path: root/arch/arm/mach-pxa
2013-11-18Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c changes from Wolfram Sang: - new drivers for exynos5, bcm kona, and st micro - bigger overhauls for drivers mxs and rcar - typical driver bugfixes, cleanups, improvements - got rid of the superfluous 'driver' member in i2c_client struct This touches a few drivers in other subsystems. All acked. * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits) i2c: bcm-kona: fix error return code in bcm_kona_i2c_probe() i2c: i2c-eg20t: do not print error message in syslog if no ACK received i2c: bcm-kona: Introduce Broadcom I2C Driver i2c: cbus-gpio: Fix device tree binding i2c: wmt: add missing clk_disable_unprepare() on error i2c: designware: add new ACPI IDs i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCH i2c: exynos5: Remove incorrect clk_disable_unprepare i2c: i2c-st: Add ST I2C controller i2c: exynos5: add High Speed I2C controller driver i2c: rcar: fixup rcar type naming i2c: scmi: remove some bogus NULL checks i2c: sh_mobile & rcar: Enable the driver on all ARM platforms i2c: sh_mobile: Convert to clk_prepare/unprepare i2c: mux: gpio: use reg value for i2c_add_mux_adapter i2c: mux: gpio: use gpio_set_value_cansleep() i2c: Include linux/of.h header i2c: mxs: Fix PIO mode on i.MX23 i2c: mxs: Rework the PIO mode operation i2c: mxs: distinguish i.MX23 and i.MX28 based I2C controller ...
2013-11-16Merge tag 'pwm/for-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm changes from Thierry Reding: "Mostly bug fixes and clean up. There is a new driver, which is actually moving a custom PWM driver from drivers/misc. The majority of the patches are enhancements to the device tree support in the pwm-backlight driver. Backlights can now additionally be powered using a regulator and enabled using a GPIO in addition to just the PWM input" * tag 'pwm/for-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (30 commits) Documentation/pwm: Update supported SoC name for pwm-samsung pwm: samsung: Fix kernel warning while unexporting a channel MAINTAINERS: Move PWM subsystem tree to kernel.org Documentation/pwm: Fix trivial typos pwm-backlight: Remove unused variable pwm_backlight: avoid short blank screen while doing hibernation pwm-backlight: Fix brightness adjustment pwm: add ep93xx PWM support pwm-backlight: Allow for non-increasing brightness levels pwm-backlight: Add power supply support pwm-backlight: Use new enable_gpio field unicore32: Initialize PWM backlight enable_gpio field ARM: shmobile: Initialize PWM backlight enable_gpio field ARM: SAMSUNG: Initialize PWM backlight enable_gpio field ARM: pxa: Initialize PWM backlight enable_gpio field ARM: OMAP: Initialize PWM backlight enable_gpio field pwm-backlight: Add optional enable GPIO pwm-backlight: Track enable state pwm-backlight: Refactor backlight power on/off pwm-backlight: Improve readability ...
2013-11-14Merge tag 'pm+acpi-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael J Wysocki: - New power capping framework and the the Intel Running Average Power Limit (RAPL) driver using it from Srinivas Pandruvada and Jacob Pan. - Addition of the in-kernel switching feature to the arm_big_little cpufreq driver from Viresh Kumar and Nicolas Pitre. - cpufreq support for iMac G5 from Aaro Koskinen. - Baytrail processors support for intel_pstate from Dirk Brandewie. - cpufreq support for Midway/ECX-2000 from Mark Langsdorf. - ARM vexpress/TC2 cpufreq support from Sudeep KarkadaNagesha. - ACPI power management support for the I2C and SPI bus types from Mika Westerberg and Lv Zheng. - cpufreq core fixes and cleanups from Viresh Kumar, Srivatsa S Bhat, Stratos Karafotis, Xiaoguang Chen, Lan Tianyu. - cpufreq drivers updates (mostly fixes and cleanups) from Viresh Kumar, Aaro Koskinen, Jungseok Lee, Sudeep KarkadaNagesha, Lukasz Majewski, Manish Badarkhe, Hans-Christian Egtvedt, Evgeny Kapaev. - intel_pstate updates from Dirk Brandewie and Adrian Huang. - ACPICA update to version 20130927 includig fixes and cleanups and some reduction of divergences between the ACPICA code in the kernel and ACPICA upstream in order to improve