path: root/arch/arm/mach-omap2/usb-musb.c
2010-05-20usb: musb: Add extvbus in musb_board_dataAjay Kumar Gupta
EXTVBUS programming is required by OMAP3EVM REV >=E to supply 500mA power so adding a flag which can be used by musb driver to program EXTVBUS. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-23omap4: Use irq line defines from irq-44xx.hSantosh Shilimkar
This patch removes all the omap4 specific irq line defines from plat/irqs.h and includes auto-generated irqs-44xx.h All the legacy naming style defines are replaced with the one from irqs-44xx.h Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Reviewed-by: Paul Walmsley <paul@pwsan.com> [tony@atomide.com: updated to compile with usb-musb.c] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-23omap: musb: Add USB support to 4430 SDP board fileMaulik Mankad
This patch adds support for Mentor USB to 4430 SDP board file. It also defines the base address for HS USB OTG controller in OMAP4. Also updates platform specfic structure with base address and IRQ details. Signed-off-by: Maulik Mankad <x0082077@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Felipe Balbi <felipe.balbi@nokia.com> Cc: David Brownell <david-b@pacbell.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Olof Johansson <olof@lixom.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-19omap: musb: remove unnecessary returnFelipe Balbi
trivial patch, no functional changes. Cc: linux-usb@vger.kernel.org Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-19omap: musb: remove unused dma dataFelipe Balbi
we don't use those anywhere on musb driver, so let's remove those old stuff. Cc: linux-usb@vger.kernel.org Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-19omap: musb: remove unused soft_con fieldFelipe Balbi
remove unused data. Cc: linux-usb@vger.kernel.org Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-19arm: omap: musb: we can use clk frameworkFelipe Balbi
... in order to handle musb's clock. Let's start removing the old musb-only set_clock function. Cc: linux-usb@vger.kernel.org Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-19omap: musb: remove unused dataFelipe Balbi
eps_bits wasn't being used anywhere, let's remove it. Cc: linux-usb@vger.kernel.org Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-19omap: musb: Pass board specific data from board fileMaulik Mankad
Pass board specific data for MUSB (like interface_type, mode etc) from board file by defining board specific structure. Each board file can define this structure based on its requirement and pass this information to the driver. Signed-off-by: Maulik Mankad <x0082077@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Felipe Balbi <felipe.balbi@nokia.com> Cc: David Brownell <david-b@pacbell.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Gupta Ajay Kumar <ajay.gupta@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-19arm: omap: musb: ioremap only what's oursFelipe Balbi
omap3430 TRM says the OTG address space is 4k, not 8k. Cc: linux-usb@vger.kernel.org Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-02MUSB: Remove usb_musb_pm_init() callAnand Gadiyar
In usb_musb_pm_init, we attempt to access an MUSB register when the i-clock may not be on, or the module is otherwise not accessible. We need to either: - enable the clock before this access, or - remove this code and move it to the bootloader, or - enable the clock in the bootloader If we enable the clock in the bootloader, we might as well add the workaround in the bootloader itself. This code will anyway be changed once hwmod is in place, so remove it for now This allows us to boot the kernel on certain OMAP3 boards with a bootloader that doesn't enable this clock. Without this, we will need to upgrade the bootloaders on these boards. Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-08-07USB: musb: fix the nop registration for OMAP3EVMGupta, Ajay Kumar
OMAP3EVM uses ISP1504 phy which doesn't require any programming and thus has to use NOP otg transceiver. Cleanups being done: - Remove unwanted code in usb-musb.c file - Register NOP in OMAP3EVM board file using usb_nop_xceiv_register(). - Select NOP_USB_XCEIV for OMAP3EVM boards. - Don't enable TWL4030_USB in omap3_evm_defconfig Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Eino-Ville Talvala <talvala@stanford.edu> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-28OMAP3: PM: Ensure MUSB block can idle when driver not loadedPeter 'p2' De Schrijver
Otherwise, bootloaders may leave MUSB in a state which prevents retention. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-28OMAP2/3: PM: push core PM code from linux-omapKevin Hilman
This patch is to sync the core linux-omap PM code with mainline. This code has evolved and been used for a while the linux-omap tree, but the attempt here is to finally get this into mainline. Following this will be a series of patches from the 'PM branch' of the linux-omap tree to add full PM hardware support from the linux-omap tree. Much of this PM core code was written by Jouni Hogander with significant contributions from Paul Walmsley as well as many others from Nokia, Texas Instruments and linux-omap community. Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-04-13Replace all DMA_nBIT_MASK macro with DMA_BIT_MASK(n)Yang Hongyang
This is the second go through of the old DMA_nBIT_MASK macro,and there're not so many of them left,so I put them into one patch.I hope this is the last round. After this the definition of the old DMA_nBIT_MASK macro could be removed. Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Tony Lindgren <tony@atomide.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Greg KH <greg@kroah.com> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-23ARM: OMAP3: MUSB initialization for omap hw, v2Felipe Balbi
Create a generic board-file for initializing usb on omap2430 and omap3 boards. Patch modified by Tony to build the module based on CONFIG_USB_MUSB_SOC. Also merged in a patch adding the nop xceiv from Ajay Kumar Gupta <ajay.gupta@ti.com>. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
