path: root/arch/arm/mach-pxa
2012-03-27Merge branch 'platforms' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM platform updates from Russell King: "This covers platform stuff for platforms I have a direct interest in (iow, I have the hardware). Essentially: - as we no longer support any other Acorn platforms other than RiscPC anymore, we can collect all that code into mach-rpc. - convert Acorn expansion card stuff to use IRQ allocation functions, and get rid of NO_IRQ from there. - cleanups to the ebsa110 platform to move some private stuff out of its header files. - large amount of SA11x0 updates: - conversion of private DMA implementation to DMA engine support (this actually gives us greater flexibility in drivers over the old API.) - re-worked ucb1x00 updates - convert to genirq, remove sa11x0 dependencies, fix various minor issues - move platform specific sa11x0 framebuffer data into platform files in arch/arm instead of keeping this in the driver itself - update sa11x0 IrDA driver for DMA engine, and allow it to use DMA for SIR transmissions as well as FIR - rework sa1111 support for genirq, and irq allocation - fix sa1111 IRQ support so it works again - use sparse IRQ support After this, I have one more pull request remaining from my current set, which I think is going to be the most problematical as it generates 8 conflicts." Fixed up the trivial conflict in arch/arm/mach-rpc/Makefile as per Russell. * 'platforms' of git://git.linaro.org/people/rmk/linux-arm: (125 commits) ARM: 7343/1: sa11x0: convert to sparse IRQ ARM: 7342/2: sa1100: prepare for sparse irq conversion ARM: 7341/1: input: prepare jornada720 keyboard and ts for sa11x0 sparse irq ARM: 7340/1: rtc: sa1100: include mach/irqs.h instead of asm/irq.h ARM: sa11x0: remove unused DMA controller definitions ARM: sa11x0: remove old SoC private DMA driver USB: sa1111: add hcd .reset method USB: sa1111: add OHCI shutdown methods USB: sa1111: reorganize ohci-sa1111.c USB: sa1111: get rid of nasty printk(KERN_DEBUG "%s: ...", __FILE__) USB: sa1111: sparse and checkpatch cleanups ARM: sa11x0: don't static map sa1111 ARM: sa1111: use dev_err() rather than printk() ARM: sa1111: cleanup sub-device registration and unregistration ARM: sa1111: only setup DMA for DMA capable devices ARM: sa1111: register sa1111 devices with dmabounce in bus notifier ARM: sa1111: move USB interface register definitions to ohci-sa1111.c ARM: sa1111: move PCMCIA interface register definitions to sa1111_generic.c ARM: sa1111: move PS/2 interface register definitions to sa1111p2.c ARM: sa1111: delete unused physical GPIO register definitions ...
2012-03-27Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: driver specific updates" from Arnd Bergmann: "These are all specific to some driver. They are typically the platform side of a change in the drivers directory, such as adding a new driver or extending the interface to the platform. In cases where there is no maintainer for the driver, or the maintainer prefers to have the platform changes in the same branch as the driver changes, the patches to the drivers are included as well. A much smaller set of driver updates that depend on other branches getting merged first will be sent later. The new export of tegra_chip_uid conflicts with other changes in fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED conflicts with the cleanup of the interrupt handling of that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up aforementioned trivial conflicts. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci mmc: sdhci-s3c: add platform data for the second capability ARM: SAMSUNG: support the second capability for samsung-soc ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1 ARM: EXYNOS: Enable MDMA driver regulator: Remove bq24022 regulator driver rtc: sa1100: add OF support pxa: magician/hx4700: Convert to gpio-regulator from bq24022 ARM: OMAP3+: SmartReflex: fix error handling ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API ARM: OMAP3+: SmartReflex: micro-optimization for sanity check ARM: OMAP3+: SmartReflex: misc cleanups ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata() ARM: OMAP3+: hwmod: add SmartReflex IRQs ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register ARM: OMAP3+: SmartReflex: Add a shutdown hook ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP ... Conflicts: arch/arm/mach-tegra/Makefile arch/arm/mach-tegra/fuse.c drivers/rtc/rtc-sa1100.c
