The USB phy-nop nop driver expects the RESET line information
to be sent as a GPIO number via platform data. Adapt to that.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
The platform data bits can be inferred from the other members of
struct usbhs_phy_data. So get rid of the platform_data member.
Build the platform data for the PHY device in usbhs_init_phys() instead.
The "nop" driver isn't a do-nothing-stub but supports a couple functions
like clock on/off or is able to use a voltage regulator. This patch
simply renames the driver to "generic" since it is easy possible to
extend it by a simple function istead of writing a complete driver.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Pull ARM SoC cleanups from Arnd Bergmann:
"This contains cleanups as preparation for other branches adding new
features, we pulled 16 branches for 9 platforms into this one.
Most notable here is the removal of support for ATAGS based OMAP4
systems. Since all OMAP4 machines are fully functional with DT based
booting in 3.10, we can remove a lot of code here.
Also noteworthy is Maxime Ripard's cleanup of the machine descriptors,
which means we need no machine descriptors in a lot more cases and can
boot additional machines by just having the respective device drivers
enabled."
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (76 commits)
ARM: picoxcell: remove .nr_irqs reference
ARM: s5p64x0: avoid build warning for uncompress.h
ARM: SAMSUNG: Remove unused plat/regs-watchdog.h header
ARM: SAMSUNG: Remove legacy watchdog reset code
ARM: SAMSUNG: Let platforms use the new watchdog reset driver
ARM: SAMSUNG: Add watchdog reset driver
ARM: SAMSUNG: Use local definitions of watchdog registers
watchdog: s3c2410_wdt: Use local register definitions
ARM: S5P64X0: Use common uncompress.h part for plat-samsung
ARM: SAMSUNG: Consolidate uncompress subroutine
ARM: at91: drop rm9200dk board support
ARM: dts: msm: Fix merge resolution
ARM: OMAP1: Remove dma.h
ARM: OMAP1: Remove legacy irda.h and irda setup from board files
ARM: OMAP1: Remove duplicated DMA channel definitions
ARM: OMAP1: Remove McBSP DMA channel definitions
ARM: OMAP2+: Remove dma.h
ARM: OMAP2+: hwmod: Remove remaining DMA channel definitions
ARM: OMAP2+: Remove duplicated DMA channel definitions
ARM: OMAP2+: Remove AES crypto device DMA channel definitions
Fix memory leaks in the error path.
Also, use platform_device_register_full() to allocate
the platform devices and set platform data.
This is no longer needed as omap4 is now booted
using device tree.
This helper allows board support code to add the PHY's
VCC and RESET regulators which are GPIO controlled as well
as the NOP PHY device.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/soc
These changes contain the OMAP USB related platform data changes
that were dropped from linux next because of the merge conflicts
as requested by me and Olof. The reason was that at this point
we really should be able to do the arch/arm related changes
separately from driver changes to avoid dependencies between
branches.
These patches were initially part of the USB related MFD patches.
Based on our comments, Roger Quadros quickly reworked these
patches into a shared branch between ARM SoC tree and the MFD
tree, then separate patches for the OMAP platform data and
MFD driver.
Note that this branch will conflict with c1d1cd597fc7
("ARM: OMAP2+: omap_device: remove obsolete pm_lats and
early_device code"). Please see http://lkml.org/lkml/2013/2/11/16
for the merge resolution.
[arnd - resolved the merge conflict]
Let's have a single platform data structure for the OMAP's High-Speed
USB host subsystem instead of having 3 separate ones i.e. one for
board data, one for USB Host (UHH) module and one for USB-TLL module.
This makes the code much simpler and avoids creating multiple copies of
platform data.
Reviewed-by: Felipe Balbi <balbi@ti.com>
Remove now-obsolete code from arch/arm/mach-omap2/omap_device.c. This
mostly consists of removing the first attempt at device PM latency
handling. This was never really used, has been replaced by the common
dev_pm_qos code, and needs to go away as part of the DT conversion.
Also, the early platform_device creation code has been removed, as it
appears to be unused.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Instead of using cpu_is_omap..() macros in the device driver we
rely on information provided in the platform data.
