In preparation for adding OMAP4-specific PRCM accessor/mutator
functions, split the existing OMAP2/3 PRCM code into OMAP2/3-specific
files. Most of what was in mach-omap2/{cm,prm}.{c,h} has now been
moved into mach-omap2/{cm,prm}2xxx_3xxx.{c,h}, since it was
OMAP2xxx/3xxx-specific.
This process also requires the #includes in each of these files to be
changed to reference the new file name. As part of doing so, add some
comments into plat-omap/sram.c and plat-omap/mcbsp.c, which use
"sideways includes", to indicate that these users of the PRM/CM includes
should not be doing so.
Thanks to Felipe Contreras <felipe.contreras@gmail.com> for comments on this
patch.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Jarkko Nikula <jhnikula@gmail.com>
Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Acked-by: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Felipe Contreras <felipe.contreras@gmail.com>
Acked-by: Felipe Contreras <felipe.contreras@gmail.com>
Cc: Greg Kroah-Hartman <greg@kroah.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
Tested-by: Rajendra Nayak <rnayak@ti.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
clock34xx_data.c now contains data for the OMAP34xx family, the
OMAP36xx family, and the OMAP3517 family, so rename it to
clock3xxx_data.c. Rename clock34xx.c to clock3xxx.c, and move the
chip family-specific clock functions to clock34xx.c, clock36xx.c, or
clock3517.c, as appropriate. So now "clock3xxx.*" refers to the OMAP3
superset.
The main goal here is to prepare to compile chip family-specific clock
functions only for kernel builds that target that chip family. To get to
that point, we also need to add CONFIG_SOC_* options for those other
chip families; that will be done in future patches, planned for 2.6.35.
OMAP4 is also affected by this. It duplicated the OMAP3 non-CORE DPLL
clkops structure. The OMAP4 variant of this clkops structure has been
removed, and since there was nothing else currently in clock44xx.c, it
too has been removed -- it can always be added back later when there
is some content for it. (The OMAP4 clock autogeneration scripts have been
updated accordingly.)
Cc: BenoƮt Cousson <b-cousson@ti.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Cc: Ranjith Lohithakshan <ranjithl@ti.com>
Cc: Tony Lindgren <tony@atomide.com>