2012-03-27Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: board specific updates" from Arnd Bergmann/Olof Johansson: "These changes are all specific to one board only. We're trying to keep the number of board files low, but generally board level updates are ok on platforms that are working on moving towards DT based probing, which will eventually lead to removing them. The board-ams-delta.c board file gets a conflict between the removal of ams_delta_config and the addition of a lot of other data. The Kconfig file has two changes in the same line, and in exynos, the power domain cleanup conflicts with the addition of the image sensor device. Signed-off-by: Arnd Bergmann <arnd@arndb.de> [olof: Amended a fix for a mismerge to board-omap4panda.c] Signed-off-by: Olof Johansson <olof@lixom.net>" Fixed up some fairly trivial conflicts manually. * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (82 commits) i.MX35-PDK: Add Camera support ARM : mx35: 3ds-board: add framebuffer device pxa/hx4700: Remove pcmcia platform_device structure ARM: pxa/hx4700: Reduce sleep mode battery discharge by 35% ARM: pxa/hx4700: Remove unwanted request for GPIO105 ARM: EXYNOS: support Exynos4210-bus Devfreq driver on Nuri board ARM: EXYNOS: Register JPEG on nuri ARM: EXYNOS: Register JPEG on universal_c210 ARM: S5PV210: Enable JPEG on SMDKV210 ARM: S5PV210: Add JPEG board definition ARM: EXYNOS: Enable JPEG on Origen ARM: EXYNOS: Enable JPEG on SMDKV310 ARM: EXYNOS: Add __init attribute to universal_camera_init() ARM: EXYNOS: Add __init attribute to nuri_camera_init() ARM: S5PV210: Enable FIMC on SMDKC110 ARM: S5PV210: Enable FIMC on SMDKV210 ARM: S5PV210: Enable MFC on SMDKC110 ARM: S5PV210: Enable MFC on SMDKV210 ARM: EXYNOS: Enable G2D on SMDKV310 ARM: tegra: update defconfig ...
2012-03-24ARM: sa1111: provide a generic way to prevent devices from registeringRussell King
Some platforms don't want certain devices to be registered, because, eg, the interface is not wired. Provide a way for platforms to prevent various devices from being registered via a devid bitmask in the platform data. Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-23Merge branch 'pcmcia' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull #3 ARM updates from Russell King: "This adds gpio support to soc_common, allowing an amount of code to be deleted from each PCMCIA socket driver for the PXA/SA11x0 SoCs." * 'pcmcia' of git://git.linaro.org/people/rmk/linux-arm: PCMCIA: sa1111: rename sa1111 socket drivers to have sa1111_ prefix. PCMCIA: make lubbock socket driver part of sa1111_cs PCMCIA: add Kconfig control for building sa11xx_base.c PCMCIA: sa1111: jornada720: no need to disable IRQs around sa1111_set_io PCMCIA: sa1111: pass along sa1111_pcmcia_configure_socket() failure code PCMCIA: soc_common: remove explicit wrprot initialization in socket drivers PCMCIA: soc_common: remove soc_pcmcia_*_irqs functions PCMCIA: sa11x0: h3600: convert to use new irq/gpio management PCMCIA: sa11x0: simpad: convert to use new irq/gpio management PCMCIA: sa11x0: shannon: convert to use new irq/gpio management PCMCIA: sa11x0: nanoengine: convert reset handling to use GPIO subsystem PCMCIA: sa11x0: nanoengine: convert to use new irq/gpio management PCMCIA: sa11x0: cerf: convert reset handling to use GPIO subsystem PCMCIA: sa11x0: cerf: convert to use new irq/gpio management PCMCIA: sa11x0: assabet: convert to use new irq/gpio management PCMCIA: sa1111: use new per-socket irq/gpio infrastructure PCMCIA: pxa: convert PXA socket drivers to use new irq/gpio management PCMCIA: soc_common: add GPIO support for card status signals PCMCIA: soc_common: move common initialization into soc_common