the automatic ACPICA patch generation process. From Bob Moore, Lv Zheng, Tomasz Nowicki, Naresh Bhat, Bjorn Helgaas, David E Box. - ACPI IPMI driver fixes and cleanups from Lv Zheng. - ACPI hotplug fixes and cleanups from Bjorn Helgaas, Toshi Kani, Zhang Yanfei, Rafael J Wysocki. - Conversion of the ACPI AC driver to the platform bus type and multiple driver fixes and cleanups related to ACPI from Zhang Rui. - ACPI processor driver fixes and cleanups from Hanjun Guo, Jiang Liu, Bartlomiej Zolnierkiewicz, Mathieu Rhéaume, Rafael J Wysocki. - Fixes and cleanups and new blacklist entries related to the ACPI video support from Aaron Lu, Felipe Contreras, Lennart Poettering, Kirill Tkhai. - cpuidle core cleanups from Viresh Kumar and Lorenzo Pieralisi. - cpuidle drivers fixes and cleanups from Daniel Lezcano, Jingoo Han, Bartlomiej Zolnierkiewicz, Prarit Bhargava. - devfreq updates from Sachin Kamat, Dan Carpenter, Manish Badarkhe. - Operation Performance Points (OPP) core updates from Nishanth Menon. - Runtime power management core fix from Rafael J Wysocki and update from Ulf Hansson. - Hibernation fixes from Aaron Lu and Rafael J Wysocki. - Device suspend/resume lockup detection mechanism from Benoit Goby. - Removal of unused proc directories created for various ACPI drivers from Lan Tianyu. - ACPI LPSS driver fix and new device IDs for the ACPI platform scan handler from Heikki Krogerus and Jarkko Nikula. - New ACPI _OSI blacklist entry for Toshiba NB100 from Levente Kurusa. - Assorted fixes and cleanups related to ACPI from Andy Shevchenko, Al Stone, Bartlomiej Zolnierkiewicz, Colin Ian King, Dan Carpenter, Felipe Contreras, Jianguo Wu, Lan Tianyu, Yinghai Lu, Mathias Krause, Liu Chuansheng. - Assorted PM fixes and cleanups from Andy Shevchenko, Thierry Reding, Jean-Christophe Plagniol-Villard. * tag 'pm+acpi-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (386 commits) cpufreq: conservative: fix requested_freq reduction issue ACPI / hotplug: Consolidate deferred execution of ACPI hotplug routines PM / runtime: Use pm_runtime_put_sync() in __device_release_driver() ACPI / event: remove unneeded NULL pointer check Revert "ACPI / video: Ignore BIOS initial backlight value for HP 250 G1" ACPI / video: Quirk initial backlight level 0 ACPI / video: Fix initial level validity test intel_pstate: skip the driver if ACPI has power mgmt option PM / hibernate: Avoid overflow in hibernate_preallocate_memory() ACPI / hotplug: Do not execute "insert in progress" _OST ACPI / hotplug: Carry out PCI root eject directly ACPI / hotplug: Merge device hot-removal routines ACPI / hotplug: Make acpi_bus_hot_remove_device() internal ACPI / hotplug: Simplify device ejection routines ACPI / hotplug: Fix handle_root_bridge_removal() ACPI / hotplug: Refuse to hot-remove all objects with disabled hotplug ACPI / scan: Start matching drivers after trying scan handlers ACPI: Remove acpi_pci_slot_init() headers from internal.h ACPI / blacklist: fix name of ThinkPad Edge E530 PowerCap: Fix build error with option -Werror=format-security ... Conflicts: arch/arm/mach-omap2/opp.c drivers/Kconfig drivers/spi/spi.c
2013-10-16ARM: pxa: Initialize PWM backlight enable_gpio fieldThierry Reding
The GPIO API defines 0 as being a valid GPIO number, so this field needs to be initialized explicitly. A special case is the Palm Tungsten|C board. Since it doesn't use any quirks that would require the existing .init() or .exit() hooks it can simply use the new enable_gpio field. Signed-off-by: Thierry Reding <treding@nvidia.com>
2013-10-16cpufreq: remove CONFIG_CPU_FREQ_TABLEViresh Kumar
CONFIG_CPU_FREQ_TABLE will be always enabled when cpufreq framework is used, as cpufreq core depends on it. So, we don't need this CONFIG option anymore as it is not configurable. Remove CONFIG_CPU_FREQ_TABLE and update its users. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-30misc: (at24) move header to linux/platform_data/Vivien Didelot
