path: root/arch/arm/mach-omap2/devices.c
2010-10-25Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits) omap: complete removal of machine_desc.io_pg_offst and .phys_io omap: UART: fix wakeup registers for OMAP24xx UART2 omap: Fix spotty MMC voltages ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h serial: omap-serial: fix signess error OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish omap: dma: Fix buffering disable bit setting for omap24xx omap: serial: Fix the boot-up crash/reboot without CONFIG_PM OMAP3: PM: fix scratchpad memory accesses for off-mode omap4: pandaboard: enable the ehci port on pandaboard omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set omap4: pandaboard: remove unused hsmmc definition OMAP: McBSP: Remove null omap44xx ops comment OMAP: McBSP: Swap CLKS source definition OMAP: McBSP: Fix CLKR and FSR signal muxing OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks OMAP: control: move plat-omap/control.h to mach-omap2/control.h OMAP: split plat-omap/common.c OMAP: McBSP: implement functional clock switching via clock framework OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c ... Fixed up trivial conflicts in arch/arm/mach-omap2/ {board-zoom-peripherals.c,devices.c} as per Tony
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
2010-10-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: Makefile - replace the use of <module>-objs with <module>-y crypto: hifn_795x - use cancel_delayed_work_sync() crypto: talitos - sparse check endian fixes crypto: talitos - fix checkpatch warning crypto: talitos - fix warning: 'alg' may be used uninitialized in this function crypto: cryptd - Adding the AEAD interface type support to cryptd crypto: n2_crypto - Niagara2 driver needs to depend upon CRYPTO_DES crypto: Kconfig - update broken web addresses crypto: omap-sham - Adjust DMA parameters crypto: fips - FIPS requires algorithm self-tests crypto: omap-aes - OMAP2/3 AES hw accelerator driver crypto: updates to enable omap aes padata: add missing __percpu markup in include/linux/padata.h MAINTAINERS: Add maintainer entries for padata/pcrypt
2010-10-08OMAP: control: move plat-omap/control.h to mach-omap2/control.hPaul Walmsley
Only OMAP2+ platforms have the System Control Module (SCM) IP block. In the past, we've kept the SCM header file in plat-omap. This has led to abuse - device drivers including it; includes being added that create implicit dependencies on OMAP2+ builds; etc. In response, move the SCM headers into mach-omap2/. As part of this, remove the direct SCM access from the OMAP UDC driver. It was clearly broken. The UDC code needs an indepth review for use on OMAP2+ chips. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Cory Maccarrone <darkstar6262@gmail.com> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2010-10-08OMAP2PLUS: WDT: Fix: Disable WDT after reset during initCharulatha V
Inorder to avoid any assumptions from bootloader, the watchdog timer module is reset during init. This enables the watchdog timer. Therefore, it is required to disable WDT after it is reset during init. Otherwise the system would reboot as per the default watchdog timer registers settings. Later, when the watchdog driver is loaded, the watchdog timer settings is adjusted as per the default timer_margin set in the driver and the driver would supports the normal operations supported by OMAP watchdog timer. Signed-off-by: Charulatha V <charu@ti.com> Reported-by: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-10-08Merge branch 'pm-hwmods' of ↵Tony Lindgren
ssh://master.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-linus
2010-10-04omap: devices: Avoid merge conflict between ASoC and OMAP hwmod changesJarkko Nikula
Upcoming ASoC multi-component and OMAP hwmod changes will conflict in arch/arm/mach-omap2/devices.c. Avoid this by moving a little bit include statement introduced by ASoC Multi-Component Support patch. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-01omap4 hsmmc: Register offset handlingkishore kadiyala
In OMAP4, as per new PM programming model, the legacy registers which were there in OMAP3 are all shifted by 0x100 while new one's are added from offset 0 to 0x10. For OMAP4, the register offset appending of 0x100 done in devices.c currently, is moved to driver file.This change fits in for current implementation as well as once the driver undergoes hwmod adaptation. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Kishore Kadiyala <kishore.kadiyala@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-09-29OMAP: WDT: Split OMAP1 and OMAP2PLUS device registrationVaradarajan, Charulatha
