path: root/arch/arm/mach-omap2
2013-06-07Merge tag 'omap-fixes-b-for-3.10-rc' of ↵Tony Lindgren
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into omap-for-v3.10/fixes More OMAP hwmod and clock fixes for v3.10-rc. Fixes the AM33xx UART2. Also fixes some CCF-related breakage on OMAP36xx/37xx, affecting DSS at the very least. Basic test logs for this branch are here: http://www.pwsan.com/omap/testlogs/fixes_b_v3.10-rc/20130606093449/
2013-06-06ARM: omap3: clock: fix wrong container_of in clock36xx.cJean-Philippe Francois
omap36xx_pwrdn_clk_enable_with_hsdiv_restore expects the parent hw of the clock to be a clk_hw_omap. However, looking at cclock3xxx_data.c, all concerned clock have parent defined as clk_divider. Fix the function to use clk_divider. Tested with 3.9 on dm3730. Signed-off-by: Jean-Philippe François <jp.francois@cynove.com> Cc: NeilBrown <neilb@suse.de> Cc: Mike Turquette <mturquette@linaro.org> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-06-03arm: omap2: fix AM33xx hwmod infos for UART2Thomas Petazzoni
The UART2 hwmod structure is pointing to the EDMA channels of UART1, which doesn't look right. This patch fixes this by making the UART2 hwmod structure to a new structure that lists the EDMA channels to be used by the UART2. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Vaibhav Hiremath <hvaibhav@ti.com> [paul@pwsan.com: updated to apply] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-05-30ARM: OMAP3: Fix iva2_pwrdm settings for 3703Tony Lindgren
Commit a819c4f1 (ARM: OMAP3: PM: Only access IVA if one exists) changed PM to not access IVA registers on omaps that don't have them. Turns out we still need to idle iva2 as otherwise iva2_pwrdm will stay on and block deeper idle states. It seems that the only part of the reset that may not be needed is the setting of the iva2 boot mode to idle. But as that register seems to be there and is harmless if no iva2 is on the SoC, it's probably safest to do the complete reset. Acked-by: Mark A. Greer <mgreer@animalcreek.com> Acked-by: Kevin Hilman <khilman@linaro.org> Tested-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-22Merge tag 'omap-fixes-a-for-3.10-rc' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into fixes From Paul Walmsley: Fix the OMAP serial driver to work correctly on OMAP4 when booting with DT. * tag 'omap-fixes-a-for-3.10-rc' of git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending: ARM: OMAP2+: hwmod: Remove sysc slave idle and auto idle apis SERIAL: OMAP: Remove the slave idle handling from the driver ARM: OMAP2+: serial: Remove the un-used slave idle hooks ARM: OMAP2+: hwmod-data: UART IP needs software control to manage sidle modes ARM: OMAP2+: hwmod: Add a new flag to handle SIDLE in SWSUP only in active ARM: OMAP2+: hwmod: Fix sidle programming in _enable_sysc()/_idle_sysc() Signed-off-by: Olof Johansson <olof@lixom.net>
2013-05-19ARM: OMAP2+: hwmod: Remove sysc slave idle and auto idle apisSantosh Shilimkar
With the OMAP serial driver sysc cleanup patches in this series, we can now remove the hwmod external apis for sysc fiddling. While at this, also remove unused sysc auto idle api from hwmod code. Tested-by: Vaibhav Bedia <vaibhav.bedia@ti.com> Tested-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Rajendra nayak <rnayak@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@linaro.org> Tested-by: Kevin Hilman <khilman@linaro.org> # OMAP4/Panda Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-05-19ARM: OMAP2+: serial: Remove the un-used slave idle hooksSantosh Shilimkar
UART IP idle handling now taken care by runtime pm backend(hwmod) indirectly and OMAP serial driver is also cleaned up accordingly. So remove the un-used slave idle platforms hooks now. Tested-by: Vaibhav Bedia <vaibhav.bedia@ti.com> Tested-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Rajendra nayak <rnayak@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@linaro.org> Tested-by: Kevin Hilman <khilman@linaro.org> # OMAP4/Panda Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-05-19ARM: OMAP2+: hwmod-data: UART IP needs software control to manage sidle modesSantosh Shilimkar
OMAP UART IP needs software control for slave idle modes based on functional state of the IP. i.e The IP slave idle settings should be set to 'noidle' when being used and then put back to 'smart_idle' when unused. Currently this is handled by the driver with function pointers implemented in platform code. This however breaks in case of device tree because of missing idle handling APIs. Previous patches in this series added a flag HWMOD_SWSUP_SIDLE_ACTIVE which takes care of the mentioned requirement. Hence add the flag for all UART IPs to take advantage of feature supported by framework. Subsequent patches removes the slave idle handling from driver code. Tested-by: Vaibhav Bedia <vaibhav.bedia@ti.com> Tested-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@linaro.org> Tested-by: Kevin Hilman <khilman@linaro.org> # OMAP4/Panda Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-05-19ARM: OMAP2+: hwmod: Add a new flag to handle SIDLE in SWSUP only in activeRajendra Nayak
Some IPs (like UART) need the sidle mode to be controlled in SW only while they are active. Once they go inactive, they need the IP to be put back in HW control so they are also wakeup capable. The flag HWMOD_SWSUP_SIDLE takes care of IPs which need the sidle mode to be *always* controlled in SWSUP. We now have a need to control IPs sidle mode in SWSUP only while its active. So define a new flag 'HWMOD_SWSUP_SIDLE_ACT' to help the framework know about these new IP requirements. Tested-by: Vaibhav Bedia <vaibhav.bedia@ti.com> Tested-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@linaro.org> Tested-by: Kevin Hilman <khilman@linaro.org> # OMAP4/Panda Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-05-19ARM: OMAP2+: hwmod: Fix sidle programming in _enable_sysc()/_idle_sysc()Rajendra Nayak
