path: root/arch/arm/mach-omap2/timer.c
2013-07-23Merge tag 'remove-local-timers' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm into next/cleanup From Stephen Boyd: Now that we have a generic arch hook for broadcast we can remove the local timer API entirely. Doing so will reduce code in ARM core, reduce the architecture dependencies of our timer drivers, and simplify the code because we no longer go through an architecture layer that is essentially a hotplug notifier. * tag 'remove-local-timers' of git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm: ARM: smp: Remove local timer API clocksource: time-armada-370-xp: Divorce from local timer API clocksource: time-armada-370-xp: Fix sparse warning ARM: msm: Divorce msm_timer from local timer API ARM: PRIMA2: Divorce timer-marco from local timer API ARM: EXYNOS4: Divorce mct from local timer API ARM: OMAP2+: Divorce from local timer API ARM: smp_twd: Divorce smp_twd from local timer API ARM: smp: Remove duplicate dummy timer implementation Resolved a large number of conflicts due to __cpuinit cleanups, etc. Signed-off-by: Olof Johansson <olof@lixom.net>
2013-07-13Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "This is our first set of fixes from arm-soc for 3.11. - A handful of build and warning fixes from Arnd - A collection of OMAP fixes - defconfig updates to make the default configs more useful for real use (and testing) out of the box on hardware And a couple of other small fixes. Some of these have been recently applied but it's normally how we deal with fixes, with less bake time in -next needed" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits) arm: multi_v7_defconfig: Tweaks for omap and sunxi arm: multi_v7_defconfig: add i.MX options and NFS root ARM: omap2: add select of TI_PRIV_EDMA ARM: exynos: select PM_GENERIC_DOMAINS only when used ARM: ixp4xx: avoid circular header dependency ARM: OMAP: omap_common_late_init may be unused ARM: sti: move DEBUG_STI_UART into alphabetical order ARM: OMAP: build mach-omap code only if needed ARM: zynq: use DT_MACHINE_START ARM: omap5: omap5 has SCU and TWD ARM: OMAP2+: omap2plus_defconfig: Enable appended DTB support ARM: OMAP2+: Enable TI_EDMA in omap2plus_defconfig ARM: OMAP2+: omap2plus_defconfig: enable DRA752 thermal support by default ARM: OMAP2+: omap2plus_defconfig: enable TI bandgap driver ARM: OMAP2+: devices: remove duplicated include from devices.c ARM: OMAP3: igep0020: Set DSS pins in correct mux mode. ARM: OMAP2+: N900: enable N900-specific drivers even if device tree is enabled ARM: OMAP2+: Cocci spatch "ptr_ret.spatch" ARM: OMAP2+: Remove obsolete Makefile line ARM: OMAP5: Enable Cortex A15 errata 798181 ...
2013-07-06Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer core updates from Thomas Gleixner: "The timer changes contain: - posix timer code consolidation and fixes for odd corner cases - sched_clock implementation moved from ARM to core code to avoid duplication by other architectures - alarm timer updates - clocksource and clockevents unregistration facilities - clocksource/events support for new hardware - precise nanoseconds RTC readout (Xen feature) - generic support for Xen suspend/resume oddities - the usual lot of fixes and cleanups all over the place The parts which touch other areas (ARM/XEN) have been coordinated with the relevant maintainers. Though this results in an handful of trivial to solve merge conflicts, which we preferred over nasty cross tree merge dependencies. The patches which have been committed in the last few days are bug fixes plus the posix timer lot. The latter was in akpms queue and next for quite some time; they just got forgotten and Frederic collected them last minute." * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (59 commits) hrtimer: Remove unused variable hrtimers: Move SMP function call to thread context clocksource: Reselect clocksource when watchdog validated high-res capability posix-cpu-timers: don't account cpu timer after stopped thread runtime accounting posix_timers: fix racy timer delta caching on task exit posix-timers: correctly get dying task time sample in posix_cpu_timer_schedule() selftests: add basic posix timers selftests posix_cpu_timers: consolidate expired timers check posix_cpu_timers: consolidate timer list cleanups posix_cpu_timer: consolidate expiry time type tick: Sanitize broadcast control logic tick: Prevent uncontrolled switch to oneshot mode tick: Make oneshot broadcast robust vs. CPU offlining x86: xen: Sync the CMOS RTC as well as the Xen wallclock x86: xen: Sync the wallclock when the system time is set timekeeping: Indicate that clock was set in the pvclock gtod notifier timekeeping: Pass flags instead of multiple bools to timekeeping_update() xen: Remove clock_was_set() call in the resume path hrtimers: Support resuming with two or more CPUs online (but stopped) timer: Fix jiffies wrap behavior of round_jiffies_common() ...
