path: root/arch/arm/mach-pxa
2013-03-06ARM: PXA3xx: program the CSMSADRCFG registerIgor Grinberg
commit d107a204154ddd79339203c2deeb7433f0cf6777 upstream. The Chip Select Configuration Register must be programmed to 0x2 in order to achieve the correct behavior of the Static Memory Controller. Without this patch devices wired to DFI and accessed through SMC cannot be accessed after resume from S2. Do not rely on the boot loader to program the CSMSADRCFG register by programming it in the kernel smemc module. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06ALSA: pxa27x: fix ac97 warm resetMike Dunn
commit 3b4bc7bccc7857274705b05cf81a0c72cfd0b0dd upstream. This patch fixes some code that implements a work-around to a hardware bug in the ac97 controller on the pxa27x. A bug in the controller's warm reset functionality requires that the mfp used by the controller as the AC97_nRESET line be temporarily reconfigured as a generic output gpio (AF0) and manually held high for the duration of the warm reset cycle. This is what was done in the original code, but it was broken long ago by commit fb1bf8cd ([ARM] pxa: introduce processor specific pxa27x_assert_ac97reset()) which changed the mfp to a GPIO input instead of a high output. The fix requires the ac97 controller to obtain the gpio via gpio_request_one(), with arguments that configure the gpio as an output initially driven high. Tested on a palm treo 680 machine. Reportedly, this broken code only prevents a warm reset on hardware that lacks a pull-up on the line, which appears to be the case for me. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-08-19Input: eeti_ts: pass gpio value instead of IRQArnd Bergmann
commit 4eef6cbfcc03b294d9d334368a851b35b496ce53 upstream. The EETI touchscreen asserts its IRQ line as soon as it has data in its internal buffers. The line is automatically deasserted once all data has been read via I2C. Hence, the driver has to monitor the GPIO line and cannot simply rely on the interrupt handler reception. In the current implementation of the driver, irq_to_gpio() is used to determine the GPIO number from the i2c_client's IRQ value. As irq_to_gpio() is not available on all platforms, this patch changes this and makes the driver ignore the passed in IRQ. Instead, a GPIO is added to the platform_data struct and gpio_to_irq is used to derive the IRQ from that GPIO. If this fails, bail out. The driver is only able to work in environments where the touchscreen GPIO can be mapped to an IRQ. Without this patch, building raumfeld_defconfig results in: drivers/input/touchscreen/eeti_ts.c: In function 'eeti_ts_irq_active': drivers/input/touchscreen/eeti_ts.c:65:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration] Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Sven Neumann <s.neumann@raumfeld.com> Cc: linux-input@vger.kernel.org Cc: Haojian Zhuang <haojian.zhuang@gmail.com> [bwh: Backported to 3.2: raumfeld_controller_i2c_board_info.irq was initialised using gpio_to_irq(), but this doesn't seem to matter] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2011-11-10ARM: pxa: fix inconsistent CONFIG_USB_PXA27XHaojian Zhuang
Since CONFIG_USB_GADGET_PXA27X and other macros are renamed to CONFIG_USB_PXA27X. Update them in arch/arm/mach-pxa and arch/arm/configs to keep consistent. Cc: stable@kernel.org Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-11-07Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (226 commits) mtd: tests: annotate as DANGEROUS in Kconfig mtd: tests: don't use mtd0 as a default mtd: clean up usage of MTD_DOCPROBE_ADDRESS jffs2: add compr=lzo and compr=zlib options jffs2: implement mount option parsing and compression overriding mtd: nand: initialize ops.mode mtd: provide an alias for the redboot module name mtd: m25p80: don't probe device which has status of 'disabled' mtd: nand_h1900 never worked mtd: Add DiskOnChip G3 support mtd: m25p80: add EON flash EN25Q32B into spi flash id table mtd: mark block device queue as non-rotational mtd: r852: make r852_pm_ops static mtd: m25p80: add support for at25df321a spi data flash mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks mtd: nand: switch `check_pattern()' to standard `memcmp()' mtd: nand: invalidate cache on unaligned reads mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set mtd: nand: wait to set BBT version mtd: nand: scrub BBT on ECC errors ... Fix up trivial conflicts: - arch/arm/mach-at91/board-usb-a9260.c Merged into board-usb-a926x.c - drivers/mtd/maps/lantiq-flash.c add_mtd_partitions -> mtd_device_register vs changed to use mtd_device_parse_register.
