path: root/arch/arm/mach-pxa/generic.c
2007-10-15[ARM] pxa: Avoid pxa_gpio_mode() in gpio_direction_{in,out}put()Russell King
pxa_gpio_mode() is a universal call that fiddles with the GAFR (gpio alternate function register.) GAFR does not exist on PXA3 CPUs, but instead the alternate functions are controlled via the MFP support code. Platforms are expected to configure the MFP according to their needs in their platform support code rather than drivers. We extend this idea to the GAFR, and make the gpio_direction_*() functions purely operate on the GPIO level. This means platform support code is entirely responsible for configuring the GPIOs alternate functions on all PXA CPU types. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] pxa: PXA3xx base supporteric miao
Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4559/1: pxa: make PXA_LAST_GPIO a run-time variableeric miao
This definition produces processor specific code in generic function pxa_gpio_mode(), thus creating inconsistencies for support of pxa25x and pxa27x in a single zImage. As David Brownell suggests, make it a run-time variable and initialize at run-time according to the number of GPIOs on the processor. For now the initialization happens in pxa_init_irq_gpio(), since there is already a parameter for that, besides, this is and MUST be earlier than any subsequent calls to pxa_gpio_mode(). Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] pxa: mark pxa_set_cken deprecatedRussell King
Allow the generic clock support code to fiddle with the CKEN register and mark pxa_set_cken() deprecated. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] pxa: remove get_lcdclk_frequency_10khz()Russell King
get_lcdclk_frequency_10khz() is now redundant, remove it. Hide pxa27x_get_lcdclk_frequency_10khz() from public view. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] pxa: fix naming of memory/lcd/core clock functionsRussell King
Rename pxa25x and pxa27x memory/lcd/core clock functions, and select the correct version at run time. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] pxa: convert PXA serial drivers to use platform resourcesRussell King
2007-10-12[ARM] 4550/1: sched_clock on PXA should cope with run time clock rate selectionNicolas Pitre
The previous implementation was relying on compile time optimizations based on a constant clock rate. However, support for different PXA flavors in the same kernel binary requires that the clock be selected at run time, so here it is. Let's move this code to a more appropriate location while at it. Signed-off-by: Nicolas Pitre <npitre@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4480/1: pxa: change the pxa device naming schemeEric Miao
1. for common devices across all the pxa variants, the names are changed to be: "pxa_device_xxx" 2. for pxa25x or pxa27x specific devices, the names are changed to be: "pxa25x_device_xxx", or "pxa27x_device_xxx" Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] pxa: move platform devices to separate header fileRussell King
2007-07-12[ARM] pxa: move device registration into CPU-specific fileRussell King
This allows individual CPU support to determine which platform devices should be registered. Also fix a copy-n-paste bug in the I2C power platform device entry. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] pxa: introduce cpu_is_pxaXXX macrosRussell King
2007-04-21[ARM] 4304/1: removes the unnecessary bit number from CKENnn_XXXXEric Miao
This patch removes the unnecessary bit number from CKENnn_XXXX definitions for PXA, so that CKEN0_PWM0 --> CKEN_PWM0 CKEN1_PWM1 --> CKEN_PWM1 ... CKEN24_CAMERA --> CKEN_CAMERA The reasons for the change of these defitions are: 1. they do not scale - they are currently valid for pxa2xx, but definitely not valid for pxa3xx, e.g., pxa3xx has bit 3 for camera instead of bit 24 2. they are unnecessary - the peripheral name within the definition has already announced its usage, we don't need those bit numbers to know which peripheral we are going to enable/disable clock for 3. they are inconvenient - think about this: a driver programmer for pxa has to remember which bit in the CKEN register to turn on/off Another change in the patch is to make the definitions equal to its clock bit index, so that #define CKEN_CAMERA (24) instead of #define CKEN_CAMERA (1 << 24) this change, however, will add a run-time bit shift operation in pxa_set_cken(), but the benefit of this change is that it scales when bit index exceeds 32, e.g., pxa3xx has two registers CKENA and CKENB, totally 64 bit for this, suppose CAMERA clock enabling bit is CKENB:10, one can simply define CKEN_CAMERA to be (32 + 10) and so that pxa_set_cken() need minimum change to adapt to that. Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-20[PATCH] GPIO API: PXA wrapper cleanupPhilipp Zabel
