path: root/arch/arm/mach-omap2/prm.h
2010-05-20OMAP4: PRM: Remove MPU internal code name and apply PRCM naming conventionBenoit Cousson
The MPU subsystem was named based on internal code name (CHIRON). This patch will remove all the occurences of the chiron name are replace it with PRCM_MPU in order to differentiate the MPU local PRCM to the global one. Remove PDA_ from PRCM_MPU registers names to stick to the global PRM naming convention. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Rajendra Nayak <rnayak@ti.com>
2010-05-20OMAP2+ PRCM: convert remaining PRCM macros to the _SHIFT/_MASK suffixesPaul Walmsley
Fix all of the remaining PRCM register shift/bitmask macros that did not use the _SHIFT/_MASK suffixes to use them. This makes the use of these macros consistent. It is intended to reduce error, as code can be inspected visually by reviewers to ensure that bitshifts and bitmasks are used in the appropriate places. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com>
2010-01-26ARM: OMAP4: PM: OMAP4 Power Domain Porting Related Clean-up.Abhijit Pagare
Module offsets were same for OMAP2 and OMAP3 while they differ for OMAP4. Hence we need different macros for identifying platform specific offsets. Signed-off-by: Abhijit Pagare <abhijitpagare@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Rajendra Nayak <rnayak@ti.com>
2010-01-20OMAP4: PRCM: Fix the base address for CHIRONSS reg definesRajendra Nayak
The CHIRONSS has its own local PRCM module and the register defines need to use the CHIRONSS base and not the PRM base. The changes are generated by updating the script which autogenerates the file modifed in the patch. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-12-11ARM: OMAP4: PM: Adds PRM register defs for OMAP4Rajendra Nayak
This patch adds OMAP4 specific PRM register defs. Auto generated using a python script (gen_prm_4430_h.py) developed by Paul Walmsley and Benoit Cousson. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com>
2009-10-19omap: Split OMAP2_IO_ADDRESS to L3 and L4Santosh Shilimkar
This patch splits OMAP2_IO_ADDRESS to OMAP2_L3_IO_ADDRESS and OMAP2_L4_IO_ADDRESS to reclaim more IO space. The omap_read*() and omap_write*() functions will work only over L4 address space. Current omap kernel stack uses these functions only to access registers over L4 io address space Note that these macros should only be used when ioremap does not work. Please use ioremap instead in all new code. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-08-28OMAP: Remove OMAP_IO_ADDRESS, use OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS insteadTony Lindgren
Search and replace OMAP_IO_ADDRESS with OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS, and convert omap_read/write into a functions instead of a macros. Also rename OMAP_MPUIO_VBASE to OMAP1_MPUIO_VBASE. In the long run, most code should use ioremap + __raw_read/write instead. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-05-28OMAP3: PM: prevent module wakeups from waking IVA2Kevin Hilman
By default, prevent functional wakeups from inside a module from waking up the IVA2. Let DSP Bridge code handle this when loaded. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-25ARM: OMAP2/3: Remove OMAP_PRM_REGADDR and OMAP2_PRM_BASETony Lindgren
Remove OMAP_PRM_REGADDR and use processor specific defines instead. Also fold in a patch from Kevin Hilman to add _OFFSET #defines for the PRCM registers to be used with the prm_[read|write]_* macros. These are used extensively in the forthcoming OMAP PM support. Also remove now unused OMAP2_PRM_BASE. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-02-08[ARM] OMAP34XX: Add miscellaneous definitions related to 34xxJouni Hogander
Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-03Merge unstable branch 'omap-rmk'Russell King
Merge branch 'omap-rmk' into omap-all
2008-09-05[ARM] omap: Fix IO_ADDRESS() macrosRussell King
OMAP1_IO_ADDRESS(), OMAP2_IO_ADDRESS() and IO_ADDRESS() returns cookies for use with __raw_{read|write}* for accessing registers. Therefore, these macros should return (void __iomem *) cookies, not integer values. Doing this improves typechecking, and means we can find those places where, eg, DMA controllers are incorrectly given virtual addresses to DMA to, or physical addresses are thrown through a virtual to physical address translation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-19ARM: OMAP2: Powerdomain: Add OMAP2/3 common powerdomainsPaul Walmsley
Add powerdomains common to both OMAP2 and OMAP3 (WKUP and GFX/SGX). Modify mach-omap2/io.c to initialize the powerdomain code on boot. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: Turn CM and PRM access into functionsTony Lindgren
Otherwise compiling in omap2 and omap3 will not work. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: Introduce omap_globals and prcm access functions for multi-omapTony Lindgren
New struct omap_globals contains the omap processor specific module bases. Use omap_globals to set the various base addresses to make detecting omap chip type simpler. Also introduce OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS for future multi-omap patches. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: SRAM: Split sram24xx.S into sram242x.S and sram243x.STony Lindgren
Split sram24xx.S into sram242x.S and sram243x.S Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-05-09ARM: OMAP: Fixed comments on global PRM register usageKalle Jokiniemi
Fixed comments on global PRM register usage. Signed-off-by: Kalle Jokiniemi <ext-kalle.jokiniemi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Add common register access for 24xx and 34xxPaul Walmsley
This patch adds common register access for 24xx and 34xx power and clock management in order to share code between 24xx and 34xx. Only change USB platform init code to use new register access, other access will be changed in later patches. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