2013-07-04ARM: OMAP2+: timer: initialize before using oh_nameAfzal Mohammed
of_property_read_string_index(...,&oh_name) in omap_dm_timer_init_one does not alter the value of 'oh_name' even if the relevant function fails and as 'oh_name' in stack may have a non-zero value, it would be misunderstood by timer code that DT has specified "ti,hwmod" property for timer. 'oh_name' in this scenario would be a junk value, this would result in module not being enabled by hwmod API's for timer, and in turn crash. Signed-off-by: Afzal Mohammed <afzal@ti.com> Acked-by: Jon Hunter <jgchunter@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-06-24ARM: OMAP2+: Divorce from local timer APIStephen Boyd
Now that the TWD doesn't rely on the local timer API, OMAP can stop selecting it in Kconfig and relying on the config option to decide if it should call smp_twd functions. Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2013-06-13ARM: OMAP2+: AM43x: basic dt supportAfzal Mohammed
Describe minimal DT boot machine details for AM43x based SoC's. AM43x SoC's are ARM Cortex-A9 based with one core. AM43x is similar to AM335x w.r.t L4 PER/WKUP memory map. AM43x has a sync timer, here that is being used as clocksource, while 1ms dmtimer as clockevent. Signed-off-by: Ankur Kishore <a-kishore@ti.com> Signed-off-by: Afzal Mohammed <afzal@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-06-12sched_clock: Make ARM's sched_clock generic for all architecturesStephen Boyd
Nothing about the sched_clock implementation in the ARM port is specific to the architecture. Generalize the code so that other architectures can use it by selecting GENERIC_SCHED_CLOCK. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> [jstultz: Merge minor collisions with other patches in my tree] Signed-off-by: John Stultz <john.stultz@linaro.org>
2013-05-07arm: fix mismerge of arch/arm/mach-omap2/timer.cLinus Torvalds
I badly screwed up the merge in commit 6fa52ed33bea ("Merge tag 'drivers-for-linus' of git://git.kernel.org/pub/.../arm-soc") by incorrectly taking the arch/arm/mach-omap2/* data fully from the merge target because the 'drivers-for-linus' branch seemed to be a proper superset of the duplicate ARM commits. That was bogus: commit ff931c821bab ("ARM: OMAP: clocks: Delay clk inits atleast until slab is initialized") only existed in head, and the changes to arch/arm/mach-omap2/timer.c from that commit got list. Re-doing the merge more carefully, I do think this part was the only thing I screwed up. Knock wood. Reported-by: Tony Lindgren <tony@atomide.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Olof Johansson <olof@lixom.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07Merge tag 'cleanup-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late cleanups from Arnd Bergmann: "These are cleanups and smaller changes that either depend on earlier feature branches or came in late during the development cycle. We normally try to get all cleanups early, so these are the exceptions: - A follow-up on the clocksource reworks, hopefully the last time we need to merge clocksource subsystem changes through arm-soc. A first set of patches was part of the original 3.10 arm-soc cleanup series because of interdependencies with timer drivers now moved out of arch/arm. - Migrating the SPEAr13xx platform away from using auxdata for DMA channel descriptions towards using information in device tree, based on the earlier SPEAr multiplatform series - A few follow-ups on the Atmel SAMA5 support and other changes for Atmel at91 based on the larger at91 reworks. - Moving the armada irqchip implementation to drivers/irqchip - Several OMAP cleanups following up on the larger series already merged in 3.10." * tag 'cleanup-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits) ARM: OMAP4: change the device names in usb_bind_phy ARM: OMAP2+: Fix mismerge for timer.c between ff931c82 and da4a686a ARM: SPEAr: conditionalize SMP code ARM: arch_timer: Silence debug preempt warnings ARM: OMAP: remove unused variable serial: amba-pl011: fix !CONFIG_DMA_ENGINE case ata: arasan: remove the need for platform_data ARM: at91/sama5d34ek.dts: remove not needed compatibility string ARM: at91: dts: add MCI DMA support ARM: at91: dts: add i2c dma support ARM: at91: dts: set #dma-cells to the correct value ARM: at91: suspend both memory controllers on at91sam9263 irqchip: armada-370-xp: slightly cleanup irq controller driver irqchip: armada-370-xp: move IRQ handler to avoid forward declaration irqchip: move IRQ driver for Armada 370/XP ARM: mvebu: move L2 cache initialization in init_early() devtree: add binding documentation for sp804 ARM: integrator-cp: convert use CLKSRC_OF for timer init ARM: versatile: use OF init for sp804 timer ARM: versatile: add versatile dtbs to dtbs target ...
2013-05-07Merge tag 'dt-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device tree updates (part 2) from Arnd Bergmann: "These are mostly new device tree bindings for existing drivers, as well as changes to the device tree source files to add support for those devices, and a couple of new boards, most notably Samsung's Exynos5 based Chromebook. The changes depend on earlier platform specific updates and touch the usual platforms: omap, exynos, tegra, mxs, mvebu and davinci." * tag 'dt-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (169 commits) ARM: exynos: dts: cros5250: add EC device ARM: dts: Add sbs-battery for exynos5250-snow ARM: dts: Add i2c-arbitrator bus for exynos5250-snow ARM: dts: add mshc controller node for Exynos4x12 SoCs ARM: dts: Add chip-id controller node on Exynos4/5 SoC ARM: EXYNOS: Create virtual I/O mapping for Chip-ID controller using device tree ARM: davinci: da850-evm: add SPI flash support ARM: davinci: da850: override SPI DT node device name ARM: davinci: da850: add SPI1 DT node spi/davinci: add DT binding documentation spi/davinci: no wildcards in DT compatible property ARM: dts: mvebu: Convert mvebu device tree files to 64 bits ARM: dts: mvebu: introduce internal-regs node ARM: dts: mvebu: Convert all the mvebu files to use the range property ARM: dts: mvebu: move all peripherals inside soc ARM: dts: mvebu: fix cpus section indentation ARM: davinci: da850: add EHRPWM & ECAP DT node ARM/dts: OMAP3: fix pinctrl-single configuration ARM: dts: Add OMAP3430 SDP NOR flash memory binding ARM: dts: Add NOR flash bindings for OMAP2420 H4 ...
