path: root/arch/arm/mach-pxa/time.c
2008-10-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (236 commits) [ARM] 5300/1: fixup spitz reset during boot [ARM] 5295/1: make ZONE_DMA optional [ARM] 5239/1: Palm Zire 72 power management support [ARM] 5298/1: Drop desc_handle_irq() [ARM] 5297/1: [KS8695] Fix two compile-time warnings [ARM] 5296/1: [KS8695] Replace macro's with trailing underscores. [ARM] pxa: allow multi-machine PCMCIA builds [ARM] pxa: add preliminary CPUFREQ support for PXA3xx [ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.h [ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.c [ARM] pxa/zylonite: add support for USB OHCI [ARM] ohci-pxa27x: use ioremap() and offset for register access [ARM] ohci-pxa27x: introduce pxa27x_clear_otgph() [ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resource [ARM] ohci-pxa27x: move OHCI controller specific registers into the driver [ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registers [ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.c [ARM] pxa: simplify DMA register definitions [ARM] pxa: make additional DCSR bits valid for PXA3xx [ARM] pxa: move i2c register and bit definitions into i2c-pxa.c ... Fixed up conflicts in arch/arm/mach-versatile/core.c sound/soc/pxa/pxa2xx-ac97.c sound/soc/pxa/pxa2xx-i2s.c manually.
2008-09-25[ARM] pxa: make cpu_is_pxa2* macros more consistentEric Miao
1. add a CPUID table in the comment 2. make cpu_is_pxa25x() true for PXA210/250/255/26x 3. PXA210 is treated as PXA25x, all related code modified to reflect this Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-24MN10300: Move asm-arm/cnt32_to_63.h to include/linux/David Howells
Move asm-arm/cnt32_to_63.h to include/linux/ so that MN10300 can make use of it too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: fix PXA27x resumeRussell King
When PXA27x wakes up, tick_resume_oneshot() tries to set a timer interrupt to occur immediately. Since PXA27x requires at least MIN_OSCR_DELTA, this causes us to flag an error. tick_program_event() then increments the next event time by min_delta_ns. However, by the time we get back to programming the next event, the OSCR has incremented such that we fail again. We repeatedly retry, but the OSCR is too fast for us - we never catch up, so we never break out of the loop - resulting in us never apparantly resuming. Fix this by doubling min_delta_ns. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: Don't wind OSCR backwards over suspend/resumeRussell King
OSCR is supposed to monotonically increment; however restoring it to a time prior to OSMR0 may result in it being wound backwards. Instead, if OSMR0 is within the minimum expiry time, wind OSMR0 forwards. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: remove periodic mode emulation supportRussell King
Apparantly, the generic time subsystem can accurately emulate periodic mode via the one-shot support code, so we don't need our own periodic emulation code anymore. Just ensure that we build support for one shot into the generic time subsystem. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-08[ARM] pxa: fix one-shot timer modeRussell King
One-shot timer mode on PXA has various bugs which prevent kernels build with NO_HZ enabled booting. They end up spinning on a permanently asserted timer interrupt because we don't properly clear it down - clearing the OIER bit does not stop the pending interrupt status. Fix this in the set_mode handler as well. Moreover, the code which sets the next expiry point may race with the hardware, and we might not set the match register sufficiently in the future. If we encounter that situation, return -ETIME so the generic time code retries. Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-31[ARM] pxa: shut up CLOCK_EVT_MODE_RESUME warningRussell King
Resolve: CC arch/arm/mach-pxa/time.o arch/arm/mach-pxa/time.c: In function `pxa_osmr0_set_mode': arch/arm/mach-pxa/time.c:154: warning: enumeration value `CLOCK_EVT_MODE_RESUME' not handled in switch Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] pxa: make pxa timer initialisation select clock rate at runtimeRussell King
Rather than using the compile-time constant CLOCK_TICK_RATE, select the clock tick rate at run time. We organise the selection so that PXA3 automatically falls out with the right tick rate. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4550/1: sched_clock on PXA should cope with run time clock rate selectionNicolas Pitre
The previous implementation was relying on compile time optimizations based on a constant clock rate. However, support for different PXA flavors in the same kernel binary requires that the clock be selected at run time, so here it is. Let's move this code to a more appropriate location while at it. Signed-off-by: Nicolas Pitre <npitre@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4507/1: pxa2xx clock_event_deviceBill Gatliff
Reimplements arch/arm/mach-pxa/time.c using a clock_event_device based on OSMR0. Tested on PXA270, linux-2.6.22+arm:pxa patches. Signed-off-by: Bill Gatliff <bgat@billgatliff.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] pxa: remove boot time RTC initialisationRussell King
The RTC library code contains everything necessary to set the system time from the RTC; for similar reasons as the previous commit, it's far better to let the RTC library code sort this out rather than implement something which might not be appropriate for everyone. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] clocksource: fixup is_continous changes on ARMThomas Gleixner
Fixup the is_contionous replacement by a flag field. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-30[ARM] 4064/1: make pxa_get_cycles() staticNicolas Pitre
... and fix a comment as well. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-13[ARM] 4012/1: Clocksource for pxaSascha Hauer
Add a clocksource driver for pxa2xx systems Signed-off-by: Luotao Fu <lfu@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] 3940/1: don't reset PXA2xx clock counterNicolas Pitre
Don't reset OSCR to zero as this prevents us from having a contiguous time source. The value returned by sched_clock() is reset to zero in the middle of the boot process otherwise, making CONFIG_PRINTK_TIME rather messed up. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08[ARM] 3135/1: harden SA11x0 and PXA2xx timer init codeNicolas Pitre
Patch from Nicolas Pitre Make it completely deterministic and leave nothing to chance (even if it had at worst 0.001% probability of failing). Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-01[ARM] 2863/1: clarify comment in PXA2xx and SA1x00 timer codeNicolas Pitre
Patch from Nicolas Pitre Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-01[ARM] 2862/1: VST aka CONFIG_NO_IDLE_HZ support for PXA2xxNicolas Pitre
2005-06-26[PATCH] ARM: Add SA_TIMER flag to timer interruptsRussell King
VST needs to know which timer handler is for the timer interrupt. Mark all timer interrupts with the SA_TIMER flag. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