This patch moves the at24.h header from include/linux/i2c to include/linux/platform_data and updates existing support accordingly. It also fixes the following checkpatch warning: WARNING: please, no space before tabs #436: FILE: include/linux/platform_data/at24.h:31: + * ^Iu8 *mac_addr = ethernet_pdata->mac_addr;$ Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-09-27ARM: pxa: delete the custom GPIO headerLinus Walleij
The PXA sub-architecture appears to have a custom <mach/gpio.h> for no reason whatsoever. The file became completely empty after Haojian removed the remaining content in commit 157d2644cb0c1e71a18baaffca56d2b1d0ebf10f "ARM: pxa: change gpio to platform device". That commit added these two lines: However it seems like deleting the file has no effect whatsoever on the kernel compilation. Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-06Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "Device tree and bindings updates for 3.12. General additions of various on-chip and on-board peripherals on various platforms as support gets added. Some of the bigger changes are: - Addition of (new) PCI-e support on Tegra. - More Tegra4 support, including PMC configuration for Dalmore. - Addition of a new board for Exynos4 (trats2) and more bindings for 4x12 IP. - Addition of Allwinner A20 and A31 SoC and board files. - Move of the ST Ericsson device tree files to now use ste-* prefix. - More move of hardware description of shmobile platforms to DT. - Two new board dts files for Freescale MXs" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (177 commits) dts: Rename DW APB timer compatible strings dts: Deprecate ALTR as a vendor prefix of: add vendor prefix for Altera Corp. ARM: at91/dt: sam9x5ek: add sound configuration ARM: at91/dt: sam9x5ek: enable SSC ARM: at91/dt: sam9x5ek: add WM8731 codec ARM: at91/dt: sam9x5: add SSC DMA parameters ARM: at91/dt: add at91rm9200 PQFP package version ARM: at91: at91rm9200: set default mmc0 pinctrl-names ARM: at91: at91sam9n12: correct pin number of gpio-key ARM: at91: at91sam9n12: add qt1070 support ARM: at91: at91sam9n12: add pinctrl of TWI ARM: at91: Add PMU support for sama5d3 ARM: at91: at91sam9260: add missing pinctrl-names on mmc ARM: tegra: configure power off for Dalmore ARM: DT: binding fixup to align with vendor-prefixes.txt (DT) ARM: dts: add sdio blocks to bcm28155-ap board ARM: dts: align sdio numbers to HW definition ARM: sun7i: Add Olimex A20-Olinuxino-Micro support ARM: sun7i: Add Allwinner A20 DTSI ...
2013-09-06Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This branch contains code cleanups, moves and removals for 3.12. There's a large number of various cleanups, and a nice net removal of 13500 lines of code. Highlights worth mentioning are: - A series of patches from Stephen Boyd removing the ARM local timer API. - Move of Qualcomm MSM IOMMU code to drivers/iommu. - Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM driver and switching over to the drivers/pwm one. - Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM). There's also a move of a header file out of include/linux/i2c/ to platform_data, where it really belongs. It touches mostly ARM platform code for include changes so we took it through our tree" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits) ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK gpio: (gpio-pca953x) move header to linux/platform_data/ arm: zynq: hotplug: Remove unreachable code ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*() tegra: simplify use of devm_ioremap_resource ARM: SAMSUNG: Remove plat/regs-timer.h header ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header ARM: SAMSUNG: Remove pwm-clock infrastructure ARM: SAMSUNG: Remove old PWM timer platform devices pwm: Remove superseded pwm-samsung-legacy driver ARM: SAMSUNG: Modify board files to use new PWM platform device ARM: SAMSUNG: Rework private data handling in dev-backlight pwm: Add new pwm-samsung driver ARM: mach-mvebu: remove redundant DT parsing and validation ARM: msm: Only compile io.c on platforms that use it iommu/msm: Move mach includes to iommu directory ARM: msm: Remove devices-iommu.c ARM: msm: Move mach/board.h contents to common.h ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE ARM: msm: Remove TMR and TMR0 static mappings ...
