path: root/arch/arm/mach-omap2/irq.c
2011-01-13ARM: omap2: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
2010-12-17OMAP3: add comments for erratas i540 and i478 workaroundsJean Pihet
Add comments and IDs for the following erratas: - i540: MPU cannot exit from Standby, - i478: Unexpected Cold-Reset is generated when device is coming back from OFF mode Signed-off-by: Jean Pihet <j-pihet@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-10-08OMAP: mach-omap2: Fix miscellaneous sparse warningsManjunath Kondaiah G
This patch fixes miscellaneous sparse warnings in mach-omap2. arch/arm/mach-omap2/board-am3517evm.c:141:17: warning: Initializer entry defined twice arch/arm/mach-omap2/board-am3517evm.c:142:18: also defined here arch/arm/mach-omap2/irq.c:50:35: warning: Using plain integer as NULL pointer Signed-off-by: Manjunath Kondaiah G <manjugk@ti.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-03OMAP2/3: IRQ: ensure valid base addressKevin Hilman
Ensure valid base address during IRQ init. Fixes compiler warning about potential use of uninitialized variable. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-01-20OMAP3: PM: Disable interrupt controller AUTOIDLE before WFITero Kristo
OMAP interrupt controller goes to unknown state when there is right combination of l3,l4 sleep/wake-up transitions, l4 autoidle in interrupt controller and some interrupt. When this happens, interrupts are not delivered to ARM anymore and ARM will remain in WFI (wait for interrupt) until interrupt controller is forced to wake-up (i.e. lauterbach). Signed-off-by: Tero Kristo <tero.kristo@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-01-20OMAP3: PM: Ack pending interrupts before entering suspendTero Kristo
Suspending drivers may still generate interrupts just before their suspend is completed. Any pending interrupts here will prevent sleep. Signed-off-by: Tero Kristo <tero.kristo@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-11-11OMAP3: PM: Fix INTC context save/restoreAaro Koskinen
Wrong index was used for ILR. Signed-off-by: Aaro Koskinen <Aaro.Koskinen@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-11-11OMAP3: PM: INTC context save/restoreRajendra Nayak
Add context save and restore for the INTC module to support off-mode. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-10-19omap: Use ioremap in irq.cTony Lindgren
Use ioremap in irq.c Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-05-28OMAP: Add new function to check wether there is irq pendingJouni Hogander
Add common omap2/3 function to check wether there is irq pending. Switch to use it in omap2 pm code instead of its own. Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-26Revert "ARM: OMAP: Mask interrupts when disabling interrupts, v2"Kevin Hilman
This reverts commit 5461af5af5c6a7fee78978aafe720541bf3a2f55. Adding a disable hook to the irq_chip is not the way to fix the problem being addressed by this patch. Instead, we need to fix support for [enable|disable]_irq_wake(). Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-04-23ARM: OMAP3: Clean up spurious interrupt check logicRoger Quadros
SPURIOUSIRQ is contained in bits 31:7 of INTC_SIR, so INTC_SIR must be right shifted by 7, not 6. No change in logic, only changes for better readability. Refer to register definition of INTCPS_SIR_IRQ in OMAP3 Manual. Signed-off-by: Roger Quadros <ext-roger.quadros@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-01-29ARM: OMAP: Mask interrupts when disabling interrupts, v2김규원
By Ingo Molnar, interrupts are not masked by default. (refer to 76d2160147f43f982dfe881404cfde9fd0a9da21) But if interrupts are not masked, the processor can wake up while in Suspend-to-RAM state by an external interrupt. For example, if an OMAP3 board is connected to Host PC by USB and entered to Suspend-to-RAM state, it wake up automatically by M_IRQ_92. The disable_irq() function can't disable the interrupt in H/W level, So I modified arch/arm/mach-omap2/irq.c Signed-off-by: Kim Kyuwon <chammoru@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10ARM: OMAP3: Warn about spurious interruptsTony Lindgren
In the case of spurious interrupt, the handler for previous interrupt handler needs to flush posted writes with a read back of the interrupt ack register. Warn about handlers that need to flush posted writes. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-20Merge branch 'genirq-v28-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip This merges branches irq/genirq, irq/sparseirq-v4, timers/hpet-percpu and x86/uv. The sparseirq branch is just preliminary groundwork: no sparse IRQs are actually implemented by this tree anymore - just the new APIs are added while keeping the old way intact as well (the new APIs map 1:1 to irq_desc[]). The 'real' sparse IRQ support will then be a relatively small patch ontop of this - with a v2.6.29 merge target. * 'genirq-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (178 commits) genirq: improve include files intr_remapping: fix typo io_apic: make irq_mis_count available on 64-bit too genirq: fix name space collisions of nr_irqs in arch/* genirq: fix name space collision of nr_irqs in autoprobe.c genirq: use iterators for irq_desc loops proc: fixup irq iterator genirq: add reverse iterator for irq_desc x86: move ack_bad_irq() to irq.c x86: unify show_interrupts() and proc helpers x86: cleanup show_interrupts genirq: cleanup the sparseirq modifications genirq: remove artifacts from sparseirq removal genirq: revert dynarray genirq: remove irq_to_desc_alloc genirq: remove sparse irq code genirq: use inline function for irq_to_desc genirq: consolidate nr_irqs and for_each_irq_desc() x86: remove sparse irq from Kconfig genirq: define nr_irqs for architectures with GENERIC_HARDIRQS=n ...
