path: root/arch/arm/mach-pxa
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-02[ARM] 3848/1: pxafb: Add option of fixing video modes and spitz QVGA mode ↵Richard Purdie
support Add the ability to have pxafb use only certain fixed video modes (selected on a per platform basis). This is useful on production hardware such as the Zaurus cxx00 models where the valid modes are known in advance and any other modes could result in hardware damage. Following this, add support for the cxx00 QVGA mode. Mode information is passed to the lcd_power call to allowing the panel drivers to configure the display hardware accordingly (corgi_lcd already contains the functionality for the cxx00 panel). This mirrors the setup already used by w100fb. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27USB: pxa2xx_udc understands GPIO based VBUS sensingDavid Brownell
This updates the PXA 25x UDC board-independent infrastructure for VBUS sensing and the D+ pullup. The original code evolved from rather bizarre support on Intel's "Lubbock" reference hardware, so that on more sensible hardware it doesn't work as well as it could/should. The change is just to teach the UDC driver how to use built-in PXA GPIO pins directly. This reduces the amount of board-specfic object code needed, and enables the use of a VBUS sensing IRQ on boards (like Gumstix) that have one. With VBUS sensing, the UDC is unclocked until a host is actually connected. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-27[ARM] 3760/1: This patch adds timeouts while working with SSP registers. ↵Paul Sokolovsky
Such timeouts were en Patch from Paul Sokolovsky This patch adds timeouts while working with SSP registers. Such timeouts were envisioned by docstrings in ssp.c, but were not implemented. There were actual lockups while accessing touchscreen for iPaqs h1910, h4000 due to lack of the timeouts. This is updated version of previously submitted patch: 3738/1. Signed-off-by: Paul Sokolovsky <pmiscml@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-01[ARM] 3739/1: genirq updates: irq_chip, add and use irq_chip.nameDavid Brownell
Patch from David Brownell ARM genirq cleanups/updates: - Start switching platforms to newer APIs * use "irq_chip" name, not "irqchip" * providing irq_chip.name - Show irq_chip.name in /proc/interrupts, like on x86. This update a bit more than half of the ARM code. The irq_chip.name values were chosen to match docs (if I have them) or be otherwise obvious ("FPGA", "CPLD", or matching the code). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02Merge branch 'genirq' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'genirq' of master.kernel.org:/home/rmk/linux-2.6-arm: (24 commits) [ARM] 3683/2: ARM: Convert at91rm9200 to generic irq handling [ARM] 3682/2: ARM: Convert ixp4xx to generic irq handling [ARM] 3702/1: ARM: Convert ixp23xx to generic irq handling [ARM] 3701/1: ARM: Convert plat-omap to generic irq handling [ARM] 3700/1: ARM: Convert lh7a40x to generic irq handling [ARM] 3699/1: ARM: Convert s3c2410 to generic irq handling [ARM] 3698/1: ARM: Convert sa1100 to generic irq handling [ARM] 3697/1: ARM: Convert shark to generic irq handling [ARM] 3696/1: ARM: Convert clps711x to generic irq handling [ARM] 3694/1: ARM: Convert ecard driver to generic irq handling [ARM] 3693/1: ARM: Convert omap1 to generic irq handling [ARM] 3691/1: ARM: Convert imx to generic irq handling [ARM] 3688/1: ARM: Convert clps7500 to generic irq handling [ARM] 3687/1: ARM: Convert integrator to generic irq handling [ARM] 3685/1: ARM: Convert pxa to generic irq handling [ARM] 3684/1: ARM: Convert l7200 to generic irq handling [ARM] 3681/1: ARM: Convert ixp2000 to generic irq handling [ARM] 3680/1: ARM: Convert footbridge to generic irq handling [ARM] 3695/1: ARM drivers/pcmcia: Fixup includes [ARM] 3689/1: ARM drivers/input/touchscreen: Fixup includes ... Manual conflict resolved in kernel/irq/handle.c (butt-ugly ARM tickless code).
