path: root/arch/arm/mach-omap2/prm3xxx.c
2014-05-16Merge tag 'for-v3.16/prcm-cleanup-a' of ↵Tony Lindgren
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into omap-for-v3.16/prcm Some OMAP PRCM cleanup patches. These help prepare to convert the PRCM code into drivers. Basic build, boot, and PM test results are available here: http://www.pwsan.com/omap/testlogs/prcm-cleanup-v3.16/20140515213244/ Conflicts: arch/arm/mach-omap2/cm3xxx.c arch/arm/mach-omap2/cm44xx.c Also fixed up new section mismatch warnings.
2014-05-15ARM: OMAP3/4: PRM: add support of late_init call to prm_ll_opsTero Kristo
SoC specific late_init call is now registered during PRM init, and will be called automatically by PRM core. This helps to get rid of some redundant initcalls and cpu_is_X checks from the PRM code. Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2014-05-15ARM: OMAP3/OMAP4: PRM: add prm_features flags and add IO wakeup under itTero Kristo
prm_features flag will contain SoC specific feature enabler flags. Initially IO wakeup is added under this. Helps to get rid of runtime cpu_is_X checks. Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2014-05-15ARM: OMAP3/4: PRM: provide io chain reconfig function through irq setupTero Kristo
This helps to make the PRM registration modular, and also gets rid of a cpu type check done later. Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2014-05-15ARM: OMAP2+: PRM: remove unnecessary cpu_is_XXX calls from prm_init / exitTero Kristo
Done in preparation to make PRM its own driver, as the cpu_is_XXX calls are not available outside mach-omap2 folder. The init functions are called only from cpu specific init chain, and thus don't need to double check against cpu type. The exit calls check against the data provided during init-time registration and thus don't need cpu check either. Signed-off-by: Tero Kristo <t-kristo@ti.com> [paul@pwsan.com: updated to apply] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-01-11ARM: OMAP2+: Use omap initcallsTony Lindgren
This way the initcalls don't run on other SoCs on multiplatform kernels. Otherwise we'll get something like this when booting on vexpress: omap_hwmod: _ensure_mpu_hwmod_is_setup: MPU initiator hwmod mpu not yet registered ... WARNING: at arch/arm/mach-omap2/pm.c:82 _init_omap_device+0x74/0x94() _init_omap_device: could not find omap_hwmod for mpu ... omap-dma-engine omap-dma-engine: OMAP DMA engine driver ... Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-01-03Merge tag 'omap-fixes-a2-for-v3.8-rc' of ↵Tony Lindgren
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into omap-for-v3.8-rc2/fixes Some OMAP PRCM and sparse fixes against v3.8-rc1. A basic set of test logs are available here: http://www.pwsan.com/omap/testlogs/prcm_fixes_b_3.8-rc/20130102120724/ The 3730 Beagle XM here has an intermittent failure mounting SD root, but the suspicion right now is that this is due to a failing SD card, rather than any change introduced by these patches. This second version includes a few changes requested by Tony Lindgren.