2012-03-23Merge branch 'for-armsoc' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull #1 ARM updates from Russell King: "This one covers stuff which Arnd is waiting for me to push, as this is shared between both our trees and probably other trees elsewhere. Essentially, this contains: - AMBA primecell device initializer updates - mostly shrinking the size of the device declarations in platform code to something more reasonable. - Getting rid of the NO_IRQ crap from AMBA primecell stuff. - Nicolas' idle cleanups. This in combination with the restart cleanups from the last merge window results in a great many mach/system.h files being deleted." Yay: ~80 files, ~2000 lines deleted. * 'for-armsoc' of git://git.linaro.org/people/rmk/linux-arm: (60 commits) ARM: remove disable_fiq and arch_ret_to_user macros ARM: make entry-macro.S depend on !MULTI_IRQ_HANDLER ARM: rpc: make default fiq handler run-time installed ARM: make arch_ret_to_user macro optional ARM: amba: samsung: use common amba device initializers ARM: amba: spear: use common amba device initializers ARM: amba: nomadik: use common amba device initializers ARM: amba: u300: use common amba device initializers ARM: amba: lpc32xx: use common amba device initializers ARM: amba: netx: use common amba device initializers ARM: amba: bcmring: use common amba device initializers ARM: amba: ep93xx: use common amba device initializers ARM: amba: omap2: use common amba device initializers ARM: amba: integrator: use common amba device initializers ARM: amba: realview: get rid of private platform amba_device initializer ARM: amba: versatile: get rid of private platform amba_device initializer ARM: amba: vexpress: get rid of private platform amba_device initializer ARM: amba: provide common initializers for static amba devices ARM: amba: make use of -1 IRQs warn ARM: amba: u300: get rid of NO_IRQ initializers ...
2012-03-20Merge branch 'next/fixes-non-critical' into next/driversArnd Bergmann
Conflicts: arch/arm/mach-lpc32xx/clock.c arch/arm/mach-pxa/pxa25x.c arch/arm/mach-pxa/pxa27x.c The conflicts with pxa are non-obvious, we have multiple branches adding and removing the same clock settings. According to Haojian Zhuang, removing the sa1100 rtc dummy clock is the correct fix here. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-15Merge branch 'board-specific' of git://github.com/hzhuang1/linux into ↵Arnd Bergmann
next/boards * 'board-specific' of git://github.com/hzhuang1/linux: pxa/hx4700: Remove pcmcia platform_device structure ARM: pxa/hx4700: Reduce sleep mode battery discharge by 35% ARM: pxa/hx4700: Remove unwanted request for GPIO105 (update to 3.3-rc7) Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-14pxa/hx4700: Remove pcmcia platform_device structurePaul Parsons
The existing pcmcia platform_device structure is not used and is not needed by the pending hx4700 PCMCIA/CF support. So let's remove it. Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Acked-by: Philipp Zabel <philipp.zabel@gmail.com> signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-03-14ARM: pxa/hx4700: Reduce sleep mode battery discharge by 35%Paul Parsons
Drive the two Bluetooth UART output GPIOs (GPIO43_BTUART_TXD, GPIO45_BTUART_RTS) LOW during sleep mode instead of HIGH. This reduces sleep mode battery discharge from approximately 46 mA to approximately 30 mA. Signed-off-by: Oliver Winker <oliver@oli1170.net> Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-03-14ARM: pxa/hx4700: Remove unwanted request for GPIO105Paul Parsons
GPIO105 (nIR_ON) is requested twice: first in gpio_request_array(), then in pxa_irda_probe(). Consequently the second request fails with EBUSY: pxa2xx-ir: probe of pxa2xx-ir failed with error -16 This patch removes the first request, allowing pxa_irda_probe() to succeed. Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-03-12Merge 3.3-rc7 into usb-nextGreg Kroah-Hartman