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-05ARM: PXA: fix gpio-pxa.h build errorsRussell King
A mismerge in 43872fa (Merge branch 'depends/rmk/gpio' into next/fixes) causes these build errors: In file included from arch/arm/mach-pxa/include/mach/gpio.h:30, from arch/arm/include/asm/gpio.h:6, from include/linux/gpio.h:31, from arch/arm/mach-pxa/generic.c:20: arch/arm/mach-pxa/include/mach/gpio-pxa.h: In function ■__gpio_is_occupied■: arch/arm/mach-pxa/include/mach/gpio-pxa.h:121: error: invalid operands to binary >> (have ■void *■ and ■unsigned int■) arch/arm/mach-pxa/include/mach/gpio-pxa.h:122: error: invalid operands to binary & (have ■void *■ and ■int■) arch/arm/mach-pxa/include/mach/gpio-pxa.h:129: error: invalid operands to binary & (have ■void *■ and ■int■) So fix them. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-05ARM: PXA: eseries: fix eseries_register_clks section mismatch warningRussell King
Fix: WARNING: vmlinux.o(.text+0x1a820): Section mismatch in reference from the function eseries_register_clks() to the function .init.text:clkdev_add_table() The function eseries_register_clks() references the function __init clkdev_add_table(). This is often because eseries_register_clks lacks a __init annotation or the annotation of clkdev_add_table is wrong. by adding the __init annotation to eseries_register_clks() - this function is only called from other __init-marked functions. While we're here, mark it static as it's only called from within eseries.c. Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-04Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (144 commits) [media] saa7134.h: Suppress compiler warnings when CONFIG_VIDEO_SAA7134_RC is not set [media] it913x [VER 1.07] Support for single ITE 9135 devices [media] Support for Terratec G1 [media] cx25821: off by one in cx25821_vidioc_s_input() [media] media: tea5764: reconcile Kconfig symbol and macro [media] omap_vout: Add poll() support [media] omap3isp: preview: Add crop support on the sink pad [media] omap3isp: preview: Rename min/max input/output sizes defines [media] omap3isp: preview: Remove horizontal averager support [media] omap3isp: Report the ISP revision through the media controller API [media] omap3isp: ccdc: remove redundant operation [media] omap3isp: Fix memory leaks in initialization error paths [media] omap3isp: Add missing mutex_destroy() calls [media] omap3isp: Move *_init_entities() functions to the init/cleanup section [media] omap3isp: Move media_entity_cleanup() from unregister() to cleanup() [media] MFC: Change MFC firmware binary name [media] vb2: add vb2_get_unmapped_area in vb2 core [media] v4l: Add v4l2 subdev driver for S5K6AAFX sensor [media] v4l: Add AUTO option for the V4L2_CID_POWER_LINE_FREQUENCY control [media] media: ov6650: stylistic improvements ...
2011-11-03[media] ARM: PXA: use gpio_set_value_cansleep() on pcm990Guennadi Liakhovetski
Camera-switching GPIOs are provided by a i2c GPIO extender, switching them can send the caller to sleep. Use the GPIO API *_cansleep methods explicitly to avoid runtime warnings. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-01Merge branch 'next/fixes' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/fixes' of git://git.linaro.org/people/arnd/arm-soc: (28 commits) ARM: pxa/cm-x300: properly set bt_reset pin ARM: mmp: rename SHEEVAD to GPLUGD ARM: imx: Fix typo 'MACH_MX31_3DS_MXC_NAND_USE_BBT' ARM: i.MX28: shift frac value in _CLK_SET_RATE plat-mxc: iomux-v3.h: implicitly enable pull-up/down when that's desired ARM: mx5: fix clock usage for suspend ARM: pxa: use correct __iomem annotations ARM: pxa: sharpsl pm needs SPI ARM: pxa: centro and treo680 need palm27x ARM: pxa: make pxafb_smart_*() empty when not enabled ARM: pxa: select POWER_SUPPLY on raumfeld ARM: pxa: pxa95x is incompatible with earlier pxa ARM: pxa: CPU_FREQ_TABLE is needed for CPU_FREQ ARM: pxa: pxa95x/saarb depends on pxa3xx code ARM: pxa: allow selecting just one of TREO680/CENTRO ARM: pxa: export symbols from pxa3xx-ulpi ARM: pxa: make zylonite_pxa*_init declaration match code ARM: pxa/z2: fix building error of pxa27x_cpu_suspend() no longer available ARM: at91: add defconfig for at91sam9g45 family ARM: at91: remove dependency for Atmel PWM driver selector in Kconfig ...