2013-05-06Merge branch 'late/clksrc' into late/cleanupArnd Bergmann
There is no reason to keep the clksrc cleanups separate from the other cleanups, and this resolves some merge conflicts. Conflicts: arch/arm/mach-spear/spear13xx.c drivers/irqchip/Makefile
2013-05-06Merge branch 'late/dt' into next/dt2Arnd Bergmann
This is support for the ARM Chromebook, originally scheduled as a "late" pull request. Since it's already late now, we can combine this into the existing next/dt2 branch. * late/dt: ARM: exynos: dts: cros5250: add EC device ARM: dts: Add sbs-battery for exynos5250-snow ARM: dts: Add i2c-arbitrator bus for exynos5250-snow ARM: dts: Add chip-id controller node on Exynos4/5 SoC ARM: EXYNOS: Create virtual I/O mapping for Chip-ID controller using device tree
2013-04-23ARM: OMAP: remove unused variableArnd Bergmann
Commit 0583fe478a7 "ARM: convert arm/arm64 arch timer to use CLKSRC_OF init" has left the omap5_realtime_timer_init() function with a stale variable and broken whitespace. This fixes both. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-04-19Merge branch 'omap/fixes-non-critical' into late/cleanupOlof Johansson
* omap/fixes-non-critical: ARM: OMAP2+: fix typo "CONFIG_BRIDGE_DVFS" ARM: OMAP1: remove "config MACH_OMAP_HTCWIZARD" ARM: OMAP: dpll: enable bypass clock only when attempting dpll bypass ARM: OMAP2+: powerdomain: avoid testing whether an unsigned char is less than 0 ARM: OMAP2+: hwmod: Remove unused _HWMOD_WAKEUP_ENABLED flag ARM: OMAP2+: am335x: Change the wdt1 func clk src to per_32k clk ARM: OMAP2+: AM33xx: hwmod: Add missing sysc definition to wdt1 entry ARM: OMAP: fix typo "CONFIG_SMC91x_MODULE" ARM: OMAP5: clock: No Freqsel on OMAP5 devices too ARM: OMAP5: Make errata i688 workaround available ARM: OMAP5: Update SAR memory layout for WakeupGen ARM: OMAP5: Update SAR RAM base address ARM: OMAP5: Reuse prm read_inst/write_inst ARM: OMAP5: prm: Allow prm init to succeed ARM: OMAP5: timer: Update the clocksource name as per clock data ARM: OMAP5: Update SOC id detection code for ES2
2013-04-17Merge tag 'clksrc-cleanup-for-3.10-part2' of ↵Olof Johansson
git://sources.calxeda.com/kernel/linux into late/clksrc This is the 2nd part of ARM timer clean-ups for 3.10. This series has the following changes: - Add sched_clock selection logic to select the highest frequency clock - Use full 64-bit arch timer counter for sched_clock - Convert arch timer, sp804 and integrator-cp timers to CLKSRC_OF and adapt all users to use clocksource_of_init * tag 'clksrc-cleanup-for-3.10-part2' of git://sources.calxeda.com/kernel/linux: devtree: add binding documentation for sp804 ARM: integrator-cp: convert use CLKSRC_OF for timer init ARM: versatile: use OF init for sp804 timer ARM: versatile: add versatile dtbs to dtbs target ARM: vexpress: remove extra timer-sp control register clearing ARM: dts: vexpress: disable CA9 core tile sp804 timer ARM: vexpress: remove sp804 OF init ARM: highbank: use OF init for sp804 timer ARM: timer-sp: convert to use CLKSRC_OF init OF: add empty of_device_is_available for !OF ARM: convert arm/arm64 arch timer to use CLKSRC_OF init ARM: make machine_desc->init_time default to clocksource_of_init ARM: arch_timer: use full 64-bit counter for sched_clock ARM: make sched_clock just call a function pointer ARM: sched_clock: allow changing to higher frequency counter Signed-off-by: Olof Johansson <olof@lixom.net> This has a nasty set of conflicts with the exynos MCT code, which was moved in a separate branch, and then fixed up when merged in, but still conflicts a bit here. It should have been sorted out by this merge though.
2013-04-11ARM: convert arm/arm64 arch timer to use CLKSRC_OF initRob Herring
This converts arm and arm64 to use CLKSRC_OF DT based initialization for the arch timer. A new function arch_timer_arch_init is added to allow for arch specific setup. This has a side effect of enabling sched_clock on omap5 and exynos5. There should not be any reason not to use the arch timers for sched_clock. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Simon Horman <horms@verge.net.au> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-samsung-soc@vger.kernel.org Cc: linux-omap@vger.kernel.org Cc: linux-sh@vger.kernel.org Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2013-04-11Merge tag 'omap-for-v3.10/dt-signed-v2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt2 From Tony Lindgren: Device tree updates for omaps via Benoit Cousson <b-cousson@ti.com>. Note that the branch has dependencies to two other branches: - omap-devel-b-for-3.10 from Paul to get the AM33xx missing hwmod and thus avoid a regression with Santosh's hwmod cleanup including in this DT series [1]. It avoids breaking bisect if this series is merged before Paul's fixes. - omap-for-v3.10/usb branch to avoid nasty merge conflict in omap3.dtsi and omap4.dtsi due to the DTS patches contained in the USB branch because of a screw up by the unnamed person typing this signed tag based on