2006-07-02Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (44 commits) [ARM] 3541/2: workaround for PXA27x erratum E7 [ARM] nommu: provide a way for correct control register value selection [ARM] 3705/1: add supersection support to ioremap() [ARM] 3707/1: iwmmxt: use the generic thread notifier infrastructure [ARM] 3706/2: ep93xx: add cirrus logic edb9315a support [ARM] 3704/1: format IOP Kconfig with tabs, create more consistency [ARM] 3703/1: Add help description for ARCH_EP80219 [ARM] 3678/1: MMC: Make OMAP MMC work [ARM] 3677/1: OMAP: Update H2 defconfig [ARM] 3676/1: ARM: OMAP: Fix dmtimers and timer32k to compile on OMAP1 [ARM] Add section support to ioremap [ARM] Fix sa11x0 SDRAM selection [ARM] Set bit 4 on section mappings correctly depending on CPU [ARM] 3666/1: TRIZEPS4 [1/5] core ARM: OMAP: Multiplexing for 24xx GPMC wait pin monitoring ARM: OMAP: Fix SRAM to use MT_MEMORY instead of MT_DEVICE ARM: OMAP: Update dmtimers ARM: OMAP: Make clock variables static ARM: OMAP: Fix GPMC compilation when DEBUG is defined ARM: OMAP: Mux updates for external DMA and GPIO ...
2006-07-01[ARM] 3685/1: ARM: Convert pxa to generic irq handlingThomas Gleixner
Patch from Thomas Gleixner From: Thomas Gleixner <tglx@linutronix.de> Fixup the conversion to generic irq subsystem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-29[ARM] 3666/1: TRIZEPS4 [1/5] coreJürgen Schindele
Patch from Jürgen Schindele This patch adds support for Trizeps4 SoM and ConXS-evalboard from "Keith und Koep" This DIMM-module is based on PXA270. Signed-off-by: Jürgen Schindele <linux@schindele.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-29[ARM] 3673/1: lpd270: parse lcd= command line parameterLennert Buytenhek
Patch from Lennert Buytenhek The bootloader on the LogicPD PXA270 platform informs the kernel of which type of TFT screen is connected via an lcd=$FOO kernel command line parameter. Before this patch, we ignored this parameter and just hardcoded the use of the Sharp lq64d343 display kit. This patch implement parsing of the command line option, and chooses the right pxafb_mach_info to use (six choices) based on this command line option. Also fix the fb settings to correspond with those of the bootloader. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-28[ARM] 3672/1: PXA: don't probe output GPIOs for interruptGuennadi Liakhovetski
Patch from Guennadi Liakhovetski Currently probe_irq_on() on PXA will silently reconfigure all output GPIOs, that are not configured as alternate functions, for input. Avoid that. Upon CPU reset all GPIOs are configured as inputs, so, if a GPIO is configured as output, it has been done so intentionally. Signed-off-by: G. Liakhovetski <gl@dsa-ac.de> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-25[ARM] Remove MODE_(SVC|IRQ|FIQ|USR) and DEFAULT_FIQRussell King
DEFAULT_FIQ was entirely unused. MODE_* are just redefinitions of *_MODE. Use *_MODE instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-20[ARM] Fix tosa build errorRussell King
tosa.c references mdelay(), but was missing linux/delay.h Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3594/1: Poodle: Add touchscreen support + other updatesRichard Purdie
Patch from Richard Purdie Poodle Updates: * Update corgi_ssp to make the GPIO chip selects optional * Enable corgi_ssp for use by poodle * Add corgi touchscreen platform device for poodle * Export locomo platform device. * Set framebuffer device parent correctly Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3564/1: sharpsl_pm: Abstract some machine specific parametersRichard Purdie
Patch from Richard Purdie Abstract some machine specific parameters from the sharpsl_pm core into the machine specific drivers. This allows the core to support tosa/poodle. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3561/1: Poodle: Correct the MMC/SD power controlRichard Purdie
Patch from Richard Purdie Correct the Poodle power control for the MMC/SD port. Also add write protection switch support. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3593/1: Add reboot and shutdown handlers for Zaurus handheldsRichard Purdie
Patch from Richard Purdie Add functionality to allow machine specific reboot handlers on ARM. Add machine specific reboot and poweroff handlers for all PXA Zaurus models. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3534/1: add spi support to lubbock platformDavid Brownell
