegra: Prep boards for gpio/pinmux conversion to pdevs ARM: mx5: fix clock usage for suspend ARM i.MX entry-macro.S: remove now unused code ARM i.MX boards: use CONFIG_MULTI_IRQ_HANDLER ARM i.MX tzic: add handle_irq function ARM i.MX avic: add handle_irq function ARM: mx25: Add the missing IIM base definition ARM i.MX avic: convert to use generic irq chip mx31moboard: Add poweroff support ARM: mach-qong: Add watchdog support ARM: davinci: AM18x: Add wl1271/wlan support ... Fix up conflicts in: arch/arm/mach-at91/at91sam9g45.c arch/arm/mach-mx5/devices-imx53.h arch/arm/plat-mxc/include/mach/memory.h
2011-10-13arm/tegra: add support for ventana pinmuxingPeter De Schrijver
Add support for ventana pinmuxing as a seaboard derivative. This is a cut down version of work done by Jong Kim <jongk@nvidia.com>. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-10-13arm/tegra: prepare Seaboard pinmux code for derived boardsPeter De Schrijver
This patch splits out the common part of pinmux and GPIO initialization for seaboard and derived boards. This code is based on work done by Jong Kim <jongk@nvidia.com>. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-10-11arm/tegra: Prep boards for gpio/pinmux conversion to pdevsStephen Warren
The Tegra GPIO driver will be converted from static registration via postcore_initcall() to be a platform device later in this patch series. A new Tegra pinmux platform device will also be added. Prepare for this by modifying all boards to register the appropriate platform devices before-hand, so that when the drivers are converted, those devices will be probed, and git bisectability will be maintained. v2: Add resource definitions for GPIO and pinmux Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-08-09ARM: Tegra: Seaboard: Add USB devicesStephen Warren
Seaboard has a couple of external USB ports. Add the platform devices and GPIO infra-structure to enable these. I tested both ports with a mouse on Seaboard non-clamshell. This change is extracted from code in the ChromeOS 2.6.38 kernel. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-08-09ARM: Tegra: Seaboard board updates for audioStephen Warren
* Initialize clock tree for audio * Add GPIO base definitions * Add audio GPIO definitions * Define platform data for WM8903 and ASoC machine driver * Add special case for Kaen to handle HP_MUTE GPIO * Register platform devices for audio * Update pinmux to cater for new GPIOs used for audio Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-03-07ARM: tegra: seaboard: register i2c devicesOlof Johansson
Register the base i2c devices on seaboard. A few more are pending, but it's a start. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Stephen Warren <swarren@nvidia.com>
2011-03-07ARM: tegra: create defines for SD-related GPIO namesStephen Warren
This ensures they're kept in sync between platform_data definitions and the GPIO table initialization. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-02-22ARM: tegra: add seaboard, wario and kaen boardsOlof Johansson
This adds board support for the Seaboard eval platform and some of the derivatives that are very similar. Since they only differ in some very minor ways, most of the code is shared. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Colin Cross <ccross@android.com>
