path: root/arch/arm/mach-s3c2416/s3c2416.c
2011-01-06ARM: S3C2416: Add platform helpers for setup SDHCIYauhen Kharuzhy
Samsung S3C2416 has two SDHCI controllers compatible with other Samsung's SoCs (S3C64XX, S5PC100 etc...). Add required platform setup code that the devices can be used with sdhci-s3c driver. Signed-off-by: Yauhen Kharuzhy <yauhen.kharuzhy@promwad.com> [kgene.kim@samsung.com: change to __raw_{readl,writel} from {readl,writel}] [kgene.kim@samsung.com: build error fixes] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: S3C2416: Change S3C2416 NAND platform device nameAtul Dahiya
This patch changes the platform device name from 's3c2416-nand' to 's3c2412-nand' so that S3C2416 can reuse the nand functionality available on S3C2412. Signed-off-by: Atul Dahiya <atul.dahiya@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: SAMSUNG: Add setname core function for S3C24XX NANDAtul Dahiya
This patch replaces the device name assignment method from string assignment to set_name method for all s3c24xx machines and adds device core file. Signed-off-by: Atul Dahiya <atul.dahiya@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-08-11s3c-fb: add device name initializationPawel Osciak
Add framebuffer device name initialization calls for S3C2443, S3C64xx and S5P machines. Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: InKi Dae <inki.dae@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-18ARM: SMDK2416: Add support for framebuffer device and ensure correct setupBen Dooks
Add support for the LCD display on the SMDJK2416, and correctly name the framebuffer device. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-10ARM: S3C2413: Update GPIO pull-up supportBen Dooks
Ensure the right get/set pull code is selected and assigned to the GPIO core. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-10ARM: S3C2416: Use s3c2440 style i2c controllerBen Dooks
The s3c2416 i2c controllers are compatible with the s3c2440 style i2c block, so change the device name appropriately. Signed-off-by: Ben Dooks <ben-linux@fluff.org>y
2010-05-10ARM: S3C2416: Add arch supportYauhen Kharuzhy
Add arch/arm/mach-s3c2416 for support of the Samsung S3C2416 SoC. This patch adds support of the S3C2416 SoC, clocks, timers, and initial IRQ support (without support of secondary set of registers). Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> [ben-linux@fluff.org: removed files to be reworked, fixed conflicts] [ben-linux@fluff.org: use s3c2443 reset instead of specific reset code] Signed-off-by: Ben Dooks <ben-linux@fluff.org>
