path: root/arch/arm/mach-picoxcell/time.c
2012-01-09ARM: picoxcell: fix sched_clock() cleanup falloutJamie Iles
Commit 2f0778afa (ARM: 7205/2: sched_clock: allow sched_clock to be selected at runtime) replaced the picoxcell specific sched_clock() with a generic runtime selectable version but replaced "unsigned long long notrace sched_clock(void)" with "unsigned u32 notrace picoxcell_read_sched_clock(void)" fix this up to return a u32 as expected. Cc: Marc Zyngier <Marc.Zyngier@arm.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com>
2011-12-18ARM: 7205/2: sched_clock: allow sched_clock to be selected at runtimeMarc Zyngier
sched_clock() is yet another blocker on the road to the single image. This patch implements an idea by Russell King: http://www.spinics.net/lists/linux-omap/msg49561.html Instead of asking the platform to implement both sched_clock() itself and the rollover callback, simply register a read() function, and let the ARM code care about sched_clock() itself, the conversion to ns and the rollover. sched_clock() uses this read() function as an indirection to the platform code. If the platform doesn't provide a read(), the code falls back to the jiffy counter (just like the default sched_clock). This allow some simplifications and possibly some footprint gain when multiple platforms are compiled in. Among the drawbacks, the removal of the *_fixed_sched_clock optimization which could negatively impact some platforms (sa1100, tegra, versatile and omap). Tested on 11MPCore, OMAP4 and Tegra. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Colin Cross <ccross@android.com> Cc: Erik Gilling <konkers@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Alessandro Rubini <rubini@unipv.it> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Ben Dooks <ben-linux@fluff.org> Tested-by: Jamie Iles <jamie@jamieiles.com> Tested-by: Tony Lindgren <tony@atomide.com> Tested-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Krzysztof Halasa <khc@pm.waw.pl> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-26picoxcell: support for Picochip picoxcell devicesJamie Iles
picoXcell is a family of femtocell devices with an ARM application processor and picoArray DSP processor array. This patch adds support for picoXcell boards to be booted using the device tree registering the VIC's, UART's and timers. v3: - fixup vic compatible string in binding v2: - cleanup empty mach headers - convert to of_platform_populate() - simplify uncompress.h - split vic node into 2 devices - add missing __initconst attributes Signed-off-by: Jamie Iles <jamie@jamieiles.com>