2013-01-02ARM: OMAP2/3: PRM: fix bogus OMAP2xxx powerstate return valuesPaul Walmsley
On OMAP2xxx chips, the register bitfields for the PM_PWSTCTRL_*.POWERSTATE and PM_PWSTST_*.LASTSTATEENTERED are different than those used on OMAP3/4. The order is reversed. So, for example, on OMAP2xxx, 0x0 indicates 'ON'; but on OMAP3/4, 0x0 indicates 'OFF'. Similarly, on OMAP2xxx, 0x3 indicates 'OFF', but on OMAP3/4, 0x3 indicates 'ON'. To fix this, we treat the OMAP3/4 values as the powerdomain API values, and create new low-level powerdomain functions for the OMAP2xxx chips which translate between the OMAP2xxx values and the OMAP3/4 values. Without this patch, the conversion of the OMAP2xxx PM code to the functional powerstate code results in a non-booting kernel. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-12-17ARM: OMAP2+: Drop plat/cpu.h for omap2plusTony Lindgren
The cpu_is_omap macros are now local to arch/arm/mach-omap2 in soc.h and plat/cpu.h can finally be dropped for omap2+. Thanks everybody for help with fixing the drivers. Note that we can now also remove the unused plat/cpu.h from smartreflex.c and isp.c as they will cause compile errors with ARCH_MULTIPLATFORM enabled. Cc: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Jean Pihet <jean.pihet@newoldbits.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-11-21ARM: OMAP2+: PRM: initialize some PRM functions earlyPaul Walmsley
Some PRM functions will need to be called by the hwmod code early in kernel init. To handle this, split the PRM initialization code into early and late phases. The early init is handled via mach-omap2/io.c, while the late init is handled by subsys_initcall(). Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-11-08ARM: OMAP2+: PRCM: remove obsolete prcm.[ch]Paul Walmsley
arch/arm/mach-omap2/prcm.c and arch/arm/plat-omap/include/plat/prcm.h are now completely unused and can be removed. Signed-off-by: Paul Walmsley <paul@pwsan.com> Tested-by: Vaibhav Hiremath <hvaibhav@ti.com>
2012-11-08ARM: OMAP2/3: PRM: add SoC reset functions (using the CORE DPLL method)Paul Walmsley
Add SoC reset functions into the PRM code. These functions are based on code from mach-omap2/prcm.c. They reset the SoC using the CORE DPLL reset method (as opposed to one of the other two or three chip reset methods). Adding them here will facilitate their removal from arch/arm/mach-omap2/prcm.c. (prcm.c is deprecated.) Signed-off-by: Paul Walmsley <paul@pwsan.com> Tested-by: Vaibhav Hiremath <hvaibhav@ti.com>
2012-10-21ARM: OMAP2+: PRM: create PRM reset source API for the watchdog timer driverPaul Walmsley
The OMAP watchdog timer driver needs to determine what caused the SoC to reset for its GETBOOTSTATUS ioctl. So, define a set of standard reset sources across OMAP SoCs. For OMAP2xxx, 3xxx, and 4xxx SoCs, define mappings from the SoC-specific reset source register bits to the standardized reset source IDs. Create SoC-specific PRM functions that read the appropriate per-SoC register and use the mapping to return the standardized reset bits. Register the SoC-specific PRM functions with the common PRM code via prm_register(). Create a function in the common PRM code, prm_read_reset_sources(), that calls the SoC-specific function, registered during boot. This patch does not yet handle some SoCs, such as AM33xx. Those SoCs were not handled by the code this will replace. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-10-21ARM: OMAP2+: powerdomain/PRM: move the low-level powerdomain functions into PRMPaul Walmsley
Move the low-level SoC-specific powerdomain control functions into prm*.c. For example, OMAP2xxx low-level powerdomain functions go into prm2xxx.c. Then remove the unnecessary powerdomain*xxx*.c files. The objective is to centralize low-level PRM register accesses into the prm*.[ch] files, and then to export an OMAP SoC-independent API to higher-level OMAP power management code. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Rajendra Nayak <rnayak@ti.com> Reviewed-by: Russ Dill <Russ.Dill@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2012-10-21ARM: OMAP2+: PRM: split PRM functions into OMAP2, OMAP3-specific filesPaul Walmsley
Move OMAP3xxx-specific PRM functions & macros into prm3xxx.[ch] and OMAP2xxx-specific macros into prm2xxx.h. (prm2xxx.c will be created by a subsequent patch when it's needed.) Move basic PRM register access functions into static inline functions in prm2xxx_3xxx.h, leaving only OMAP2/3 hardreset functions in prm2xxx_3xxx.c. Also clarify the initcall function naming to reinforce that this code is specifically for the PRM IP block. This is in preparation for the upcoming powerdomain series and the upcoming move of this code to drivers/. Signed-off-by: Paul Walmsley <paul@pwsan.com> Reviewed-by: Russ Dill <Russ.Dill@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