2011-10-31arm: Add moduleparam.h to arch/arm files as requiredPaul Gortmaker
Things like module_param and core_param come from the header moduleparam.h -- these files were relying on the fact that module.h is implicitly present everywhere and it in turn includes the moduleparam header. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31arm: fix implicit module.h users by adding it to arch/arm as required.Paul Gortmaker
These files will fail to compile if we dont clean them up in advance and have them include the appropriate headers they need. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31arm: Add export.h to ARM specific files as required.Paul Gortmaker
These files all make use of one of the EXPORT_SYMBOL variants or the THIS_MODULE macro. So they will need <linux/export.h> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-11-01Merge branch 'depends/rmk/memory_h' into next/fixesArnd Bergmann
Fix up all conflicts between the memory.h cleanup and bug fixes. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-31Merge branch 'depends/rmk/gpio' into next/fixesArnd Bergmann
This sorts out merge conflicts with the arm/gpio branch that already got merged into mainline Linux. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-27Merge branch 'gpio' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'gpio' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (43 commits) ARM: 7135/1: ep93xx: bring back missing <mach/gpio.h> ARM: 7104/1: plat-pxa: break out GPIO driver specifics ARM: 7103/1: plat-pxa: move PXA GPIO driver to GPIO subsystem ARM: 7042/3: mach-ep93xx: break out GPIO driver specifics ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h> ARM: 7094/1: arm/tegra: Move EN_VDD_1V05_GPIO to board-harmony.h ARM: 7083/1: rewrite U300 GPIO to use gpiolib ARM: 7074/1: gpio: davinci: eliminate unused variable warnings ARM: 7063/1: Orion: gpio: add missing include of linux/types.h ARM: 7055/1: arm/tegra: mach/gpio.h: include linux/types.h to fix build ARM: 7054/1: arm/tegra: Delete custom gpio_to_irq, and irq_to_gpio ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irq ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpio ARM: 7057/1: mach-pnx4008: rename GPIO header ARM: 7056/1: plat-nomadik: kill off <plat/gpio.h> ARM: 7050/1: mach-sa1100: delete irq_to_gpio() function ARM: 7049/1: mach-sa1100: move SA1100 GPIO driver to GPIO subsystem ARM: 7045/1: mach-lpc32xx: break out GPIO driver specifics ARM: 7044/1: mach-lpc32xx: move LPC32XX GPIO driver to GPIO subsystem ARM: 7043/1: mach-ixp2000: rename GPIO header ... Fix up trivial conflicts in arch/arm/mach-u300/Kconfig manually
2011-10-25ARM: pxa/cm-x300: properly set bt_reset pinAxel Lin
Fix below build warning and properly set bt_reset pin. CC arch/arm/mach-pxa/cm-x300.o arch/arm/mach-pxa/cm-x300.c: In function 'cm_x300_init_wi2wi': arch/arm/mach-pxa/cm-x300.c:779: warning: unused variable 'wlan_en' arch/arm/mach-pxa/cm-x300.c:795: warning: 'bt_reset' may be used uninitialized in this function Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: <stable@kernel.org> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits) MAINTAINERS: linux-m32r is moderated for non-subscribers linux@lists.openrisc.net is moderated for non-subscribers Drop default from "DM365 codec select" choice parisc: Kconfig: cleanup Kernel page size default Kconfig: remove redundant CONFIG_ prefix on two symbols cris: remove arch/cris/arch-v32/lib/nand_init.S microblaze: add missing CONFIG_ prefixes h8300: drop puzzling Kconfig dependencies MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers tty: drop superfluous dependency in Kconfig ARM: mxc: fix Kconfig typo 'i.MX51' Fix file references in Kconfig files aic7xxx: fix Kconfig references to READMEs Fix file references in drivers/ide/ thinkpad_acpi: Fix printk typo 'bluestooth' bcmring: drop commented out line in Kconfig btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888' doc: raw1394: Trivial typo fix CIFS: Don't free volume_info->UNC until we are entirely done with it. treewide: Correct spelling of successfully in comments ...