_enable_sysc() and _idle_sysc() handle the midle mode programming correctly and program HWMOD_IDLEMODE_SMART or HWMOD_IDLEMODE_SMART_WKUP respectively for supported IPs (The ones which support hardware controlled midle modes) However the same programming logic is missing when it comes to sidle mode programming. Here they seem to just set HWMOD_IDLEMODE_SMART (Again for the ones which support hardware controlled sidle modes) This problem was hidden due to the fact that a call to _enable_wakeup() in those same functions would overwrite the idlemodes and program them correctly (to HWMOD_IDLEMODE_SMART_WKUP in the supported cases) So fix the sidlemode handling correctly in these functions and handle the _enable_wakeup() for SIDLEMODE supported IPs same as the way its handled for MIDLEMODE supported ones. Tested-by: Vaibhav Bedia <vaibhav.bedia@ti.com> Tested-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@linaro.org> Tested-by: Kevin Hilman <khilman@linaro.org> # OMAP4/Panda Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-05-17ARM: AM33XX: Add missing .clkdm_name to clkdiv32k_ick clockVaibhav Hiremath
It is required to enable respective clock-domain before enabling any clock/module inside that clock-domain. During common-clock migration, .clkdm_name field got missed for "clkdiv32k_ick" clock, which leaves "clk_24mhz_clkdm" unused; so it will be disabled even if childs of this clock-domain is enabled, which keeps child modules in idle mode. This fixes the kernel crash observed on AM335xEVM-SK platform, where clkdiv32_ick clock is being used as a gpio debounce clock and since clkdiv32k_ick is in idle mode it leads to below crash - Crash Log: ========== [ 2.598347] Unhandled fault: external abort on non-linefetch (0x1028) at 0xfa1ac150 [ 2.606434] Internal error: : 1028 [#1] SMP ARM [ 2.611207] Modules linked in: [ 2.614449] CPU: 0 Not tainted (3.8.4-01382-g1f449cd-dirty #4) [ 2.620973] PC is at _set_gpio_debounce+0x60/0x104 [ 2.626025] LR is at clk_enable+0x30/0x3c Cc: stable@vger.kernel.org # v3.9 Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Rajendra Nayak <rnayak@ti.com> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-16ARM: OMAP: fix __init section mismatch for _enable_preprogramjean-philippe francois
_enable_preprogram is marked as __init, but is called from _enable which is not. Without this patch, the board oopses after init. Tested on custom hardware and on beagle board xM. Otherwise we can get: Unable to handle kernel paging request at virtual address 000b0012 pgd = cf968000 *pgd=8fb06831, *pte=00000000, *ppte=00000000 PREEMPT ARM Modules linked in: CPU: 0 Not tainted (3.9.0 #2) PC is at _enable_preprogram+0x1c/0x24 LR is at omap_hwmod_enable+0x34/0x60 psr: 80000093 sp : cf95de08 ip : 00002de5 fp : bec33d4c r10: 00000000 r9 : 00000002 r8 : b6dd2c78 r7 : 00000004 r6 : 00000000 r5 : a0000013 r4 : cf95c000 r3 : 00000000 r2 : b6dd2c7c r1 : 00000000 r0 : 000b0012 Flags: Nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user Control: 10c5387d Table: 8f968019 DAC: 00000015 Process otpcmd (pid: 607, stack limit = 0xcf95c230) Stack: (0xcf95de08 to 0xcf95e000) de00: 00000001 cf91f840 00000000 c001d6fc 00000002 cf91f840 de20: cf8f7e10 c001de54 cf8f7e10 c001de78 c001de68 c01d5e80 00000000 cf8f7e10 de40: cf8f7e10 c01d5f28 cf8f7e10 c0530d30 00000000 c01d6f28 00000000 c0088664 de60: b6ea1000 cfb05284 cf95c000 00000001 cf95c000 60000013 00000001 cf95dee4 de80: cf870050 c01d7308 cf870010 cf870050 00000001 c0278b14 c0526f28 00000000 dea0: cf870050 ffff8e18 00000001 cf95dee4 00000000 c0274f7c cf870050 00000001 dec0: cf95dee4 cf1d8484 000000e0 c0276464 00000008 cf9c0000 00000007 c0276980 dee0: cf9c0000 00000064 00000008 cf1d8404 cf1d8400 c01cc05c 0000270a cf1d8504 df00: 00000023 cf1d8484 00000007 c01cc670 00000bdd 00000001 00000000 cf449e60 df20: cf1dde70 cf1d8400 bec33d18 cf1d8504 c0246f00 00000003 cf95c000 00000000 df40: bec33d4c c01cd078 00000003 cf1d8504 00000081 c01cbcb8 bec33d18 00000003 df60: bec33d18 c00a9034 00002000 c00a9c68 cf92fe00 00000003 c0246f00 cf92fe00 df80: 00000000 c00a9cb0 00000003 00000000 00008e70 00000000 b6f17000 00000036 dfa0: c000e484 c000e300 00008e70 00000000 00000003 c0246f00 bec33d18 bec33d18 dfc0: 00008e70 00000000 b6f17000 00000036 00000000 00000000 b6f6d000 bec33d4c dfe0: b6ea1bd0 bec33d0c 00008c9c b6ea1bdc 60000010 00000003 00000000 00000000 (_omap_device_enable_hwmods+0x20/0x34) (omap_device_enable+0x3c/0x50) (_od_runtime_resume+0x10/0x1c) (__rpm_callback+0x54/0x98) (rpm_callback+0x64/0x7c) (rpm_resume+0x434/0x554) (__pm_runtime_resume+0x48/0x74) (omap_i2c_xfer+0x28/0xe8) (__i2c_transfer+0x3c/0x78) (i2c_transfer+0x6c/0xc0) (i2c_master_send+0x38/0x48) (sha204p_send_command+0x60/0x9c) (sha204c_send_and_receive+0x5c/0x1e0) (sha204m_read+0x94/0xa0) (otp_do_read+0x50/0xa4) (vfs_ioctl+0x24/0x40) (do_vfs_ioctl+0x1b0/0x1c0) (sys_ioctl+0x38/0x54) (ret_fast_syscall+0x0/0x30) Code: e1a08002 ea000009 e598003c e592c05c (e7904003) Cc: stable@vger.kernel.org Signed-off-by: Jean-Philippe Fran=C3=A7ois <jp.francois@cynove.com> Acked-by: Kevin Hilman <khilman@linaro.org> [tony@atomide.com: updated description with oops] Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-09Merge tag 'omap-for-v3.10/fixes-for-merge-window-part2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes From Tony Lindgren: Omap fixes for things that were discovered during the merge window: - Few GPMC fixes and binding doc updates noted after sending pull requests for the GPMC branch. - Board fixes for beagle usb host and rx51 spi probe order - SoC fixes dt earlyprintk, omap1 dma and omap2+ id.c error handling fixes Then few minor things that are not strictly fixes but are good to get out of the way: - Add missing legacy mux registers for am/dm73x gpio - Add detection for am33xx pg2.1 silicon - Enable twl4030 audio modules in defconfig * tag 'omap-for-v3.10/fixes-for-merge-window-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP2+: Remove bogus IS_ERR_OR_NULL checking from id.c ARM: OMAP4+: omap2plus_defconfig: Enable audio via TWL6040 as module ARM: OMAP2: AM33XX: id: Add support for new AM335x PG2.1 Si omap: mux: add AM/DM37x gpios ARM: OMAP1: DMA: fix error handling in omap1_system_dma_init() ARM: OMAP2+: omap_device: use late_initcall_sync ARM: OMAP: RX-51: change probe order of touchscreen and panel SPI devices ARM: OMAP3: Beagle: Fix USB Host on beagle xM Ax/Bx ARM: OMAP2+: only WARN if a GPMC child probe function fail ARM: OMAP2+: only search for GPMC DT child nodes on probe Documentation: dt: update properties in TI GPMC NAND example Documentation: dt: update TI GPMC ethernet binding properties Signed-off-by: Olof Johansson <olof@lixom.net>
