path: root/arch/arm/mach-omap2/clockdomains.h
2010-12-21OMAP2+: clockdomains: move clockdomain static data to .c filesPaul Walmsley
Static data should be declared in .c files, not .h files. It should be possible to #include .h files at any point without creating multiple copies of the same data. We converted the clock data to .c files some time ago. This patch does the same for the clockdomain data. Signed-off-by: Paul Walmsley <paul@pwsan.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP: powerdomain: Move static allocations from powerdomains.h to a .c fileRajendra Nayak
powerdomains.h header today has only static definitions. Adding any function declarations into it and including it in multiple source file is expected to cause issues. Hence move all the static definitions from powerdomains.h file into powerdomains_data.c file. Also, create a new powerdomain section of the mach-omap2/Makefile, and rearrange the prcm-common part of the Makefile, now that the powerdomain code is in its own Makefile section. Signed-off-by: Rajendra Nayak <rnayak@ti.com> [paul@pwsan.com: rearrange Makefile changes, tweaked commit message] Signed-off-by: Paul Walmsley <paul@pwsan.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-02-15omap2: Convert ARCH_OMAP24XX to ARCH_OMAP2Tony Lindgren
Convert ARCH_OMAP24XX to ARCH_OMAP2 Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-01-29OMAP2+ powerdomains/clockdomains: prepare for multi-OMAP configsPaul Walmsley
Convert CONFIG_ARCH_OMAP34XX to CONFIG_ARCH_OMAP3, and CONFIG_ARCH_OMAP24XX to CONFIG_ARCH_OMAP2, in preparation for Tony's multi-OMAP patches. While here, update some copyrights, convert instances of "34xx" to "3xxx" where applicable, and convert preprocessor directives of the form #if defined(CONFIG_ARCH_OMAP2) | defined(CONFIG_ARCH_OMAP3) to #if defined(CONFIG_ARCH_OMAP2) || defined(CONFIG_ARCH_OMAP3) for standardization. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com>
2010-01-26OMAP2 clockdomain: modem clockdomain is only present on OMAP2430Paul Walmsley
For some reason, previously, we included the MDM clockdomain on all 24xx, but the stacked die-on-die modem configuration (chassis mode) is only available on OMAP2430. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-01-26OMAP2/3 clockdomains: split shared structures so usecounting worksPaul Walmsley
Previously some of the clockdomain wakeup/sleep dependency structures were shared between several domains. For the subsequent wakeup and sleep dependency usecounting patch to work, these can no longer be shared. This patch splits the shared structures apart. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-01-26OMAP2/3 clkdm/pwrdm: move wkdep/sleepdep handling from pwrdm to clkdmPaul Walmsley
Move clockdomain wakeup dependency and sleep dependency data structures from the powerdomain layer to the clockdomain layer, where they belong. These dependencies were originally placed in the powerdomain layer due to unclear documentation; however, it is clear now that these dependencies are between clockdomains. For OMAP2/3, this is not such a big problem, but for OMAP4 this needs to be fixed. Thanks to Benoît Cousson <b-cousson@ti.com> for his advice on this patch. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com>
2010-01-26ARM: OMAP4 clock domains : Add the missing Clock Domain StructureAbhijit Pagare
One of the clock domains was missing from the auto-generated file. It has been added here. Signed-off-by: Abhijit Pagare <abhijitpagare@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-01-26ARM: OMAP4: PM: Adapt the existing OMAP2/3 Clock Domain Frameworks.Abhijit Pagare
The introduction of the OMAP4 Clock Domain framework requires some adaptaions to be done in the earlier files to place the common and uncommon data in the proper places where they belong. Signed-off-by: Abhijit Pagare <abhijitpagare@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Rajendra Nayak <rnayak@ti.com>
2010-01-26ARM: OMAP4: PM: Make OMAP3 Clock-domain framework compatible for OMAP4.Abhijit Pagare
Here the ".clkstctrl_reg" field is added to the clockdomain stucture as the module offsets for OMAP4 do not map one to one for powerdomains and clockdomains as it used to for OMAP3. Hence we need to use absolute addresses to access the control registers. Some of the clock domains have modules falling in the address space of PRM partition. Hence necessitating the use of absolute adresses. Signed-off-by: Abhijit Pagare <abhijitpagare@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Rajendra Nayak <rnayak@ti.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-05-28OMAP3: PM: D2D clockdomain supports SW supervised transitionsKevin Hilman
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-02-23[ARM] OMAP3: update ES level flags to discriminate between post-ES2 revisionsPaul Walmsley
Some OMAP3 chip behaviors change in ES levels after ES2. Modify the existing omap_chip flags to add options for ES3.0 and ES3.1. Add a new macro, CHIP_GE_OMAP3430ES2, to cover ES levels from ES2 onwards - a common pattern for OMAP3 features. Update all current users of the omap_chip macros to use this new macro. Also add CHIP_GE_OMAP3430ES3_1 to cover the USBTLL SAR errata case (described and fixed in the following patch) Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP3: PM: Emu_pwrdm is switched off by hardware even when sdti is in useJouni Hogander
Using sdti doesn't keep emu_pwrdm on if hardware supervised pwrdm transitions are used. This causes sdti stop to work when power management is initialized and hardware supervised pwrdm control is enabled. This patch disables hardware supervised pwrdm control for emu_pwrdm. Now emu_pwrdm is switched off on boot by software when it is not used. Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP3 PRCM: add DPLL1-5 powerdomains, clockdomains; mark clocksPaul Walmsley
Each DPLL exists in its own powerdomain (cf 34xx TRM figure 4-18) and clockdomain; so, create powerdomain and clockdomain structures for them. Mark each DPLL clock as belonging to their respective DPLL clockdomain. cf. 34xx TRM Table 4-27 (among other references). linux-omap source commits are acdb615850b9b4f7d1ab68133a16be8c8c0e7419 and a8798a48f33e9268dcc7f30a4b4a3ce4220fe0c9. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP2/3 clockdomains: add CM and PRM clkdmsPaul Walmsley
Add clockdomains for the CM and PRM. These will ultimately replace the "wkup_clkdm", which appears to not actually exist on the hardware. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP2/3 clockdomains: combine pwrdm, pwrdm_name into union in struct ↵Paul Walmsley
clockdomain struct clockdomain contains a struct powerdomain *pwrdm and const char *pwrdm_name. The pwrdm_name is only used at initialization to look up the appropriate pwrdm pointer. Combining these into a union saves about 100 bytes on 3430SDP. This patch should not cause any change in kernel function. Updated to gracefully handle autodeps that contain invalid powerdomains, per Russell King's review comments. Boot-tested on BeagleBoard ES2.1. linux-omap source commit is 718fc6cd4db902aa2242a736cc3feb8744a4c71a. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-19ARM: OMAP2: Clockdomain: Integrate OMAP3 clocks with clockdomain codePaul Walmsley
This patch integrates the OMAP3 clock tree with the clockdomain code. This patch: - marks OMAP34xx clocks with their corresponding clockdomain. - adds code to convert the clockdomain name to a clockdomain pointer in the struct clk during clk_register(). - modifies OMAP2 clock usecounting to call into the clockdomain code when clocks are enabled or disabled. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-08-19ARM: OMAP2: Clockdomain: Encode OMAP2/3 clockdomainsPaul Walmsley
Add clockdomain definitions for OMAP24xx and OMAP34xx chips. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