Benoit's comments. [1] https://patchwork.kernel.org/patch/2366291/ * tag 'omap-for-v3.10/dt-signed-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (69 commits) ARM/dts: OMAP3: fix pinctrl-single configuration ARM: dts: Add OMAP3430 SDP NOR flash memory binding ARM: dts: Add NOR flash bindings for OMAP2420 H4 ARM: dts: Update OMAP3430 SDP NAND and ONENAND properties ARM: dts: OMAP2+: Identify GPIO banks that are always powered ARM: OMAP2+: Populate DMTIMER errata when using device-tree ARM: dts: OMAP2+: Update DMTIMER compatibility property ARM: OMAP: Add function to request timer by node ARM: OMAP: Force dmtimer restore if context loss is not detectable ARM: OMAP: Simplify dmtimer context-loss handling ARM: dts: AM33XX: Corrects typo in interrupt field in SPI node ARM: dts: OMAP4460: Add CPU OPP table ARM: dts: omap4-panda: move generic sections to panda-common ARM: dts: OMAP443x: Add CPU OPP table ARM: dts: OMAP3: use twl4030 vdd1 regulator for CPU ARM: dts: OMAP36xx: Add CPU OPP table ARM: dts: OMAP34xx/35xx: Add CPU OPP table Documentation: dt: gpio-omap: Move interrupt-controller from #interrupt-cells description ARM: OMAP2+: hwmod: Don't call _init_mpu_rt_base if no sysc ARM: OMAP2+: hwmod: extract module address space from DT blob ... Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-11Merge branch 'omap/fixes-non-critical' into next/dt2Olof Johansson
Merging in dependencies for the omap/dt branch. * omap/fixes-non-critical: ARM: OMAP2+: fix typo "CONFIG_BRIDGE_DVFS" ARM: OMAP1: remove "config MACH_OMAP_HTCWIZARD" ARM: OMAP: dpll: enable bypass clock only when attempting dpll bypass ARM: OMAP2+: powerdomain: avoid testing whether an unsigned char is less than 0 ARM: OMAP2+: hwmod: Remove unused _HWMOD_WAKEUP_ENABLED flag ARM: OMAP2+: am335x: Change the wdt1 func clk src to per_32k clk ARM: OMAP2+: AM33xx: hwmod: Add missing sysc definition to wdt1 entry ARM: OMAP: fix typo "CONFIG_SMC91x_MODULE" ARM: OMAP5: clock: No Freqsel on OMAP5 devices too ARM: OMAP5: Make errata i688 workaround available ARM: OMAP5: Update SAR memory layout for WakeupGen ARM: OMAP5: Update SAR RAM base address ARM: OMAP5: Reuse prm read_inst/write_inst ARM: OMAP5: prm: Allow prm init to succeed ARM: OMAP5: timer: Update the clocksource name as per clock data ARM: OMAP5: Update SOC id detection code for ES2 Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-09ARM: dts: OMAP2+: Update DMTIMER compatibility propertyJon Hunter
Update the DMTIMER compatibility property to reflect the register level compatibilty between devices and update the various OMAP/AM timer bindings with the appropriate compatibility string. By doing this we can add platform specific data applicable to specific timer versions to the driver. For example, errata flags can be populated for the timer versions that are impacted. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-08Merge tag 'omap-for-v3.10/timer-signed' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/drivers From Tony Lindgren <tony@atomide.com>: Clean-up for omap2+ timers from Jon Hunter <jon-hunter@ti.com>: This series consists mainly of clean-ups for clockevents and clocksource timers on OMAP2+ devices. The most significant change in functionality comes from the 5th patch which is changing the selection of the clocksource timer for OMAP3 and AM335x devices when gptimers are used for clocksource. Note that this series depends on 7185684 (ARM: OMAP: use consistent error checking) in RMK's tree and 960cba6 (ARM: OMAP5: timer: Update the clocksource name as per clock data) in omap-for-v3.10/fixes-non-critical. So this branch is based on a merge of 7185684 and omap-for-v3.10/fixes-non-critical to avoid non-trivial merge conflicts. * tag 'omap-for-v3.10/timer-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP4+: Fix sparse warning in system timers ARM: OMAP2+: Store ID of system timers in timer structure ARM: OMAP3: Update clocksource timer selection ARM: OMAP2+: Simplify system timers definitions ARM: OMAP2+: Simplify system timer clock definitions ARM: OMAP2+: Remove hard-coded test on timer ID ARM: OMAP2+: Display correct system timer name ARM: OMAP2+: fix typo "CONFIG_BRIDGE_DVFS" ARM: OMAP1: remove "config MACH_OMAP_HTCWIZARD" ARM: OMAP: dpll: enable bypass clock only when attempting dpll bypass ARM: OMAP2+: powerdomain: avoid testing whether an unsigned char is less than 0 ARM: OMAP2+: hwmod: Remove unused _HWMOD_WAKEUP_ENABLED flag ARM: OMAP2+: am335x: Change the wdt1 func clk src to per_32k clk ARM: OMAP2+: AM33xx: hwmod: Add missing sysc definition to wdt1 entry Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-04-03Merge branch 'omap-timer-for-v3.10' of git://github.com/jonhunter/linux into ↵Tony Lindgren
omap-for-v3.10/timer Conflicts: arch/arm/mach-omap2/timer.c
2013-04-03Merge commit '7185684' into omap-for-v3.10/timerTony Lindgren
Conflicts: arch/arm/plat-omap/dmtimer.c Resolve merge conflict in omap_device.c as per Lothar Waßmann <LW@KARO-electronics.de>.