2013-08-29gpio: (gpio-pca953x) move header to linux/platform_data/Vivien Didelot
This patch moves the pca953x.h header from include/linux/i2c to include/linux/platform_data and updates existing support accordingly. Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-21can: mcp251x: Replace power callbacks with regulator APIAlexander Shiyan
This patch replaces power callbacks to the regulator API. To improve the readability of the code, helper for the regulator enable/disable was added. Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2013-08-14Merge branch 'zynq/dt' into next/dtKevin Hilman
* zynq/dt: (1054 commits) arm: zynq: dt: Set correct L2 ram latencies + v3.11-rc5 Conflicts: arch/arm/Makefile
2013-08-13ARM: pxa: fix DT auxdata for pxa3xx-gpioDaniel Mack
Commit f87311743 ("ARM: mmp: add more compatible names in gpio driver") changed the DT match string for pxa3xx-gpio, but left the auxdata table unchanged. Signed-off-by: Daniel Mack <zonque@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@linaro.org> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Arnd Bergmann <arnd@arndb.de>
2013-07-23ARM: pxa: propagate errors from regulator_enable() to pxamciArnd Bergmann
The em_x270_mci_setpower() and em_x270_usb_hub_init() functions call regulator_enable(), which may return an error that must be checked. This changes the em_x270_usb_hub_init() function to bail out if it fails, and changes the pxamci_platform_data->setpower callback so that the a failed em_x270_mci_setpower call can be propagated by the pxamci driver into the mmc core. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Mike Rapoport <mike@compulab.co.il> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Acked-by: Chris Ball <cjb@laptop.org> [olof: fixed order of regulator_enable() and test in em_x270_usb_hub_init] Signed-off-by: Olof Johansson <olof@lixom.net>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09reboot: arm: remove unused restart_mode fields from some arm subarchsRobin Holt
These restart_mode fields are not used at all. Remove them to make moving the reboot= cmdline options to the general kernel easier. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-06Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer core updates from Thomas Gleixner: "The timer changes contain: - posix timer code consolidation and fixes for odd corner cases - sched_clock implementation moved from ARM to core code to avoid duplication by other architectures - alarm timer updates - clocksource and clockevents unregistration facilities - clocksource/events support for new hardware - precise nanoseconds RTC readout (Xen feature) - generic support for Xen suspend/resume oddities - the usual lot of fixes and cleanups all over the place The parts which touch other areas (ARM/XEN) have been coordinated with the relevant maintainers. Though this results in an handful of trivial to solve merge conflicts, which we preferred over nasty cross tree merge dependencies. The patches which have been committed in the last few days are bug fixes plus the posix timer lot. The latter was in akpms queue and next for quite some time; they just got forgotten and Frederic collected them last minute." * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (59 commits) hrtimer: Remove unused variable hrtimers: Move SMP function call to thread context clocksource: Reselect clocksource when watchdog validated high-res capability posix-cpu-timers: don't account cpu timer after stopped thread runtime accounting posix_timers: fix racy timer delta caching on task exit posix-timers: correctly get dying task time sample in posix_cpu_timer_schedule() selftests: add basic posix timers selftests posix_cpu_timers: consolidate expired timers check posix_cpu_timers: consolidate timer list cleanups posix_cpu_timer: consolidate expiry time type tick: Sanitize broadcast control logic tick: Prevent uncontrolled switch to oneshot mode tick: Make oneshot broadcast robust vs. CPU offlining x86: xen: Sync the CMOS RTC as well as the Xen wallclock x86: xen: Sync the wallclock when the system time is set timekeeping: Indicate that clock was set in the pvclock gtod notifier timekeeping: Pass flags instead of multiple bools to timekeeping_update() xen: Remove clock_was_set() call in the resume path hrtimers: Support resuming with two or more CPUs online (but stopped) timer: Fix jiffies wrap behavior of round_jiffies_common() ...
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "First round of updates for the input subsystem. You will get a new touchsreen driver for Cypress 4th generation devices, a driver for a special controller implementing PS/2 protocol in OLPC devices, and a driver for power key for SiRFprimaII PWRC. HID and bcm5497 now support for the 2013 MacBook Air. EVIOCGKEY and the rest of evdev ioctls now flush events of matching type from the client's event queue so that clients can be sure any events received after issuing EVIOCG* ioctl are new events. And a host of cleanups and improvements in other drivers" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (87 commits) Input: cyttsp4 - kfree xfer_buf on error path in probe() Input: tps6507x-ts - select INPUT_POLLDEV Input: bcm5974 - add support for the 2013 MacBook Air HID: apple: Add support for the 2013 Macbook Air Input: cyttsp4 - leak on error path in probe() Input: cyttsp4 - silence NULL dereference warning Input: cyttsp4 - silence shift wrap warning Input: tps6507x-ts - convert to polled input device infrastructure ARM: davinci: da850-evm: remove vref from touchscreen platform data Input: cyttsp4 - SPI driver for Cypress TMA4XX touchscreen devices Input: cyttsp4 - I2C driver for Cypress TMA4XX touchscreen devices Input: cyttsp4 - add core driver for Cypress TMA4XX touchscreen devices Input: cyttsp - I2C driver split into two modules Input: add OLPC AP-SP driver Input: nspire-keypad - remove redundant dev_err call in nspire_keypad_probe() Input: tps6507x-ts - remove vref from platform data Input: tps6507x-ts - use bool for booleans Input: tps6507x-ts - remove bogus unreachable code Input: samsung-keypad - let device core setup the default pin configuration Input: wacom_i2c - implement hovering capability ...
