git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup
* 'uart' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP2+: remove some orphan function declarations.
ARM: OMAP2+: UART: remove unused fields in omap_uart_state.
The platform_suspend_ops can be shared across OMAP2, 3, and 4, along
with all of the functions referenced in that structure. This patch
shares them. It also removes the suspend_state file-scoped variable
in the OMAP2 and 3 PM code; it does not appear to be actually needed
by anything.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
[khilman@ti.com: minor rework needed due to rebase/merge with conflicting changes]
Signed-off-by: Kevin Hilman <khilman@ti.com>
clkdms_setup() is identical across OMAP2, 3, and 4, so share it.
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Kevin Hilman <khilman@ti.com>
commit 2fd149645eb (ARM: OMAP2+: UART: Remove omap_uart_can_sleep and
add pm_qos) removed omap_uart_can_sleep and omap3_can_sleep, but not
their declarations. So remove those now.
Signed-off-by: NeilBrown <neilb@suse.de>
Reviewed-by: Shubhrajyoti D <shubhrajyoti@ti.com>
[khilman@ti.com: minor changelog edits]
Add OMAP4 CPUIDLE support. CPU1 is left with defualt idle and
the low power state for it is managed via cpu-hotplug.
This patch adds MPUSS low power states in cpuidle.
C1 - CPU0 ON + CPU1 ON + MPU ON
C2 - CPU0 OFF + CPU1 OFF + MPU CSWR
C3 - CPU0 OFF + CPU1 OFF + MPU OSWR
OMAP4460 onwards, MPUSS power domain doesn't support OFF state any more
anymore just like CORE power domain. The deepest state supported is OSWr.
Ofcourse when MPUSS and CORE PD transitions to OSWR along with device
off mode, even the memory contemts are lost which is as good as
the PD off state.
On OMAP4 because of hardware constraints, no low power states are
targeted when both CPUs are online and in SMP mode. The low power
states are attempted only when secondary CPU gets offline to OFF
through hotplug infrastructure.
Thanks to Nicole Chalhoub <n-chalhoub@ti.com> for doing exhaustive
C-state latency profiling.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Jean Pihet <j-pihet@ti.com>
Tested-by: Vishwanath BS <vishwanath.bs@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits)
ARM: EXYNOS4: Change devname for FIMD clkdev
ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx
ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210
ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100
ARM: S3C24XX: Use generic s3c_set_platdata for devices
ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND
ARM: SAMSUNG: Use generic s3c_set_platdata for NAND
ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI
ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON
ARM: SAMSUNG: Use generic s3c_set_platdata for FB
ARM: SAMSUNG: Use generic s3c_set_platdata for TS
ARM: S3C64XX: Add PWM backlight support on SMDK6410
ARM: S5P64X0: Add PWM backlight support on SMDK6450
ARM: S5P64X0: Add PWM backlight support on SMDK6440
ARM: S5PC100: Add PWM backlight support on SMDKC100
ARM: S5PV210: Add PWM backlight support on SMDKV210
ARM: EXYNOS4: Add PWM backlight support on SMDKC210
ARM: EXYNOS4: Add PWM backlight support on SMDKV310
ARM: SAMSUNG: Create a common infrastructure for PWM backlight support
clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0
Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
Move the saving of the auxiliary control registers into C; there's
no need for this to be in assembly code. This results in less
assembly code to deal with in OMAP.
Kevin tested full-chip retention and off on 3430/n900, 3530/Overo and
3630/Zoom3.
Most of the ASM sleep code (in arch/arm/mach-omap2/sleep34xx.S)
is copied to internal SRAM at boot and after wake-up from CORE OFF
mode. However only a small part of the code really needs to run from
internal SRAM.
This fix lets most of the ASM idle code run from the DDR in order to
minimize the SRAM usage and the overhead in the code copy.
The only pieces of code that are mandatory in SRAM are:
- the i443 erratum WA,
- the i581 erratum WA,
- the security extension code.
SRAM usage:
- original code:
. 560 bytes for omap3_sram_configure_core_dpll (used by DVFS),
. 852 bytes for omap_sram_idle (used by suspend/resume in RETention),
. 124 bytes for es3_sdrc_fix (used by suspend/resume in OFF mode on ES3.x),
. 108 bytes for save_secure_ram_context (used on HS parts only).