2013-05-09Merge branch 'late/fixes' into fixesOlof Johansson
* late/fixes: ARM: OMAP2+: Fix unmet direct dependencies for SERIAL_OMAP ARM: ux500: always select ABX500_CORE ARM: SIRF: select SMP_ON_UP only on SMP builds ARM: SPEAr: conditionalize l2x0 support ARM: imx: build CPU suspend code only when needed ARM: OMAP: build SMP code only for OMAP4/5 ARM: tegra: Tegra114 needs CPU_FREQ_TABLE ARM: default machine descriptor for multiplatform Signed-off-by: Olof Johansson <olof@lixom.net>
2013-05-09Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "This time we have dmatest improvements from Andy along with dw_dmac fixes. He has also done support for acpi for dmanegine. Also we have bunch of fixes going in DT support for dmanegine for various folks. Then Haswell and other ioat changes from Dave and SUDMAC support from Shimoda." * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits) dma: tegra: implement suspend/resume callbacks dma:of: Use a mutex to protect the of_dma_list dma: of: Fix of_node reference leak dmaengine: sirf: move driver init from module_init to subsys_initcall sudmac: add support for SUDMAC dma: sh: add Kconfig at_hdmac: move to generic DMA binding ioatdma: ioat3_alloc_sed can be static ioatdma: Adding write back descriptor error status support for ioatdma 3.3 ioatdma: S1200 platforms ioatdma channel 2 and 3 falsely advertise RAID cap ioatdma: Adding support for 16 src PQ ops and super extended descriptors ioatdma: Removing hw bug workaround for CB3.x .2 and earlier dw_dmac: add ACPI support dmaengine: call acpi_dma_request_slave_channel as well dma: acpi-dma: introduce ACPI DMA helpers dma: of: Remove unnecessary list_empty check DMA: OF: Check properties value before running be32_to_cpup() on it DMA: of: Constant names ioatdma: skip silicon bug workaround for pq_align for cb3.3 ioatdma: Removing PQ val disable for cb3.3 ...
2013-05-09ARM: OMAP2+: Remove bogus IS_ERR_OR_NULL checking from id.cTony Lindgren
Commit 6770b211 (ARM: OMAP2+: Export SoC information to userspace) had some broken return value handling as noted by Russell King: + soc_dev = soc_device_register(soc_dev_attr); + if (IS_ERR_OR_NULL(soc_dev)) { + kfree(soc_dev_attr); + return; + } + + parent = soc_device_to_device(soc_dev); + if (!IS_ERR_OR_NULL(parent)) + device_create_file(parent, &omap_soc_attr); This is nonsense. For the first, IS_ERR() is sufficient. For the second, tell me what error checking is required in the return value of this function: struct device *soc_device_to_device(struct soc_device *soc_dev) { return &soc_dev->dev; } when you've already determined that the passed soc_dev is a valid pointer. If you read the comments against the prototype: /** * soc_device_to_device - helper function to fetch struct device * @soc: Previously registered SoC device container */ struct device *soc_device_to_device(struct soc_device *soc); if "soc" is valid, it means the "previously registered SoC device container" must have succeeded and that can only happen if the struct device has been registered. Ergo, there will always be a valid struct device pointer for any registered SoC device container. Therefore, if soc_device_register() succeeds, then the return value from soc_device_to_device() will always be valid and no error checking of it is required. Simples. The rule as ever applies here: get to know the APIs your using and don't fumble around in the dark hoping that you'll get this stuff right. Fix it as noted by Russell. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-08ARM: OMAP2: AM33XX: id: Add support for new AM335x PG2.1 SiVaibhav Hiremath
Add support for chip id detection of AM335x PG2.1 Silicon. Currently omap3xxx_check_revision() detects PG1.0 and PG2.0 only, this patch extends it by adding PG2.1 Si support. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-08omap: mux: add AM/DM37x gpiosChristoph Fritz
This patch adds GPIO pins found on AM/DM37x. Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-08Merge branch 'omap-gpmc-fixes-for-v3.10' of git://github.com/jonhunter/linux ↵Tony Lindgren
into fixes
2013-05-08ARM: OMAP2+: omap_device: use late_initcall_syncKevin Hilman
If DEBUG_LL and earlyprintk are enabled, and omap-serial.c is compiled as a module, the kernel boot hangs early as the clocks for serial port are cut while earlyprintk still uses the port. The problem is a race between the late_initcall for omap_device (which idles devices that have no drivers) and the late_initcall in kernel/printk.c which turns off the earlyconsole. Any printks that happen between this omap_device late initcall and the earlyconsole late initcall will crash when accessing the UART. The fix is to ensure the omap_device initcall happens after the earlyconsole initcall. Reported-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-08ARM: OMAP: RX-51: change probe order of touchscreen and panel SPI devicesAaro Koskinen