2013-04-01ARM: OMAP4+: Fix sparse warning in system timersJon Hunter
Commit 6bb27d7 (ARM: delete struct sys_timer) changed the function created by the macro OMAP_SYS_32K_TIMER_INIT from static void to void. For OMAP4+ devices this created the following sparse warning ... arch/arm/mach-omap2/timer.c:585:1: warning: symbol 'omap4_sync32k_timer_init' was not declared. Should it be static? The function omap4_sync32k_timer_init() is not referenced outside of the file timer.c and so make this function static. Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2013-04-01ARM: OMAP2+: Store ID of system timers in timer structureJon Hunter
Currently, the timer ID is being passed to the function omap_dm_timer_init_one(). Instead of passing the ID separately, store it in the omap_dm_timer structure, that is also passed, and access the ID from this structure. Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2013-04-01ARM: OMAP3: Update clocksource timer selectionJon Hunter
When booting with device-tree for OMAP3 and AM335x devices and a gptimer is used as the clocksource (which is always the case for AM335x), a gptimer located in a power domain that is not always-on is selected. Ideally we should use a gptimer for clocksource that is located in a power domain that is always on (such as the wake-up domain) so that time can be maintained during a kernel suspend without keeping on additional power domains unnecessarily. In order to fix this so that we can select a gptimer located in a power domain that is always-on, the following changes were made ... 1. Currently, only when selecting a gptimer to use for a clockevent timer, do we pass a timer property that can be used to select a specific gptimer. Change this so that we can pass a property when selecting a gptimer to use for a clocksource timer too. 2. Currently, when selecting either a gptimer to use for a clockevent timer or a clocksource timer and no timer property is passed, then the first available timer is selected regardless of the properties it has. Change this so that if no properties are passed, then a timer that does not have additional features (such as always-on, dsp-irq, pwm, and secure) is selected. For OMAP3 and AM335x devices that use a gptimer for clocksource, change the selection of the gptimer so that by default the gptimer located in the always-on power domain is used for clocksource instead of clockevents. Please note that using a gptimer for both clocksource and clockevents can have a system power impact during idle. The reason being is that OMAP and AMxxx devices typically only have one gptimer in a power domain that is always-on. Therefore when the kernel is idle both the clocksource and clockevent timers will be active and this will keep additional power domains on. During kernel suspend, only the clocksource timer is active and therefore, it is better to use a gptimer in a power domain that is always-on for clocksource. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-04-01ARM: OMAP2+: Simplify system timers definitionsJon Hunter
There is a lot of redundancy in the definitions for the various system timers for OMAP2+ devices. For example, the omap3_am33xx_gptimer_timer_init() function is the same as the omap3_gp_gptimer_timer_init() function and the function omap4_sync32k_timer_init() can be re-used for OMAP5 devices. Therefore, consolidate the definitions to simplify the code. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-04-01ARM: OMAP2+: Simplify system timer clock definitionsJon Hunter
In commit c59b537 (ARM: OMAP2+: Simplify dmtimer clock aliases), new clock aliases for dmtimers were added to simplify the code. These clock aliases can also be used when configuring the system timers and allow us to remove the current definitions, simplifying the code. Please note that for OMAP4/5 devices (unlike OMAP2/3 devices), there is no clock alias for "timer_sys_ck" with NULL as the device name. Therefore we still need to use the alias "sys_clkin_ck" for these devices. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2013-04-01ARM: OMAP2+: Remove hard-coded test on timer IDJon Hunter
Currently, when configuring the clock-events and clock-source timers for OMAP2+ devices, we check whether the timer ID is 12 before attempting to set the parent clock for the timer. This test was added for OMAP3 general purpose devices (no security features enabled) that a 12th timer available but unlike the other timers only has a single functional clock source. Calling clk_set_parent() for this 12th timer would always return an error because there is only one choice for a parent clock. Therefore, this hard-coded timer ID test was added. To avoid this timer ID test, simply check to see if the timer's current parent clock is the desired parent clock and only call clk_set_parent() if this is not the case. Also if clk_get() fails, then use PTR_ERR() to return the error code. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2013-04-01ARM: OMAP2+: Display correct system timer nameJon Hunter
Currently on boot, when displaying the name of the gptimer used for clockevents and clocksource timers, the timer ID is shown. However, when booting with device-tree, the timer ID is not used to select a gptimer but a timer property. Hence, it is possible that the timer selected when booting with device-tree does not match the ID shown. Therefore, instead display the HWMOD name of the gptimer and use the HWMOD name as the name of clockevent and clocksource timer (if a gptimer is used). Signed-off-by: Jon Hunter <jon-hunter@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2013-04-01Merge commit '6bb27d7349db51b50c40534710fe164ca0d58902' into ↵Jon Hunter
2013-03-26ARM: OMAP: clocks: Delay clk inits atleast until slab is initializedRajendra Nayak
clk inits on OMAP happen quite early, even before slab is available. The dependency comes from the fact that the timer init code starts to use clocks and hwmod and we need clocks to be initialized by then. There are various problems doing clk inits this early, one is, not being able to do dynamic clk registrations and hence the dependency on clk-private.h. The other is, inability to debug early kernel crashes without enabling DEBUG_LL and earlyprintk. Doing early clk init also exposed another instance of a kernel panic due to a BUG() when CONFIG_DEBUG_SLAB is enabled. [ 0.000000] Kernel BUG at c01174f8 [verbose debug info unavailable] [ 0.000000] Internal error: Oops - BUG: 0 [#1] SMP ARM [ 0.000000] Modules linked in: [ 0.000000] CPU: 0 Not tainted (3.9.0-rc1-12179-g72d48f9 #6) [ 0.000000] PC is at __kmalloc+0x1d4/0x248 [ 0.000000] LR is at __clk_init+0x2e0/0x364 [ 0.000000] pc : [<c01174f8>] lr : [<c0441f54>] psr: 600001d3 [ 0.000000] sp : c076ff28 ip : c065cefc fp : c0441f54 [ 0.000000] r10: 0000001c r9 : 000080d0 