2013-06-27Merge branch 'for-next' of git://github.com/rydberg/linux into nextDmitry Torokhov
Pull in changes from Henrik: "a trivial MT documentation fix".
2013-06-18Input: pxa27x-keypad - use matrix_keymap for matrix keysChao Xie
pxa27x-keypad includes matrix keys. Make use of matrix_keymap for the matrix keys. Signed-off-by: Chao Xie <chao.xie@marvell.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-06-18cpufreq: pxa: select CPU_FREQ_TABLEViresh Kumar
CPUFreq driver of this platform uses APIs from freq_table.c and so must select CPU_FREQ_TABLE. Cc: Eric Miao <eric.y.miao@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2013-06-12sched_clock: Make ARM's sched_clock generic for all architecturesStephen Boyd
Nothing about the sched_clock implementation in the ARM port is specific to the architecture. Generalize the code so that other architectures can use it by selecting GENERIC_SCHED_CLOCK. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> [jstultz: Merge minor collisions with other patches in my tree] Signed-off-by: John Stultz <john.stultz@linaro.org>
2013-05-09Merge tag 'for-linus-20130509' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD update from David Woodhouse: - Lots of cleanups from Artem, including deletion of some obsolete drivers - Support partitions larger than 4GiB in device tree - Support for new SPI chips * tag 'for-linus-20130509' of git://git.infradead.org/linux-mtd: (83 commits) mtd: omap2: Use module_platform_driver() mtd: bf5xx_nand: Use module_platform_driver() mtd: denali_dt: Remove redundant use of of_match_ptr mtd: denali_dt: Change return value to fix smatch warning mtd: denali_dt: Use module_platform_driver() mtd: denali_dt: Fix incorrect error check mtd: nand: subpage write support for hardware based ECC schemes mtd: omap2: use msecs_to_jiffies() mtd: nand_ids: use size macros mtd: nand_ids: improve LEGACY_ID_NAND macro a bit mtd: add 4 Toshiba nand chips for the full-id case mtd: add the support to parse out the full-id nand type mtd: add new fields to nand_flash_dev{} mtd: sh_flctl: Use of_match_ptr() macro mtd: gpio: Use of_match_ptr() macro mtd: gpio: Use devm_kzalloc() mtd: davinci_nand: Use of_match_ptr() mtd: dataflash: Use of_match_ptr() macro mtd: remove h720x flash support mtd: onenand: remove OneNAND simulator ...
2013-05-04Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board specific changes (part 1) from Olof Johansson: "These changes are all for board specific files. These used to make up a large portion of the ARM changes in the past, but as we are generalizing the support and moving to device tree probing, this has gotten significantly smaller. The only platform actually adding new code here at the moment is Renesas shmobile, as they are still busy converting their code to device tree and have not come far enough to not need it." * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits) ARM: msm: USB_MSM_OTG needs USB_PHY ARM: davinci: da850 evm: fix const qualifier placement ARM: davinci: da850 board: add remoteproc support ARM: pxa: move debug uart code ARM: pxa: select PXA935 on saar & tavorevb ARM: mmp: add more compatible names in gpio driver ARM: pxa: move PXA_GPIO_TO_IRQ macro ARM: pxa: remove cpu_is_xxx in gpio driver ARM: Kirkwood: update Network Space Mini v2 description ARM: Kirkwood: DT board setup for CloudBox ARM: Kirkwood: sort board entries by ASCII-code order ARM: OMAP: board-4430sdp: Provide regulator to pwm-backlight ARM: OMAP: zoom: Use pwm stack for lcd and keyboard backlight ARM: OMAP2+: omap2plus_defconfig: Add support for BMP085 pressure sensor omap2+: Remove useless Makefile line omap2+: Remove useless Makefile line ARM: OMAP: RX-51: add missing regulator supply definitions for lis3lv02d ARM: OMAP1: fix omap_udc registration ARM: davinci: use is IS_ENABLED macro ARM: kirkwood: add MACH_GURUPLUG_DT to defconfig ...