Commit 9fdca9df (spi: omap2-mcspi: convert to module_platform_driver) broke the SPI display/panel driver probe on RX-51/N900. The exact cause is not fully understood, but it seems to be related to the probe order. SPI communication to the panel driver (spi1.2) fails unless the touchscreen (spi1.0) has been probed/initialized before. When the omap2-mcspi driver was converted to a platform driver, it resulted in that the devices are probed immediately after the board registers them in the order they are listed in the board file. Fix the issue by moving the touchscreen before the panel in the SPI device list. The patch fixes the following failure: [ 1.260955] acx565akm spi1.2: invalid display ID [ 1.265899] panel-acx565akm display0: acx_panel_probe panel detect error [ 1.273071] omapdss CORE error: driver probe failed: -19 Tested-by: Sebastian Reichel <sre@debian.org> Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Joni Lapilainen <joni.lapilainen@gmail.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: stable@vger.kernel.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-08ARM: OMAP3: Beagle: Fix USB Host on beagle xM Ax/BxRoger Quadros
On Beagle xM Rev. Ax/Bx, the USB power enable GPIO logic is reversed when compared to other revisions i.e. it is active high instead of active low. Use the beagle_config.usb_pwr_level flag correctly so that the power regulator can be configured at runtime. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-07arm: fix mismerge of arch/arm/mach-omap2/timer.cLinus Torvalds
I badly screwed up the merge in commit 6fa52ed33bea ("Merge tag 'drivers-for-linus' of git://git.kernel.org/pub/.../arm-soc") by incorrectly taking the arch/arm/mach-omap2/* data fully from the merge target because the 'drivers-for-linus' branch seemed to be a proper superset of the duplicate ARM commits. That was bogus: commit ff931c821bab ("ARM: OMAP: clocks: Delay clk inits atleast until slab is initialized") only existed in head, and the changes to arch/arm/mach-omap2/timer.c from that commit got list. Re-doing the merge more carefully, I do think this part was the only thing I screwed up. Knock wood. Reported-by: Tony Lindgren <tony@atomide.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Olof Johansson <olof@lixom.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07Merge tag 'cleanup-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late cleanups from Arnd Bergmann: "These are cleanups and smaller changes that either depend on earlier feature branches or came in late during the development cycle. We normally try to get all cleanups early, so these are the exceptions: - A follow-up on the clocksource reworks, hopefully the last time we need to merge clocksource subsystem changes through arm-soc. A first set of patches was part of the original 3.10 arm-soc cleanup series because of interdependencies with timer drivers now moved out of arch/arm. - Migrating the SPEAr13xx platform away from using auxdata for DMA channel descriptions towards using information in device tree, based on the earlier SPEAr multiplatform series - A few follow-ups on the Atmel SAMA5 support and other changes for Atmel at91 based on the larger at91 reworks. - Moving the armada irqchip implementation to drivers/irqchip - Several OMAP cleanups following up on the larger series already merged in 3.10." * tag 'cleanup-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits) ARM: OMAP4: change the device names in usb_bind_phy ARM: OMAP2+: Fix mismerge for timer.c between ff931c82 and da4a686a ARM: SPEAr: conditionalize SMP code ARM: arch_timer: Silence debug preempt warnings ARM: OMAP: remove unused variable serial: amba-pl011: fix !CONFIG_DMA_ENGINE case ata: arasan: remove the need for platform_data ARM: at91/sama5d34ek.dts: remove not needed compatibility string ARM: at91: dts: add MCI DMA support ARM: at91: dts: add i2c dma support ARM: at91: dts: set #dma-cells to the correct value ARM: at91: suspend both memory controllers on at91sam9263 irqchip: armada-370-xp: slightly cleanup irq controller driver irqchip: armada-370-xp: move IRQ handler to avoid forward declaration irqchip: move IRQ driver for Armada 370/XP ARM: mvebu: move L2 cache initialization in init_early() devtree: add binding documentation for sp804 ARM: integrator-cp: convert use CLKSRC_OF for timer init ARM: versatile: use OF init for sp804 timer ARM: versatile: add versatile dtbs to dtbs target ...
2013-05-07Merge tag 'dt-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device tree updates (part 2) from Arnd Bergmann: "These are mostly new device tree bindings for existing drivers, as well as changes to the device tree source files to add support for those devices, and a couple of new boards, most notably Samsung's Exynos5 based Chromebook. The changes depend on earlier platform specific updates and touch the usual platforms: omap, exynos, tegra, mxs, mvebu and davinci." * tag 'dt-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (169 commits) ARM: exynos: dts: cros5250: add EC device ARM: dts: Add sbs-battery for exynos5250-snow ARM: dts: Add i2c-arbitrator bus for exynos5250-snow ARM: dts: add mshc controller node for Exynos4x12 SoCs ARM: dts: Add chip-id controller node on Exynos4/5 SoC ARM: EXYNOS: Create virtual I/O mapping for Chip-ID controller using device tree ARM: davinci: da850-evm: add SPI flash support ARM: davinci: da850: override SPI DT node device name ARM: davinci: da850: add SPI1 DT node spi/davinci: add DT binding documentation spi/davinci: no wildcards in DT compatible property ARM: dts: mvebu: Convert mvebu device tree files to 64 bits ARM: dts: mvebu: introduce internal-regs node ARM: dts: mvebu: Convert all the mvebu files to use the range property ARM: dts: mvebu: move all peripherals inside soc ARM: dts: mvebu: fix cpus section indentation ARM: davinci: da850: add EHRPWM & ECAP DT node ARM/dts: OMAP3: fix pinctrl-single configuration ARM: dts: Add OMAP3430 SDP NOR flash memory binding ARM: dts: Add NOR flash bindings for OMAP2420 H4 ...