This resolves the conflict with drivers/usb/host/ehci-fsl.h that happened with changes in Linus's and this branch at the same time. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-10Merge branch 'board' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/boards * 'board' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP: add minimal support for Nokia RM-696 ARM: OMAP: enable Bluetooth on the PandaBoard ARM: OMAP: pandora: add support for backlight and poweroff ARM: OMAP4: board-4430sdp: don't initialize value that is never used ARM: OMAP3: cm-t3517: add EMAC support ARM: OMAP: move generic EMAC init to separate file ARM: OMAP3: RX-51: add explicit mux configuration of tsc2005 control gpios ARM: OMAP: Add omap_reserve functionality (includes sync-up to 3.3-rc6)
2012-03-08Merge branch 'regulator' of git://github.com/hzhuang1/linux into next/driversOlof Johansson
* 'regulator' of git://github.com/hzhuang1/linux: (2 commits) regulator: Remove bq24022 regulator driver pxa: magician/hx4700: Convert to gpio-regulator from bq24022 (plus update to v3.3-rc6)
2012-03-06ARM: pxa: fix invalid mfp pin issueHaojian Zhuang
Failure is reported on hx4700 with kernel v3.3-rc1. __mfp_validate: GPIO20 is invalid pin __mfp_validate: GPIO21 is invalid pin __mfp_validate: GPIO15 is invalid pin __mfp_validate: GPIO78 is invalid pin __mfp_validate: GPIO79 is invalid pin __mfp_validate: GPIO80 is invalid pin __mfp_validate: GPIO33 is invalid pin __mfp_validate: GPIO48 is invalid pin __mfp_validate: GPIO49 is invalid pin __mfp_validate: GPIO50 is invalid pin Since pxa_last_gpio is used in mfp-pxa2xx driver. But it's only updated in pxa-gpio driver that run after mfp-pxa2xx driver. So update the pxa_last_gpio first in mfp-pxa2xx driver. Reported-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-03-06ARM: pxa: remove duplicated registeration on pxa-gpioHaojian Zhuang
Both reboot (via reboot(RB_AUTOBOOT)) and suspend freeze on hx4700. Registration of pxa_gpio_syscore_ops is moved into pxa-gpio driver, but it still exists in arch-pxa directory. It resulsts failure on reboot and suspend. Now remove the registration code in arch-pxa. Reported-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-03-06ARM: pxa: add dummy clock for pxa25x and pxa27xHaojian Zhuang
gpio-pxa driver is shared among arch-pxa and arch-mmp. Clock is the essential component on pxa3xx/pxa95x and arch-mmp. So we need to define dummy clock in pxa25x/pxa27x instead. This regression was introduced by the commit "ARM: pxa: add dummy clock for sa1100-rtc", id a55b5adaf403c4d032e0871ad4ee3367782f4db6. Reported-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
2012-03-06pxa: magician/hx4700: Convert to gpio-regulator from bq24022Heiko Stübner
The bq24022 on these machines is a very simple regulator using gpios. One provides the on/off functionality and a second one is used to change the current between 100 and 500 mA. This functionality can also be provided by the more generic gpio-regulator. Therefore convert both machines which makes it possible to remove the bq24022 driver later on. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-02-28Merge branch 'board-specific' of git://github.com/hzhuang1/linux into ↵Arnd Bergmann
next/boards * 'board-specific' of git://github.com/hzhuang1/linux: (5 commits) ARM: pxa: add dummy clock for pxa25x and pxa27x ARM: mmp: append irq name of gpio device pxa/hx4700: Fix PXA_GPIO_IRQ_BASE/IRQ_NUM values pxa/hx4700: Add ASIC3 LED support pxa/hx4700: Correct StrataFlash block size discovery (update to v3.3-rc5)
2012-02-28Merge branch 'rtc-sa1100' of git://github.com/hzhuang1/linux into next/driversArnd Bergmann
* 'rtc-sa1100' of git://github.com/hzhuang1/linux: ARM: mmp: enable rtc in pxa910 rtc: sa1100: enable clk support ARM: pxa: add rtc dummy clock ARM: sa1100: clean up clock support rtc: sa1100: declare irq in resource rtc: sa1100: remove verification code of alarm rtc: sa1100: remove periodic code
2012-02-28ARM: pxa: add dummy clock for pxa25x and pxa27xHaojian Zhuang
gpio-pxa driver is shared among arch-pxa and arch-mmp. Clock is the essential component on pxa3xx/pxa95x and arch-mmp. So we need to define dummy clock in pxa25x/pxa27x instead. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