2013-04-11ARM: pxa: move debug uart codeHaojian Zhuang
Move debug uart code from mach-pxa/mach-mmp to debug directory. Since they are similar, merge them together. Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org> Acked-by: Eric Mico <eric.y.miao@gmail.com>
2013-04-11ARM: pxa: select PXA935 on saar & tavorevbHaojian Zhuang
Since both PXA930 and PXA935 are used in Saar & TavorEVB platform, select PXA935 too. Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
2013-04-11ARM: pxa: move PXA_GPIO_TO_IRQ macroHaojian Zhuang
Since PXA_GPIO_TO_IRQ() & MMP_GPIO_TO_IRQ() macro are depended on arch code, move them from gpio driver to platform driver instead. Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-11ARM: pxa: remove cpu_is_xxx in gpio driverHaojian Zhuang
Avoid to use cpu_is_xxx() in pxa gpio driver. Use platform_device_id to identify the difference. Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-08cpufreq: pxa2xx: move cpufreq driver to drivers/cpufreqViresh Kumar
This patch moves cpufreq driver of ARM based pxa2xx platform to drivers/cpufreq. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-08cpufreq: pxa3xx: move cpufreq driver to drivers/cpufreqViresh Kumar
This patch moves cpufreq driver of ARM based pxa3xx platform to drivers/cpufreq. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-05arm: mach-pxa: amend Kconfig after mtdchar mergeArtem Bityutskiy
The mtdchar module was merged with the mtdcore module, which means that the MTD_CHAR Kconfig symbol does not exist any more. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-02cpufreq: Notify all policy->cpus in cpufreq_notify_transition()Viresh Kumar
policy->cpus contains all online cpus that have single shared clock line. And their frequencies are always updated together. Many SMP system's cpufreq drivers take care of this in individual drivers but the best place for this code is in cpufreq core. This patch modifies cpufreq_notify_transition() to notify frequency change for all cpus in policy->cpus and hence updates all users of this API. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-03-12ARM: w1-gpio: fix erroneous gpio requestsJohan Hovold
Fix regression introduced by commit d2323cf773 ("onewire: w1-gpio: add ext_pullup_enable pin in platform data") which added a gpio entry to the platform data, but did not add the required initialisers to the board files using it. Consequently, the driver would request gpio 0 at probe, which could break other uses of the corresponding pin. On AT91 requesting gpio 0 changes the pin muxing for PIOA0, which, for instance, breaks SPI0 on at91sam9g20. Cc: stable <stable@vger.kernel.org> Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-26Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull GPIO changes from Grant Likely: "This branch contains the usual set of individual driver improvements and bug fixes, as well as updates to the core code. The more notable changes include: - Internally add new API for referencing GPIOs by gpio_desc instead of number. Eventually this will become a public API - ACPI GPIO binding support" * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: (33 commits) arm64: select ARCH_WANT_OPTIONAL_GPIOLIB gpio: em: Use irq_domain_add_simple() to fix runtime error gpio: using common order: let 'static const' instead of 'const static' gpio/vt8500: memory cleanup missing gpiolib: Fix locking on gpio debugfs files gpiolib: let gpio_chip reference its descriptors gpiolib: use descriptors internally gpiolib: use gpio_chips list in gpiochip_find_base gpiolib: use gpio_chips list in sysfs ops gpiolib: use gpio_chips list in gpiochip_find gpiolib: use gpio_chips list in gpiolib_sysfs_init gpiolib: link all gpio_chips using a list gpio/langwell: cleanup driver gpio/langwell: Add Cloverview ids to pci device table gpio/lynxpoint: add chipset gpio driver. gpiolib: add missing braces in gpio_direction_show gpiolib-acpi: Fix error checks in interrupt requesting gpio: mpc8xxx: don't set IRQ_TYPE_NONE when creating irq mapping gpiolib: remove gpiochip_reserve() arm: pxa: tosa: do not use gpiochip_reserve() ...
