path: root/arch/arm/mach-s3c2440/mach-nexcoder.c
2009-05-18[ARM] S3C24XX: GPIO: Change to macros for GPIO numberingBen Dooks
Prepare to remove the large number of S3C2410_GPxn defines by moving to S3C2410_GPx(n) in arch/arm. The following perl was used to change the files: perl -pi~ -e 's/S3C2410_GP([A-Z])([0-9]+)([^_^0-9])/S3C2410_GP\1\(\2\)\3/g' Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-18[ARM] S3C24XX: GPIO: Move gpio functions out of <mach/hardware.h>Ben Dooks
Move all the gpio functions out of <mach/hardware.h> as this file is for defining the generic IO base addresses for the kernel IO calls. Make a new header <mach/gpio-fns.h> to take this and include it via the chain from <linux/gpio.h> which is what most of these files should be using (and will be changed as soon as possible). Note, this does make minor changes to some drivers but should not mess up any pending merges. CC: Richard Purdie <rpurdie@rpsys.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> CC: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-17[ARM] S3C24XX: GPIO: Remove pin specific input and output definesBen Dooks
The use of S3C2410_GP[A-Z]x_INP and S3C2410_GP[A-Z]x_OUTP are very rare and are taking up large amounts of space in the regs-gpio.h header. The GPIO layer has had generic input and out defines called S3C2410_GPIO_INPUT and S3C2410_GPIO_OUTPUT for a while which work for all S3C24XX GPIOs. Do the following replacements: S3C2410_GP[A-Z][0-9]*_\OUTP => S3C2410_GPIO_OUTPUT S3C2410_GP[A-Z][0-9]*_\INP => /S3C2410_GPIO_INPUT S3C2410_GPA[0-9]*_OUT => S3C2410_GPIO_OUTPUT to remove any usages of these and prepare the header for the removal of these. The following command was used to acheive this: find . -type f -writable ! -name regs-gpio.h ! -name "*~" | xargs sed -i~ -e 's/S3C2410_GP[A-Z][0-9]*_\OUTP/S3C2410_GPIO_OUTPUT/g' -e 's/S3C2410_GP[A-Z][0-9]*_\INP/S3C2410_GPIO_INPUT/g' -e 's/S3C2410_GPA[0-9]*_OUT/S3C2410_GPIO_OUTPUT/g' Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C: Make i2c device definition common to plat-s3cBen Dooks
Make the device i2c0 common to plat-s3c and move the definitions from arch/arm/plat-s3c24xx/devs.c Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-14Merge branch 's3c-move' into develRussell King
Conflicts: arch/arm/mach-versatile/core.c
2008-10-07[ARM] S3C24XX: Additional include movesBen Dooks
Continue moving the include files into arch/arm Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-07[ARM] S3C24XX: Move files out of include/asm-arm/plat-s3c*Ben Dooks
First move of items out of include/asm-arm/plat-s3c* to their new homes under arch/arm/plat-s3c/include/plat and arch/arm/plat-s3c24xx/include/plat directories. Note, we have to create a dummy arch/arm/plat-s3c/Makefile to allow us to add arch/arm/plat-s3c/include/plat to the path. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4508/1: S3C: Move items to include/asm-arm/plat-s3cBen Dooks
This patch moves items of the s3c24xx support into a new plat-s3c directory for items that use the s3c24xx support but are not directly s3c24xx compatible, such as the s3c2400 and s3c6400. git mv commands: git mv include/asm-arm/arch-s3c2410/iic.h include/asm-arm/plat-s3c/iic.h git mv include/asm-arm/arch-s3c2410/nand.h include/asm-arm/plat-s3c/nand.h git mv include/asm-arm/arch-s3c2410/regs-iic.h include/asm-arm/plat-s3c/regs-iic.h git mv include/asm-arm/arch-s3c2410/regs-nand.h include/asm-arm/plat-s3c/regs-nand.h git mv include/asm-arm/arch-s3c2410/regs-rtc.h include/asm-arm/plat-s3c/regs-rtc.h git mv include/asm-arm/arch-s3c2410/regs-serial.h include/asm-arm/plat-s3c/regs-serial.h git mv include/asm-arm/arch-s3c2410/regs-timer.h include/asm-arm/plat-s3c/regs-timer.h git mv include/asm-arm/arch-s3c2410/regs-watchdog.h include/asm-arm/plat-s3c/regs-watchdog.h Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4325/1: S3C24XX: remove s3c24xx_boardBen Dooks
Remove the use of struct s3c24xx_board as this is just as easily done by using the platform device registration functions to make the initialisation sequence easier. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4157/2: S3C24XX: move arch/arch/mach-s3c2410 into cpu componentsBen Dooks
The following patch and script moves the arch/arm/mach-s3c2410 directory into arch/arm/plat-s3c24xx for the generic core code and inti arch/arm/mach-s3c{cpu} for the cpu/machine support files Include directory include/asm-arm/plat-s3c24xx is added for the core include files. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