2013-05-07Merge tag 'omap-for-v3.10/fixes-for-merge-window' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into late/cleanup From Tony Lindgren <tony@atomide.com>: An urgent fix for a timer mismerge for and a regression fix for musb device naming change. * tag 'omap-for-v3.10/fixes-for-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP4: change the device names in usb_bind_phy ARM: OMAP2+: Fix mismerge for timer.c between ff931c82 and da4a686a Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-05-06ARM: OMAP4: change the device names in usb_bind_phyKishon Vijay Abraham I
After the device names are created using PLATFORM_DEVID_AUTO, the old device names given in usb_bind_phy are no longer valid causing the musb controller not to get the phy reference. Updated the usb_bind_phy with the new device names to get MUSB functional in omap4 panda. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-06ARM: OMAP2+: Fix mismerge for timer.c between ff931c82 and da4a686aVaibhav Hiremath
Looks like the timer.c fixes in commit ff931c82 (ARM: OMAP: clocks: Delay clk inits atleast until slab is initialized) got lost in a merge with da4a686a (ARM: smp_twd: convert to use CLKSRC_OF init). Without the omap_clk_init() calls none of OMAP family of devices boot. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> [tony@atomide.com: updated comments to describe merge error] Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-06Merge branch 'late/clksrc' into late/cleanupArnd Bergmann
There is no reason to keep the clksrc cleanups separate from the other cleanups, and this resolves some merge conflicts. Conflicts: arch/arm/mach-spear/spear13xx.c drivers/irqchip/Makefile
2013-05-06Merge branch 'late/dt' into next/dt2Arnd Bergmann
This is support for the ARM Chromebook, originally scheduled as a "late" pull request. Since it's already late now, we can combine this into the existing next/dt2 branch. * late/dt: ARM: exynos: dts: cros5250: add EC device ARM: dts: Add sbs-battery for exynos5250-snow ARM: dts: Add i2c-arbitrator bus for exynos5250-snow ARM: dts: Add chip-id controller node on Exynos4/5 SoC ARM: EXYNOS: Create virtual I/O mapping for Chip-ID controller using device tree
2013-05-04Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board specific changes (part 1) from Olof Johansson: "These changes are all for board specific files. These used to make up a large portion of the ARM changes in the past, but as we are generalizing the support and moving to device tree probing, this has gotten significantly smaller. The only platform actually adding new code here at the moment is Renesas shmobile, as they are still busy converting their code to device tree and have not come far enough to not need it." * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits) ARM: msm: USB_MSM_OTG needs USB_PHY ARM: davinci: da850 evm: fix const qualifier placement ARM: davinci: da850 board: add remoteproc support ARM: pxa: move debug uart code ARM: pxa: select PXA935 on saar & tavorevb ARM: mmp: add more compatible names in gpio driver ARM: pxa: move PXA_GPIO_TO_IRQ macro ARM: pxa: remove cpu_is_xxx in gpio driver ARM: Kirkwood: update Network Space Mini v2 description ARM: Kirkwood: DT board setup for CloudBox ARM: Kirkwood: sort board entries by ASCII-code order ARM: OMAP: board-4430sdp: Provide regulator to pwm-backlight ARM: OMAP: zoom: Use pwm stack for lcd and keyboard backlight ARM: OMAP2+: omap2plus_defconfig: Add support for BMP085 pressure sensor omap2+: Remove useless Makefile line omap2+: Remove useless Makefile line ARM: OMAP: RX-51: add missing regulator supply definitions for lis3lv02d ARM: OMAP1: fix omap_udc registration ARM: davinci: use is IS_ENABLED macro ARM: kirkwood: add MACH_GURUPLUG_DT to defconfig ...
2013-05-04Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Olof Johansson: "This is a rather large set of patches for device drivers that for one reason or another the subsystem maintainer preferred to get merged through the arm-soc tree. There are both new drivers as well as existing drivers that are getting converted from platform-specific code into standalone drivers using the appropriate subsystem specific interfaces. In particular, we can now have pinctrl, clk, clksource and irqchip drivers in one file per driver, without the need to call into platform specific interface, or to get called from platform specific code, as long as all information about the hardware is provided through a device tree. Most of the drivers we touch this time are for clocksource. Since now most of them are part of drivers/clocksource, I expect that we won't have to touch these again from arm-soc and can let the clocksource maintainers take care of these in the future. Another larger part of this series is specific to the exynos platform, which is seeing some significant effort in upstreaming and modernization of its device drivers this time around, which unfortunately is also the cause for the churn and a lot of the merge conflicts. There is one new subsystem that gets merged as part of this series: the reset controller interface, which is a very simple interface for taking devices on the SoC out of reset or back into reset. Patches to use this interface on i.MX follow later in this merge window, and we are going to have other platforms (at least tegra and sirf) get converted in 3.11. This will let us get rid of platform specific callbacks in a number of platform independent device drivers." * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits) irqchip: s3c24xx: add missing __init annotations ARM: dts: Disable the RTC by default on exynos5 clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3} ARM: exynos: restore mach/regs-clock.h for exynos5 clocksource: exynos_mct: fix build error on non-DT pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register() irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure reset: NULL deref on allocation failure reset: Add reset controller API dt: describe base reset signal binding ARM: EXYNOS: Add arm-pmu DT binding for exynos421x ARM: EXYNOS: Add arm-pmu DT binding for exynos5250 ARM: EXYNOS: Enable PMUs for exynos4 irqchip: exynos-combiner: Correct combined IRQs for exynos4 irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq ARM: EXYNOS: fix compilation error introduced due to common clock migration clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3} clk: exynos4: export clocks required for fimc-is clk: samsung: Fix compilation error clk: tegra: fix enum tegra114_clk to match binding ...
