path: root/arch/arm/mach-rpc/riscpc.c
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 2989/1: Replace map_desc.physical with map_desc.pfn: RiscPCDeepak Saxena
Patch from Deepak Saxena RiscPC map_desc.pfn conversion Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[SERIAL] Use an enum for serial8250 platform device IDsRussell King
Rather than hard-coding the platform device IDs, enumerate them. We don't particularly care about the actual ID we get, just as long as they're unique. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ARM: Remove machine description macrosRussell King
Remove the pointless machine description macros, favouring C99 initialisers instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-22[PATCH] ARM: Allow riscpc to parse "acorn" boot info tagRussell King