r8 : c076ffd4 [ 0.000000] r7 : c074b578 r6 : c0794d88 r5 : 00000040 r4 : 00000000 [ 0.000000] r3 : 00000000 r2 : c07cac70 r1 : 000080d0 r0 : 0000001c [ 0.000000] Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel [ 0.000000] Control: 10c53c7d Table: 8000404a DAC: 00000017 [ 0.000000] Process swapper (pid: 0, stack limit = 0xc076e240) [ 0.000000] Stack: (0xc076ff28 to 0xc0770000) [ 0.000000] ff20: 22222222 c0794ec8 c06546e8 00000000 00000040 c0794d88 [ 0.000000] ff40: c074b578 c076ffd4 c07951c8 c076e000 00000000 c0441f54 c074b578 c076ffd4 [ 0.000000] ff60: c0793828 00000040 c0794d88 c074b578 c076ffd4 c0776900 c076e000 c07272ac [ 0.000000] ff80: 2f800000 c074c968 c07f93d0 c0719780 c076ffa0 c076ff98 00000000 00000000 [ 0.000000] ffa0: 00000000 00000000 00000000 00000001 c074cd6c c077b1ec 8000406a c0715724 [ 0.000000] ffc0: 00000000 00000000 00000000 00000000 00000000 c074c968 10c53c7d c0776974 [ 0.000000] ffe0: c074cd6c c077b1ec 8000406a 411fc092 00000000 80008074 00000000 00000000 [ 0.000000] [<c01174f8>] (__kmalloc+0x1d4/0x248) from [<c0441f54>] (__clk_init+0x2e0/0x364) [ 0.000000] [<c0441f54>] (__clk_init+0x2e0/0x364) from [<c07272ac>] (omap4xxx_clk_init+0xbc/0x140) [ 0.000000] [<c07272ac>] (omap4xxx_clk_init+0xbc/0x140) from [<c0719780>] (setup_arch+0x15c/0x284) [ 0.000000] [<c0719780>] (setup_arch+0x15c/0x284) from [<c0715724>] (start_kernel+0x7c/0x334) [ 0.000000] [<c0715724>] (start_kernel+0x7c/0x334) from [<80008074>] (0x80008074) [ 0.000000] Code: e5883004 e1a00006 e28dd00c e8bd8ff0 (e7f001f2) [ 0.000000] ---[ end trace 1b75b31a2719ed1c ]--- [ 0.000000] Kernel panic - not syncing: Attempted to kill the idle task! It was a know issue, that slab allocations would fail when common clock core tries to cache parent pointers for mux clocks on OMAP, and hence a patch 'clk: Allow late cache allocation for clk->parents, commit 7975059d' was added to work this problem around. A BUG() within kmalloc() with CONFIG_DEBUG_SLAB enabled was completely overlooked causing this regression. More details on the issue reported can be found here, http://www.mail-archive.com/linux-omap@vger.kernel.org/msg85932.html With all these issues around clk inits happening way too early, it makes sense to at least move them to a point where dynamic memory allocations are possible. So move them to a point just before the timer code starts using clocks and hwmod. This should at least pave way for clk inits on OMAP moving to dynamic clock registrations instead of using the static macros defined in clk-private.h. The issue with kernel panic while CONFIG_DEBUG_SLAB is enabled was reported by Piotr Haber and Tony Lindgren and this patch fixes the reported issue as well. Reported-by: Piotr Haber <phaber@broadcom.com> Reported-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Mike Turquette <mturquette@linaro.org> Acked-by: Paul Walmsley <paul@pwsan.com> Cc: stable@vger.kernel.org # v3.8 Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-03-19ARM: OMAP5: timer: Update the clocksource name as per clock dataSantosh Shilimkar
OMAP5 clockdata has different sys clock node name. Fix the timer code to take care of it. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2013-03-13ARM: OMAP: use consistent error checkingRussell King
Consistently check errors using the usual method used in the kernel for much of its history. For instance: int gpmc_cs_set_timings(int cs, const struct gpmc_timings *t) { int div; div = gpmc_calc_divider(t->sync_clk); if (div < 0) return div; static int gpmc_set_async_mode(int cs, struct gpmc_timings *t) { ... return gpmc_cs_set_timings(cs, t); ..... ret = gpmc_set_async_mode(gpmc_onenand_data->cs, &t); if (IS_ERR_VALUE(ret)) return ret; So, gpmc_cs_set_timings() thinks any negative return value is an error, but where we check that in higher levels, only a limited range are errors... There is only _one_ use of IS_ERR_VALUE() in arch/arm which is really appropriate, and that is in arch/arm/include/asm/syscall.h: static inline long syscall_get_error(struct task_struct *task, struct pt_regs *regs) { unsigned long error = regs->ARM_r0; return IS_ERR_VALUE(error) ? error : 0; } because this function really does have to differentiate between error return values and addresses which look like negative numbers (eg, from mmap()). So, here's a patch to remove them from OMAP, except for the above. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-03-11ARM: smp_twd: convert to use CLKSRC_OF initRob Herring
Now that we have OF based init with CLKSRC_OF, convert smp_twd init function to use it and covert all callers of twd_local_timer_of_register. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Viresh Kumar <viresh.linux@gmail.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-omap@vger.kernel.org Cc: spear-devel@list.st.com Reviewed-by: Stephen Warren <swarren@nvidia.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-21Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC-specific updates from Arnd Bergmann: "This is a larger set of new functionality for the existing SoC families, including: - vt8500 gains support for new CPU cores, notably the Cortex-A9 based wm8850 - prima2 gains support for the "marco" SoC family, its SMP based cousin - tegra gains support for the new Tegra4 (Tegra114) family - socfpga now supports a newer version of the hardware including SMP - i.mx31 and bcm2835 are now using DT probing for their clocks - lots of updates for sh-mobile - OMAP updates for clocks, power management and USB - i.mx6q and tegra now support cpuidle - kirkwood now supports PCIe hot plugging - tegra clock support is updated - tegra USB PHY probing gets implemented diffently" * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (148 commits) ARM: prima2: remove duplicate v7_invalidate_l1 ARM: shmobile: r8a7779: Correct TMU clock support again ARM: prima2: fix __init section for cpu hotplug ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3) ARM: OMAP: Consolidate OMAP USB-HS platform data (part 1/3) arm: socfpga: Add SMP support for actual socfpga harware arm: Add v7_invalidate_l1 to cache-v7.S arm: socfpga: Add entries to enable make dtbs socfpga arm: socfpga: Add new device tree source for actual socfpga HW ARM: tegra: sort Kconfig selects for Tegra114 ARM: tegra: enable ARCH_REQUIRE_GPIOLIB for Tegra114 ARM: tegra: Fix build error w/ ARCH_TEGRA_114_SOC w/o ARCH_TEGRA_3x_SOC ARM: tegra: Fix build error for gic update ARM: tegra: remove empty tegra_smp_init_cpus() ARM: shmobile: Register ARM architected timer ARM: MARCO: fix the build issue due to gic-vic-to-irqchip move ARM: shmobile: r8a7779: Correct TMU clock support ARM: mxs_defconfig: Select CONFIG_DEVTMPFS_MOUNT ARM: mxs: decrease mxs_clockevent_device.min_delta_ns to 2 clock cycles ARM: mxs: use apbx bus clock to drive the timers on timrotv2 ...