2011-10-25Merge branch 'misc' into for-linusRussell King
Conflicts: arch/arm/mach-integrator/integrator_ap.c
2011-10-23Merge branch 'ppi-irq-core-for-rmk' of ↵Russell King
git://github.com/mzyngier/arm-platforms into devel-stable
2011-10-17ARM: platform fixups: remove mdesc argument to fixup functionRussell King
Get rid of the mdesc pointer in the fixup function call. No one uses the mdesc pointer, it shouldn't be modified anyway, and we can't wrap it, so let's remove it. Platform files found by: $ regexp=$(git grep -h '\.fixup.*=' arch/arm | sed 's!.*= *\([^,]*\),* *!\1!' | sort -u | tr '\n' '|' | sed 's,|$,,;s,|,\\|,g') $ git grep $regexp arch/arm Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-17ARM: 7022/1: allow to detect conflicting zreladdrsSascha Hauer
Boards used to specify zreladdr in their Makefile.boot with zreladdr-y := x, so conflicting zreladdrs were silently overwritten. This patch changes this to zreladdr-y += x, so that we end up with multiple words in zreladdr in such a case. We can detect this later and complain if necessary. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-17ARM: 7006/1: Migrate to asm-generic wrapper supportStephen Boyd
With d8ecc5c (kbuild: asm-generic support, 2011-04-27) we can remove a handful of asm-generic wrappers in ARM code. Since the generic version of sizes.h doesn't contain SZ_48M, we replace the 4 users of SZ_48M with the equivalent SZ_32M + SZ_16M. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Imre Kaloz <kaloz@openwrt.org> Acked-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-17ARM: 7115/4: move __exception and friends to asm/exception.hJamie Iles
The definition of __exception_irq_entry for CONFIG_FUNCTION_GRAPH_TRACER=y needs linux/ftrace.h, but this creates a circular dependency with it's current home in asm/system.h. Create asm/exception.h and update all current users. v4: - rebase to rmk/for-next v3: - remove redundant includes of linux/ftrace.h v2: - document the usage restricitions of __exception* Cc: Zoltan Devai <zdevai@gmail.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-13ARM: mach-pxa: remove mach/memory.hNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-10-08ARM: pxa: use correct __iomem annotationsArnd Bergmann
This tries to clear up the confusion between integers and iomem pointers in the marvell pxa platform. MMIO addresses are supposed to be __iomem* values, in order to let the Linux type checking work correctly. This patch moves the cast to __iomem as far back as possible, to the place where the MMIO virtual address windows are defined. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: sharpsl pm needs SPIArnd Bergmann
The sharpsl code selects the max1111 spi driver, so it must also ensure that SPI itself is enabled. The platform does not work without max1111. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: centro and treo680 need palm27xArnd Bergmann
The two platforms are part of the palm27x family and use the same code. Select the palm27x symbol to make sure they can be built standalone. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: make pxafb_smart_*() empty when not enabledEric Miao
Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: select POWER_SUPPLY on raumfeldArnd Bergmann
The raumfeld platform code calls power_supply_set_battery_charged which is part of the power supply layer, so that always has to be enabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: pxa95x is incompatible with earlier pxaArnd Bergmann
We cannot support ARMv5 and ARMv7 based boards in a single kernel, so introduce a new option in mach-pxa to select between the two. The PJ4 (ARMv7) based boards are now only visible when CONFIG_ARCH_PXA_V7 is set, the other boards are only visible when it's not set. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: pxa95x/saarb depends on pxa3xx codeEric Miao
saarb uses pxa3xx_map_io and pxa3xx_handle_irq, which are part of the pxa3xx code. This makes sure the necessary header and implementation is used when building the board file. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: allow selecting just one of TREO680/CENTROArnd Bergmann