2012-02-28pxa/hx4700: Add ASIC3 LED supportPaul Parsons
Add LED support for the HTC ASIC3. Underlying support is provided by the mfd/asic3 and leds/leds-asic3 drivers. An example configuration is provided by the pxa/hx4700 platform. Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Acked-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-02-28pxa/hx4700: Correct StrataFlash block size discoveryPaul Parsons
The HP iPAQ hx4700 has 128Mb of flash provided by two Intel StrataFlash devices. The hx4700 platform configuration defines a single 128Mb flash resource, resulting in the MTD physmap-flash driver probing the first device only and presuming the second device is identical: physmap platform flash device: 08000000 at 00000000 physmap-flash: Found 2 x16 devices at 0x0 in 32-bit bank. Manufacturer ID 0x000089 Chip ID 0x008816 physmap-flash: Found 2 x16 devices at 0x4000000 in 32-bit bank <snip> erase region 0: offset=0x0,size=0x10000,blocks=4 erase region 1: offset=0x40000,size=0x40000,blocks=255 erase region 2: offset=0x4000000,size=0x10000,blocks=4 erase region 3: offset=0x4040000,size=0x40000,blocks=255 physmap-flash: 2 set(s) of 2 interleaved chips --> 32 partitions of 4096 KiB Unfortunately the two devices are not identical. The first has a device ID of 0x8816, identifying a bottom parameter device. The second has a device ID of 0x8813, identifying a top parameter device. By not probing the second device, physmap-flash does not discover the correct block sizes. This patch splits the configuration into two 64Mb flash resources, forcing physmap-flash to probe both devices and thus discover the correct block sizes: physmap platform flash device: 04000000 at 00000000 physmap-flash: Found 2 x16 devices at 0x0 in 32-bit bank. Manufacturer ID 0x000089 Chip ID 0x008816 <snip> erase region 0: offset=0x0,size=0x10000,blocks=4 erase region 1: offset=0x40000,size=0x40000,blocks=255 physmap-flash: 1 set(s) of 2 interleaved chips --> 16 partitions of 4096 KiB physmap platform flash device: 04000000 at 04000000 physmap-flash: Found 2 x16 devices at 0x0 in 32-bit bank. Manufacturer ID 0x000089 Chip ID 0x008813 <snip> erase region 0: offset=0x0,size=0x40000,blocks=255 erase region 1: offset=0x3fc0000,size=0x10000,blocks=4 physmap-flash: 1 set(s) of 2 interleaved chips --> 16 partitions of 4096 KiB Concatenating MTD devices: (0): "physmap-flash" (1): "physmap-flash" into device "physmap-flash" Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-02-28ARM: pxa: add rtc dummy clockHaojian Zhuang
sa1100-rtc driver could be shared among sa1100/pxa/mmp series silicon. Since clk is used in mmp series silicon, add dummy clock support in pxa also. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
2012-02-28rtc: sa1100: declare irq in resourceHaojian Zhuang
Avoid to hard coded irq in rtc-sa1100 driver since we could share it among arch-sa1100/arch-pxa/arch-mmp. We still keep hard coded register address since the requirement is enabling both rtc-sa1100 and rtc-pxa driver. The register addresses are conflict since they're only two wrappers on the same rtc device. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2012-02-27usb: otg: Convert all users to pass struct usb_otg for OTG functionsHeikki Krogerus
This changes the otg functions so that they receive struct otg instead of struct usb_phy as parameter and converts all users of these functions to pass the otg member of their usb_phy. Includes fixes to IMX code from Sascha Hauer. [ balbi@ti.com : fixed a compile warning on ehci-mv.c ] Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Acked-by: Li Yang <leoli@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-02-22Merge branch 'entry-macro-cleanup' of git://sources.calxeda.com/kernel/linux ↵Russell King
into for-armsoc
2012-02-21ARM: remove disable_fiq and arch_ret_to_user macrosRob Herring
