path: root/arch/arm/mach-omap2/clock.c
2011-03-11perf: add OMAP support for the new power eventsJean Pihet
The patch adds the new power management trace points for the OMAP architecture. The trace points are for: - default idle handler. Since the cpuidle framework is instrumented in the generic way there is no need to add trace points in the OMAP specific cpuidle handler; - SoC clocks changes (enable, disable, set_rate), - power domain states: the desired target state and -if different- the actually hit state. Because of the generic nature of the changes, OMAP3 and OMAP4 are supported. Tested on OMAP3 with suspend/resume, cpuidle, basic DVFS. Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-02-25OMAP3/4: DPLL: Add allow_idle/deny_idle support for all DPLL'sRajendra Nayak
All OMAP3/4 dpll's support hardware level autogating. Populate allow_idle/deny_idle function pointers for all DPLL's in clkops. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2011-02-25omap: clock: Check for enable/disable ops supportRajendra Nayak
Check if enable/disable operations are supported for a given clock node before attempting to call them. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2011-02-25OMAP: clockdomain: Arch specific funcs for clkdm_clk_enable/disableRajendra Nayak
Define the following architecture specific funtions for omap2/3/4 .clkdm_clk_enable .clkdm_clk_disable Convert the platform-independent framework to call these functions. Also rename the api's by removing the omap2_ preamble. Hence call omap2_clkdm_k_enable as clkdm_clk_enable and omap2_clkdm_clk_disable as clkdm_clk_disable.a Remove unused functions (_enable/_disable_hwsup) and unsed headers from clockdomain.c file. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-12-21OMAP2+: clockdomain: move header file from plat-omap to mach-omap2Paul Walmsley
The OMAP clockdomain code and data is all OMAP2+-specific. This seems unlikely to change any time soon. Move plat-omap/include/plat/clockdomain.h to mach-omap2/clockdomain.h. The primary point of doing this is to remove the temptation for unrelated upper-layer code to access clockdomain code and data directly. DSPBridge also uses the clockdomain headers for some reason, so, modify it also. The DSPBridge code should not be including the clockdomain headers; these should be removed. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Felipe Contreras <felipe.contreras@gmail.com> Cc: Greg Kroah-Hartman <greg@kroah.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP2/3: PRCM: split OMAP2/3-specific PRCM code into OMAP2/3-specific filesPaul Walmsley
In preparation for adding OMAP4-specific PRCM accessor/mutator functions, split the existing OMAP2/3 PRCM code into OMAP2/3-specific files. Most of what was in mach-omap2/{cm,prm}.{c,h} has now been moved into mach-omap2/{cm,prm}2xxx_3xxx.{c,h}, since it was OMAP2xxx/3xxx-specific. This process also requires the #includes in each of these files to be changed to reference the new file name. As part of doing so, add some comments into plat-omap/sram.c and plat-omap/mcbsp.c, which use "sideways includes", to indicate that these users of the PRM/CM includes should not be doing so. Thanks to Felipe Contreras <felipe.contreras@gmail.com> for comments on this patch. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Jarkko Nikula <jhnikula@gmail.com> Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Acked-by: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Felipe Contreras <felipe.contreras@gmail.com> Acked-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Greg Kroah-Hartman <greg@kroah.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-10-08OMAP2+: clock: reduce the amount of standard debugging while disabling ↵Paul Walmsley
unused clocks Reduce the amount of debugging generated by default when unused clocks are being disabled by the clock code. The previous code would only generate debug-level messages, but some people who wished to run production kernels with debug-level messages enabled reported that the large number of clock disable messages were slowing boot. Now to enable clock-by-clock disable messages, DEBUG needs to be defined in mach-omap2/clock.c. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Tuukka Tikkanen <tuukka.tikkanen@nokia.com> Cc: Tim Bird <tim.bird@am.sony.com>
2010-05-20OMAP2+ clock: clean up clkt_clksel.cPaul Walmsley
This patch cleans up arch/arm/mach-omap2/clkt_clksel.c. It: - makes several functions static that are not called outside the file; - adds documentation; - makes some code paths easier to read (hopefully), by breaking up compound statements and removing redundant checks; - converts some pr_err()s that indicate clock tree data problems into WARN()s, so they are more likely to be noticed; - and moves omap2_clk_round_rate() back into mach-omap2/clock.c, its proper home, since it is not clksel-specific. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-02-24OMAP2+ clock: revise omap2_clk_{disable,enable}()Paul Walmsley
