path: root/arch/arm/mach-omap2/smartreflex.c
2011-01-31OMAP: PM: SmartReflex: Fix possible null pointer read accessStefan Weil
These errors were found by cppcheck: arch/arm/mach-omap2/smartreflex.c:784: error: Possible null pointer dereference: sr_info arch/arm/mach-omap2/smartreflex.c:799: error: Possible null pointer dereference: sr_info Both conditional statements are executed when sr_info == NULL, so accessing sr_info->voltdm would fail. Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-omap@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-01-31OMAP: PM: SmartReflex: Fix possible memory leakStefan Weil
sr_info was allocated and needs a kfree before returning. This error was reported by cppcheck: arch/arm/mach-omap2/smartreflex.c:837: error: Memory leak: sr_info To: Tony Lindgren <tony@atomide.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-omap@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Acked-by: Shweta Gulati <shweta.gulati@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-01-24OMAP: PM: SmartReflex: Add missing IS_ERR testJulia Lawall
Function _sr_lookup, defined in the same file, returns ERR_PTR not NULL in an error case. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier f; @@ f(...) { ... return ERR_PTR(...); } @@ identifier r.f, fld; expression x; statement S1,S2; @@ x = f(...) ... when != IS_ERR(x) ( if (IS_ERR(x) ||...) S1 else S2 | *x->fld ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Kevin Hilman <khilman@ti.com>
2010-12-22OMAP4: Smartreflex framework extensionsThara Gopinath
This patch extends the smartreflex framework to support OMAP4. The changes are minor like compiling smartreflex Kconfig option for OMAP4 also, and a couple of OMAP4 checks in the smartreflex framework. The change in sr_device.c where new logic has to be introduced for reading the efuse registers is due to the fact that in OMAP4 the efuse registers are 24 bit aligned. A __raw_readl will fail for non-32 bit aligned address and hence the 8-bit read and shift. Signed-off-by: Thara Gopinath <thara@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-22OMAP3: PM: Adding debug support to Voltage and Smartreflex driversThara Gopinath
This patch adds debug support to the voltage and smartreflex drivers. This means a whole bunch of voltage processor and smartreflex parameters are now visible through the pm debugfs. The voltage parameters can be viewed at /debug/voltage/vdd_<x>/<parameter> and the smartreflex parameters can be viewed at /debug/voltage/vdd_<x>/smartreflex/<parameter> Also smartreflex n-target values are now exposed out at /debug/voltage/vdd_<x>/smartreflex/nvalue/<voltage> This is a read-write interface which means user has the flexibility to change the n-target values for any opp. Signed-off-by: Thara Gopinath <thara@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-22OMAP3: PM: Adding smartreflex driver support.Thara Gopinath
SmartReflex modules do adaptive voltage control for real-time voltage adjustments. With Smartreflex the power supply voltage can be adapted to the silicon performance(manufacturing process, temperature induced performance, age induced performance etc). There are differnet classes of smartreflex implementation. Class-0: Manufacturing Test Calibration Class-1: Boot-Time Software Calibration Class-2: Continuous Software Calibration Class-3: Continuous Hardware Calibration Class-4: Fully Integrated Power Management OMAP3 has two smartreflex modules one associated with VDD MPU and the other associated with VDD CORE. This patch adds support for smartreflex driver. The driver is designed for Class-1 , Class-2 and Class-3 support and is a platform driver. Smartreflex driver can be enabled through a Kconfig option "SmartReflex support" under "System type"->"TI OMAP implementations" menu. Smartreflex autocompensation feature can be enabled runtime through a debug fs option. To enable smartreflex autocompensation feature echo 1 > /debug/voltage/vdd_<X>/smartreflex/autocomp To disable smartreflex autocompensation feature echo 0 > /debug/voltage/vdd_<X>/smartreflex/autocomp where X can be mpu, core , iva etc. This patch contains code originally in linux omap pm branch. Major contributors to this driver are Lesly A M, Rajendra Nayak, Kalle Jokiniemi, Paul Walmsley, Nishant Menon, Kevin Hilman. Signed-off-by: Thara Gopinath <thara@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
