path: root/arch/arm/mach-omap2/board-overo.c
2010-05-20omap: Overo: Add support for second ethernet portSteve Sakoman
Some Overo add-on boards include a second ethernet port. This patch adds support for that second port. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-03-11omap2/3/4: ehci: avoid compiler error with touchbookFelipe Balbi
the early_param() call in board-omap3touchbook.c expands to: static const char __setup_str_early_touchbook_revision[] __section(.init.rodata) _aligned(1) = tbr; [...] and we have a non-const variable being added to the same section: static struct ehci_hcd_omap_platform_data ehci_pdata __section(.init.rodata); because of that, gcc generates a section type conflict which can (and actually should) be avoided by marking const every variable marked with __initconst. This patch fixes that for the ehci_hdc_omap_platform_data. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-19omap: musb: Pass board specific data from board fileMaulik Mankad
Pass board specific data for MUSB (like interface_type, mode etc) from board file by defining board specific structure. Each board file can define this structure based on its requirement and pass this information to the driver. Signed-off-by: Maulik Mankad <x0082077@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Felipe Balbi <felipe.balbi@nokia.com> Cc: David Brownell <david-b@pacbell.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Gupta Ajay Kumar <ajay.gupta@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap: Rename hsmmc symbols to reflect independence from twl4030Adrian Hunter
hsmmc.[ch] no longer has any dependency on twl4030 and variable names should be renamed to reflect that. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap: Rename mmc-twl4030 files to hsmmcAdrian Hunter
mmc-twl4030.[ch] no longer has any dependency on twl4030 and should be renamed to reflect that. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap2/3/4: Fix omap2_map_common_io for multi-omapTony Lindgren
Fix omap2_map_common_io for multi-omap Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-13mfd: Rename twl4030* driver files to enable re-useSantosh Shilimkar
The upcoming TWL6030 is companion chip for OMAP4 like the current TWL4030 for OMAP3. The common modules like RTC, Regulator creates opportunity to re-use the most of the code from twl4030. This patch renames few common drivers twl4030* files to twl* to enable the code re-use. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-11omap: mux: Remove old mux code for 34xxTony Lindgren
Remove old mux code for 34xx Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: mux: Replace omap_cfg_reg() with new style signal or gpio functionsTony Lindgren
Replace omap_cfg_reg() with new style signal or gpio functions Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: mux: Add new style init functions to omap3 board-*.c filesTony Lindgren
Add new style mux init functions to omap3 board-*.c files So far Beagle has been confirmed to be a CBB package, and CM-T35 a CUS package. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap: Add platform init code for EHCI driverFelipe Balbi
Add platform init code for EHCI driver. Various fixes to the original patch by Ajay Kumar Gupta <ajay.gupta@ti.com> and Anand Gadiyar <gadiyar@ti.com>. Overo support added by Olof Johansson <olof@lixom.net> Beagle support added by Koen Kooi <koen@beagleboard.org> CM-T32 support added by Mike Rapoport <mike@compulab.co.il> Signed-off-by: Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Koen Kooi <koen@beagleboard.org> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22OMAP: Configure audio_mclk for twl4030-codec MFDPeter Ujfalusi
audio_mclk value is going to be handled by the twl4030-codec MFD driver, configure the correct value for boards, which is using the twl4030 audio. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-22OMAP: Platform support for twl4030_codec MFDPeter Ujfalusi
Add needed platform data for the twl4030_codec MFD on boards, where the audio part of the twl4030 codec is used. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-19omap: Fix DEBUG_LL UART io addressSantosh Shilimkar
This patch fixes the low level debug UART io address as per this series. The change is essential to have CONFIG_DEBUG_LL working. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-03OMAP2/3 board-*.c files: read bootloader configuration earlierPaul Walmsley
Most board-*.c files read configuration data from the bootloader in their .init_machine() function. This needs to happen earlier, at some point before omap2_init_common_hw() is called. This is because a future patch will use the bootloader serial console port information to enable the UART clocks earlier, immediately after omap2_clk_init(). This is in turn necessary since otherwise clock tree usecounts on clocks like dpll4_m2x2_ck will be bogus, which can cause the currently-active console UART clock to be disabled during boot. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-08-28OMAP: UART: drop OMAP_TAG_UART, enable all UARTs, auto-disabled on idleKalle Valo
OMAP tags are deprecrated so drop them. Drop UART config data which decides which UARTs to enable during boot. This is no longer necessary since serial core code disables clocks after inactivity. Background: with new UART idle code, all on-chip UARTs are idled using a configurable inactivity timer (default 5 seconds.) After the inactivity timer, UART clocks are disabled automatically. Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-08-10Merge branch 'pm-upstream/fixes' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm
