path: root/arch/arm/mach-omap2/mcbsp.c
2012-03-27Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: Non-critical bug fixes" from Ardn Bergmann: "Simple bug fixes that were not considered important enough for inclusion into 3.3. One bug fix was originally intended for 3.3 but accidentally got missed, but is not marked stable because it should only get backported once later fixes also make it into v3.4. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (66 commits) iomux-mx25.h slew rate adjusted for LCD __LD pins ARM: davinci: DA850: move da850_register_pm to .init.text ARM: davinci: cpufreq: fix compiler warning ARM: OMAP2+: Fix build for omap4 only builds with missing include of linux/bug.h ARM: OMAP2+: Fix section warnings for hsmmc_init_one ARM: OMAP2+: Fix build issues with missing include of linux/bug.h ARM: OMAP2+: gpmc-smsc911x: only register regulator for first instance ARM: OMAP3+: PM: VP: fix integer truncation error ARM: OMAP2+: PM: fix wakeupgen warning when hotplug disabled ARM: OMAP2+: PM: fix section mismatch with omap2_init_processor_devices() ARM: OMAP2: Fix section warning for n8x0 when CONFIG_MMC_OMAP is not set ARM: OMAP2+: Fix omap24xx_io_desc warning if SoC subtypes are not selected ARM: OMAP1: Fix section mismatch for omap1_init_early() ARM: OMAP1: Fix typo in lcd_dma.c ARM: OMAP: mailbox: trivial whitespace fix ARM: OMAP: Remove definition cpu_is_omap4430() ARM: OMAP2+: included some headers twice ARM: OMAP: clock.c: included linux/debugfs.h twice ARM: OMAP: don't build hwspinlock in vain ARM: OMAP2+: ads7846_init: put gpio_pendown into pdata if it's provided ...
2012-03-12ARM: OMAP2+: McBSP: Correct CLKR/FSR clock source mux configurationPeter Ujfalusi
On OMAP2/3 McBSP1 port has 6 pin setup, while on OMAP4 the port is McBSP4. Implement the CLKR/FSR clock mux selection for OMAP4, and make sure that we add the correct callback for the correct port across supported OMAP versions. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2012-03-12ASoC: omap-mcbsp: Create a single driver for McBSPPeter Ujfalusi
The OMAP McBSP driver stack used to contain two different drivers. One of them was used as kind low-level access to the IP, while the other driver was the ASoC DAI driver. There were global, shared structures, in different places, the McBSP instances are reffered with id numbers (sometimes 0 based, in other cases 1 based id numbers). Create one single driver for OMAP McBSP with name: omap-mcbsp. Convert the old omap-mcbsp driver initially to be a library for the omap-mcbsp DAI driver. With this change we can get rid of all global variables, structures. Further cleanup is coming... Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Grazvydas Ignotas <notasas@gmail.com> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2012-03-12ARM: OMAP: mcbsp: Convert core driver to proper platform driverPeter Ujfalusi
Convert the plat-omap/mcbsp.c driver to be proper platform driver. Remove the omap_mcbsp_init function call which was called from mach-omap1/2/mcbsp.c to register the platform driver for the just created platform device in the same function. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Tested-by: Grazvydas Ignotas <notasas@gmail.com> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2012-02-24ARM: OMAP: convert omap_device_build() and callers to __initKevin Hilman
Building omap_devices should only be done at init time, and since omap_device_build() is using early_platform calls which are also __init, this ensures that omap_device isn't trying to use functions that disappear. Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-01-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (526 commits) ASoC: twl6040 - Add method to query optimum PDM_DL1 gain ALSA: hda - Fix the lost power-setup of seconary pins after PM resume ALSA: usb-audio: add Yamaha MOX6/MOX8 support ALSA: virtuoso: add S/PDIF input support for all Xonars ALSA: ice1724 - Support for ooAoo SQ210a ALSA: ice1724 - Allow card info based on model only ALSA: ice1724 - Create capture pcm only for ADC-enabled configurations ALSA: hdspm - Provide unique driver id based on card serial ASoC: Dynamically allocate the rtd device for a non-empty release() ASoC: Fix recursive dependency due to select ATMEL_SSC in SND_ATMEL_SOC_SSC ALSA: hda - Fix the detection of "Loopback Mixing" control for VIA codecs ALSA: hda - Return the error from get_wcaps_type() for invalid NIDs ALSA: hda - Use