With this fix the usage for suspend/resume in RETention goes down 288
bytes, so the gain in SRAM usage for suspend/resume is 564 bytes.
Also fixed the SRAM initialization sequence to avoid an unnecessary
copy to SRAM at boot time and for readability.
Tested on Beagleboard (ES2.x) in idle with full RET and OFF modes.
Kevin Hilman tested retention and off on 3430/n900, 3530/Overo and
3630/Zoom3
Signed-off-by: Jean Pihet <j-pihet@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into devel-cleanup
arch/arm/mach-omap2/pm-debug.c
arch/arm/mach-omap2/pm.h
Remove OMAP3-specific register dumping feature from PM debug layer.
This is removed because:
- it's ugly
- it's OMAP3-specific, and will obviously not scale to OMAP4+
- userspace /dev/mem-based tools (like omapconf) can do this much better
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Remove the OMAP-specific PM debug 'sleep_while_idle' feature which is
currently available as an OMAP-specific debugfs entry.
This duplicates existing ARM-generic functionality available as a
boot-time option using the boot cmdline option 'hohlt'.
If runtime configuration of this is needed, then adding a debugfs
entry for the ARM-generic hlt/nohlt interface should be added.
This removes the support for setting the wake-up timer for debugging.
Later on we can reserve gptimer1 for PM code only and have similar
functionality.
The achievable power modes of the power domains in cpuidle
depends on the system wide 'enable_off_mode' knob in debugfs.
Upon changing enable_off_mode, do not change the C-states
'valid' field but instead dynamically restrict the power modes
when entering idle.
The C-states 'valid' field is just used to enable/disable some
C-states at init and shall not be changed later on.
- sleep_latency and wake_latency are not used, replace them by
exit_latency which is used by cpuidle. exit_latency simply is
the sum of sleep_latency and wake_latency,
- replace threshold by target_residency,
- changed the OMAP3 specific cpuidle code accordingly,
- changed the OMAP3 board code accordingly.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits)
omap: zoom: host should not pull up wl1271's irq line
arm: plat-omap: iommu: fix request_mem_region() error path
OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430
omap4: mux: Remove duplicate mux modes
omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag
omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set
omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected
omap4: board-omap4panda: Initialise the serial pads
omap3: board-3430sdp: Initialise the serial pads
omap4: board-4430sdp: Initialise the serial pads
omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init
omap2+: mux: Remove the use of IDLE flag
omap2+: Add separate list for dynamic pads to mux
perf: add OMAP support for the new power events
OMAP4: Add IVA OPP enteries.
OMAP4: Update Voltage Rail Values for MPU, IVA and CORE
OMAP4: Enable 800 MHz and 1 GHz MPU-OPP
OMAP3+: OPP: Replace voltage values with Macros
OMAP3: wdtimer: Fix CORE idle transition
Watchdog: omap_wdt: add fine grain runtime-pm
Fix up various conflicts in
- arch/arm/mach-omap2/board-omap3evm.c
- arch/arm/mach-omap2/clock3xxx_data.c
- arch/arm/mach-omap2/usb-musb.c
- arch/arm/plat-omap/include/plat/usb.h
- drivers/usb/musb/musb_core.h
Voltage control on TWL can be done using VMODE/I2C1/I2C_SR.
Since almost all platforms use I2C_SR on omap3, omap3_twl_init by
default expects that OMAP's I2C_SR is plugged in to TWL's I2C
and calls omap3_twl_set_sr_bit. On platforms where I2C_SR is not connected,
the board files are expected to call omap3_twl_set_sr_bit(false) to
ensure that I2C_SR path is not set for voltage control and prevent
the default behavior of omap3_twl_init.
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Thara Gopinath <thara@ti.com>
Signed-off-by: Shweta Gulati <shweta.gulati@ti.com>
The new fncpy API is better suited* for copying some
code to SRAM at runtime. This patch changes the ad-hoc
code to the more generic fncpy API.
*: 1. fncpy ensures that the thumb mode bit is propagated,
2. fncpy provides the security of type safety between the
original function and the sram function pointer.
Tested OK on OMAP3 in low power modes (RET/OFF)
using omap2plus_defconfig with !CONFIG_THUMB2_KERNEL.
Compile tested on OMAP1/2 using omap1_defconfig.