This patch splits omap_init_wdt() into separate omap_init_wdt() functions under mach-omap1 and mach-omap2 and set them up with subsys_initcall. Also it uses omap_device_build() API instead of platform_device_register() for watchdog timer device registration for OMAP2plus chips. For OMAP2plus chips, the device specific data defined in centralized hwmod database will be used. Signed-off-by: Charulatha V <charu@ti.com> Acked-by: Cousson, Benoit <b-cousson@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-27omap: mmc: extended to pass host capabilities from board fileSukumar Ghorai
wires variable is renamed, extended and this single variable to be used to pass the platform capabilities, e.g DDR mode. Also removed the hardcoded value was using as bus-width. Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-09-27omap: crypto: updates to enable omap aesDmitry Kasatkin
Updates to enable omap aes Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@nokia.com> [tony@atomide.com: updated to use CONFIG_ARCH_OMAP2/3 instead of old 24XX/34XX] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-09-03crypto: updates to enable omap aesDmitry Kasatkin
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@nokia.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-08-16Merge branch 'for-2.6.36' into for-2.6.37Mark Brown
Fairly simple conflicts, the most serious ones are the i.MX ones which I suspect now need another rename. Conflicts: arch/arm/mach-mx2/clock_imx27.c arch/arm/mach-mx2/devices.c arch/arm/mach-omap2/board-rx51-peripherals.c arch/arm/mach-omap2/board-zoom2.c sound/soc/fsl/mpc5200_dma.c sound/soc/fsl/mpc5200_dma.h sound/soc/fsl/mpc8610_hpcd.c sound/soc/pxa/spitz.c
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-04Merge branch 'v2.6.35-omap-mailbox-for-next' of ↵Tony Lindgren
git://gitorious.org/~doyu/lk/mainline into omap-for-linus Conflicts: arch/arm/mach-omap1/devices.c
2010-08-04omap: mailbox: standarize on 'omap-mailbox'Felipe Contreras
omap{1,2}-mailbox are modules that provide the 'omap-mailbox' driver. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: add IRQ namesFelipe Contreras
Will be useful to identify them later. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-07-05Removing dead OMAP_STIChristoph Egger
OMAP_STI doesn't exist in Kconfig, therefore removing all references for it from the source code. Signed-off-by: Christoph Egger <siccegge@cs.fau.de> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05omap: mux: Convert 2420 platform init code to use new mux codeTony Lindgren
Convert 2420 platform init code to use new mux code Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (46 commits) random: simplify fips mode crypto: authenc - Fix cryptlen calculation crypto: talitos - add support for sha224 crypto: talitos - add hash algorithms crypto: talitos - second prepare step for adding ahash algorithms crypto: talitos - prepare for adding ahash algorithms crypto: n2 - Add Niagara2 crypto driver crypto: skcipher - Add ablkcipher_walk interfaces crypto: testmgr - Add testing for async hashing and update/final crypto: tcrypt - Add speed tests for async hashing crypto: scatterwalk - Fix scatterwalk_done() test crypto: hifn_795x - Rename ablkcipher_walk to hifn_cipher_walk padata: Use get_online_cpus/put_online_cpus in padata_free padata: Add some code comments padata: Flush the padata queues actively padata: Use a timer to handle remaining objects in the reorder queues crypto: shash - Remove usage of CRYPTO_MINALIGN crypto: mv_cesa - Use resource_size crypto: omap - OMAP macros corrected padata: Use get_online_cpus/put_online_cpus ... Fix up conflicts in arch/arm/mach-omap2/devices.c
2010-05-20Merge branch 'omap4-i2c-init' into omap-for-linusTony Lindgren
2010-05-20omap: init the gpio pinmux for mmcstanley.miao
There is two gpio for mmc use, one is for card detecting, another is used for checking write protect. Intialize its pinmux in case the bootloader doesn't set it. Signed-off-by: Stanley.Miao <stanley.miao@windriver.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-05-17Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/include/asm/system.h arch/arm/mm/Kconfig
2010-05-14crypto: omap - OMAP macros correctedDmitry Kasatkin
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-10OMAP2/3: Add V4L2 DSS driver support in device.cVaibhav Hiremath
Add V4L2 DSS driver support in device.c Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-05-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Herbert Xu
2010-05-03crypto: omap - Updates omap sham device related platform codeDmitry Kasatkin
- registration with multi OMAP kernels support - clocks Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@nokia.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-04-29ARM: 6046/1: ARM: OMAP: register PMU IRQs during board initialisationWill Deacon
This patch updates the initialisation routines for the OMAP2 and OMAP3 boards so that they register their PMU IRQs with the PMU framework in the Kernel. Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-23OMAP4-HSMMC: FIX for MMC5 Controller IRQ Basekishore kadiyala