2013-05-03ARM: OMAP2+: Fix unmet direct dependencies for SERIAL_OMAPTony Lindgren
Commit 8a6201b9 (ARM: OMAP2+: Fix unmet direct dependencies for zoom for 8250 serial) fixed unmet direct dependencies for 8250, but failed to do the same for omap serial. This can cause the following warning: warning: (ARCH_OMAP2PLUS_TYPICAL) selects SERIAL_OMAP which has unmet direct dependencies (TTY && HAS_IOMEM && GENERIC_HARDIRQS && ARCH_OMAP2PLUS). We should not select drivers, they should be selected by the user. Fix the issue by removing the select and adding them to omap2plus_defconfig instead. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-05-03ARM: OMAP: build SMP code only for OMAP4/5Arnd Bergmann
The OMAP platform code assumes that SMP is only ever enabled when CONFIG_ARCH_OMAP4 or CONFIG_SOC_OMAP5 is enabled, which is not necessarirly true in a multiplatform configuration. arch/arm/mach-omap2/built-in.o: In function `omap4_smp_prepare_cpus': :(.init.text+0x413c): undefined reference to `omap_get_wakeupgen_base' :(.init.text+0x415c): undefined reference to `omap_secure_apis_support' arch/arm/mach-omap2/built-in.o: In function `omap4_boot_secondary': :(.cpuinit.text+0x28): undefined reference to `omap_get_wakeupgen_base' :(.cpuinit.text+0x3c): undefined reference to `omap_secure_apis_support' arch/arm/mach-omap2/built-in.o: In function `omap4_cpu_die': :(.ref.text+0x8): undefined reference to `omap_get_wakeupgen_base' :(.ref.text+0x10): undefined reference to `omap_secure_apis_support' :(.ref.text+0x4c): undefined reference to `omap4_hotplug_cpu' :(.ref.text+0x50): undefined reference to `omap_secure_apis_support' Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Tony Lindgren <tony@atomide.com>
2013-05-03Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "The major items included in here are: - MCPM, multi-cluster power management, part of the infrastructure required for ARMs big.LITTLE support. - A rework of the ARM KVM code to allow re-use by ARM64. - Error handling cleanups of the IS_ERR_OR_NULL() madness and fixes of that stuff for arch/arm - Preparatory patches for Cortex-M3 support from Uwe Kleine-König. There is also a set of three patches in here from Hugh/Catalin to address freeing of inappropriate page tables on LPAE. You already have these from akpm, but they were already part of my tree at the time he sent them, so unfortunately they'll end up with duplicate commits" * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (77 commits) ARM: EXYNOS: remove unnecessary use of IS_ERR_VALUE() ARM: IMX: remove unnecessary use of IS_ERR_VALUE() ARM: OMAP: use consistent error checking ARM: cleanup: OMAP hwmod error checking ARM: 7709/1: mcpm: Add explicit AFLAGS to support v6/v7 multiplatform kernels ARM: 7700/2: Make cpu_init() notrace ARM: 7702/1: Set the page table freeing ceiling to TASK_SIZE ARM: 7701/1: mm: Allow arch code to control the user page table ceiling ARM: 7703/1: Disable preemption in broadcast_tlb*_a15_erratum() ARM: mcpm: provide an interface to set the SMP ops at run time ARM: mcpm: generic SMP secondary bringup and hotplug support ARM: mcpm_head.S: vlock-based first man election ARM: mcpm: Add baremetal voting mutexes ARM: mcpm: introduce helpers for platform coherency exit/setup ARM: mcpm: introduce the CPU/cluster power API ARM: multi-cluster PM: secondary kernel entry code ARM: cacheflush: add synchronization helpers for mixed cache state accesses ARM: cpu hotplug: remove majority of cache flushing from platforms ARM: smp: flush L1 cache in cpu_die() ARM: tegra: remove tegra specific cpu_disable() ...
2013-05-02Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm pull request for 3.10. Wierd bits: - OMAP drm changes required OMAP dss changes, in drivers/video, so I took them in here. - one more fbcon fix for font handover - VT switch avoidance in pm code - scatterlist helpers for gpu drivers - have acks from akpm Highlights: - qxl kms driver - driver for the spice qxl virtual GPU Nouveau: - fermi/kepler VRAM compression - GK110/nvf0 modesetting support. Tegra: - host1x core merged with 2D engine support i915: - vt switchless resume - more valleyview support - vblank fixes - modesetting pipe config rework radeon: - UVD engine support - SI chip tiling support - GPU registers initialisation from golden values. exynos: - device tree changes - fimc block support Otherwise: - bunches of fixes all over the place." * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (513 commits) qxl: update to new idr interfaces. drm/nouveau: fix build with nv50->nvc0 drm/radeon: fix handling of v6 power tables drm/radeon: clarify family checks in pm table parsing drm/radeon: consolidate UVD clock programming drm/radeon: fix UPLL_REF_DIV_MASK definition radeon: add bo tracking debugfs drm/radeon: add new richland pci ids drm/radeon: add some new SI PCI ids drm/radeon: fix scratch reg handling for UVD fence drm/radeon: allocate SA bo in the requested domain drm/radeon: fix possible segfault when parsing pm tables drm/radeon: fix endian bugs in atom_allocate_fb_scratch() OMAPDSS: TFP410: return EPROBE_DEFER if the i2c adapter not found OMAPDSS: VENC: Add error handling for venc_probe_pdata OMAPDSS: HDMI: Add error handling for hdmi_probe_pdata OMAPDSS: RFBI: Add error handling for rfbi_probe_pdata OMAPDSS: DSI: Add error handling for dsi_probe_pdata OMAPDSS: SDI: Add error handling for sdi_probe_pdata OMAPDSS: DPI: Add error handling for dpi_probe_pdata ...