2009-08-10Merge branch 'omap_fixes_31' of git://git.pwsan.com/linux-2.6Russell King
2009-08-10OMAP3: Overo: Fix smsc911x platform device resource valueSergio Aguirre
Fixes a wrong setting of resource parameter list in SMSC911x platform driver data structure for Overo case. This fixes folowing warning when compiling for Overo board: warning: initialization from incompatible pointer type Introduced since commit id: commit 172ef275444efa12d834fb9d1b1acdac92db47f7 Author: Steve Sakoman <sakoman@gmail.com> Date: Mon Feb 2 06:27:49 2009 +0000 ARM: Add SMSC911X support to Overo platform (V2) Signed-off-by: Sergio Aguirre <saaguirre@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-08-05OMAP3: Overo: add missing pen-down GPIO definitionKevin Hilman
2009-07-24OMAP3: Setup MUX settings for SDRC CKE signalsJean Pihet
This patches ensures the MUX settings are correct for the SDRC CKE signals to SDRAM. This allows the self-refresh to work when 2 chip-selects are in use. A warning is thrown away in case the initial muxing is incorrect, in order to track faulty or old-dated bootloaders. Note: The CONFIG_OMAP_MUX and CONFIG_OMAP_MUX_WARNINGS options must be enabled for the mux code to have effect. Signed-off-by: Jean Pihet <jpihet@mvista.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-07-24OMAP3 SDRC: add support for 2 SDRAM chip selectsJean Pihet
Some OMAP3 boards (Beagle Cx, Overo, RX51, Pandora) have 2 SDRAM parts connected to the SDRC. This patch adds the following: - add a new argument of type omap_sdrc_params struct* to omap2_init_common_hw and omap2_sdrc_init for the 2nd CS params - adapted the OMAP boards files to the new prototype of omap2_init_common_hw - add the SDRC 2nd CS registers offsets defines - adapt the sram sleep code to configure the SDRC for the 2nd CS Note: If the 2nd param to omap2_init_common_hw is NULL, then the parameters are not programmed into the SDRC CS1 registers Tested on 3430 SDP and Beagleboard rev C2 and B5, with suspend/resume and frequency changes (cpufreq). Signed-off-by: Jean Pihet <jpihet@mvista.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-05-28ARM: OMAP3: Initialize regulators for Beagle and OveroDavid Brownell
Initialize regulators for Beagle and Overo. Patch is based on earlier patches posted to linux-omap mailing list. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-05-28ARM: OMAP3: SDRC: add timing data for Micron MT46H32M32LF-6, v2Paul Walmsley
Add timing data for the Micron MT46H32M32LF-6 SDRAM chip, used on the OMAP3 Beagle and EVM boards. Original timing data is from the Micron datasheet PDF downloaded from: http://download.micron.com/pdf/datasheets/dram/mobile/1gb_ddr_mobile_sdram_t48m.pdf Thanks to Rajendra Nayak <rnayak@ti.com> for his help identifying the chips used on Beagle & OMAP3EVM. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-04-02ARM: Add SMSC911X support to Overo platform (V2)Steve Sakoman
Gumstix will soon be shipping a variant of their Summit board that includes an SMSC LAN9221 ethernet interface. This patch provides support via the smsc911x driver when enabled in kernel config. The Overo defconfig is not updated since the LAN9221 is an option not present on all systems. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Acked-by: Steve Glendinning <steve.glendinning@smsc.com>
2009-03-25[ARM] OMAP: Fix compile for omap2_init_common_hw()Tony Lindgren
Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-23ARM: OMAP3: Add ADS7846 touchscreen support to Overo platform, v3Steve Sakoman
An upcoming Overo expansion board includes an ADS7846 touchscreen controller. This patch adds support via the ads7846 driver when enabled in the kernel config. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23ARM: OMAP3: MUSB initialization for omap hw, v2Felipe Balbi
Create a generic board-file for initializing usb on omap2430 and omap3 boards. Patch modified by Tony to build the module based on CONFIG_USB_MUSB_SOC. Also merged in a patch adding the nop xceiv from Ajay Kumar Gupta <ajay.gupta@ti.com>. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23ARM: OMAP3: mmc-twl4030 voltage cleanupDavid Brownell
Correct twl4030 MMC power switching: fix voltage ranges reported for each slot, and handle them fully. Lies corrected: - MMC-1 doesn't support the 2.6-2.7 Volt range - MMC-2 can't normally support anything except 1.8V Omissions corrected - MMC-1 *does* handle the 2.8-2.9 Volt range - MMC-2 can handle 2.5-3.2 Volt cards, given a transceiver Add transciever support for MMC-2; enable it for Overo and Pandora. (Depends on something else to have set up pinmuxing for control signals instead of as MMC2_DAT4..7 pins.) Also shrink twl4030_hsmmc_info a smidgeon ... padding is all gone. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23ARM: OMAP: No need to include board-overo.h from hardware.hTony Lindgren
Move the defines to the associated board file and remove the now unnecessary header file. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10omap mmc: Add low-level initialization for hsmmc controllerTony Lindgren
Add low-level initialization for hsmmc controller. Merged into this patch patch are various improvments and board support by Grazvydas Ignotas and David Brownell. Also change wire4 to be wires, as some newer controllers support 8 data lines. Cc: Pierre Ossman <drzeus-mmc@drzeus.cx> Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09ARM: OMAP3: Add support for the Gumstix Overo board (rev 3)Steve Sakoman
This patch adds minimal overo support. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
