path: root/arch/arm/mach-pxa/littleton.c
2012-09-14ARM: pxa: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the pxa include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Paul Parsons <lost.distance@yahoo.com> Acked-by: Vinod Koul <vinod.koul@linux.intel.com> Acked-By: Stefan Schmidt <stefan@openezx.org> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Daniel Ribeiro <drwyrm@gmail.com> Cc: Harald Welte <laforge@openezx.org> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Tomas Cech <sleep_walker@suse.cz> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Jonathan Cameron <jic23@cam.ac.uk> Cc: Dan Williams <djbw@fb.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Liam Girdwood <lrg@ti.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: openezx-devel@lists.openezx.org
2012-01-09Merge branch 'samsung/driver' into next/driversArnd Bergmann
Conflicts: arch/arm/mach-mxs/include/mach/common.h Pull in previous samsung conflict merges and do a trivial merge of an mxs double-add conflict. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-01-05ARM: restart: pxa: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-23Merge branches 'drivers/macb-gem' and 'drivers/pxa-gpio' into next/driversArnd Bergmann
2011-11-14ARM: pxa: rename gpio_to_irq and irq_to_gpioHaojian Zhuang
Avoid to define gpio_to_irq() and irq_to_gpio() for potential name confliction since multiple architecture will be built together. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
2011-11-14ARM: pxa: rename IRQ_GPIO to PXA_GPIO_TO_IRQHaojian Zhuang
Avoid potential naming confliction since multiple architecture will be built in a single kernel. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2011-11-07Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (226 commits) mtd: tests: annotate as DANGEROUS in Kconfig mtd: tests: don't use mtd0 as a default mtd: clean up usage of MTD_DOCPROBE_ADDRESS jffs2: add compr=lzo and compr=zlib options jffs2: implement mount option parsing and compression overriding mtd: nand: initialize ops.mode mtd: provide an alias for the redboot module name mtd: m25p80: don't probe device which has status of 'disabled' mtd: nand_h1900 never worked mtd: Add DiskOnChip G3 support mtd: m25p80: add EON flash EN25Q32B into spi flash id table mtd: mark block device queue as non-rotational mtd: r852: make r852_pm_ops static mtd: m25p80: add support for at25df321a spi data flash mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks mtd: nand: switch `check_pattern()' to standard `memcmp()' mtd: nand: invalidate cache on unaligned reads mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set mtd: nand: wait to set BBT version mtd: nand: scrub BBT on ECC errors ... Fix up trivial conflicts: - arch/arm/mach-at91/board-usb-a9260.c Merged into board-usb-a926x.c - drivers/mtd/maps/lantiq-flash.c add_mtd_partitions -> mtd_device_register vs changed to use mtd_device_parse_register.
2011-09-11mtd: pxa3xx_nand: enable multiple chip select supportLei Wen
Current pxa3xx_nand controller has two chip select which both be workable. This patch enable this feature. Update platform driver to support this feature. Another notice should be taken that: When you want to use this feature, you should not enable the keep configuration feature, for two chip select could be attached with different nand chip. The different page size and timing requirement make the keep configuration impossible. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-08-21ARM: mach-pxa: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-07-12ARM: pxa: enable MULTI_IRQ_HANDLER for all boardsEric Miao
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-03-26Merge branch 'devel' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable Conflicts: arch/arm/mach-pxa/tosa.c
2011-03-21ARM: pxa2xx: reorganize I2C filesSebastian Andrzej Siewior
This patch moves the platform data definition from arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so it can be accessed from x86 the same way as on ARM. This change should make no functional change to the PXA code. The move is verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig pxa910_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-16ARM: pxa: clean up set_pxa_fb_infoRussell King - ARM Linux
set_pxa_fb_info() has been a long-standing wart in the naming scheme of the pxa_set_xxx_info() functions. This renames the function, and combines set_pxa_fb_parent() with set_pxa_fb_info(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-07Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (77 commits) spi/omap: Fix DMA API usage in OMAP MCSPI driver spi/imx: correct the test on platform_get_irq() return value spi/topcliff: Typo fix threhold to threshold spi/dw_spi Typo change diable to disable. spi/fsl_espi: change the read behaviour of the SPIRF spi/mpc52xx-psc-spi: move probe/remove to proper sections spi/dw_spi: add DMA support spi/dw_spi: change to EXPORT_SYMBOL_GPL for exported APIs spi/dw_spi: Fix too short timeout in spi polling loop spi/pl022: convert running variable spi/pl022: convert busy flag to a bool spi/pl022: pass the returned sglen to the DMA engine spi/pl022: map the buffers on the DMA engine spi/topcliff_pch: Fix data transfer issue spi/imx: remove autodetection spi/pxa2xx: pass of_node to spi device and set a parent device spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes. spi/pxa2xx: Add chipselect support for Sodaville spi/pxa2xx: Consider CE4100's FIFO depth spi/pxa2xx: Add CE4100 support ...