auto-parser for HP laptops with cx20459 codec ALSA: asihpi - Fix potential Oops in snd_asihpi_cmode_info() ALSA: hdsp - Fix potential Oops in snd_hdsp_info_pref_sync_ref() ALSA: hda/cirrus - support for iMac12,2 model ASoC: cx20442: add bias control over a platform provided regulator ALSA: usb-audio - Avoid flood of frame-active debug messages ALSA: snd-usb-us122l: Delete calls to preempt_disable mfd: Put WM8994 into cache only mode when suspending ... Fix up trivial conflicts in: - arch/arm/mach-s3c64xx/mach-crag6410.c: renamed speyside_wm8962 to tobermory, added littlemill right next to it - drivers/base/regmap/{regcache.c,regmap.c}: duplicate diff that had already come in with other changes in the regmap tree
2011-12-17OMAP4: mcbsp: Enable FIFO usagePeter Ujfalusi
All McBSP instances on OMAP4 has 128 word long FIFO Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-12ARM: OMAP: mcbsp: Fix possible memory corruptionJarkko Nikula
Commits 09d28d ("ARM: OMAP: mcbsp: Start generalize omap2_mcbsp_set_clks_src") and 7bc0c4 ("ARM: OMAP: mcbsp: Start generalize signal muxing functions") incorrectly set two struct omap_mcbsp_platform_data fields after omap_device_build_ss and kfree calls. Fix this by moving these pdata assignments before those calls. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Reported-by: NeilBrown <neilb@suse.de> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-10-04ARM: OMAP2+: devices: Remove all omap_device_pm_latency structuresBenoit Cousson
Remove all these duplicated structures since a default one is now available. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-26ARM: OMAP: mcbsp: Start generalize signal muxing functionsJarkko Nikula
This generalizes the omap2_mcbsp1_mux_clkr_src and omap2_mcbsp1_mux_fsr_src implementation between generic McBSP and OMAP2 specific McBSP code. These functions are used to select source for CLKR and FSR signals on OMAP2+. Start generalizing the code by implementing an optional mux_signal function pointer in platform data that will implement the actual muxing and which is called now from omap2_mcbsp1_mux_clkr_src and omap2_mcbsp1_mux_fsr_src. These functions are to be removed later and cleanup the API so that mux_signal gets its arguments directly from client code. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-26ARM: OMAP: mcbsp: Start generalize omap2_mcbsp_set_clks_srcJarkko Nikula
This generalizes the omap2_mcbsp_set_clks_src implementation between generic McBSP and OMAP2 specific McBSP code. Currently this function is used to select either internal fclk or clks pin as a McBSP CLKS source on OMAP2+. Implement generalization by having an optional set_clk_src function pointer in platform data that is used to select parent for a given clock. Idea is to pass higher level source clock name (later coming from client driver) that platform specific code will map to platform specific clock name. API cleanup between McBSP and client code comes later. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-26ARM: OMAP: mcbsp: Move sidetone clock management to mach-omap2/mcbsp.cJarkko Nikula
Active sidetone requires that McBSP interface clock doesn't idle and there is no mechanism in hwmod to turn autoidling on/off in runtime. McBSP2 and 3 in OMAP34xx share their interface clock with McBSP sidetone module and that interface clock must be active when the sidetone is operating. Sidetone has its own autoidle bit which should keep the interface clock active but it is broken. Putting the McBSP core to no-idle mode when the sidetone is active is no good either since it results to higher power consumption when using the threshold based DMA transfers. For making the McBSP code more generic, move this sidetone clock management with fixme comments to mach-omap2/mcbsp.c and pass pointer to it via platform data. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Paul Wamsley <paul@pwsan.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-26ARM: OMAP: mcbsp: Make tranceiver configuration control register access genericJarkko Nikula
McBSP transmit and receive configuration control registers must be set up for OMAP2430 and later. Replace is_omap tests in generic code with a new feature flag has_ccr in platform data so that there is no need to change code for any upcoming OMAP version. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-26ARM: OMAP: mcbsp: Make wakeup control genericJarkko Nikula
