path: root/arch/arm/mach-pxa/e400.c
2010-08-05[ARM] pxa: merge all eseries board code into eseries.cEric Miao
Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-12-01[ARM] pxa: allow platforms to control which uarts are registeredRussell King
For some platforms, it is inappropriate to register all PXA UARTs. In some cases, the UARTs may not be used, and in others we may want to avoid registering the UARTs to allow other drivers (eg, FICP) to make use of the UART. In addition, a while back there was a request to be able to pass platform data to the UART driver. This patch enables all of this by providing functions platforms can call to register each individual UART. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-03-09[ARM] pxa: introduce pxa{25x,27x,300,320,930}.h for board usageEric Miao
Considering the header mess ATM, it is not always possible to include the correct header files within board code. Let's keep this simple: <mach/pxa25x.h> - for pxa25x based platforms <mach/pxa27x.h> - for pxa27x based platforms <mach/pxa300.h> - for pxa300 based platforms <mach/pxa320.h> - for pxa320 based platforms <mach/pxa930.h> - for pxa930 based platforms NOTE: 1. one header one board file, they are not compatible (i.e. they have conflicting definitions which won't compile if included together). 2. Unless strictly necessary, the following header files are considered to be SoC files use _only_, and is not recommended to be included in board code: <mach/hardware.h> <mach/pxa-regs.h> <mach/pxa2xx-regs.h> <mach/pxa3xx-regs.h> <mach/mfp.h> <mach/mfp-pxa2xx.h> <mach/mfp-pxa25x.h> <mach/mfp-pxa27x.h> <mach/mfp-pxa3xx.h> <mach/mfp-pxa300.h> <mach/mfp-pxa320.h> <mach/mfp-pxa930.h> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-01-08[ARM] fix AT91, davinci, h720x, ks8695, msm, mx2, mx3, netx, omap1, omap2, ↵Russell King
pxa, s3c arch/arm/mach-at91/at91cap9.c:337: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91rm9200.c:301: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9260.c:351: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9261.c:287: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9263.c:312: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9rl.c:304: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-h720x/h7202-eval.c:38: error: implicit declaration of function 'IRQ_CHAINED_GPIOB' arch/arm/mach-ks8695/devices.c:46: error: 'KS8695_IRQ_WAN_RX_STATUS' undeclared here (not in a function) arch/arm/mach-msm/devices.c:28: error: 'INT_UART1' undeclared here (not in a function) arch/arm/mach-mx2/devices.c:233: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-mx3/devices.c:128: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:140: error: 'INT_730_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:165: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:200: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap2/board-apollon.c:286: error: implicit declaration of function 'omap_set_gpio_direction' arch/arm/mach-omap2/mcbsp.c:154: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-omap2/mcbsp.c:181: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-pxa/e350.c:36: error: 'IRQ_BOARD_START' undeclared here (not in a function) arch/arm/plat-s3c/dev-i2c0.c:32: error: 'IRQ_IIC' undeclared here (not in a function) ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-23Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel Conflicts: arch/arm/mach-pxa/am200epd.c arch/arm/mach-pxa/ezx.c
2008-12-17[ARM] pxa: convert legacy LCD setup of other boards to new oneEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Ian Molton <spyro@f2s.com> Cc: pHilipp Zabel <philipp.zabel@gmail.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Juergen Schindele <linux@schindele.name> Acked-by: Stefan Schmidt <stefan@datenfreihafen.org> Acked-by: Marc Zyngier <maz@misterjones.org> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com>
2008-12-15[ARM] pxa: Add multi-io support for e-seriesIan Molton
This patchset provides support for the TMIO based IO controller used in the Toshiba e-series PDAs. Signed-off-by: Ian Molton <spyro@f2s.com> Acked-by: Samuel Ortiz <sameo@openedhand.com> Acked-by: Eric Miao <eric.y.miao@gmail.com>
2008-08-19[ARM] eseries: move UDC defs to machine filesIan Molton
This patchset moves the UDC definitons for e7xx compatible eseries machines to a common location and moves the 'oddball' e800 definition to its machine file. Signed-off-by: Ian Molton <spyro@f2s.com>
2008-08-19[ARM] eseries: move LCD defs into machine filesIan Molton
This patch removes the seperate files used for the LCD definitions on e-series and places the definitions into the machine specific files. Signed-off-by: Ian Molton <spyro@f2s.com>
2008-08-19[ARM] eseries: Split machine definitionsIan Molton
This patchset breaks out the e-series machine definitions into one-per-machine. Signed-off-by: Ian Molton <spyro@f2s.com>
