This patch adds hard-reset support for processor modules (e.g., DSP, IVA)
on OMAP2/3 platforms. It's based on the OMAP4 hard-reset support that Benoît
developed in the previous patch.
This patch is a collaboration between Benoît Cousson <b-cousson@ti.com>
and Paul Walmsley <paul@pwsan.com>.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Benoît Cousson <b-cousson@ti.com>
Most processor modules (e.g., DSP, IVA, IPU) on OMAPs can be reset
under the control of the PRM. This patch adds an API for this purpose
for OMAP4 devices:
int omap4_prm_is_hardreset_asserted(void __iomem *rstctrl_reg, u8 shift);
int omap4_prm_assert_hardreset(void __iomem *rstctrl_reg, u8 shift);
int omap4_prm_deassert_hardreset(void __iomem *rstctrl_reg, u8 shift);
This API is intended to be used only by the hwmod code - a subsequent
patch will add that support to hwmod.
Signed-off-by: Benoît Cousson <b-cousson@ti.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
The MPU subsystem was named based on internal code name (CHIRON).
This patch will remove all the occurences of the chiron name
are replace it with PRCM_MPU in order to differentiate
the MPU local PRCM to the global one.
Remove PDA_ from PRCM_MPU registers names to stick to the global
PRM naming convention.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Fix all of the remaining PRCM register shift/bitmask macros that did not
use the _SHIFT/_MASK suffixes to use them. This makes the use of these
macros consistent. It is intended to reduce error, as code can be inspected
visually by reviewers to ensure that bitshifts and bitmasks are used in
the appropriate places.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Module offsets were same for OMAP2 and OMAP3 while they differ for OMAP4.
Hence we need different macros for identifying platform specific offsets.
Signed-off-by: Abhijit Pagare <abhijitpagare@ti.com>
Cc: Benoit Cousson <b-cousson@ti.com>
The CHIRONSS has its own local PRCM module and the register defines
need to use the CHIRONSS base and not the PRM base.
The changes are generated by updating the script which autogenerates
the file modifed in the patch.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
This patch adds OMAP4 specific PRM register defs. Auto generated
using a python script (gen_prm_4430_h.py) developed by Paul
Walmsley and Benoit Cousson.
This patch splits OMAP2_IO_ADDRESS to OMAP2_L3_IO_ADDRESS and
OMAP2_L4_IO_ADDRESS to reclaim more IO space.
The omap_read*() and omap_write*() functions will work only over
L4 address space. Current omap kernel stack uses these functions
only to access registers over L4 io address space
Note that these macros should only be used when ioremap does
not work. Please use ioremap instead in all new code.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Search and replace OMAP_IO_ADDRESS with OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS,
and convert omap_read/write into a functions instead of a macros.
Also rename OMAP_MPUIO_VBASE to OMAP1_MPUIO_VBASE.
In the long run, most code should use ioremap + __raw_read/write instead.
By default, prevent functional wakeups from inside a module from
waking up the IVA2. Let DSP Bridge code handle this when loaded.
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
Remove OMAP_PRM_REGADDR and use processor specific defines instead.
Also fold in a patch from Kevin Hilman to add _OFFSET #defines
for the PRCM registers to be used with the prm_[read|write]_* macros.
These are used extensively in the forthcoming OMAP PM support.
Also remove now unused OMAP2_PRM_BASE.
Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com>
Merge branch 'omap-rmk' into omap-all
OMAP1_IO_ADDRESS(), OMAP2_IO_ADDRESS() and IO_ADDRESS() returns cookies
for use with __raw_{read|write}* for accessing registers. Therefore,
these macros should return (void __iomem *) cookies, not integer values.
Doing this improves typechecking, and means we can find those places
where, eg, DMA controllers are incorrectly given virtual addresses to
DMA to, or physical addresses are thrown through a virtual to physical
address translation.
Add powerdomains common to both OMAP2 and OMAP3 (WKUP and GFX/SGX).
Modify mach-omap2/io.c to initialize the powerdomain code on boot.
Otherwise compiling in omap2 and omap3 will not work.
New struct omap_globals contains the omap processor specific
module bases. Use omap_globals to set the various base addresses
to make detecting omap chip type simpler.
Also introduce OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS for future multi-omap
patches.
Split sram24xx.S into sram242x.S and sram243x.S
Fixed comments on global PRM register usage.
Signed-off-by: Kalle Jokiniemi <ext-kalle.jokiniemi@nokia.com>
This patch adds common register access for 24xx and 34xx power
and clock management in order to share code between 24xx and 34xx.
Only change USB platform init code to use new register access, other
access will be changed in later patches.
