path: root/arch/arm/mach-omap2/board-omap3touchbook.c
2010-05-27arm: omap: switch over to gpio_set_debounceFelipe Balbi
Stop using the omap-specific implementations for gpio debouncing now that gpiolib provides its own support. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Cc: Tony Lindgren <tony@atomide.com> Cc: David Brownell <david-b@pacbell.net> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-11omap2/3/4: ehci: avoid compiler error with touchbookFelipe Balbi
the early_param() call in board-omap3touchbook.c expands to: static const char __setup_str_early_touchbook_revision[] __section(.init.rodata) _aligned(1) = tbr; [...] and we have a non-const variable being added to the same section: static struct ehci_hcd_omap_platform_data ehci_pdata __section(.init.rodata); because of that, gcc generates a section type conflict which can (and actually should) be avoided by marking const every variable marked with __initconst. This patch fixes that for the ehci_hdc_omap_platform_data. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-03-09omap3: Fix compile for Touch Book early_paramTony Lindgren
Commit 2b0d8c251b8876d530a6bf671eb5425838fa698a changed ARM to use the common early_param code. Fix compile for Touch Book accordingly. Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-19omap: musb: Pass board specific data from board fileMaulik Mankad
Pass board specific data for MUSB (like interface_type, mode etc) from board file by defining board specific structure. Each board file can define this structure based on its requirement and pass this information to the driver. Signed-off-by: Maulik Mankad <x0082077@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Felipe Balbi <felipe.balbi@nokia.com> Cc: David Brownell <david-b@pacbell.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Gupta Ajay Kumar <ajay.gupta@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap: Rename hsmmc symbols to reflect independence from twl4030Adrian Hunter
hsmmc.[ch] no longer has any dependency on twl4030 and variable names should be renamed to reflect that. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap: Rename mmc-twl4030 files to hsmmcAdrian Hunter
mmc-twl4030.[ch] no longer has any dependency on twl4030 and should be renamed to reflect that. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap2/3/4: Fix omap2_map_common_io for multi-omapTony Lindgren
Fix omap2_map_common_io for multi-omap Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-16mfd: twl: fix twl4030 rename for remaining driver, board filesBalaji T K
Recent drivers/mfd/twl4030* renames to twl broke compile for various boards as the series was missing a patch to change the board-*.c files. This patch renames include twl4030.h to include twl.h and also renames twl4030_i2c_ routines. Signed-off-by: Balaji T K <balajitk@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Felipe Balbi <felipe.balbi@nokia.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap3: Board file of Always Innovating OMAP3-based Touch BookGregoire Gentil
Board file of Always Innovating OMAP3-based Touch Book Signed-off-by: Gregoire Gentil <gregoire@gentil.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