Boot tested on OMAP1 & OMAP2
Tested OK with suspend/resume on OMAP2420/n810
Boots fine on osk5912 and n800
Acked-by: Kevin Hilman <khilman@ti.com>
Reviewed-by: Dave Martin <dave.martin@linaro.org>
Tested-by: Tony Lindgren <tony@atomide.com>
TWL6030 is the power IC used along with OMAP4 in OMAP4 SDPs,
blaze boards and panda boards. This patch registers the OMAP4
PMIC specific information with the voltage layer.
This also involves implementing a different formula for
voltage to vsel and vsel to voltage calculations from
TWL4030.
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
This patch registers the TWL4030 PMIC specific informtion
with the voltage driver. Failing this patch the voltage driver
is unware of the formula to use for vsel to voltage and vice versa
conversion and lot of other PMIC dependent parameters.
This file is based on the arch/arm/plat-omap opp_twl_tpl.c file
by Paul Walmsley. The original file is replaced by this file.
This patch adds support for device registration of various
smartreflex module present in the system. This patch introduces
the platform data for smartreflex devices which include
the efused n-target vaules, a parameter to indicate
whether smartreflex autocompensation needs to be
enabled on init or not. An API
omap_enable_smartreflex_on_init is provided for the
board files to enable smartreflex autocompensation during
system boot up.
The OMAP powerdomain code and data is all OMAP2+-specific. This seems
unlikely to change any time soon. Move plat-omap/include/plat/powerdomain.h
to mach-omap2/powerdomain.h. The primary point of doing this is to remove
the temptation for unrelated upper-layer code to access powerdomain code
and data directly.
As part of this process, remove the references to powerdomain data
from the GPIO "driver" and the OMAP PM no-op layer, both in plat-omap.
Change the DSPBridge code to point to the new location for the
powerdomain headers. The DSPBridge code should not be including the
powerdomain headers; these should be removed.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Felipe Contreras <felipe.contreras@gmail.com>
Cc: Greg Kroah-Hartman <greg@kroah.com>
ssh://master.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-linus
Remove unused code:
- macros,
- variables,
- unused semaphore locking API. This API shall be added back
when needed,
- infinite loops for debug.
Tested on N900 and Beagleboard with full RET and OFF modes,
using cpuidle and suspend.
Reviewed-by: Nishanth Menon <nm@ti.com>
Tested-by: Nishanth Menon<nm@ti.com>
Limitation i583: Self_Refresh Exit issue after OFF mode
Issue:
When device is waking up from OFF mode, then SDRC state machine sends
inappropriate sequence violating JEDEC standards.
Impact:
OMAP3630 < ES1.2 is impacted as follows depending on the platform:
CS0: for 38.4MHz as internal sysclk, DDR content seen to be stable, while
for all other sysclk frequencies, varied levels of instability
seen based on varied parameters.
CS1: impacted
This patch takes option #3 as recommended by the Silicon erratum:
Avoid core power domain transitioning to OFF mode. Power consumption
impact is expected in this case.
To do this, we route core OFF requests to RET request on the impacted
revisions of silicon.
[nm@ti.com: rebased the code to 2.6.37-rc2- short circuit code changed a bit]
Signed-off-by: Eduardo Valentin <eduardo.valentin@nokia.com>
Currently omap3_cpuidle_update_states makes whole sale decision
on which C states to update based on enable_off_mode variable
Instead, achieve the same functionality by independently providing
mpu and core deepest states the system is allowed to achieve and
update the idle states accordingly.
[khilman: fixed additional user of this API in OMAP CPUidle driver]
While coming out of MPU OSWR/OFF states, L2 controller is reseted.
The reset behavior is implementation specific as per ARMv7 TRM and
hence $L2 needs to be invalidated before it's use. Since the
AUXCTRL register is also reconfigured, disable L2 cache before
invalidating it and re-enables it afterwards. This is as per
Cortex-A8 ARM documentation.
Currently this is identified as being needed on OMAP3630 as the
disable/enable is done from "public side" while, on OMAP3430, this
is done in the "secure side".
Cc: Tony Lindgren <tony@atomide.com>
[nm@ti.com: ported to 2.6.37-rc2, added hooks to enable the logic only on 3630]
Signed-off-by: Peter 'p2' De Schrijver <peter.de-schrijver@nokia.com>
Erratum id: i608
RTA (Retention Till Access) feature is not supported and leads to device
stability issues when enabled. This impacts modules with embedded memories
on OMAP3630
Workaround is to disable RTA on boot and coming out of core off.