2008-10-16genirq: fix name space collisions of nr_irqs in arch/*Thomas Gleixner
local shadows of global variables are _bad_ Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-10-09ARM: OMAP3: Add minimal omap3430 supportSyed Mohammed, Khasim
Add minimal omap3430 support based on earlier patches from Syed Mohammed Khasim. Also merge in omap34xx SRAM support from Karthik Dasu and use consistent naming for sram init functions. Also do following changes that make 34xx support usable: - Remove unused sram.c functions for 34xx - Rename IRQ_SIR_IRQ to INTCPS_SIR_IRQ and define it locally in entry-macro.S - Update mach-omap2/io.c to support 2420, 2430, and 34xx - Also merge in 34xx GPMC changes to add fields wr_access and wr_data_mux_bus from Adrian Hunter - Remove memory initialization call omap2_init_memory() until until more generic memory initialization patches are posted. It's OK to rely on bootloader initialization until then. Signed-off-by: Syed Mohammed, Khasim <khasim@ti.com> Signed-off-by: Karthik Dasu<karthik-dp@ti.com> Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09ARM: OMAP2: Fix sparse, checkpatch warnings in OMAP2/3 IRQ codePaul Walmsley
Fix sparse warnings in mach-omap2/irq.c. Fix by defining intc_bank_write_reg() and intc_bank_read_reg(), and convert INTC module register access to use them rather than __raw_{read,write}l. Also clear up some checkpatch warnings involving includes from asm/ rather than linux/. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-06ARM: OMAP2: Misc updates from linux-omap treeTony Lindgren
Misc updates from linux-omap tree, mostly to update common device initialization and add missing defines from linux-omap tree. Also some changes to make room for adding 34xx in following patches. Note that the I2C resources are now set up in arch/arm/plat-omap/i2c.c helper, and can be removed from devices.c. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-09-05[ARM] omap: Fix IO_ADDRESS() macrosRussell King
OMAP1_IO_ADDRESS(), OMAP2_IO_ADDRESS() and IO_ADDRESS() returns cookies for use with __raw_{read|write}* for accessing registers. Therefore, these macros should return (void __iomem *) cookies, not integer values. Doing this improves typechecking, and means we can find those places where, eg, DMA controllers are incorrectly given virtual addresses to DMA to, or physical addresses are thrown through a virtual to physical address translation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-09-20ARM: OMAP: Optimize INTC register accesses and enable autoidlingJuha Yrjola
Use virtual addresses directly instead of physical addresses to avoid having to recalculate the virtual address with every register access. Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-25ARM: OMAP: Remove IVA IRQ bankKomal Shah
ARM11 can't access the IVA interrupt controller from IVA slave port. From Richard Woodruff: "The 0x40000000 is an IVA-ARM7 local bus address. The IVA-INTC is NOT accessible through the IVA-L3-Slave Port. The current TRM does say this directly and indirectly in a few spots and in figures." Signed-off-by: Komal Shah <komal_shah802003@yahoo.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-08-01[ARM] 3739/1: genirq updates: irq_chip, add and use irq_chip.nameDavid Brownell
Patch from David Brownell ARM genirq cleanups/updates: - Start switching platforms to newer APIs * use "irq_chip" name, not "irqchip" * providing irq_chip.name - Show irq_chip.name in /proc/interrupts, like on x86. This update a bit more than half of the ARM code. The irq_chip.name values were chosen to match docs (if I have them) or be otherwise obvious ("FPGA", "CPLD", or matching the code). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3145/1: OMAP 3a/5: Add support for omap24xxTony Lindgren
Patch from Tony Lindgren This patch adds support for omap24xx series of processors. The files live in arch/arm/mach-omap2, and share common files with omap15xx and omap16xx processors in arch/arm/plat-omap. Omap24xx support was originally added for 2.6.9 by TI. This code was then improved and integrated to share common code with omap15xx and omap16xx processors by various omap developers, such as Paul Mundt, Juha Yrjola, Imre Deak, Tony Lindgren, Richard Woodruff, Nishant Menon, Komal Shah et al. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