Simplify the code in the omap2_clk_disable() and omap2_clk_enable() functions, reducing levels of indentation. This makes the code easier to read. Add some additional debugging pr_debug()s here also to help others understand what is going on. Revise the omap2_clk_disable() logic so that it now attempts to disable the clock's clockdomain before recursing up the clock tree. Simultaneously, ensure that omap2_clk_enable() is called on parent clocks first, before enabling the clockdomain. This ensures that a parent clock's clockdomain is enabled before the child clock's clockdomain. These sequences should be the inverse of each other. Revise the omap2_clk_enable() logic so that it now cleans up after itself upon encountering an error. Previously, an error enabling a parent clock could have resulted in inconsistent usecounts on the enclosing clockdomain. Remove the trivial _omap2_clk_disable() and _omap2_clk_enable() static functions, and replace it with the clkops calls that they were executing. For all this to work, the clockdomain omap2_clkdm_clk_enable() and omap2_clkdm_clk_disable() code must not return an error on clockdomains without CLKSTCTRL registers; so modify those functions to simply return 0 in that case. While here, add some basic kerneldoc documentation on both functions, and get rid of some old non-CodingStyle-compliant comments that have existed since the dawn of time (at least, the OMAP clock framework's time). Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Richard Woodruff <r-woodruff2@ti.com> Cc: Rajendra Nayak <rnayak@ti.com>
2010-02-24OMAP2/3 clock: combine OMAP2 & 3 boot-time MPU rate change codePaul Walmsley
The OMAP2 and OMAP3 boot-time MPU rate change code is almost identical. Merge them into mach-omap2/clock.c, and add kerneldoc documentation. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-02-24OMAP2 clock: drop DELAYED_APP clock flagPaul Walmsley
All of the clocks that are marked with DELAYED_APP are changed as part of the virt_prcm_set OPP virtual clock. On 24xx, these clocks all need to be changed as part of a group to keep the clock tree functional - hence the need for the VALID_CONFIG bit, which is not present on later OMAPs. These clocks should not be rate-changed independently. So prevent these clocks from being changed independently by dropping their .round_rate and .set_rate function pointers. It then turns out that the DELAYED_APP clock flag is no longer useful, so drop it and the associated code and renumber the clock flags. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Richard Woodruff <r-woodruff2@ti.com>
2010-02-24OMAP3/4 clock: split into per-chip family filesPaul Walmsley
clock34xx_data.c now contains data for the OMAP34xx family, the OMAP36xx family, and the OMAP3517 family, so rename it to clock3xxx_data.c. Rename clock34xx.c to clock3xxx.c, and move the chip family-specific clock functions to clock34xx.c, clock36xx.c, or clock3517.c, as appropriate. So now "clock3xxx.*" refers to the OMAP3 superset. The main goal here is to prepare to compile chip family-specific clock functions only for kernel builds that target that chip family. To get to that point, we also need to add CONFIG_SOC_* options for those other chip families; that will be done in future patches, planned for 2.6.35. OMAP4 is also affected by this. It duplicated the OMAP3 non-CORE DPLL clkops structure. The OMAP4 variant of this clkops structure has been removed, and since there was nothing else currently in clock44xx.c, it too has been removed -- it can always be added back later when there is some content for it. (The OMAP4 clock autogeneration scripts have been updated accordingly.) Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Ranjith Lohithakshan <ranjithl@ti.com> Cc: Tony Lindgren <tony@atomide.com>
2010-02-24OMAP2 clock: drop CONFIG_PARTICIPANT clock flagPaul Walmsley
It turns out that the only purpose of the CONFIG_PARTICIPANT clock flag is to prevent omap2_clk_set_rate() and omap2_clk_set_parent() from being executed on clocks with that flag set. The rate-changing component can be more directly accomplished by dropping the .set_rate and .round_rate function pointers from those CONFIG_PARTICIPANT struct clks. As far as the parent-changing component is concerned, it turns out that none of the CONFIG_PARTICIPANT clocks have multiple parent choices, so all that is necessary is for omap2_clk_set_parent() to bail out early if the new parent is equal to the old parent. Implement this change and get rid of the flag, which has always had a confusing name (it appears to be a Kconfig option, falsely). Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Richard Woodruff <r-woodruff2@ti.com>