For disabling RTA coming out of off mode, we do this by overriding the
restore pointer for 3630 as the first point of entry before caches are
touched and is common for GP and HS devices. To disable earlier than
this could be possible by modifying the PPA for HS devices, but not for
GP devices.
[ambresh@ti.com: co-developer]
Signed-off-by: Ambresh K <ambresh@ti.com>
Introduce errata handling for OMAP3. This patch introduces
errata variable and stub for initialization which will be
filled up by follow-on patches.
This patch adds OPP tables for OMAP4. New file has been added to keep
the OMAP4 opp tables and the registration of these tables with the
generic opp framework by OMAP SoC OPP interface.
Based on:
http://dev.omapzoom.org/?p=santosh/kernel-omap4-base.git;a=blob;f=arch/arm/mach-omap2/opp44xx_data.c;h=252e3d0cb6050a64f390b9311c1c4977d74f762a;hb=refs/heads/omap4_next
Add OPP data for OMAP34xx and OMAP36xx and initialization functions
to populate OPP tables based on current SoC.
introduce an OMAP generic opp initialization routine which OMAP3
and OMAP4+ SoCs can use to register their OPP definitions.
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Since 6cdee91257bee23a46dc869ca62469b67cba2c7e the references to
enable_off_mode and sleep_while_idle can't be resolved when CONFIG_PM_DEBUG
isn't set:
arch/arm/mach-omap2/built-in.o: In function `omap_uart_restore_context':
arch/arm/mach-omap2/serial.c:253: undefined reference to `enable_off_mode'
arch/arm/mach-omap2/built-in.o: In function `omap3_can_sleep':
arch/arm/mach-omap2/pm34xx.c:479: undefined reference to `sleep_while_idle'
Simply #define these in pm.h just like omap2_pm_debug.
Signed-off-by: Loïc Minier <loic.minier@linaro.org>
[khilman: moved down into existing #ifdef section]
The set_pwrdm_state() is needed on omap4 as well so move
this routine to common pm.c file so that it's available for omap3/4
This patch moves omap2_pm_wakeup_on_timer() and pm debug entries
form pm34xx.c to pm-debug.c and export it, so that it is available
to other OMAPs
Millisecond resolution is possible and there are use cases for it
(automatic testing).
Seconds-based interface is preserved for compatibility.
Signed-off-by: Ari Kauppi <Ext-Ari.Kauppi@nokia.com>
Reviewed-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Different boards benefit differently from the available
seven C-states for cpu idle. In most cases, only few,
properly spaced (in terms of consumption and latency)
C-states are required to make the power management
optimal. Hence we need a possibility to pass which
C-states are actually used for each board.
So added the valid field to cpuidle_params and added
support to 3430sdp, which uses the paramenter passing.
Signed-off-by: Kalle Jokiniemi <kalle.jokiniemi@digia.com>
The CPUidle C state latencies and thresholds are dependent on various
board specific details. This patch makes it possible to configure
these values from the respective board files.
omap3_pm_init_cpuidle() can now be optionally called from board files
to pass board specific cpuidle parameters. If the board files do not
use this function to pass the params default values are used which
might cause higher consumption dur to wrong state selection by the
governor.
This patch only updates the 3430sdp board files to use
omap3_pm_init_cpuidle().
From Kalle, in addition to original patch from Rajendra:
Building without CONFIG_CPU_IDLE or CONFIG_PM causes build to fail if
cpu idle parameters are tried to pass using omap3_pm_init_cpuidle
function.
When 'enable_off_mode' is 0, the target power state for MPU
and CORE was locally changed to PWRDM_POWER_RET but, the
statistics are updated for idle state originally selected
by the governor.
This patch 'invalidates' the idle states that lead either of
MPU or Core to PWRDM_POWER_OFF state when 'enable_off_mode'
is '0'. The states are valid once 'enable_off_mode' is set
to '1'.
Added function next_valid_state() to check if current state
is valid; else get the next valid state. It is called from
omap3_enter_idle_bm().
Signed-off-by: Sanjeev Premi <premi@ti.com>
The PM debug code fails to build on when CONFIG_DEBUG_FS is not
enabled.