Now that most platforms don't need disable_fiq and arch_ret_to_user macros, we can remove the empty macros or empty entry-macro.S files. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2012-02-17pxa/hx4700: add platform device and I2C info for AK4641 codecAxel Lin
The audio on hx4700 needs this to properly work. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Tested-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-02-16arch/arm/mach-pxa/: included linux/gpio.h twiceDanny Kukawka
arch/arm/mach-pxa/pxa25x.c and arch/arm/mach-pxa/saarb.c included 'linux/gpio.h' twice, remove the duplicates. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-02-16ARM: pxa: fix including linux/gpio.h twiceDanny Kukawka
arch/arm/mach-pxa/pxa27x.c included 'linux/gpio.h' twice, remove the duplicate. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-02-16ARM: pxa: fix mixed declarations and code in sharpsl_pmHaojian Zhuang
arch/arm/mach-pxa/sharpsl_pm.c: In function 'sharpsl_pm_pxa_read_max1111': arch/arm/mach-pxa/sharpsl_pm.c:180: warning: ISO C90 forbids mixed declarations and code Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
2012-02-16ARM: pxa: fix wrong parsing gpio event on spitzHaojian Zhuang
(~GPLR0 & GPIO_bit(SPITZ_GPIO_KEY_INT)) | (GPLR0 & GPIO_bit(SPITZ_GPIO_SYNC)); After using gpio_get_value, the statement should be in below. ((!gpio_get_value(SPITZ_GPIO_KEY_INT) << GPIO_bit(SPITZ_GPIO_KEY_INT)) | gpio_get_value(SPITZ_GPIO_SYNC)); Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
2012-02-13usb: otg: ulpi: Start using struct usb_otgHeikki Krogerus
Use struct usb_otg members with OTG specific functions instead of usb_phy members. Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-02-13usb: otg: Rename otg_transceiver to usb_phyHeikki Krogerus
This is the first step in separating USB transceivers from USB OTG utilities. Includes fixes to IMX code from Sascha Hauer. Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Acked-by: Li Yang <leoli@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-02-07Merge tag 'v3.3-rc2' into depends/rmk/for-armsocOlof Johansson
There were conflicts between fixes going in after 3.3-rc1 and Russell's stable arm-soc base branch. Resolving it in the dependency branch so that each topic branch shares the same resolution. Conflicts: arch/arm/mach-at91/at91cap9.c arch/arm/mach-at91/at91sam9g45.c
2012-02-04PCMCIA: pxa: convert PXA socket drivers to use new irq/gpio managementRussell King
Convert all the PXA platform socket drivers to use the new irq/gpio management provided by soc_common. This relieves these drivers from having to do anything with these GPIOs other than provide the numbers to soc_common. Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-01-20ARM: big removal of now unused arch_idle()Nicolas Pitre
When this is the only content remaining in mach/system.h then the whole file is removed. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-19Revert "RTC: sa1100: support sa1100, pxa and mmp soc families"Russell King
This reverts commit 7cea00657dd4daef66ad95e976d5d67ed94cb97e. The sa1100 cleanups fatally broke the SA1100 RTC driver - the first hint that something is wrong are these compiler warnings: drivers/rtc/rtc-sa1100.c:42:1: warning: "RCNR" redefined In file included from arch/arm/mach-sa1100/include/mach/hardware.h:73, from drivers/rtc/rtc-sa1100.c:35: arch/arm/mach-sa1100/include/mach/SA-1100.h:877:1: warning: this is the location of the previous definition drivers/rtc/rtc-sa1100.c:43:1: warning: "RTAR" redefined arch/arm/mach-sa1100/include/mach/SA-1100.h:876:1: warning: this is the location of the previous definition drivers/rtc/rtc-sa1100.c:44:1: warning: "RTSR" redefined arch/arm/mach-sa1100/include/mach/SA-1100.h:879:1: warning: this is the location of the previous definition drivers/rtc/rtc-sa1100.c:45:1: warning: "RTTR" redefined arch/arm/mach-sa1100/include/mach/SA-1100.h:878:1: warning: this is the location of the previous definition drivers/rtc/rtc-sa1100.c:47:1: warning: "RTSR_HZE" redefined arch/arm/mach-sa1100/include/mach/SA-1100.h:891:1: warning: this is the location of the previous definition drivers/rtc/rtc-sa1100.c:48:1: