path: root/arch/arm/mach-omap2/dsp.c
2012-10-18ARM: OMAP: Make plat/omap-pm.h local to mach-omap2Tony Lindgren
We must move this for ARM common zImage support. Note that neither drivers/media/rc/ir-rx51.c or drivers/media/platform/omap3isp/ispvideo.c need to include omap-pm.h, so this patch removes the include for those files. Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Timo Kokkonen <timo.t.kokkonen@iki.fi> Cc: linux-media@vger.kernel.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-19ARM: omap: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the omap include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Kevin Hilman <khilman@ti.com> Cc: "BenoƮt Cousson" <b-cousson@ti.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Jean Pihet <j-pihet@ti.com> Cc: J Keerthy <j-keerthy@ti.com> Cc: linux-omap@vger.kernel.org
2012-06-28Merge branch 'cleanup-hwmod' into cleanupTony Lindgren
Conflicts: arch/arm/mach-omap2/dsp.c
2012-06-18ARM: OMAP: dsp: interface to control module functionsOmar Ramirez Luna
Provide an interface for a driver to call SCM functions to set a boot address and boot mode. Signed-off-by: Omar Ramirez Luna <omar.luna@linaro.org> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-06-06ARM: OMAP2+: Fix compile for CONFIG_TIDSPBRIDGE platform init codeTony Lindgren
Commit 7f28427b (ARM: OMAP2+: Move omap_dsp_reserve_sdram_memblock() to mach-omap2) moved DSP platform init code, but failed to include memblock.h causing: arch/arm/mach-omap2/dsp.c: In function 'omap_dsp_reserve_sdram_memblock': arch/arm/mach-omap2/dsp.c:58: error: implicit declaration of function 'arm_memblock_steal' Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-05-09ARM: OMAP2+: Move omap_dsp_reserve_sdram_memblock() to mach-omap2Tony Lindgren
This hardware exists only on 2430 and later omaps, so there's no need to have it in plat-omap/devices.c. Note that we don't have any users for exported omap_dsp_get_mempool_base(), so we can make it static. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-05-09ARM: OMAP: fix trivial warnings for dspbridgeFelipe Contreras
arch/arm/plat-omap/devices.c: In function 'omap_dsp_reserve_sdram_memblock': arch/arm/plat-omap/devices.c:170: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'phys_addr_t' arch/arm/mach-omap2/dsp.c: In function 'omap_dsp_init': arch/arm/mach-omap2/dsp.c:60: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'phys_addr_t' arch/arm/mach-omap2/dsp.c:60: warning: format '%x' expects type 'unsigned int', but argument 4 has type 'phys_addr_t' Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-11-07ARM: OMAP: Fix export.h or module.h includesTony Lindgren
Commit 32aaeffbd4a7457bf2f7448b33b5946ff2a960eb (Merge branch 'modsplit-Oct31_2011'...) caused some build errors. Fix these and make sure we always have export.h or module.h included for MODULE_ and EXPORT_SYMBOL users: $ grep -rl ^MODULE_ arch/arm/*omap*/*.c | xargs \ grep -L linux/module.h arch/arm/mach-omap2/dsp.c arch/arm/mach-omap2/mailbox.c arch/arm/mach-omap2/omap-iommu.c arch/arm/mach-omap2/smartreflex.c Also check we either have export.h or module.h included for the files exporting symbols: $ grep -rl EXPORT_SYMBOL arch/arm/*omap*/*.c | xargs \ grep -L linux/export.h | xargs grep -L linux/module.h Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-21OMAP2/3: PRM/CM: prefix OMAP2 PRM/CM functions with "omap2_"Paul Walmsley
Now that OMAP4-specific PRCM functions have been added, distinguish the existing OMAP2/3-specific PRCM functions by prefixing them with "omap2_". This patch should not result in any functional change. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jarkko Nikula <jhnikula@gmail.com> Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP2/3: PRCM: split OMAP2/3-specific PRCM code into OMAP2/3-specific filesPaul Walmsley
In preparation for adding OMAP4-specific PRCM accessor/mutator functions, split the existing OMAP2/3 PRCM code into OMAP2/3-specific files. Most of what was in mach-omap2/{cm,prm}.{c,h} has now been moved into mach-omap2/{cm,prm}2xxx_3xxx.{c,h}, since it was OMAP2xxx/3xxx-specific. This process also requires the #includes in each of these files to be changed to reference the new file name. As part of doing so, add some comments into plat-omap/sram.c and plat-omap/mcbsp.c, which use "sideways includes", to indicate that these users of the PRM/CM includes should not be doing so. Thanks to Felipe Contreras <felipe.contreras@gmail.com> for comments on this patch. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Jarkko Nikula <jhnikula@gmail.com> Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Acked-by: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Felipe Contreras <felipe.contreras@gmail.com> Acked-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Greg Kroah-Hartman <greg@kroah.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-10-05omap: add dsp platform deviceFelipe Contreras
Otherwise tidspbridge cannot work. It looks like this was dropped in the conversion to staging. I took the liberty of doing some cleaning up. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