Build error log:
arch/arm/mach-omap2/built-in.o: In function `omap_sram_idle':
arch/arm/mach-omap2/pm34xx.c:449: undefined reference to `pm_dbg_regset_save'
arch/arm/mach-omap2/pm34xx.c:460: undefined reference to `pm_dbg_regset_save'
arch/arm/mach-omap2/built-in.o: In function `configure_vc':
arch/arm/mach-omap2/pm34xx.c:1237: undefined reference to `pm_dbg_regset_init'
arch/arm/mach-omap2/pm34xx.c:1238: undefined reference to `pm_dbg_regset_init'
make: *** [.tmp_vmlinux1] Error 1
This patch fixes the above errors.
Kernel booting is tested on omap zoom2 and zoom3 boards.
Signed-off-by: Manjunatha GK <manjugk@ti.com>
Previously omap3_idle_init() was called in device_init, while
omap_pm_init() is called at late_initcall. This causes the cpu idle
driver to call omap_sram_idle before it is properly initialized. This
patch fixes the issue by moving omap3_idle_init into omap3_pm_init.
Signed-off-by: Kalle Jokiniemi <ext-kalle.jokiniemi@nokia.com>
This patch adds support and enables state C4(MPU RET + CORE RET)
and MPU OFF states (C3 and C5.)
Basic CPUidle driver for OMAP3 with deepest sleep state supported
being MPU CSWR.
Using debugfs, export a configurable wakeup timer to be used to
wakeup system from suspend.
If a non-zero value is written to
/debug/pm_debug/wakeup_timer_seconds, A timer wakeup event will wake
the system and resume after the configured number of seconds.
Allow enable/disable of low-power states during idle. To
enable low-power idle:
echo 1 > /debug/pm_debug/sleep_while_idle
to disable:
echo 0 > /debug/pm_debug/sleep_while_idle
Also allow enable/disable of OFF-mode. To enable:
echo 1 > /debug/pm_debug/enable_off_mode
to disable:
echo 0 > /debug/pm_debug/enable_off_mode
For HS/EMU devices, some additional resources need to be
saved/restored for off-mode support. Namely, saving the secure RAM
and a pointer to it in the scratchpad.
Signed-off-by: Tero Kristo <tero.kristo@nokia.com>
Move the remaining headers under plat-omap/include/mach
to plat-omap/include/plat. Also search and replace the
files using these headers to include using the right path.
This was done with:
#!/bin/bash
mach_dir_old="arch/arm/plat-omap/include/mach"
plat_dir_new="arch/arm/plat-omap/include/plat"
headers=$(cd $mach_dir_old && ls *.h)
omap_dirs="arch/arm/*omap*/ \
drivers/video/omap \
sound/soc/omap"
other_files="drivers/leds/leds-ams-delta.c \
drivers/mfd/menelaus.c \
drivers/mfd/twl4030-core.c \
drivers/mtd/nand/ams-delta.c"
for header in $headers; do
old="#include <mach\/$header"
new="#include <plat\/$header"
for dir in $omap_dirs; do
find $dir -type f -name \*.[chS] | \
xargs sed -i "s/$old/$new/"
done
find drivers/ -type f -name \*omap*.[chS] | \
for file in $other_files; do
sed -i "s/$old/$new/" $file
done
done
for header in $(ls $mach_dir_old/*.h); do
git mv $header $plat_dir_new/
done
Target state can be read / programmed via files under:
[debugfs]/pm_debug/[pwrdm]/suspend
Allows dumping out current register contents from the debug filesystem, and
also allows user to add arbitrary register save points into code. Current
register contents are available under debugfs at:
[debugfs]/pm_debug/registers/current
To add a save point, do following:
From module init (or somewhere before the save call, called only once):
pm_dbg_init_regset(n); // n=1..4, allocates memory for dump area #n
From arbitrary code location:
pm_dbg_regset_save(n); // n=1..4, saves registers to dump area #n
After this, the register dump can be seen under [debugfs]/pm_debug/registers/n
This patch provides the debugfs entries and a function which will be
called by the PM code to register the time spent per domain per
state. Also some new fields are added to the powerdomain struct to
keep the time information.
NOTE: As of v2.6.29, using getnstimeofday() after drivers are
suspended is no longer safe since the timekeeping subsystem is also
suspended as part of the suspend process. Instead use sched_clock()
which on OMAP returns the 32k SYNC timer in nanoseconds.
Also, do not print out status for meta powerdomains (dpll*)
