path: root/arch/arm/mach-omap2/clock.h
2006-09-25ARM: OMAP: Add support for forcing osc_ck onJuha Yrjola
Some boards might use the oscillator clock for powering external peripherals. Add support for making sure osc_ck stays active even when trying to go to sleep. Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-06-26ARM: OMAP: Fix gpt2_ick clock bitTony Lindgren
CM_ICLKEN1_CORE bit should be 4, not 0 as noted by Richard Woodruff. Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-04-02[ARM] 3426/1: ARM: OMAP: 1/8 Update clock frameworkTony Lindgren
Patch from Tony Lindgren Update OMAP clock framework from linux-omap tree. The highlights of the patch are: - Add support for omap730 clocks by Andrzej Zaborowski - Fix compile warnings by Dirk Behme - Add support for using dev id by Tony Lindgren and Komal Shah - Move memory timings and PRCM into separate files by Tony Lindgren Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-17ARM: OMAP: 3/4 Fix clock framework to use clk_enable/disable for omap2Tony Lindgren
This patch fixes OMAP clock framework to use clk_enable/disable instead of clk_use/unuse as specified in include/linux/clk.h. Signed-off-by: Tony Lindgren <tony@atomide.com>
2005-11-10[ARM] 3146/1: OMAP 3b/5: Add omap24xx clock frameworkTony Lindgren
Patch from Tony Lindgren This patch adds omap24xx specific clock code by Richard Woodruff, Nishant Menon, Tony Lindgren et al. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