2010-02-24OMAP2/3 clock: Extend find_idlest() to pass back idle state valueRanjith Lohithakshan
Current implementation defines clock idle state indicators based on the cpu information (cpu_is_omap24xx() or cpu_is_omap34xx()) in a system wide manner. This patch extends the find_idlest() function in clkops to pass back the idle state indicator for that clock, thus allowing idle state indicators to be defined on a per clock basis if required. This is specifically needed on AM35xx devices as the new IPSS clocks indicates the idle status (0 is idle, 1 is ready) in a way just opposite to how its handled in OMAP3 (0 is ready, 1 is idle). Signed-off-by: Ranjith Lohithakshan <ranjithl@ti.com> [paul@pwsan.com: updated to apply after commit 98c45457 et seq.] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-01-26OMAP2/3/4 clock: combine all omap2_clk_functionsPaul Walmsley
The struct clk_functions for OMAP2, 3, and 4 are all essentially the same, so combine them. This removes one multi-OMAP kernel impediment and saves memory on multi-OMAP builds. The stubs for omap2_clk_{init,exit}_cpufreq() code will removed once the OPP layer code that's currently in Kevin's PM branch is merged. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com>
2010-01-26OMAP2 clock: move all static functions to the top of the filePaul Walmsley
Move static functions to the top of the file and ensure that their names are prefixed with an underscore to conform with the practice in the newer OMAP clock code files. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-01-26OMAP2/3/4 clock: move clksel clock functions into mach-omap2/clkt_clksel.cPaul Walmsley
Move all clksel-related clock functions from mach-omap2/clock.c to mach-omap2/clkt_clksel.c. This is intended to make the clock code easier to understand, since all of the functions needed to manage clksel clocks are now located in their own file, rather than being mixed with other, unrelated functions. Clock debugging is also now more finely-grained, since the DEBUG macro can now be defined for clksel clocks alon. This should reduce unnecessary console noise when debugging. Also, if at some future point the mach-omap2/ directory is split into OMAP2/3/4 variants, this clkt file can be moved to the plat-omap/ directory to be shared. Thanks to Alexander Shishkin <virtuoso@slind.org> for his comments to improve the patch description. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Alexander Shishkin <virtuoso@slind.org>
2010-01-26OMAP2/3/4 clock: move DPLL clock functions into mach-omap2/clkt_dpll.cPaul Walmsley
Move all DPLL-related clock functions from mach-omap2/clock.c to mach-omap2/clkt_dpll.c. This is intended to make the clock code easier to understand, since all of the functions needed to manage DPLLs are now located in their own file, rather than being mixed with other, unrelated functions. Clock debugging is also now more finely-grained, since the DEBUG macro can now be defined for DPLLs alone. This should reduce unnecessary console noise when debugging. Also, if at some future point the mach-omap2/ directory is split into OMAP2/3/4 variants, this clkt file can be moved to the plat-omap/ directory to be shared. Thanks to Alexander Shishkin <virtuoso@slind.org> for his comments to improve the patch description. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Alexander Shishkin <virtuoso@slind.org>
2010-01-26ARM: OMAP4 clock framework: Remove the checks preventing OMAP4 clockdomain ↵Abhijit Pagare
validation The clockdomain related code being in place, it is not necessary to have some part of the clock code commented out. This would help the validation of the clockdomain functions using the clock level interfaces. Signed-off-by: Abhijit Pagare <abhijitpagare@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-01-26OMAP clock: make the fixed divisor clock code available for all OMAPsPaul Walmsley
One of the OMAP1 clocks can use the fixed divisor recalculation code introduced in the OMAP2 clock code, so rename the omap2_fixed_divisor_recalc() function to omap_fixed_divisor_recalc() and make it available to all OMAPs. A followup patch converts the OMAP1 clock. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-12-11ARM: OMAP4: PM: Add init api for DPLL nodesRajendra Nayak
An api at init for all dpll nodes seem to be needed to reparent the dpll clk node to its bypass clk in case the dpll is in bypass. If not done this causes sequencing issues at init during propogate_rate. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com>
2009-12-11ARM: OMAP4: PM: Add support for OMAP4 dpll api'sRajendra Nayak
Most of the dpll api's from dpll.c are reused for OMAP4. This patch does extend a few api's for OMAP4 support. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com>
2009-12-11ARM: OMAP4: PM: Add dummy hooks for OMAP4 dpll api'sRajendra Nayak