warning: "RTSR_ALE" redefined arch/arm/mach-sa1100/include/mach/SA-1100.h:890:1: warning: this is the location of the previous definition drivers/rtc/rtc-sa1100.c:49:1: warning: "RTSR_HZ" redefined arch/arm/mach-sa1100/include/mach/SA-1100.h:889:1: warning: this is the location of the previous definition drivers/rtc/rtc-sa1100.c:50:1: warning: "RTSR_AL" redefined arch/arm/mach-sa1100/include/mach/SA-1100.h:888:1: warning: this is the location of the previous definition and the second problem, which is far more severe, are the different register layouts, resulting in the wrong registers being read on SA11x0 platforms. This patch adds: #define RCNR 0x00 /* RTC Count Register */ #define RTAR 0x04 /* RTC Alarm Register */ #define RTSR 0x08 /* RTC Status Register */ #define RTTR 0x0c /* RTC Timer Trim Register */ but the SA11x0 registers are: #define RTAR __REG(0x90010000) /* RTC Alarm Reg. */ #define RCNR __REG(0x90010004) /* RTC CouNt Reg. */ #define RTTR __REG(0x90010008) /* RTC Trim Reg. */ #define RTSR __REG(0x90010010) /* RTC Status Reg. */
2012-01-19Revert "ARM: pxa: add dummy clock for sa1100-rtc"Russell King
This reverts commit 7557c175f60d8d40baf16b22caf79beadef8f081. This revert is necessary to revert the broken "RTC: sa1100: support sa1100, pxa and mmp soc families" change.
2012-01-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (526 commits) ASoC: twl6040 - Add method to query optimum PDM_DL1 gain ALSA: hda - Fix the lost power-setup of seconary pins after PM resume ALSA: usb-audio: add Yamaha MOX6/MOX8 support ALSA: virtuoso: add S/PDIF input support for all Xonars ALSA: ice1724 - Support for ooAoo SQ210a ALSA: ice1724 - Allow card info based on model only ALSA: ice1724 - Create capture pcm only for ADC-enabled configurations ALSA: hdspm - Provide unique driver id based on card serial ASoC: Dynamically allocate the rtd device for a non-empty release() ASoC: Fix recursive dependency due to select ATMEL_SSC in SND_ATMEL_SOC_SSC ALSA: hda - Fix the detection of "Loopback Mixing" control for VIA codecs ALSA: hda - Return the error from get_wcaps_type() for invalid NIDs ALSA: hda - Use auto-parser for HP laptops with cx20459 codec ALSA: asihpi - Fix potential Oops in snd_asihpi_cmode_info() ALSA: hdsp - Fix potential Oops in snd_hdsp_info_pref_sync_ref() ALSA: hda/cirrus - support for iMac12,2 model ASoC: cx20442: add bias control over a platform provided regulator ALSA: usb-audio - Avoid flood of frame-active debug messages ALSA: snd-usb-us122l: Delete calls to preempt_disable mfd: Put WM8994 into cache only mode when suspending ... Fix up trivial conflicts in: - arch/arm/mach-s3c64xx/mach-crag6410.c: renamed speyside_wm8962 to tobermory, added littlemill right next to it - drivers/base/regmap/{regcache.c,regmap.c}: duplicate diff that had already come in with other changes in the regmap tree
2012-01-09Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Driver specific changes Again, a lot of platforms have changes in here: pxa, samsung, omap, at91, imx, ... * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits) ARM: sa1100: clean up of the clock support ARM: pxa: add dummy clock for sa1100-rtc RTC: sa1100: support sa1100, pxa and mmp soc families RTC: sa1100: remove redundant code of setting alarm RTC: sa1100: Clean out ost register Input: zylonite-wm97xx - replace IRQ_GPIO() with gpio_to_irq() pcmcia: pxa: replace IRQ_GPIO() with gpio_to_irq() ARM: EXYNOS: Modified files for SPI consolidation work ARM: S5P64X0: Enable SDHCI support ARM: S5P64X0: Add lookup of sdhci-s3c clocks using generic names ARM: S5P64X0: Add HSMMC setup for host Controller ARM: EXYNOS: Add USB OHCI support to ORIGEN board USB: Add Samsung Exynos OHCI diver ARM: EXYNOS: Add USB OHCI support to SMDKV310 board ARM: EXYNOS: Add USB OHCI device net: macb: fix build break with !CONFIG_OF i2c: tegra: Support DVC controller in device tree i2c: tegra: Add __devinit/exit to probe/remove net/at91_ether: use gpio_is_valid for phy IRQ line ARM: at91/net: add macb ethernet controller in 9g45/9g20 DT ...