Currently wakeup control code is compiled only when CONFIG_ARCH_OMAP3 is set even it should be available for CONFIG_ARCH_OMAP4 only builds also. Fix this by making wakeup control generic so that it is executed whenever new feature flag has_wakeup in platform data is set. Currently flag is set for McBSP config types 3 and 4. Remove also old comments about idle mode settings and HW bug workarounds that were not updated during hwmod conversion. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-26ARM: OMAP: mcbsp: Implement generic register accessJarkko Nikula
Register access can be made more generic by calculating register address offsets runtime from common register definitions and by using reg_size and reg_step variables that are passed via platform data. Common register definitions are possible since McBSP registers are ordered similarly between OMAP versions. Remove also references to OMAP2+ specific config_type variable from generic McBSP code since other variables and feature flags are better to carry needed information from platform code. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-15OMAP: omap_device: when building return platform_device instead of omap_deviceKevin Hilman
All of the device init and device driver interaction with omap_device is done using platform_device pointers. To make this more explicit, have omap_device return a platform_device pointer instead of an omap_device pointer. All current users of the omap_device pointer were only using it to get at the platform_device pointer or struct device pointer, so fixing all of the users was trivial. This also makes it more difficult for device init code to directly access members of struct omap_device, and allows for easier changing of omap_device internals. Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-02-24OMAP: McBSP: APIs to pass DMA params from McBSP driver to client driversKishon Vijay Abraham I
After McBSP driver is hwmod adapted, the information about the hw would be obtained from the hwmod database by the mcbsp driver. Since DMA programming is handled by the client driver, APIs are provided to pass the DMA channel number and base address of data register required by the client driver for DMA programming. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Charulatha V <charu@ti.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-24OMAP: McBSP: Add pm runtime supportKishon Vijay Abraham I
Add pm runtime support for McBSP driver. Reference to fclk is not removed because it is required when the functional clock is switched from one source to another. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Cc: Paul Walmsley <paul@pwsan.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-24OMAP2+: McBSP: hwmod adaptation for McBSPKishon Vijay Abraham I
Modify OMAP2+ McBSP to use omap hwmod framework APIs Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Charulatha V <charu@ti.com> Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-24OMAP: McBSP: Convert McBSP to platform device modelKishon Vijay Abraham I
Implement McBSP as platform device and add support for registering through platform device layer using resource structures. Later in this patch series, OMAP2+ McBSP driver would be modified to use hwmod framework after populating the omap2+ hwmod database. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-01-27omap: Start using CONFIG_SOC_OMAPTony Lindgren
We want to have just CONFIG_ARCH_OMAP2, 3 and 4. The rest are nowadays just subcategories of these. Search and replace the following: ARCH_OMAP2420 SOC_OMAP2420 ARCH_OMAP2430 SOC_OMAP2430 ARCH_OMAP3430 SOC_OMAP3430 No functional changes. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Sourav Poddar <sourav.poddar@ti.com>
2010-10-08OMAP: McBSP: Remove null omap44xx ops commentJarkko Nikula
It seems these comments where accidentally added so remove them. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Paul Walmsley <paul@pwsan.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
2010-10-08OMAP: McBSP: Fix CLKR and FSR signal muxingJarkko Nikula
Fix bit clear. Now it clears all other bits than mask bit where it should clear only it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Paul Walmsley <paul@pwsan.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
2010-10-08OMAP: control: move plat-omap/control.h to mach-omap2/control.hPaul Walmsley