This patch adds dummy hooks for OMAP4 dpll api's. Removes dummy hooks for clkdev api's and enables CLKDEV for OMAP4. Also comments clockdomain calls from within the clock framework as its not supported yet for OMAP4. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-02OMAP: PM: Hook into PM countersPeter 'p2' De Schrijver
This patch modifies the clock, clockdomain and OMAP3 specific powerdomain code to call the PM counter infrastructure whenever one or more powerdomains might have changed state. Signed-off-by: Peter 'p2' De Schrijver <peter.de-schrijver@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-07-24OMAP2/3 clock: split, rename omap2_wait_clock_ready()Paul Walmsley
Some OMAP2/3 hardware modules have CM_IDLEST attributes that are not handled by the current omap2_wait_clock_ready() code. In preparation for patches that fix the unusual devices, rename the function omap2_wait_clock_ready() to omap2_wait_module_ready() and split it into three parts: 1. A clkops-specific companion clock return function (by default, omap2_clk_dflt_find_companion()) 2. A clkops-specific CM_IDLEST register address and bit shift return function (by default, omap2_clk_dflt_find_idlest()) 3. Code to wait for the CM to indicate that the module is ready (omap2_cm_wait_idlest()) Clocks can now specify their own custom find_companion() and find_idlest() functions; used in subsequent patches. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-06-19OMAP2 clock/powerdomain: off by 1 error in loop timeout comparisonsRoel Kluin
with while (i++ < MAX_CLOCK_ENABLE_WAIT); i can reach MAX_CLOCK_ENABLE_WAIT + 1 after the loop, so if (i == MAX_CLOCK_ENABLE_WAIT) that's still success. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-05-26Merge branch 'omap-clock-upstream' of git://git.pwsan.com/linux-2.6 into ↵Tony Lindgren
for-next
2009-05-25ARM: OMAP2/3: Remove OMAP_PRM_REGADDR and OMAP2_PRM_BASETony Lindgren
Remove OMAP_PRM_REGADDR and use processor specific defines instead. Also fold in a patch from Kevin Hilman to add _OFFSET #defines for the PRCM registers to be used with the prm_[read|write]_* macros. These are used extensively in the forthcoming OMAP PM support. Also remove now unused OMAP2_PRM_BASE. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-05-12OMAP3 clock: lessen amount of noisy messagesArtem Bityutskiy
On our system we see the following messages: Disabling unused clock "gpt2_ick" Disabling unused clock "gpt3_ick" Disabling unused clock "gpt4_ick" Disabling unused clock "gpt5_ick" ... The messages have KERN_INFO level and if you have serial console, they normally go there. I do not think it is good idea to print that much stuff there. Moreover, messages are not properly prefixed and for mortals it is not immeadietly clear where they come from. Let's give them debugging level instead. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> [paul@pwsan.com: trimmed debugging output in patch description]
2009-05-12OMAP3 clock: use pr_debug() rather than pr_info() in some clock change codePaul Walmsley
The CORE DPLL M2 frequency change code should use pr_debug(), not pr_info(), for its debug messages. Same with omap2_clksel_round_rate_div(). While here, convert a few printk(KERN_ERR .. into pr_err(). Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-03-19Merge branch 'omap-clks3' into develRussell King
Conflicts: arch/arm/mach-omap2/clock.c
2009-03-03[ARM] omap: clk_set_parent: deny changing parent if clock is enabledRussell King
Richard Woodruff writes: | The historic usage of this has been against single use leaf clocks | (1st instance of gptimer). When it was used it did: | clk_get() | clk_set_parent() | clk_enable() | | This usage was ok for that. Use on a disabled clock is needed. | | If there are multiple users on the clock or it is enabled there are | problems. | | The call can still be unfriendly if 2 different drivers are using the | clock with their own clock get/enable. It might be the function should | return an error if usecount != 0 to stop surprises. It is all around | better if the parenting is done when the clock is off. This is a good reason to ensure that the clock is not enabled when clk_set_parent() is called. Acked-by: Richard Woodruff <r-woodruff2@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-19[ARM] omap: add support for bypassing DPLLsRussell King
This roughly corresponds with OMAP commits: 7d06c48, 3241b19, 88b5d9b, 18a5500, 9c909ac, 5c6497b, 8b1f0bd, 2ac1da8. For both OMAP2 and OMAP3, we note the reference and bypass clocks in the DPLL data structure. Whenever we modify the DPLL rate, we first ensure that both the reference and bypass clocks are enabled. Then, we decide whether to use the reference and DPLL, or the bypass clock if the desired rate is identical to the bypass rate, and program the DPLL appropriately. Finally, we update the clock's parent, and then disable the unused clocks. This keeps the parents correctly balanced, and more importantly ensures that the bypass clock is running whenever we reprogram the DPLL. This is especially important because the procedure for reprogramming the DPLL involves switching to the bypass clock. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-19[ARM] omap: fix clock reparenting in omap2_clk_set_parent()Russell King