Patch from David Brownell This adds the platform device for SSP/SPI controller, and declares the ads7846 device hooked up to it. Not all Lubbock boards appear to populate the connector needed to use this instead of the ucb1400 chip, but it can always be used as a temperature sensor. In short, this is probably most useful as an example of how to provide the configuration data used by the pxa2xx_spi driver. (Last tested against a slightly earlier version of that driver.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-08[ARM] 3547/1: PXA-OHCI: Allow platforms to specify a power budgetRichard Purdie
Patch from Richard Purdie Add a power budget variable to the PXA OHCI platform data and add a default value for the spitz platform(s) which prevents known failures with certain USB devices. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-05[ARM] 3543/1: [Fwd: PXA270 bootparams address not set]Steve Yang
Patch from Steve Yang MACHINE_START struct doesn't have any bootargs location for the mainstone. Result is no kernel command args get passed; no serial driver is selected for console and results in a silent boot failure. Signed-off-by: Steve Yang <steve.yang@windriver.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-17[ARM] 3530/1: PXA Mainstone: prevent double enable_irq() in pcmciaThomas Gleixner
Patch from Thomas Gleixner The mainstone board pcmcia interrupt have been enabled via setup_irq() and the following socket check calls enable_irq again. Set the NOAUTOEN flag so the interrupt is not automatically enabled in setup_irq() Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-05[ARM] 3500/1: fix PXA27x DMA allocation priorityNicolas Pitre
Patch from Nicolas Pitre Intel PXA27x developers manual section 5.4.1.1 lists a priority distribution for the DMA channels differently than what the code currently assumes. This patch fixes that. Noticed by Simon Vogl <vogl@soft.uni-linz.ac.at> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-18[ARM] 3479/1: Corgi SSP: Fix potential concurrent access problemRichard Purdie
Patch from Richard Purdie corgi_ssp_probe() should not access GPDR directly but should use pxa_gpio_mode() which has appropriate locking and other safeguards. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-02[ARM] 3453/1: Poodle: Correctly set the memory sizeRichard Purdie
Patch from Richard Purdie Force the Sharp Zaurus Poodle memory size to 32MB. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-31[PATCH] backlight: corgi_bl: Generalise to support other Sharp SL hardwareRichard Purdie
Generalise the Corgi backlight driver by moving the default intensity and limit mask settings into the platform specific data structure. This enables the driver to support other Zaurus hardware, specifically the SL-6000x (Tosa) model. Also change the spinlock to a mutex (the spinlock is overkill). Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] LED: add device support for tosaDirk Opfer
Adds LED drivers for LEDs found on the Sharp Zaurus c6000 model (tosa). Signed-off-by: Dirk Opfer <dirk@opfer-online.de> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] LED: add LED device support for the zaurus corgi and spitz modelsRichard Purdie
Adds LED drivers for LEDs found on the Sharp Zaurus c7x0 (corgi, shepherd, husky) and cxx00 (akita, spitz, borzoi) models. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3388/1: ixp23xx: add core ixp23xx support [ARM] 3417/1: add support for logicpd pxa270 card engine [ARM] 3387/1: ixp23xx: add defconfig [ARM] 3377/2: add support for intel xsc3 core [ARM] Move ice-dcc code into misc.c [ARM] Fix decompressor serial IO to give CRLF not LFCR [ARM] proc-v6: mark page table walks outer-cacheable, shared. Enable NX. [ARM] nommu: trivial patch for arch/arm/lib/Makefile [ARM] 3416/1: Update LART site URL [ARM] 3415/1: Akita: Add missing EXPORT_SYMBOL [ARM] 3414/1: ep93xx: reset ethernet controller before uncompressing
2006-03-28[ARM] 3417/1: add support for logicpd pxa270 card engineLennert Buytenhek
Patch from Lennert Buytenhek Add support for the LogicPD PXA270 Card Engine. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-27[PATCH] RTC subsystem: SA1100/PXA2XX driverRichard Purdie
Add an RTC subsystem driver for the ARM SA1100/PXA2XX processor RTC. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[ARM] 3415/1: Akita: Add missing EXPORT_SYMBOLRichard Purdie