Based on the discussion last december (http://lkml.org/lkml/2006/12/20/242), this patch: - moves the PXA_LAST_GPIO check into pxa_gpio_mode - fixes comment and includes in gpio.h - replaces the gpio_set/get_value macros with inline functions and adds a non-inline version to avoid code explosion when gpio is not a constant. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Nicolas Pitre <nico@cam.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-08[ARM] 4144/1: Fix for patch #4099/1 with CONFIG_I2C_PXA_SLAVE setGuennadi Liakhovetski
Switch the i2c-pxa driver to actually using the platform device information and let it handle the power i2c bus on pxa27x too. Original version of this patch didn't compile with CONFIG_I2C_PXA_SLAVE set. Signed-off-by: G. Liakhovetski <gl@dsa-ac.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4066/1: correct a comment about PXA's sched_clock rangeNicolas Pitre
Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[ARM] 3981/1: sched_clock for PXA2xxNicolas Pitre
Here's a 63-bit implementation of shed_clock() for PXA2xx. The actual period depends on the value of CLOCK_TICK_RATE and whether or not reduced scaling factors were provided for it. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-02[ARM] 3848/1: pxafb: Add option of fixing video modes and spitz QVGA mode ↵Richard Purdie
support Add the ability to have pxafb use only certain fixed video modes (selected on a per platform basis). This is useful on production hardware such as the Zaurus cxx00 models where the valid modes are known in advance and any other modes could result in hardware damage. Following this, add support for the cxx00 QVGA mode. Mode information is passed to the lcd_power call to allowing the panel drivers to configure the display hardware accordingly (corgi_lcd already contains the functionality for the cxx00 panel). This mirrors the setup already used by w100fb. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-27[PATCH] RTC subsystem: SA1100/PXA2XX driverRichard Purdie
Add an RTC subsystem driver for the ARM SA1100/PXA2XX processor RTC. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[ARM] 2897/2: PXA2xx IRDA supportNicolas Pitre
Patch from Nicolas Pitre This is the PXA2xx common IRDA driver, plus platform support for Lubbock and Mainstone. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 3029/1: Add HWUART support for PXA 255/26xMatt Reimer
Patch from Matt Reimer Adds support for HWUART on PXA 255 / 26x. This patch originally came from http://svn.rungie.com/svn/gumstix-buildroot/trunk/sources/kernel-patches/000-gumstix-hwuart.patch and has been tweaked by me. Signed-off-by: Matt Reimer <mreimer@vpop.net> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 3048/1: register i2s resources not i2c resources for the pxa i2s ↵Ian Campbell
platform device Patch from Ian Campbell As noted by Uli Luckas in the comments of 3025 there is a typo in the i2s platform device. The i2s platform device refers to the i2c resources. Signed-off-by: Ian Campbell <icampbell@arcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 2988/1: Replace map_desc.physical with map_desc.pfn: PXADeepak Saxena
Patch from Deepak Saxena PXA map_desc.pfn conversion Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-20[ARM] 3025/1: Add I2S platform device for PXAMatt Reimer
Patch from Matt Reimer Adds an I2S platform_device for PXA. I2S is used to interface with sound chips on systems like iPAQ h1910/h2200/hx4700 and Asus 716. Signed-off-by: mreimer@vpop.net Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-14[ARM] 3011/1: pxafb: Add ability to set device parent + fix spitz compile errorRichard Purdie
Patch from Richard Purdie Add a function to allow machines to set the parent of the pxa framebuffer device. This means the power up/down sequence can be controlled where required by the machine. Update spitz to use the new function, fixing a compile error. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-29[ARM] Fix warning in arch/arm/mach-pxa/generic.cRussell King
Fix arch/arm/mach-pxa/generic.c:242: warning: 'struct i2c_pxa_platform_data' declared inside parameter list caused by missing asm/arch/i2c.h include. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-04-30[PATCH] ARM: PXA I2C: add platform deviceRussell King
Add the PXA I2C platform device. Signed-off-by: Russell King <rmk@arm.linux.org.uk>
