path: root/arch/arm/mach-omap2/board-zoom3.c
2010-07-16ARM: OMAP: Convert to use ->reserve method to reserve boot time memoryRussell King
2010-05-03omap2/3: Fix DEBUG_LL for omap zoom2/3Tony Lindgren
Zoom2 and 3 have UARTs only on the external debug board. GPMC needs to be mapped early to use it for DEBUG_LL. Additionally, 0xfb000000 overlaps with other areas, so use 0xfa400000 for the virtual address instead. Note that with the pending serial.c patches you need to set console=ttyS0,115200n8 as it will be the only UART mapped. To use DEBUG_LL, you need to pass also earlyprintk in cmdline. Cc: Allen Pais <allen.pais@ti.com> Acked-by: Vikram Pandita <vikram.pandita@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-03-11omap2/3/4: ehci: avoid compiler error with touchbookFelipe Balbi
the early_param() call in board-omap3touchbook.c expands to: static const char __setup_str_early_touchbook_revision[] __section(.init.rodata) _aligned(1) = tbr; [...] and we have a non-const variable being added to the same section: static struct ehci_hcd_omap_platform_data ehci_pdata __section(.init.rodata); because of that, gcc generates a section type conflict which can (and actually should) be avoided by marking const every variable marked with __initconst. This patch fixes that for the ehci_hdc_omap_platform_data. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-17omap: zoom3: enable ehci supportvikram pandita
Zoom3 board has omap3630 EHCI port2 connected to a ULPI phy. GPIO_64 is connected to the PHY reset pin. Signed-off-by: Vikram Pandita <vikram.pandita@ti.com> Cc: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap2/3/4: Fix omap2_map_common_io for multi-omapTony Lindgren
Fix omap2_map_common_io for multi-omap Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap: Clean the serial port definesTony Lindgren
This way we don't have conflicts with the defines with compiling in multiple omaps. Set the addresses for uarts in struct omap_globals for the early serial init code. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: mux: Add 36xx CBP package supportTony Lindgren
Add 36xx CBP package support Cc: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap3: zoom: Introduce zoom3 board supportvikram pandita
Zoom3 is the next version of Zoom2 board. There has been a silicon update from zoom2 to zoom3. Zoom2 has OMAP34xx Zoom3 has OMAP3630 [1] Zoom3 = OMAP3630 SOM board [2] + same zoom2 main board [3] + same debugboard Zoom3 has a SDRAM part from Hynix Zoom2 had SDRAM part from micron Hynix memory timings are contributed by: Chalhoub, Nicole and Bour, Vincent Reuse the zoom2 files as much for zoom3, as at board level, there is no change at all. References: (courtesy Nishant Menon) [1] OMAP3630 http://focus.ti.com/general/docs/wtbu/wtbuproductcontent.tsp?templateId=6123&navigationId=12836&contentId=52606 [2] SOM boards http://logicpd.com/products/system-modules/texas-instruments-omap35x-som-lv [3] Zoom2 boards http://logicpd.com/products/development-kits/texas-instruments-zoom%E2%84%A2-omap34x-ii-mdp OMAP3630: Signed-off-by: Vikram Pandita <vikram.pandita@ti.com> Cc: Nicole Chalhoub <n-chalhoub@ti.com> Cc: Vincent Bour <v-bour@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