2010-12-16ARM: pxa: Introduce pxa{25x,27x,3xx}_map_io()Marek Vasut
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish between PXA25x/PXA27x and PXA3xx memory mapping. Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io() and pxa3xx_map_io() is included. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-01arm/pxa2xx: reorgazine SSP and SPI header filesSebastian Andrzej Siewior
The PXA-SPI driver relies on some files / defines which are arm specific and are within the ARM tree. The CE4100 SoC which is x86 has also the SPI core. This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to include/linux where the CE4100 can access them. This move got verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-09ARM: pxa: moved pxa27x_keypad.h to platform pxa directoryMark F. Brown
mach-mmp utilizes pxa27x_keypad code so we need to move header to platform pxa directory. Signed-off-by: Mark F. Brown <mark.brown314@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-10-08ARM: pxa: encode IRQ number into .nr_irqsHaojian Zhuang
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-11[ARM] pxa: make it clear by converting MMC 'delay_detect' to millisecondEric Miao
delay_detect in HZ is confusing, convert it to be millisecond based. And thus remove those unnecessary call to msecs_to_jiffies() at runtime for this field. Other constants are converted assuming HZ == 100, which are basically true for those platforms. The assignment in csb726.c was incorrect, and is fixed in this patch as a result. Signed-off-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Marc Zyngier <maz@misterjones.org> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Daniel Mack <daniel@caiaq.de>
2010-05-11[ARM] pxa: remove unnecessary #include of <mach/ssp.h>Eric Miao
2009-12-29[ARM] pxa/littleton: add UART3 GPIO configMarek Vasut
2009-12-01[ARM] pxa: allow platforms to control which uarts are registeredRussell King
For some platforms, it is inappropriate to register all PXA UARTs. In some cases, the UARTs may not be used, and in others we may want to avoid registering the UARTs to allow other drivers (eg, FICP) to make use of the UART. In addition, a while back there was a request to be able to pass platform data to the UART driver. This patch enables all of this by providing functions platforms can call to register each individual UART. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-12-01pxa3xx_nand: move pxa3xx_nand.h common into plat directoryHaojian Zhuang
Since the same nand controller is shared between ARCH_PXA and ARCH_MMP. Move the pxa3xx_nand.h from mach directory to plat directoy. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-09-10[ARM] pxa/littleton: update littleton to use the new gpio_card_detect for mmcEric Miao
2009-06-05[ARM] pxa/littleton: add support for the Micro-SD slot (MMC1)Eric Miao
2009-06-05[ARM] pxa: update pxa2xx_spi_chip initialization to use .gpio_cs fieldMike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-06-05[ARM] pxa: move mach/i2c.h to plat/i2c.hEric Miao
Signed-off-by: Paul Shen <paul.shen@marvell.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-04-27[ARM] pxa/littleton: add missing da9034 touchscreen supportEric Miao
2009-03-09[ARM] pxa: introduce pxa{25x,27x,300,320,930}.h for board usageEric Miao
Considering the header mess ATM, it is not always possible to include the correct header files within board code. Let's keep this simple: <mach/pxa25x.h> - for pxa25x based platforms <mach/pxa27x.h> - for pxa27x based platforms <mach/pxa300.h> - for pxa300 based platforms <mach/pxa320.h> - for pxa320 based platforms <mach/pxa930.h> - for pxa930 based platforms NOTE: 1. one header one board file, they are not compatible (i.e. they have conflicting definitions which won't compile if included together). 2. Unless strictly necessary, the following header files are considered to be SoC files use _only_, and is not recommended to be included in board code: <mach/hardware.h> <mach/pxa-regs.h> <mach/pxa2xx-regs.h> <mach/pxa3xx-regs.h> <mach/mfp.h> <mach/mfp-pxa2xx.h> <mach/mfp-pxa25x.h> <mach/mfp-pxa27x.h> <mach/mfp-pxa3xx.h> <mach/mfp-pxa300.h> <mach/mfp-pxa320.h> <mach/mfp-pxa930.h> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-12-17[ARM] pxa/littleton: add preliminary I2C board info (da9034 + max7320)Eric Miao
2008-12-02[ARM] pxa: use <linux/gpio.h> instead of unnecessary <mach/gpio.h>Eric Miao
2008-09-23[ARM] pxa/littleton: add support for SPI-based TDO24M LCD panel driverEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-12[ARM] pxa: make littleton to use the new smc91x platform dataEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] pxa: add pxa3xx NAND support for littletonEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: Sergey Podstavin <spodstavin@ru.mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] pxa: fix typo of CONFIG_*_MODULEEric Miao
The correct macro name when a driver is built as a module is CONFIG_*_MODULE instead of CONFIG_*_MODULES. This patch fixes this in several places. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] pxa: use IORESOURCE_IRQ_* instead of IRQF_* for IRQ resourceEric Miao
2008-04-30pxafb: make lubbock/mainstone/zylonite/littleton to use new LCD connection typeeric miao
Signed-off-by: eric miao <eric.miao@marvell.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19[ARM] pxa: add keypad support for littletoneric miao
Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: move ARRAY_AND_SIZE definition to generic.heric miao
for use by other platforms Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[NET] smc91x: Make smc91x use IRQ resource trigger flagsRussell King
smc91x is shared between many different platforms. Each platform needs to specify the interrupt type, and in some cases the irq type depends on more than just the build configuration - it depends on runtime checks. Rather than throwing this code into the SMC_IRQ_FLAGS definition, provide a way for these flags to be passed via the IRQ resource itself. Note that IRQF_TRIGGER_* constants are intentionally defined to correspond with the IORESOURCE_IRQ_* interrupt type flags, in much the same way that the low bits of PCI iomem resources correspond with the BAR flag bits. Also provide a way to configure smc91x to read the IRQ flags from the resource. Once all platforms have been converted over (signified by all definitions of SMC_IRQ_FLAGS being -1) SMC_IRQ_FLAGS should be removed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28[ARM] pxa: add basic support for Littleton (PXA3xx Form Factor Platform)eric miao
