path: root/arch/arm/mach-omap2/control.c
2008-07-03ARM: OMAP: Introduce omap_globals and prcm access functions for multi-omapTony Lindgren
New struct omap_globals contains the omap processor specific module bases. Use omap_globals to set the various base addresses to make detecting omap chip type simpler. Also introduce OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS for future multi-omap patches. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Add common register access for 24xx and 34xxPaul Walmsley
This patch adds common register access for 24xx and 34xx power and clock management in order to share code between 24xx and 34xx. Only change USB platform init code to use new register access, other access will be changed in later patches. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