There are two variants of the palmtreo machine, the 680 and the centro, and Kconfig allows selecting one or both of them. This changes the board file so that it's actually possible to build all configurations that are allowed. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: export symbols from pxa3xx-ulpiArnd Bergmann
The pxa3xx_u2d_start_hc/pxa3xx_u2d_stop_hc symbols are used by the ohci-pxa27x driver, which can be a module. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: make zylonite_pxa*_init declaration match codeArnd Bergmann
When support for zylonite is disabled, the zylonite_pxa300_init and zylonite_pxa320_init functions are not there, but the declaration is still kept around if any other boards for the same soc are enabled. This changes the declaration to be conditional on the same symbol as the code. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa/z2: fix building error of pxa27x_cpu_suspend() no longer availableEric Miao
Cc: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-07ARM: pxa: fix building error by palm27x_lcd_init() when FB_PXA not definedEric Miao
2011-10-01ARM: 7104/1: plat-pxa: break out GPIO driver specificsLinus Walleij
The <mach/gpio.h> file is included from upper directories and deal with generic GPIO and gpiolib stuff. Break out the platform and driver specific defines and functions into its own header file. Cc: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-26ARM: add an extra temp register to the low level debugging addruart macroNicolas Pitre
Some platforms (like OMAP not to name it) are doing rather complicated hacks just to determine the base UART address to use. Let's give their addruart macro some slack by providing an extra work register which will allow for much needed cleanups. This is basically a no-op as this commit is only adding the extra argument to the macro but no one is using it yet. Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-09-11mtd: pxa3xx_nand: enable multiple chip select supportLei Wen
Current pxa3xx_nand controller has two chip select which both be workable. This patch enable this feature. Update platform driver to support this feature. Another notice should be taken that: When you want to use this feature, you should not enable the keep configuration feature, for two chip select could be attached with different nand chip. The different page size and timing requirement make the keep configuration impossible. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-08-21ARM: mach-pxa: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-08-08ARM: gpio: convert includes of mach/gpio.h and asm/gpio.h to linux/gpio.hRussell King
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h before we start consolidating the individual platform implementations of the gpio header files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-26Merge branch 'next/cross-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: Consolidate the clkdev header files ARM: set vga memory base at run-time ARM: convert PCI defines to variables ARM: pci: make pcibios_assign_all_busses use pci_has_flag ARM: remove unnecessary mach/hardware.h includes pci: move microblaze and powerpc pci flag functions into asm-generic powerpc: rename ppc_pci_*_flags to pci_*_flags Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-25Merge branch 'next/cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits) ARM: EXYNOS4: Change devname for FIMD clkdev ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210 ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100 ARM: S3C24XX: Use generic s3c_set_platdata for devices ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND ARM: SAMSUNG: Use generic s3c_set_platdata for NAND ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON ARM: SAMSUNG: Use generic s3c_set_platdata for FB ARM: SAMSUNG: Use generic s3c_set_platdata for TS ARM: S3C64XX: Add PWM backlight support on SMDK6410 ARM: S5P64X0: Add PWM backlight support on SMDK6450 ARM: S5P64X0: Add PWM backlight support on SMDK6440 ARM: S5PC100: Add PWM backlight support on SMDKC100 ARM: S5PV210: Add PWM backlight support on SMDKV210 ARM: EXYNOS4: Add PWM backlight support on SMDKC210 ARM: EXYNOS4: Add PWM backlight support on SMDKV310 ARM: SAMSUNG: Create a common infrastructure for PWM backlight support clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0 ... Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
