path: root/arch/arm/mach-s3c2443/clock.c
2007-05-30[ARM] 4414/1: S3C2443: sparse fix for clock.cBen Dooks
Fix sparse warnings in the arch/arm/mach-s3c2443/clock.c, including an bug in initialising the cf clock initialiser where two values are being set for the ctrlbit. arch/arm/mach-s3c2443/clock.c:397:12: warning: symbol 'clk_usb_bus_host' was not declared. Should it be static? arch/arm/mach-s3c2443/clock.c:760:4: error: Initializer entry defined twice arch/arm/mach-s3c2443/clock.c:761:4: also defined here Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-20[ARM] 4396/1: S3C2443: Add missing HCLK clocksBen Dooks
Add the clocks missing form HCLKCON back into the set of clocks being registered at initalisation time. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4365/1: Add AC97 clock to s3c2443 machineGraeme Gregory
This adds the ac97 clock to the s3c2443 machine files. It seems to have been simply missed out previously. Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-16[ARM] 4198/2: S3C2443: arch/arm/mach-s3c2443 and related supportBen Dooks
Add arch/arm/mach-s3c2443 for support of the Samsung S3C2443 SoC This patch adds the core CPU support, clock framework, times and initial IRQ support, as well as adding the directory into the build tree. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