Only OMAP2+ platforms have the System Control Module (SCM) IP block. In the past, we've kept the SCM header file in plat-omap. This has led to abuse - device drivers including it; includes being added that create implicit dependencies on OMAP2+ builds; etc. In response, move the SCM headers into mach-omap2/. As part of this, remove the direct SCM access from the OMAP UDC driver. It was clearly broken. The UDC code needs an indepth review for use on OMAP2+ chips. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Cory Maccarrone <darkstar6262@gmail.com> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2010-10-08OMAP: McBSP: implement functional clock switching via clock frameworkPaul Walmsley
Previously the OMAP McBSP ASoC driver implemented CLKS switching by using omap_ctrl_{read,write}l() directly. This is against policy; the OMAP System Control Module functions are not intended to be exported to drivers. These symbols are no longer exported, so as a result, the OMAP McBSP ASoC driver does not build as a module. Resolve the CLKS clock changing portion of this problem by creating a clock parent changing function that lives in arch/arm/mach-omap2/mcbsp.c, and modify the ASoC driver to use it. Due to the unfortunate way that McBSP support is implemented in ASoC and the OMAP tree, this symbol must be exported for use by sound/soc/omap/omap-mcbsp.c. Going forward, the McBSP device driver should be moved from arch/arm/*omap* into drivers/ or sound/soc/* and the CPU DAI driver should be implemented as a platform_driver as many other ASoC CPU DAI drivers are. These two steps should resolve many of the layering problems, which will rapidly reappear during a McBSP hwmod/PM runtime conversions. Signed-off-by: Paul Walmsley <paul@pwsan.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-08OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.cPaul Walmsley
The OMAP ASoC McBSP code implemented CLKR and FSR signal muxing via direct System Control Module writes on OMAP2+. This required the omap_ctrl_{read,write}l() functions to be exported, which is against policy: the only code that should call those functions directly is OMAP core code, not device drivers. omap_ctrl_{read,write}*() are no longer exported, so the driver no longer builds as a module. Fix the pinmuxing part of the problem by removing calls to omap_ctrl_{read,write}l() from the OMAP ASoC McBSP code and implementing signal muxing functions in arch/arm/mach-omap2/mcbsp.c. Due to the unfortunate way that McBSP support is implemented in ASoC and the OMAP tree, these symbols must be exported for use by sound/soc/omap/omap-mcbsp.c. Going forward, the McBSP device driver should be moved from arch/arm/*omap* into drivers/ or sound/soc/*, and the CPU DAI driver should be implemented as a platform_driver as many other ASoC CPU DAI drivers are. These two steps should resolve many of the layering problems, which will rapidly reappear during a McBSP hwmod/PM runtime conversion. Signed-off-by: Paul Walmsley <paul@pwsan.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-27omap2: McBSP: Remove mux code for OMAP2420 McBSP2 and do cleanupsJarkko Nikula
This 'legacy' OMAP2420 McBSP2 muxing code is currently broken after recent conversion to new mux code. The omap_mcbsp_request calling this code is usually called after booting whereas the omap_mux_init_signal is __init marked so null pointer dereference would occur. Fix this by removing the muxing code and let the bootloader or board file to do it if necessary. Remove also omap2_mcbsp_ops as there is no use for it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-08Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (143 commits) omap: mailbox: reorganize headers omap: mailbox: standarize on 'omap-mailbox' omap: mailbox: only compile for configured archs omap: mailbox: simplify omap_mbox_register() omap: mailbox: reorganize registering omap: mailbox: add IRQ names omap: mailbox: remove unecessary fields omap: mailbox: don't export unecessary symbols omap: mailbox: update omap1 probing omap: mailbox: use correct config for omap1 omap: mailbox: 2420 should be detected at run-time omap: mailbox: reorganize structures omap: mailbox: trivial cleanups omap mailbox: Set a device in logical mbox instance for traceability omap: mailbox: convert block api to kfifo omap: mailbox: remove (un)likely macros from cold paths omap: mailbox cleanup: split MODULE_AUTHOR line omap: mailbox: convert rwlocks to spinlock Mailbox: disable mailbox interrupt when request queue Mailbox: new mutext lock for h/w mailbox configuration ...