2013-02-21Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC board specific changes from Arnd Bergmann: "These updates are all for board specific code, including - defconfig updates for shmobile, davinci, bcm2835, imx, omap and tegra - SD/MMC and I2C support on bcm2835 (Raspberry PI) - minor updates for PXA - shmobile updates to GPIO usage in board files - More things in OMAP board files are moved over to device tree probing - Better support for audio devices on some OMAP platforms" * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (55 commits) ARM: imx_v4_v5_defconfig: Add VPU support ARM: imx: configs: enable netfilter support ARM: OMAP2+: Fix twl section warnings related to omap_twl4030_audio_init ARM: OMAP2+: omap2plus_defconfig: enable omap1 rtc RX-51: Register twl4030-madc device RX-51: Add leds lp5523 names from Maemo 5 2.6.28 kernel ARM: OMAP2+: AM33XX: omap2plus_defconfig: Add support for few drivers ARM: OMAP1: nokia770: enable CBUS/Retu ARM: OMAP2+: omap2plus_defconfig: enable CMA allocator ARM: OMAP2+: omap2plus_defconfig: enable TFP410 chip support ARM: OMAP3: igep0020: simplify GPIO LEDs dependencies ARM: OMAP2+: craneboard: support the TPS65910 PMU ARM: OMAP2+: craneboard: support NAND device ARM: OMAP3: cm-t3517: add MMC support ARM: OMAP2+: Remove apollon board support ARM: shmobile: armadillo800eva: set clock rates before timer init ARM: tegra: defconfig updates ARM: shmobile: mackerel: Use gpio_request_one() ARM: shmobile: kzm9g: Use gpio_request_one() ARM: shmobile: bonito: Use gpio_request_one() ...
2013-02-21Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups from Arnd Bergmann: "A large number of cleanups, all over the platforms. This is dominated largely by the Samsung platforms (s3c, s5p, exynos) and a few of the others moving code out of arch/arm into more appropriate subsystems. The clocksource and irqchip drivers are now abstracted to the point where platforms that are already cleaned up do not need to even specify the driver they use, it can all get configured from the device tree as we do for normal device drivers. The clocksource changes basically touch every single platform in the process. We further clean up the use of platform specific header files here, with the goal of turning more of the platforms over to being "multiplatform" enabled, which implies that they cannot expose their headers to architecture independent code any more. It is expected that no functional changes are part of the cleanup. The overall reduction in total code lines is mostly the result of removing broken and obsolete code." * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits) ARM: mvebu: correct gated clock documentation ARM: kirkwood: add missing include for nsa310 ARM: exynos: move exynos4210-combiner to drivers/irqchip mfd: db8500-prcmu: update resource passing drivers/db8500-cpufreq: delete dangling include ARM: at91: remove NEOCORE 926 board sunxi: Cleanup the reset code and add meaningful registers defines ARM: S3C24XX: header mach/regs-mem.h local ARM: S3C24XX: header mach/regs-power.h local ARM: S3C24XX: header mach/regs-s3c2412-mem.h local ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/ ARM: S3C24XX: transform s3c2443 subirqs into new structure ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs ARM: S3C24XX: move s3c2443 irq code to irq.c ARM: S3C24XX: transform s3c2416 irqs into new structure ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs ARM: S3C24XX: move s3c2416 irq init to common irq code ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property ARM: S3C24XX: Move irq syscore-ops to irq-pm clocksource: always define CLOCKSOURCE_OF_DECLARE ...
2013-02-21Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull non-critical ARM SoC bug fixes from Arnd Bergmann: "Bug fixes that did not make it into v3.8, mostly because they were not considered important enough, and in some cases because bugs only show up in combination with other patches destined for 3.9. This includes a few larger patches for GPIO on the Marvell PXA platform and a lot of Samsung specific bug fixes, as well as a series from Arnd to fix older build warnings." * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits) ARM: SPEAr13xx: Enable CONFIG_ARCH_HAS_CPUFREQ ARM: imx: MACH_MX31ADS_WM1133_EV1 needs REGULATOR_WM8350 scripts/sortextable: silence script output ARM: s3c: i2c: add platform_device forward declaration ARM: mvebu: allow selecting mvebu without Armada XP ARM: pick Versatile by default for !MMU ARM: integrator: fix build with INTEGRATOR_AP off ARM: integrator/versatile: fix NOMMU warnings ARM: sa1100: don't warn about mach/ide.h ARM: shmobile: fix defconfig warning on CONFIG_USB ARM: w90x900: fix legacy assembly syntax ARM: samsung: fix assembly syntax for new gas ARM: disable virt_to_bus/virt_to_bus almost everywhere ARM: dts: Correct pin configuration of SD 4 for exynos4x12-pinctrl ARM: SAMSUNG: Silence empty switch warning in fimc-core.h ARM: SAMSUNG: Silence empty switch warning in sdhci.h ARM: msm: proc_comm_boot_wait should not be __init arm: vt8500: Update MAINTAINERS entry for arch-vt8500 ARM: integrator: ensure ap_syscon_base is initialised when !CONFIG_MMU ARM: S5PV210: Fix early uart output in fifo mode ...