2013-02-21Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform support from Arnd Bergmann: "Converting more ARM platforms to multiplatform support. This time, OMAP gets converted, which is a major step since this is by far the largest platform in terms of code size. The same thing happens to the vt8500 platform." * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: net: cwdavinci_cpdma: export symbols for cpsw remoteproc: omap: depend on OMAP_MBOX_FWK [media] davinci: do not include mach/hardware.h ARM: OMAP2+: Make sure files with omap initcalls include soc.h ARM: OMAP2+: Include soc.h to drm.c to fix compiling ARM: OMAP2+: Fix warning for hwspinlock omap_postcore_initcall ARM: multi_v7_defconfig: add ARCH_ZYNQ ARM: multi_v7_defconfig: remove unnecessary CONFIG_GPIOLIB arm: vt8500: Remove remaining mach includes arm: vt8500: Convert debug-macro.S to be multiplatform friendly arm: vt8500: Remove single platform Kconfig options ARM: OMAP2+: Remove now obsolete uncompress.h and debug-macro.S ARM: OMAP2+: Add minimal support for booting vexpress ARM: OMAP2+: Enable ARCH_MULTIPLATFORM support ARM: OMAP2+: Disable code that currently does not work with multiplaform ARM: OMAP2+: Add multiplatform debug_ll support ARM: OMAP: Fix dmaengine init for multiplatform ARM: OMAP: Fix i2c cmdline initcall for multiplatform ARM: OMAP2+: Use omap initcalls ARM: OMAP2+: Limit omap initcalls to omap only on multiplatform kernels
2013-02-21Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups from Arnd Bergmann: "A large number of cleanups, all over the platforms. This is dominated largely by the Samsung platforms (s3c, s5p, exynos) and a few of the others moving code out of arch/arm into more appropriate subsystems. The clocksource and irqchip drivers are now abstracted to the point where platforms that are already cleaned up do not need to even specify the driver they use, it can all get configured from the device tree as we do for normal device drivers. The clocksource changes basically touch every single platform in the process. We further clean up the use of platform specific header files here, with the goal of turning more of the platforms over to being "multiplatform" enabled, which implies that they cannot expose their headers to architecture independent code any more. It is expected that no functional changes are part of the cleanup. The overall reduction in total code lines is mostly the result of removing broken and obsolete code." * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits) ARM: mvebu: correct gated clock documentation ARM: kirkwood: add missing include for nsa310 ARM: exynos: move exynos4210-combiner to drivers/irqchip mfd: db8500-prcmu: update resource passing drivers/db8500-cpufreq: delete dangling include ARM: at91: remove NEOCORE 926 board sunxi: Cleanup the reset code and add meaningful registers defines ARM: S3C24XX: header mach/regs-mem.h local ARM: S3C24XX: header mach/regs-power.h local ARM: S3C24XX: header mach/regs-s3c2412-mem.h local ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/ ARM: S3C24XX: transform s3c2443 subirqs into new structure ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs ARM: S3C24XX: move s3c2443 irq code to irq.c ARM: S3C24XX: transform s3c2416 irqs into new structure ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs ARM: S3C24XX: move s3c2416 irq init to common irq code ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property ARM: S3C24XX: Move irq syscore-ops to irq-pm clocksource: always define CLOCKSOURCE_OF_DECLARE ...
2013-02-15Merge branch 'omap/multiplatform-fixes', tag 'v3.8-rc5' into next/multiplatformArnd Bergmann
The omap multiplatform support uncovered a bug in the cwdavinci_cpdma code and was missing two drivers that are enabled now but are not quite ready for multiplatform, as found by allyesconfig builds. There is also a conflict generated by automated merge in arch/arm/mach-omap2/drm.c between a bug fix that went into v3.8-rc5 and a different version of the same fix that went into the omap/multiplatform branch. This merge removes the extraneous #include that was causing build errors. * omap/multiplatform-fixes: net: cwdavinci_cpdma: export symbols for cpsw remoteproc: omap: depend on OMAP_MBOX_FWK [media] davinci: do not include mach/hardware.h Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-02-05Merge tag 'omap-for-v3.9/pm-signed' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/soc From Tony Lindgren: OMAP PM related updates via Paul Walmsley <paul@pwsan.com>: Remove some dead OMAP clock and device integration code and data. Also, clean up the way that the OMAP device integration code blocks WFI/WFE to use a consistent mechanism, controlled by a data flag. Several OMAP2+ power management fixes, optimizations, and cleanup. This series is a prerequisite for the functional powerdomain conversion series. * tag 'omap-for-v3.9/pm-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP2+: powerdomain: fix whitespace, improve flag comments ARM: OMAP2+: clockdomain: convert existing atomic usecounts into spinlock-protected shorts/ints ARM: OMAP2+: clockdomain: work on wkdep/sleepdep functions ARM: OMAP2xxx: CM: remove autodep handling ARM: OMAP2+: powerdomain/clockdomain: add a per-powerdomain spinlock ARM: OMAP2+: PM/powerdomain: move omap_set_pwrdm_state() to powerdomain code ARM: OMAP2: PM/powerdomain: drop unnecessary pwrdm_wait_transition() ARM: OMAP2xxx: PM: clean up some crufty powerstate programming code ARM: OMAP2+: clockdomain: add pwrdm_state_switch() call to clkdm_sleep() ARM: OMAP2+: powerdomain: fix powerdomain trace integration ARM: OMAP4: MPUSS PM: remove unnecessary shim functions for powerdomain control ARM: OMAP3xxx: CPUIdle: optimize __omap3_enter_idle() ARM: OMAP2420: hwmod data/PM: use hwmod to block WFI when I2C active ARM: OMAP2+: hwmod: add support for blocking WFI when a device is active ARM: OMAP3xxx: CPUIdle: simplify the PER next-state code ARM: OMAP2xxx: powerdomain: core powerdomain missing logic retention states ARM: OMAP2xxx: clock data: clean up unused null clocks ARM: OMAP4: clock/hwmod data: remove MODULEMODE entries in mux + gate combos ARM: OMAP4: clock/hwmod data: start to remove some IP block control "clocks" ARM: OMAP2+: omap_device: remove obsolete pm_lats and early_device code