2010-07-05omap: mux: Convert 2420 platform init code to use new mux codeTony Lindgren
Convert 2420 platform init code to use new mux code Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-06-03OMAP3: McBSP: Change the way how the FIFO is handledPeter Ujfalusi
Use the actual FIFO size in words as buffer_size on OMAP3. Change the threshold configuration to use 1 based numbering, when specifying the allowed threshold maximum or the McBSP threshold value. Set the default maximum threshold to (buffer_size - 0x10) intialy. >From users of McBSP, now it is expected to use this method. Asking for threshold 1 means that the value written to threshold registers are going to be 0, which means 1 word threshold. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolsfonmicro.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-20Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: sound/soc/codecs/ad1938.c
2010-05-14ARM: McBSP: Fix request for irq in OMAP4Jorge Eduardo Candelaria
In OMAP4, there is only one irq line for TX and RX paths. Use the correct irq line to avoid errors at runtime. Also, request irq line only once (instead of requesting for TX and RX). Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-23McBSP: OMAP3: Add sidetone featureEero Nurkkala
Add sidetone feature to McBSP instances 2 and 3 on OMAP3 based devices. Signed-off-by: Ilkka Koskinen <ilkka.koskinen@nokia.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Tested-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap: McBSP: Introduce caching in register write operationsJanusz Krzysztofik
Determine cache size required per McBSP port at init time, based on processor type running on. Allocate space for storing cached copies of McBSP register values at port request. Modify omap_msbcp_write() function to update the cache with every register write operation. Modify omap_mcbsp_read() to support reading from cache or hardware. Update MCBSP_READ() macro for modified omap_mcbsp_read() function API. Introduce a new macro that reads from the cache. Tested on OMAP1510 based Amstrad Delta using linux-omap for-next, commit fb7380d70e041e4b3892f6b19dff7efb609d15a4 (2.6.33-rc3+ dated 2010-01-11). Compile-tested with: omap_perseus2_730_defconfig, omap_generic_1610_defconfig, omap_generic_2420_defconfig, omap_2430sdp_defconfig, omap_3430sdp_defconfig, omap_4430sdp_defconfig with CONFIG_OMAP_MCBSP=y selected. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap3: Replace ARCH_OMAP34XX with ARCH_OMAP3Tony Lindgren
Replace ARCH_OMAP34XX with ARCH_OMAP3 Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-14Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (257 commits) [ARM] Update mach-types ARM: 5636/1: Move vendor enum to AMBA include ARM: Fix pfn_valid() for sparse memory [ARM] orion5x: Add LaCie NAS 2Big Network support [ARM] pxa/sharpsl_pm: zaurus c3000 aka spitz: fix resume ARM: 5686/1: at91: Correct AC97 reset line in at91sam9263ek board ARM: 5640/1: This patch modifies the support of AC97 on the at91sam9263 ek board ARM: 5689/1: Update default config of HP Jornada 700-series machines ARM: 5691/1: fix cache aliasing issues between kmap() and kmap_atomic() with highmem ARM: 5688/1: ks8695_serial: disable_irq() lockup ARM: 5687/1: fix an oops with highmem ARM: 5684/1: Add nuc960 platform to w90x900 ARM: 5683/1: Add nuc950 platform to w90x900 ARM: 5682/1: Add cpu.c and dev.c and modify some files of w90p910 platform ARM: 5626/1: add suspend/resume functions to amba-pl011 serial driver ARM: 5625/1: fix hard coded 4K resource size in amba bus detection MMC: MMCI: convert realview MMC to use gpiolib ARM: 5685/1: Make MMCI driver compile without gpiolib ARM: implement highpte ARM: Show FIQ in /proc/interrupts on CONFIG_FIQ ... Fix up trivial conflict in arch/arm/kernel/signal.c. It was due to the TIF_NOTIFY_RESUME addition in commit d0420c83f ("KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures") and follow-ups.
2009-09-12Merge branch 'devel-stable' into develRussell King
Conflicts: MAINTAINERS arch/arm/mm/fault.c
2009-09-10Merge branch 'topic/asoc' into for-linusTakashi Iwai
* topic/asoc: (226 commits) ASoC: au1x: PSC-AC97 bugfixes ASoC: Fix WM835x Out4 capture enumeration ASoC: Remove unuused hw_read_t ASoC: fix pxa2xx-ac97.c breakage ASoC: Fully specify DC servo bits to update in wm_hubs ASoC: Debugged improper setting of PLL fields in WM8580 driver ASoC: new board driver to connect bfin-5xx with ad1836 codec ASoC: OMAP: Add functionality to set CLKR and FSR sources in McBSP DAI ASoC: davinci: i2c device creation moved into board files ASoC: Don't reconfigure WM8350 FLL if not needed ASoC: Fix s3c-i2s-v2 build ASoC: Make platform data optional for TLV320AIC3x ASoC: Add S3C24xx dependencies for Simtec machines ASoC: SDP3430: Fix TWL GPIO6 pin mux request ASoC: S3C platform: Fix s3c2410_dma_started() called at improper time ARM: OMAP: McBSP: Merge two functions into omap_mcbsp_start/_stop ASoC: OMAP: Fix setup of XCCR and RCCR registers in McBSP DAI OMAP: McBSP: Use textual values in DMA operating mode sysfs files ARM: OMAP: DMA: Add support for DMA channel self linking on OMAP1510 ASoC: Select core DMA when building for S3C64xx ...