The only information we need is whether the USB Host module has
a single ULPI bypass control bit for all ports or individual bypass
control bits for each port. OMAP3 REV2.1 and earlier have the former.
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
[tony@atomide.com: updated to remove plat/cpu.h]
Conflicts resolved same as Tony did in his later dependent branch:
arch/arm/mach-omap1/clock.c
arch/arm/mach-omap2/board-2430sdp.c
arch/arm/mach-omap2/board-4430sdp.c
arch/arm/mach-omap2/board-cm-t35.c
arch/arm/mach-omap2/board-igep0020.c
arch/arm/mach-omap2/board-ldp.c
arch/arm/mach-omap2/board-omap3beagle.c
arch/arm/mach-omap2/board-omap3logic.c
arch/arm/mach-omap2/board-omap4panda.c
arch/arm/mach-omap2/board-overo.c
arch/arm/mach-omap2/board-rm680.c
arch/arm/mach-omap2/board-rx51.c
arch/arm/mach-omap2/twl-common.c
arch/arm/mach-omap2/usb-host.c
arch/arm/mach-omap2/usb-musb.c
Let's move what we can from plat/usb.h to the local usb.h
for ARM common zImage support.
This is needed so we can remove plat/usb.h for ARM common
zImage support.
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Partha Basak <parthab@india.ti.com>
Cc: Keshava Munegowda <keshava_mgowda@ti.com>
Cc: linux-usb@vger.kernel.org
Acked-by: Felipe Balbi <balbi@ti.com>
We want to remove plat/cpu.h. To do this, let's first split
it to private soc.h to mach-omap1 and mach-omap2. We have to
keep plat/cpu.h around until the remaining drivers are fixed,
so let's include the local soc.h in plat/cpu.h and for drivers
still including plat/cpu.h.
Once the drivers are fixed not to include plat/cpu.h, we
can remove the file.
This is needed for the ARM common zImage support.
[tony@atomide.com: updated to not print a warning]
Let's make omap_device local to mach-omap2 for
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFD changes from Samuel Ortiz:
"MFD bits for the 3.7 merge window.
As usual we have a few new drivers:
- TI LP8788
- TI OMAP USB TLL
- Maxim MAX8907
- SMSC ECE1099
- Dialog Semiconductor DA9055
- A simpler syscon driver that allow us to get rid of the anatop one.
Drivers are also gradually getting Device Tree and IRQ domain support.
The following drivers got DT support:
- palmas, 88pm860x, tc3589x and twl4030-audio
And those ones now use the IRQ domain APIs:
- 88pm860x, tc3589x, db8500_prcmu
Also some other interesting changes:
- Intel's ICH LPC now supports Lynx Point
- TI's twl4030-audio added a GPO child
- tps6527 enabled its backlight subdevice
- The twl6030 pwm driver moved to the new PWM subsystem
And finally a bunch of cleanup and casual fixes for mc13xxx, 88pm860x,
palmas, ab8500, wm8994, wm5110, max8907 and the tps65xxx family."
Fix up various annoying conflicts: the DT and IRQ domain support came in
twice and was already in 3.6. And then it was apparently rebased.
Guys, DON'T REBASE!
* tag 'mfd-3.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (89 commits)
ARM: dts: Enable 88pm860x pmic
mfd: 88pm860x: Move gpadc init into touch
mfd: 88pm860x: Device tree support
mfd: 88pm860x: Use irqdomain
mfd: smsc: Add support for smsc gpio io/keypad driver
backlight: tps65217_bl: Add missing platform_set_drvdata in tps65217_bl_probe
mfd: DA9055 core driver
mfd: tps65910: Add alarm interrupt of TPS65910 RTC to mfd device list
mfd: wm5110: Add register patches for revision B
mfd: wm5110: Disable control interface error report for WM5110 rev B
mfd: max8907: Remove regulator-compatible from DT docs
backlight: Add TPS65217 WLED driver
mfd: Add backlight as subdevice to the tps65217
mfd: Provide the PRCMU with its own IRQ domain
mfd: Fix max8907 sparse warning
mfd: Add lp8788 mfd driver
mfd: dbx500: Provide a more accurate smp_twd clock
mfd: rc5t583: Fix warning messages
regulator: palmas: Add DT support
mfd: palmas: Change regulator defns to better suite DT
The TLL specific code such as channels clocks enable/disable,
initialization functions are removed from the USBHS core
driver. The hwmod of the usb tll is retrieved and omap device
build is performed to created the platform device for the
usb tll component.
Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com>
Reviewed-by: Partha Basak <parthab@india.ti.com>
As the plat and mach includes need to disappear for single zImage work,
we need to remove plat/hardware.h.
Do this by splitting plat/hardware.h into omap1 and omap2+ specific files.
The old plat/hardware.h already has omap1 only defines, so it gets moved
to mach/hardware.h for omap1. For omap2+, we use the local soc.h
that for now just includes the related SoC headers to keep this patch more
readable.
Note that the local soc.h still includes plat/cpu.h that can be dealt
with in later patches. Let's also include plat/serial.h from common.h for
all the board-*.c files. This allows making the include files local later
on without patching these files again.
Note that only minimal changes are done in this patch for the
drivers/watchdog/omap_wdt.c driver to keep things compiling. Further
patches are needed to eventually remove cpu_is_omap usage in the drivers.
Also only minimal changes are done to sound/soc/omap/* to remove the
unneeded includes and to define OMAP44XX_MCPDM_L3_BASE locally so there's
no need to include omap44xx.h.
While at it, also sort some of the includes in the standard way.
Cc: linux-watchdog@vger.kernel.org
Cc: alsa-devel@alsa-project.org
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
Cc: Liam Girdwood <lrg@ti.com>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
As the interrupts should only be defined in the platform_data, and
eventually coming from device tree, there's no need to define them
in header files.
Let's remove the hardcoded references to irqs.h and fix up the includes
so we don't rely on headers included in irqs.h. Note that we're
defining OMAP_INTC_START as 0 to the interrupts. This will be needed
when we enable SPARSE_IRQ. For some drivers we need to add
#include <plat/cpu.h> for now until these drivers are fixed to
remove cpu_is_omapxxxx() usage.
While at it, sort som of the includes the standard way, and add
the trailing commas where they are missing in the related data
structures.
Note that for drivers/staging/tidspbridge we just define things
locally.
Cc: Paul Walmsley <paul@pwsan.com>
Fix the below section mismatch warning and alike:
WARNING: vmlinux.o(.text+0x281d4): Section mismatch in reference from
the function setup_ehci_io_mux() to the function
.init.text:omap_mux_init_signal()
The function setup_ehci_io_mux() references
the function __init omap_mux_init_signal().
This is often because setup_ehci_io_mux lacks a __init
annotation or the annotation of omap_mux_init_signal is wrong.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Reviewed-by: Shubhrajyoti D <shubhrajyoti@ti.com>
when commit 3528c58 (OMAP: omap_device: when
building return platform_device instead of
omap_device) started returning a platform_device
instead of a omap_device pointer when building
a device, it failed to convert all users introducing
a compile warning when building
arch/arm/mach-omap2/usb-host.c.
This patch fixes that warning.
The hwmod structure of usb_host_hs and usb_tll are
retrieved and registered with omap device
[paul@pwsan.com: this patch is merged with the understanding that the
authors will send patches for the next merge window to remove the
multiple hwmods-per-omap_device]
The prototype and defination of functions usb_ehci_init and
usb_ohci_init are removed. The ehci and ohci devices are
removed since usbhs device contains both ehci and ohci details.
A new usbhs platform device is defined;
this device will be the parent device of ehci and
ohci platform devices. the usbhs_init function
is defined which does the usbhs device initialization
and I/O mux of ehci and ohci.
Create the ehci and ohci specific platform data structures.
The port enum values are made common for both ehci and ohci.
We already have both EHCI and OHCI there, so let's
rename to be sure everybody will understand the entire
USB HOST functionality is setup on this file.