This patch fixes HSMMC Controller5 IRQ Base. Signed-off-by: Kishore Kadiyala <kishore.kadiyala@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-23omap4: Use irq line defines from irq-44xx.hSantosh Shilimkar
This patch removes all the omap4 specific irq line defines from plat/irqs.h and includes auto-generated irqs-44xx.h All the legacy naming style defines are replaced with the one from irqs-44xx.h Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Reviewed-by: Paul Walmsley <paul@pwsan.com> [tony@atomide.com: updated to compile with usb-musb.c] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap2/3: Fix initcalls for multi-omapTony Lindgren
Otherwise the wrong initcalls can run. Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap2/3/4: Fix mbox init for multi-omapTony Lindgren
Fix mbox init for multi-omap Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: mux: Replace omap_cfg_reg() with new style signal or gpio functionsTony Lindgren
Replace omap_cfg_reg() with new style signal or gpio functions Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap: mailbox: Add resources and mailbox register base address for OMAP4 mailboxC A Subramaniam
This patch adds resource information of mailbox driver for OMAP4 mailbox module. Register base address also added Signed-off-by: C A Subramaniam <subramaniam.ca@ti.com> Signed-off-by: Ramesh Gupta G <grgupta@ti.com> Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap3: HSMMC2 8-bit mux configurationMadhu
Add support for omap hsmmc2 8-bit mux configuration. Signed-off-by: Madhusudhan Chikkature <madhu.cr@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap3630: Add HSMMC related checksMadhu
Change the cpu_is_omap3430() check to cpu_is_omap34xx() to allow HSMMC1/2 mux configuration for omap3630. Signed-off-by: Madhusudhan Chikkature <madhu.cr@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-24omap: Fix mcspi compile for 2420Tony Lindgren
Commit 7869c0b9ed44404bbc675ef76f8ccb3be5496f39 added support for additional McSPI ports. Unfortunately that broke compile for 2420. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-23spi: McSPI support for OMAP4Syed Rafiuddin
tAdd adds McSPI support for OMAP4430 SDP platform. All the base addresses are changed between OMAP1/2/3 and OMAP4. The fields of the resource structures are filled at runtime to have McSPI support on OMAP4. Signed-off-by: Syed Rafiuddin <rafiuddin.syed@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23omap4: mmc driver support on OMAP4kishore kadiyala
Add basic support for all 5 MMC controllers on OMAP4. This patch doesn't include mmc-regulator support Signed-off-by: Kishore Kadiyala <kishore.kadiyala@ti.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Acked-by: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Cc: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-28OMAP3: MMC: Add mux for pinsVikram Pandita
For OMAP3 add MMC1 MMC2 pin mux MMC3 mux is not added as there are multiple configurations possible, so the muxing is left to be done in board file. Signed-off-by: Vikram Pandita <vikram.pandita@ti.com> Signed-off-by: Chikkature Rajashekar <madhu.cr@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-05-12ARM: OMAP2: Fix SPI driver failure on 2420 when running multi-omap configJarkko Nikula
SPI driver will do unhandled fault on OMAP2420 if trying to probe non-existing SPI busses. Register those additional busses runtime only for cpus having them. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-04-23ARM: OMAP2: Remove defines and resource init for OMAP24XX EACJarkko Nikula
There is no anymore legacy driver for OMAP24XX Enhanced Audio Controller in linux-omap and it was newer in mainline so cleanup these unneeded defines and initialization code. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-25Merge branch 'for-next' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
2009-03-23ARM: OMAP3: Add base address definitions and resources for OMAP 3 IS, v2Tony Lindgren
This replaces earlier patch from Sergio Aguirre titled "[REVIEW PATCH 03/14] OMAP34XX: CAM: Resources fixes". Signed-off-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23omap mailbox: fix empty struct device for omap2Hiroshi DOYU
2009-03-23omap mailbox: add initial omap3 supportHiroshi DOYU
2009-02-08[ARM] omap: hsmmc: new short connection id namesRussell King
... rather than the clock names themselves. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] omap: ensure devname is set for dummy devicesRussell King
This is needed to use these with the clkdev helpers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-29ARM: OMAP: Fix hsmmc init, v2Tony Lindgren
The naming accidentally broke while changing the name for the driver to not to conflict with the other mmc driver. Signed-off-by: Tony Lindgren <tony@atomide.com>