When changing the parent of a clock, it is necessary to keep the clock use counts balanced otherwise things the parent state will get corrupted. Since we already disable and re-enable the clock, we might as well use the recursive versions instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-14[ARM] omap: fix _omap2_clksel_get_src_field()Russell King
_omap2_clksel_get_src_field() was returning the first entry which was either the default _or_ applicable to the SoC. This is wrong - we should be returning the first default which is applicable to the SoC. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-14[ARM] omap: fix omap2_divisor_to_clksel() error return valueRussell King
The error checks for omap2_divisor_to_clksel() and comment disagree with the actual value returned on error. Fix this to return the correct error value. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-14[ARM] omap: arrange for clock recalc methods to return the rateRussell King
linux-omap source commit 33d000c99ee393fe2042f93e8422f94976d276ce introduces a way to "dry run" clock changes before they're committed. However, this involves putting logic to handle this into each and every recalc function, and unfortunately due to the caching, led to some bugs. Solve both of issues by making the recalc methods always return the clock rate for the clock, which the caller decides what to do with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] omap: fix clockdomain enable/disable orderingRussell King
Based on a patch from Paul Walmsley <paul@pwsan.com>: omap2_clk_enable() should enable a clock's clockdomain before attempting to enable its parent clock's clockdomain. Similarly, in the unlikely event that the parent clock enable fails, the clockdomain should be disabled. linux-omap source commit is 6d6e285e5a7912b1ea68fadac387304c914aaba8. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] omap: fix usecount decrement bugRussell King
Based upon a patch from Paul Walmsley <paul@pwsan.com>: If _omap2_clk_enable() fails, the clock's usecount must be decremented by one no matter whether the clock has a parent or not. but reorganised a bit. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP2/3 clock: convert remaining MPU barriers into OCP barriersPaul Walmsley
Several parts of the OMAP2/3 clock code use wmb() to try to ensure that the hardware write completes before continuing. This approach is problematic: wmb() only ensures that the write leaves the ARM. It does not ensure that the write actually reaches the endpoint device. The endpoint device in this case - either the PRM, CM, or SCM - is three interconnects away from the ARM - and the final interconnect is low-speed. And the OCP interconnects will post the write, and who knows how long that will take to complete. So the wmb() is not what we want. Worse, the wmb() is indiscriminate; it causes the ARM to flush any other unrelated buffered writes and wait for the local interconnect to acknowledge them - potentially very expensive. Fix this by converting the wmb()s into readbacks of the same PRM/CM/SCM register. Since the PRM/CM/SCM devices use a single OCP thread, this will cause the MPU to block while waiting for posted writes to that device to complete. linux-omap source commit is 260f5487848681b4d8ea7430a709a601bbcb21d1. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP2xxx clock: consolidate DELAYED_APP clock commits; fix barrierPaul Walmsley
Consolidate the commit code for DELAYED_APP clocks into a subroutine, _omap2xxx_clk_commit(). Also convert the MPU barrier wmb() into an OCP barrier, since with an MPU barrier, we have no guarantee that the write actually reached the endpoint device. linux-omap source commit is 0f5bdb736515801b296125d16937a21ff7b3cfdc. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP2/3 clock: don't use a barrier after clk_disable()Paul Walmsley