2009-08-20OMAP3: McBSP: Lower the maximum buffersize for McBSP1, 3, 4, 5Peter Ujfalusi
Do not allow applications to use the full buffer found on McBSP1,3,4,5. Using the full buffer in threshold mode causes the McBSP buffer to run dry, which can be observed as channels are switching (in reality the channels are shifting). Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-08-20OMAP: McBSP: Create and export max_(r|t)x_thres propertyEduardo Valentin
This patch export through sysfs two properties to configure maximum threshold for transmission and reception on each mcbsp instance. Also, it exports two helper functions to allow mcbsp users to read this values. Signed-off-by: Eduardo Valentin <eduardo.valentin@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-28ARM: OMAP4: Add McBSP supportSyed Rafiuddin
This patch creates McBSP support on OMAP4430 development platform. This patch includes corresponding base address changes for OMAP4. Signed-off-by: Syed Rafiuddin <rafiuddin.syed@ti.com>
2009-07-25ARM: includecheck fix: mach-omap2/mcbsp.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: arch/arm/mach-omap2/mcbsp.c: mach/irqs.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Acked-by: Eduardo Valentin <eduardo.valentin@nokia.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-11[ARM] remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in arch/arm/mach-mx3/devices.c arch/arm/mach-omap1/mcbsp.c arch/arm/mach-omap2/mcbsp.c arch/arm/plat-stmp3xxx/pinmux.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] omap: mcbsp: convert to use fck/ick clocks directlyRussell King
Rather than introducing a special 'mcbsp_clk' with code behind it in mach-omap*/mcbsp.c to handle the SoC specifics, arrange for the mcbsp driver to be like any other driver. mcbsp requests its fck and ick clocks directly, and the SoC specific code deals with selecting the correct clock. There is one oddity to deal with - OMAP1 fiddles with the DSP clocks and DSP reset, so we move this to the two callback functions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-29ARM: OMAP: Fix McBSP spin_lock deadlockStanley.Miao
A spin_lock deadlock will occur when omap_mcbsp_request() is invoked. omap_mcbsp_request() \- clk_enable(mcbsp->clk) [takes and holds clockfw_lock] \- omap2_clk_enable() \- _omap2_clk_enable() \- omap_mcbsp_clk_enable() \- clk_enable(child clock) [tries for clockfw_lock again] mcbsp_clk is a virtual clock and it comprises several child clocks. when enable mcbsp_clk in omap_mcbsp_request(), the enable function of mcbsp_clk will enable its child clocks, then the deadlock occurs. The solution is to remove the virtual clock and enable these child clocks in omap_mcbsp_request() directly. Signed-off-by: Stanley.Miao <stanley.miao@windriver.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-01-15ARM: OMAP: Fix compile for various McBSPTony Lindgren
Include irqs.h or cpu.h directly as needed to fix omap builds. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-01-08[ARM] fix AT91, davinci, h720x, ks8695, msm, mx2, mx3, netx, omap1, omap2, ↵Russell King
pxa, s3c arch/arm/mach-at91/at91cap9.c:337: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91rm9200.c:301: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9260.c:351: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9261.c:287: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9263.c:312: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9rl.c:304: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-h720x/h7202-eval.c:38: error: implicit declaration of function 'IRQ_CHAINED_GPIOB' arch/arm/mach-ks8695/devices.c:46: error: 'KS8695_IRQ_WAN_RX_STATUS' undeclared here (not in a function) arch/arm/mach-msm/devices.c:28: error: 'INT_UART1' undeclared here (not in a function) arch/arm/mach-mx2/devices.c:233: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-mx3/devices.c:128: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:140: error: 'INT_730_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:165: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:200: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap2/board-apollon.c:286: error: implicit declaration of function 'omap_set_gpio_direction' arch/arm/mach-omap2/mcbsp.c:154: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-omap2/mcbsp.c:181: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-pxa/e350.c:36: error: 'IRQ_BOARD_START' undeclared here (not in a function) arch/arm/plat-s3c/dev-i2c0.c:32: error: 'IRQ_IIC' undeclared here (not in a function) ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