2013-02-11Merge remote-tracking branch 'asoc/topic/pxa' into asoc-nextMark Brown
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-02-05Merge branch 'linusw/devel' of ↵Grant Likely
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio.git into gpio/next Device driver features, cleanups and bug fixes. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-02-04arm: pxa: tosa: do not use gpiochip_reserve()Alexandre Courbot
GPIO address space reservation during early platform initialization is not needed anymore for Tosa. Remove the calls to gpiochip_reserve() which is due to be removed. Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-27Merge branch 'armsoc/fix' of git://github.com/hzhuang1/linux into next/cleanupOlof Johansson
A couple of PXA fixes that aren't critical enough for 3.9. From Haojian Zhuang. * 'armsoc/fix' of git://github.com/hzhuang1/linux: ARM: pxa: Minor naming fixes in spitz.c ARM: PXA3xx: program the CSMSADRCFG register ARM: palmtreo: fix #ifdefs for leds-gpio device ARM: palmtreo: fix lcd initilialization on treo680 Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-27Merge tag 'v3.8-rc5' into next/cleanupOlof Johansson
Linux 3.8-rc5 Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-23ARM: pxa: Minor naming fixes in spitz.cMarko Katic
The NAND init section was erroneously named "Framebuffer". Gpio expander section should really be called "I2C devices" since it contains all i2c init code. Signed-off-by: Marko Katic <dromede@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2013-01-23ARM: pxa: pxa27x.c: add dummy SA1100 rtc clockAndrea Adami
Using pxa27x you could now build both RTC_DRV_PXA and RTC_DRV_SA1100. Make sure you don't use both together: link /dev/rtc0 or /dev/rtc1 to /dev/rtc according to your requirement. Signed-off-by: Andrea Adami <andrea.adami@gmail.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2013-01-23ARM: PXA3xx: program the CSMSADRCFG registerIgor Grinberg
The Chip Select Configuration Register must be programmed to 0x2 in order to achieve the correct behavior of the Static Memory Controller. Without this patch devices wired to DFI and accessed through SMC cannot be accessed after resume from S2. Do not rely on the boot loader to program the CSMSADRCFG register by programming it in the kernel smemc module. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: stable@vger.kernel.org Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2013-01-23ARM: palmtreo: fix #ifdefs for leds-gpio deviceMike Dunn
The #ifdefs around the leds-gpio device platform data are erroneous. Currently the device is not instantiated on the centro unless CONFIG_MACH_TREO680 is defined. This patch eliminates the #ifdefs, and uses the machine_is_* macros to initialize the data based on which machine the code is running on and the build-time configuration. Unused data is optimized out by the build tools if build configuration does not enable support for both machines. Tested on my palm treo 680, and compile-tested for all three combinations of treo680/centro build configurations. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Acked-by: Tomas Cech <sleep_walker@suse.cz> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2013-01-23ARM: palmtreo: fix lcd initilialization on treo680Mike Dunn
This patch gets the LCD working on my Palm Treo680 by adding some code that manages the three gpios interfaced to the lcd on the Treo 680. The precise role of each gpio in the hardware architecture is not entirely clear to me; this patch is the result of trial-and-error and observing how the PalmOS code initializes the lcd. The need for this patch is not evident when Linux is loaded from PalmOS, because at that point the lcd-related gpios have already been configured. But when booting the kernel by other means, this patch is required unless the bootloader has performed the necessary initialializations. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Acked-by: Tomas Cech <sleep_walker@suse.cz> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2013-01-23ARM: palmtreo: replace #if defined with IF_ENABLEDMike Dunn
Use IF_ENABLED macro from kconfig.h. Thanks Sergei. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Acked-by: Tomas Cech <sleep_walker@suse.cz> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2013-01-23ARM: palmtreo: add docg4 device initializationMike Dunn
This patch adds initialization of the docg4 nand flash device to the treo680. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tomas Cech <sleep_walker@suse.cz> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