2013-02-04Merge tag 'v3.8-rc6' into next/socOlof Johansson
Linux 3.8-rc6
2013-02-01ARM: OMAP2+: Fix selection of clockevent timer when using device-treeJon Hunter
Commit 9725f44 (ARM: OMAP: Add DT support for timer driver) added device-tree support for selecting a clockevent timer by property. However, the code is currently ignoring the property passed and selecting the first available timer found. Hence, for the OMAP3 beagle board timer-12 is not being selected as expected. Fix this problem by ensuring the timer property is passed to omap_get_timer_dt(). Signed-off-by: Jon Hunter <jon-hunter@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Vaibhav Bedia <vaibhav.bedia@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-01-27Merge tag 'v3.8-rc5' into next/cleanupOlof Johansson
Linux 3.8-rc5 Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-26ARM: OMAP2+: omap_device: remove obsolete pm_lats and early_device codePaul Walmsley
Remove now-obsolete code from arch/arm/mach-omap2/omap_device.c. This mostly consists of removing the first attempt at device PM latency handling. This was never really used, has been replaced by the common dev_pm_qos code, and needs to go away as part of the DT conversion. Also, the early platform_device creation code has been removed, as it appears to be unused. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com>
2013-01-21ARM: OMAP2+: DT node Timer iteration fixPantelis Antoniou
The iterator correctly handles of_node_put() calls. Remove it before continue'ing the loop. Without this patch you get the following with CONFIG_OF_DYNAMIC set: ERROR: Bad of_node_put() on /ocp/timer@44e31000! [<c001329c>] (unwind_backtrace+0x0/0xe0) from [<c03dd8f0>] (of_node_release+0x2c/0xa0)! [<c03dd8f0>] (of_node_release+0x2c/0xa0) from [<c03ddea0>] (of_find_matching_node_and_match+0x78/0x90)! [<c03ddea0>] (of_find_matching_node_and_match+0x78/0x90) from [<c06d349c>] (omap_get_timer_dt+0x78/0x90)! [<c06d349c>] (omap_get_timer_dt+0x78/0x90) from [<c06d3664>] (omap_dm_timer_init_one.clone.2+0x34/0x2bc)! [<c06d3664>] (omap_dm_timer_init_one.clone.2+0x34/0x2bc) from [<c06d3a2c>] (omap2_gptimer_clocksource_init.clone.4+0x24/0xa8)! [<c06d3a2c>] (omap2_gptimer_clocksource_init.clone.4+0x24/0xa8) from [<c06cca58>] (time_init+0x20/0x30)! [<c06cca58>] (time_init+0x20/0x30) from [<c06c9690>] (start_kernel+0x1a8/0x2fc)! Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com> Acked-by: Jon Hunter <jon-hunter@ti.com> [tony@atomide.com: updated description per Jon] Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-01-14Merge branch 'clocksource/cleanup' into next/cleanupOlof Johansson
Clockevent cleanup series from Shawn Guo. Resolved move/change conflict in mach-pxa/time.c due to the sys_timer cleanup. * clocksource/cleanup: clocksource: use clockevents_config_and_register() where possible ARM: use clockevents_config_and_register() where possible clockevents: export clockevents_config_and_register for module use + sync to Linux 3.8-rc3 Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-pxa/time.c
2013-01-14ARM: use clockevents_config_and_register() where possibleShawn Guo
The clockevent core is able to figure out the best mult and shift, calculate min_delta_ns and max_delta_ns, with the necessary info passed into clockevents_config_and_register(). Use this combined configure and register function where possible to make the codes less error prone and gain some positive diff stat. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Jason Cooper <jason@lakedaemon.net> Tested-by: Roland Stigge <stigge@antcom.de> Acked-by: Eric Miao <eric.y.miao@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: David Brown <davidb@codeaurora.org> Tested-by: Tony Lindgren <tony@atomide.com> Acked-by: Barry Song <baohua.song@csr.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jason Cooper <jason@lakedaemon.net> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-11ARM: OMAP2+: Use omap initcallsTony Lindgren
This way the initcalls don't run on other SoCs on multiplatform kernels. Otherwise we'll get something like this when booting on vexpress: omap_hwmod: _ensure_mpu_hwmod_is_setup: MPU initiator hwmod mpu not yet registered ... WARNING: at arch/arm/mach-omap2/pm.c:82 _init_omap_device+0x74/0x94() _init_omap_device: could not find omap_hwmod for mpu ... omap-dma-engine omap-dma-engine: OMAP DMA engine driver ... Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-20ARM: OMAP2+: Fix compillation error in mach-omap2/timer.cPeter Ujfalusi
prom_add_property() has been renamed to of_add_property() This patch fixes the following comilation error: arch/arm/mach-omap2/timer.c: In function ‘omap_get_timer_dt’: arch/arm/mach-omap2/timer.c:178:3: error: implicit declaration of function ‘prom_add_property’ [-Werror=implicit-function-declaration] cc1: some warnings being treated as errors make[1]: *** [arch/arm/mach-omap2/timer.o] Error 1 make[1]: *** Waiting for unfinished jobs.... Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-12-14ARM: OMAP2+: Fix sparse warnings in timer.cVaibhav Hiremath
Sparse generates the following warnings when compiling mach-omap2/timer.c. CHECK arch/arm/mach-omap2/timer.c arch/arm/mach-omap2/timer.c:193:13: warning: symbol 'omap_dmtimer_init' was not declared. Should it be static? arch/arm/mach-omap2/timer.c:213:12: warning: symbol 'omap_dm_timer_get_errata' was not declared. Should it be static? Add static to function declaration to fix warnings. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Jon Hunter <jon-hunter@ti.com>