2013-05-02Merge branch 'cleanup' into for-linusRussell King
Conflicts: arch/arm/plat-omap/dmtimer.c
2013-05-02Merge branches 'devel-stable', 'entry', 'fixes', 'mach-types', 'misc' and ↵Russell King
'smp-hotplug' into for-linus
2013-05-02ARM: OMAP: use consistent error checkingRussell King
Consistently check errors using the usual method used in the kernel for much of its history. For instance: int gpmc_cs_set_timings(int cs, const struct gpmc_timings *t) { int div; div = gpmc_calc_divider(t->sync_clk); if (div < 0) return div; static int gpmc_set_async_mode(int cs, struct gpmc_timings *t) { ... return gpmc_cs_set_timings(cs, t); ..... ret = gpmc_set_async_mode(gpmc_onenand_data->cs, &t); if (IS_ERR_VALUE(ret)) return ret; So, gpmc_cs_set_timings() thinks any negative return value is an error, but where we check that in higher levels, only a limited range are errors... There is only _one_ use of IS_ERR_VALUE() in arch/arm which is really appropriate, and that is in arch/arm/include/asm/syscall.h: static inline long syscall_get_error(struct task_struct *task, struct pt_regs *regs) { unsigned long error = regs->ARM_r0; return IS_ERR_VALUE(error) ? error : 0; } because this function really does have to differentiate between error return values and addresses which look like negative numbers (eg, from mmap()). So, here's a patch to remove them from OMAP, except for the above. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-05-02ARM: cleanup: OMAP hwmod error checkingRussell King
omap_hwmod_lookup() only returns NULL on error, never an error pointer. Checking the returned pointer using IS_ERR_OR_NULL() is needless overhead. Use a simple !ptr check instead. OMAP devices (oh->od) always have a valid platform device attached (see omap_device_alloc()) so there's no point validating the platform device pointer (we will have already oopsed long before if this is not the case here.) Lastly, oh->od is only ever NULL or a valid omap device pointer - 'oh' comes from the statically declared hwmod tables, and the pointer is only filled in by omap_device_alloc() at a point where the omap device pointer must be valid. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-05-02Merge tag 'multiplatform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform updates from Olof Johansson: "More multiplatform enablement for ARM platforms. The ones converted in this branch are: - bcm2835 - cns3xxx - sirf - nomadik - msx - spear - tegra - ux500 We're getting close to having most of them converted! One of the larger platforms remaining is Samsung Exynos, and there are a bunch of supporting patches in this merge window for it. There was a patch in this branch to a early version of multiplatform conversion, but it ended up being reverted due to need of more bake time. The revert commit is part of the branch since it would have required rebasing multiple dependent branches and they were stable by then" * tag 'multiplatform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits) mmc: sdhci-s3c: Fix operation on non-single image Samsung platforms clocksource: nomadik-mtu: fix up clocksource/timer Revert "ARM: exynos: enable multiplatform support" ARM: SPEAr13xx: Fix typo "ARCH_HAVE_CPUFREQ" ARM: exynos: enable multiplatform support rtc: s3c: make header file local mtd: onenand/samsung: make regs-onenand.h file local thermal/exynos: remove unnecessary header inclusions mmc: sdhci-s3c: remove platform dependencies ARM: samsung: move mfc device definition to s5p-dev-mfc.c ARM: exynos: move debug-macro.S to include/debug/ ARM: exynos: prepare for sparse IRQ ARM: exynos: introduce EXYNOS_ATAGS symbol ARM: tegra: build assembly files with -march=armv7-a ARM: Push selects for TWD/SCU into machine entries ARM: ux500: build hotplug.o for ARMv7-a ARM: ux500: move to multiplatform ARM: ux500: make remaining headers local ARM: ux500: make irqs.h local to platform ARM: ux500: get rid of <mach/[hardware|db8500-regs].h> ...
2013-05-02Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Olof Johansson: "This branch contains part 1 of the platform updates for 3.10. Among the highlights: - Support for the new Atmel Cortex-A5 based platforms (SAMA5D3) - New support for CSR SiRFatlas6 SoCs - A handful of updates for NVidia T114 (a.k.a. Tegra 4) - A bunch of updates for the shmobile platforms - A handful of updates for davinci - A few updates for Qualcomm MSM - Plus a handful of other patches, defconfig updates, etc." * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (135 commits) ARM: tegra: pm: fix build error w/o PM_SLEEP ARM: davinci: ensure global variables are declared ARM: davinci: sram.c: fix incorrect type in assignment ARM: davinci: da8xx dt: make file local symbols static ARM: davinci: da8xx: add remoteproc support ARM: socfpga: Upgrade clk driver for socfpga to make use of dts clock entries ARM: socfpga: Add clock entries into device tree ARM: socfpga: Enable soft reset ARM: EXYNOS: replace cpumask by the corresponding macro ARM: EXYNOS: handle properly the return values ARM: EXYNOS: factor out the idle states ARM: OMAP4: Enable fix for Cortex-A9 erratas ARM: OMAP2+: Export SoC information to userspace ARM: OMAP2+: SoC name and revision unification ARM: OMAP2+: Move common part of late init into common function ARM: tegra: pm: remove duplicated include from pm.c ARM: davinci: da850: override mmc DT node device name ARM: davinci: da850: add mmc DT entries mmc: davinci_mmc: add DT support ARM: SAMSUNG: check processor type before cache restoration in resume ...
2013-05-02Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanup from Olof Johansson: "Here is a collection of cleanup patches. Among the pieces that stand out are: - The deletion of h720x platforms - Split of at91 non-dt platforms to their own Kconfig file to keep them separate - General cleanups and refactoring of i.MX and MXS platforms - Some restructuring of clock tables for OMAP - Convertion of PMC driver for Tegra to dt-only - Some renames of sunxi -> sun4i (Allwinner A10) - ... plus a bunch of other stuff that I haven't mentioned" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: i.MX: remove unused ARCH_* configs ARM i.MX53: remove platform ahci support ARM: sunxi: Rework the restart code irqchip: sunxi: Rename sunxi to sun4i irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro clocksource: sunxi: Rename sunxi to sun4i clocksource: sunxi: make use of CLKSRC_OF clocksource: sunxi: Cleanup the timer code ARM: at91: remove trailing semicolon from macros ARM: at91/setup: fix trivial typos ARM: EXYNOS: remove "config EXYNOS_DEV_DRM" ARM: EXYNOS: change the name of USB ohci header ARM: SAMSUNG: Remove unnecessary code for dma ARM: S3C24XX: Remove unused GPIO drive strength register definitions ARM: OMAP4+: PM: Restore CPU power state to ON with clockdomain force wakeup method ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2412 ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2410 ARM: S3C24XX: Removed unneeded dependency on ARCH_S3C24XX for boards ARM: SAMSUNG: Fix typo "CONFIG_SAMSUNG_DEV_RTC" ARM: S5P64X0: Fix typo "CONFIG_S5P64X0_SETUP_SDHCI" ...