Patch from Richard Purdie Add an EXPORT_SYMBOL for the Akita IO Expander Device. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-24[PATCH] s/;;/;/gAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (45 commits) [ARM] 3389/1: typo and grammar fix [ARM] 3386/1: AT91RM9200 Clock update [ARM] 3384/1: AT91RM9200: Timer [ARM] 3382/1: ixp2000: unify defconfigs [ARM] 3381/1: ixp2000: fix slowport write timing control register fields [ARM] 3380/1: ixp2000: simplify ixdp2x00_master_npu() check [ARM] 3379/1: ixp2000: use generic 8250 debug macros [ARM] 3378/1: ixp2000: fix gpio interrupt handling [ARM] Quieten spurious IRQ detection [ARM] Use kcalloc to allocate counter_config array rather than kmalloc [ARM] Oprofile: dynamically allocate counter_config [ARM] Oprofile: Convert semaphore to mutex [ARM] 3376/2: S3C2410 - update defconfig [ARM] 3375/1: S3C2440 - fix osiris machine build [ARM] 3374/1: ep93xx: gpio interrupt support [ARM] 3361/1: S3C24XX - add USB bus clock source [ARM] 3360/1: S3C2440 - add set rate methods and camera clock [ARM] 3359/1: S3C24XX - add support for clk_set_rate [ARM] Convert kmalloc+memset to kzalloc [ARM] 3373/1: move uengine loader to arch/arm/common ...
2006-03-22[ALSA] Fix snd_xxx_t typedefsTakashi Iwai
Modules: PXA Mainstone driver,CX88 driver,SAA7134 driver Replace snd_xxx_t typedefs with explicit structs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-21[ARM] Convert SA1111 to use clock architectureRussell King
2006-03-21[ARM] Remove asm/arch/irq.hRussell King
asm/arch/irq.h used to be included from asm/irq.h, but was removed from the ARM kernel a long time ago. Consequently, the contents of asm/arch/irq.h (which mostly contain a definition for fixup_irq()) have not been used. Hence, remove asm/arch/irq.h. Some machine support files incorrectly included this file, making little or no use of the contents. Move the contents to a local include file, and remove those include statements as well. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-01[ARM] 3291/1: PXA27x: Correct get_clk_frequency_khz turbo flag handlingRichard Purdie
Patch from Richard Purdie The turbo flag is in bit 0 of the CLKCFG register, not bit 1. This patch corrects this so get_clk_frequency_khz returns a correct value. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-12[ARM] Convert some arm semaphores to mutexesArjan van de Ven
The arm clock semaphores are strict mutexes, convert them to the new mutex implementation Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-08[PATCH] IRQ type flagsRussell King
Some ARM platforms have the ability to program the interrupt controller to detect various interrupt edges and/or levels. For some platforms, this is critical to setup correctly, particularly those which the setting is dependent on the device. Currently, ARM drivers do (eg) the following: err = request_irq(irq, ...); set_irq_type(irq, IRQT_RISING); However, if the interrupt has previously been programmed to be level sensitive (for whatever reason) then this will cause an interrupt storm. Hence, if we combine set_irq_type() with request_irq(), we can then safely set the type prior to unmasking the interrupt. The unfortunate problem is that in order to support this, these flags need to be visible outside of the ARM architecture - drivers such as smc91x need these flags and they're cross-architecture. Finally, the SA_TRIGGER_* flag passed to request_irq() should reflect the property that the device would like. The IRQ controller code should do its best to select the most appropriate supported mode. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-07Merge with Linus' kernel.Russell King
2006-01-07[ARM] 3235/1: SharpSL PM: Fix a gcc4 build errorRichard Purdie
Patch from Richard Purdie Fix a gcc4 build error (incomplete element type) in the pxa SharpSL PM code. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 10 of 11Jean Delvare
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the drivers for arm arch. Signed-off-by: Jean Delvare <khali@linux-fr.org> CC: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Rework client usage count, 2 of 3Jean Delvare
Make I2C_CLIENT_ALLOW_USE the default for all i2c clients. It doesn't hurt if the usage count is actually never used for any given driver, and allows for nice code simplifications in i2c-core. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