2012-01-09Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Board-level changes This adds and extends support for specific boards on a number of ARM platforms: omap, imx, samsung, tegra, ... * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (49 commits) Enable 32 bit flash support for iMX21ADS board ARM: mx31pdk: Add MC13783 RTC support iomux-mx25: configuration to support CSPI3 on CSI pins MX1:apf9328: Add i2c support mioa701: add newly available DoC G3 chip arm/tegra: remove __initdata annotation from pinmux tables arm/tegra: Use bus notifiers to trigger pinmux setup arm/tegra: Refactor board-*-pinmux.c to share code arm/tegra: Fix mistake in Trimslice's pinmux arm/tegra: Rework Seaboard-vs-Ventana pinmux table arm/tegra: Remove useless entries from ventana_pinmux[] arm/tegra: PCIe: Remove include of mach/pinmux.h arm/tegra: Harmony PCIe: Don't touch pinmux arm/tegra: Add AUXDATA for tegra-pinmux and tegra-gpio arm/tegra: Split Seaboard GPIO table to allow for Ventana ARM: imx6q: generate imx6q dtb files arm/imx6q: Rename Sabreauto to Armadillo2 arm/imx6q-sabrelite: add enet phy ksz9021rn fixup arm/imx6: add imx6q sabrelite board support dts/imx: rename uart labels to consistent with hw spec ...
2012-01-09Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Non-critical bug fixes Simple bug fixes that were not considered important enough for inclusion into 3.2. * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: MAINTAINERS: update pxa and mmp ARM: pxa: Include linux/export.h in balloon3.c ARM: OMAP4: clock: Add CPU local timer clock node ARM: OMAP4: hwmod: Don't wait for the idle status if modulemode is not supported ARM: OMAP: AM3517/3505: fix crash on boot due to incorrect voltagedomain data ARM: OMAP: hwmod data: fix the panic on Nokia RM-680 during boot ARM: OMAP2+: DMA: Workaround for invalid destination position ARM: OMAP2+: DMA: Workaround for invalid source position
2012-01-09Merge branch 'samsung/cleanup' into next/boardsArnd Bergmann
Conflicts: arch/arm/mach-imx/mach-imx6q.c arch/arm/mach-omap2/board-ti8168evm.c arch/arm/mach-s3c64xx/Kconfig arch/arm/mach-tegra/Makefile arch/arm/mach-tegra/board-dt-tegra20.c arch/arm/mach-tegra/common.c Lots of relatively simple conflicts between the board changes and stuff from the arm tree. This pulls in the resolution from the samsung/cleanup tree, so we don't get conflicting merges. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-01-09Merge branch 'samsung/driver' into next/driversArnd Bergmann
Conflicts: arch/arm/mach-mxs/include/mach/common.h Pull in previous samsung conflict merges and do a trivial merge of an mxs double-add conflict. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: restart: remove the now empty arch_reset()Russell King
Remove the now empty arch_reset() from all the mach/system.h includes, and remove its callsite. Remove arm_machine_restart() as this function no longer does anything useful. For samsung platforms, remove the include of mach/system-reset.h and plat/system-reset.h from their respective mach/system.h headers as these just define their arch_reset functions. As a result, the s3c2410 and plat-samsung system-reset.h files are no longer referenced, so remove these files entirely. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-01-05ARM: restart: pxa: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