2013-05-02Merge tag 'fixes-nc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC non-critical fixes from Olof Johansson: "Here is a collection of fixes (and some intermixed cleanups) that were considered less important and thus not included in the later parts of the 3.9-rc cycle. It's a bit all over the map, contents wise. A series of ux500 fixes and cleanups, a bunch of various fixes for OMAP and tegra, and some for Freescale i.MX and even Qualcomm MSM. Note that there's also a patch on this branch to globally turn off -Wmaybe-uninitialized when building with -Os. It's been posted several times by Arnd and no dissent was raised, but nobody seemed interested to pick it up. So here it is, as the topmost patch." * tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits) Turn off -Wmaybe-uninitialized when building with -Os ARM: orion5x: include linux/cpu.h ARM: tegra: call cpu_do_idle from C code ARM: u300: fix ages old copy/paste bug ARM: OMAP2+: add dependencies on ARCH_MULTI_V6/V7 ARM: tegra: solve adr range issue with THUMB2_KERNEL enabled ARM: tegra: fix relocation truncated error when THUMB2_KERNEL enabled ARM: tegra: fix build error when THUMB2_KERNEL enabled ARM: msm: Fix uncompess.h tx underrun check ARM: vexpress: Remove A9 PMU compatible values for non-A9 platforms ARM: cpuimx27 and mbimx27: prepend CONFIG_ to Kconfig macro ARM: OMAP2+: fix typo "CONFIG_BRIDGE_DVFS" ARM: OMAP1: remove "config MACH_OMAP_HTCWIZARD" ARM: mach-imx: mach-imx6q: Fix sparse warnings ARM: mach-imx: src: Include "common.h ARM: mach-imx: gpc: Include "common.h" ARM: mach-imx: avic: Staticize *avic_base ARM: mach-imx: tzic: Staticize *tzic_base ARM: mach-imx: clk: Include "clk.h" ARM: mach-imx: clk-busy: Staticize clk_busy_mux_ops ...
2013-04-30Merge tag 'pm+acpi-3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael J Wysocki: - ARM big.LITTLE cpufreq driver from Viresh Kumar. - exynos5440 cpufreq driver from Amit Daniel Kachhap. - cpufreq core cleanup and code consolidation from Viresh Kumar and Stratos Karafotis. - cpufreq scalability improvement from Nathan Zimmer. - AMD "frequency sensitivity feedback" powersave bias for the ondemand cpufreq governor from Jacob Shin. - cpuidle code consolidation and cleanups from Daniel Lezcano. - ARM OMAP cpuidle fixes from Santosh Shilimkar and Daniel Lezcano. - ACPICA fixes and other improvements from Bob Moore, Jung-uk Kim, Lv Zheng, Yinghai Lu, Tang Chen, Colin Ian King, and Linn Crosetto. - ACPI core updates related to hotplug from Toshi Kani, Paul Bolle, Yasuaki Ishimatsu, and Rafael J Wysocki. - Intel Lynxpoint LPSS (Low-Power Subsystem) support improvements from Rafael J Wysocki and Andy Shevchenko. * tag 'pm+acpi-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (192 commits) cpufreq: Revert incorrect commit 5800043 cpufreq: MAINTAINERS: Add co-maintainer cpuidle: add maintainer entry ACPI / thermal: do not always return THERMAL_TREND_RAISING for active trip points ARM: s3c64xx: cpuidle: use init/exit common routine cpufreq: pxa2xx: initialize variables ACPI: video: correct acpi_video_bus_add error processing SH: cpuidle: use init/exit common routine ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=y ACPI: Fix wrong parameter passed to memblock_reserve cpuidle: fix comment format pnp: use %*phC to dump small buffers isapnp: remove debug leftovers ARM: imx: cpuidle: use init/exit common routine ARM: davinci: cpuidle: use init/exit common routine ARM: kirkwood: cpuidle: use init/exit common routine ARM: calxeda: cpuidle: use init/exit common routine ARM: tegra: cpuidle: use init/exit common routine for tegra3 ARM: tegra: cpuidle: use init/exit common routine for tegra2 ARM: OMAP4: cpuidle: use init/exit common routine ...
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
2013-04-30ARM: OMAP2+: only WARN if a GPMC child probe function failJavier Martinez Canillas
If any of the GPMC child nodes fails, this shouldn't make the whole gpmc_probe_dt() function to fail. It is better to just WARN and allow other devices probe function to succeed. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2013-04-30ARM: OMAP2+: only search for GPMC DT child nodes on probeJavier Martinez Canillas
The GPMC DT probe function use for_each_node_by_name() to search child device nodes of the GPMC controller. But this function does not use the GPMC device node as the root of the search and instead search across the complete Device Tree. This means that any device node on the DT that is using any of the GPMC child nodes names searched for will be returned even if they are not connected to the GPMC, making the gpmc_probe_xxx_child() function to fail. Fix this by using the GPMC device node as the search root so the search will be restricted to its children. Reported-by: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2013-04-28Merge branch 'gic/cleanup' into next/socOlof Johansson
Merge in the gic cleanup since it has a handful of annoying internal conflicts with soc development branches. All of them are delete/delete conflicts. * gic/cleanup: irqchip: vic: add include of linux/irq.h irqchip: gic: Perform the gic_secondary_init() call via CPU notifier irqchip: gic: Call handle_bad_irq() directly arm: Move chained_irq_(enter|exit) to a generic file arm: Move the set_handle_irq and handle_arch_irq declarations to asm/irq.h Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-shmobile/smp-emev2.c arch/arm/mach-shmobile/smp-r8a7779.c arch/arm/mach-shmobile/smp-sh73a0.c arch/arm/mach-socfpga/platsmp.c