clk_disable() previously used an ARM barrier, wmb(), to try to ensure that the hardware write completed before continuing. There are some problems with this approach. The first problem is that wmb() only ensures that the write leaves the ARM -- not that it actually reaches the endpoint device. In this case, the endpoint device - either the PRM, CM, or SCM - is three interconnects away from the ARM, and the final interconnect is low-speed. And the OCP interconnects will post the write, who knows how long that will take to complete. So the wmb() is not really what we want. Worse, the wmb() is indiscriminate; it will cause the ARM to flush any other unrelated buffered writes and wait for the local interconnect to acknowledge them - potentially very expensive. This first problem could be fixed by doing a readback of the same PRM/CM/SCM register. Since these devices use a single OCP thread, this will cause the MPU to wait for the write to complete. But the primary problem is a conceptual one: clk_disable() should not need any kind of barrier. clk_enable() needs one since device driver code must not access a device until its clocks are known to be enabled. But clk_disable() has no such restriction. Since blocking the MPU on a PRM/CM/SCM write can be a very high-latency operation - several hundred MPU cycles - it's worth avoiding this barrier if possible. linux-omap source commit is f4aacad2c0ed1055622d5c1e910befece24ef0e2. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] omap: create a proper tree of clocksRussell King
Traditionally, we've tracked the parent/child relationships between clk structures by setting the child's parent member to point at the upstream clock. As a result, when decending the tree, we have had to scan all clocks to find the children. Avoid this wasteful scanning by keeping a list of the clock's children. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP3: PM: Make sure clk_disable_unused() order is correctTero Kristo
Current implementation will disable clocks in the order defined in clock34xx.h, at least DPLL4_M2X2 will hang in certain cases (and prevent retention / off) if clocks are not disabled in correct order. This patch makes sure the parent clocks will be active when disabling a clock. linux-omap source commit is 672680063420ef8c8c4e7271984bb9cc08171d29. Signed-off-by: Tero Kristo <tero.kristo@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP2 SDRC: move mach-omap2/memory.h into mach/sdrc.hPaul Walmsley
Move the contents of the arch/arm/mach-omap2/memory.h file to the existing mach/sdrc.h file, and remove memory.h. Modify files which include memory.h to include asm/arch/sdrc.h instead. linux-omap source commit is e7ae2d89921372fc4b9712a32cc401d645597807. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP2/3 clock: clean up mach-omap2/clock.cPaul Walmsley
This patch rolls up several cleanup patches. 1. Some unnecessarily verbose variable names are used in several clock.c functions; clean these up per CodingStyle. 2. Remove omap2_get_clksel() and just use clk->clksel_reg and clk->clksel_mask directly. 3. Get rid of void __iomem * usage in omap2_clksel_get_src_field. Prepend the function name with an underscore to highlight that it is a static function. linux-omap source commits are 7fa95e007ea2f3c4d0ecd2779d809756e7775894, af0ea23f1ee4a5bea3b026e38761b47089f9048a, and 91c0c979b47c44b08f80e4f8d4c990fb158d82c4. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP3 clock: avoid invalid FREQSEL values during DPLL rate roundingPaul Walmsley
The DPLL FREQSEL jitter correction bits are set based on a table in the 34xx TRM, Table 4-38, according to the DPLL's internal clock frequency "Fint." Several Fint frequency ranges are missing from this table. Previously, we allowed these Fint frequency ranges to be selected in the rate rounding code, but did not change the FREQSEL bits. Correspondence with the OMAP hardware team indicates that Fint values not in the table should not be used. So, prevent them from being selected during DPLL rate rounding. This removes warnings and also can prevent the chip from locking up. The first pass through the rate rounding code will update the DPLL max and min dividers appropriately, so later rate rounding passes will run faster than the first. Peter de Schrijver <peter.de-schrijver@nokia.com> put up with several test cycles of this patch - thanks Peter. linux-omap source commit is f9c1b82f55b60fc39eaa6e7aa1fbe380c0ffe2e9. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Peter de Schrijver <peter.de-schrijver@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP3 clock: optimize DPLL rate rounding algorithmPaul Walmsley
The previous DPLL rate rounding algorithm counted the divider (N) down from the maximum to 1. Since we currently use a broad DPLL rate tolerance, and lower N values are more power-efficient, we can often bypass several iterations through the loop by counting N upwards from 1. Peter de Schrijver <peter.de-schrijver@nokia.com> put up with several test cycles of this patch - thanks Peter. linux-omap source commit is 6f6d82bb2f80fa20a841ac3e95a6f44a5a156188. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Peter de Schrijver <peter.de-schrijver@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08[ARM] OMAP3 clock: remove unnecessary dpll_data dereferencesPaul Walmsley
Remove some clutter from omap2_dpll_round_rate(). linux-omap source commit is 4625dceb8583c02a6d67ededc9f6a8347b6b8cb7. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
