path: root/arch/arm/mach-omap2/board-omap3logic.c
2011-08-24ARM: OMAP: Introduce SoC specific early_initTony Lindgren
Introduce them for each omap variant and just make them all call omap2_init_common_infrastructure for now. Do this for each board-*.c file except for board-generic and board-omap3beagle as they use the same machine ID for multiple SoCs. No functional changes. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-24ARM: OMAP: Move omap2_init_common_devices out of init_earlyTony Lindgren
There's no need to call omap2_init_common_devices from init_early. It no longer does anything else except reprogram the memory timings for some boards, so it's better to do it later so we have a chance to get console messages if something goes wrong. Move it to happen after omap_serial_init gets called. And while patching it anyways, rename it to omap_sdrc_init as suggested by Benoit Cousson <b-cousson@ti.com>. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-06-29Merge branch 'devel-timer' into devel-cleanupTony Lindgren
2011-06-27omap2+: Remove omap2_gp_clockevent_set_gptimerTony Lindgren
This is no longer needed as we now just set the desired .timer in MACHINE_START. We can now also remove timer-gp.h. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-06-20omap: Set separate timer init functions to avoid cpu_is_omap testsTony Lindgren
This is needed for the following patches so we can initialize the rest of the hardware timers later on. As with the init_irq calls, there's no need to do cpu_is_omap calls during the timer init as we only care about the major omap generation. This means that we can initialize the sys_timer with the .timer entries alone. Note that for now we just set stubs for the various sys_timer entries that will get populated in a later patch. The following patches will also remove the omap_dm_timer_init calls and change the init for the rest of the hardware timers to happen with an arch_initcall. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-06-16omap: Use separate init_irq functions to avoid cpu_is_omap tests earlyTony Lindgren
This allows us to remove cpu_is_omap calls from init_irq functions. There should not be any need for cpu_is_omap calls as at this point. During the timer init we only care about SoC generation, and not about subrevisions. The main reason for the patch is that we want to initialize only minimal omap specific code from the init_early call. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-06-14Remove old-style supply.dev assignments common in hsmmc initOleg Drokin
CC: Mark Brown <broonie@opensource.wolfsonmicro.com> CC: Mike Rapoport <mike@compulab.co.il> CC: Nishant Kamat <nskamat@ti.com> CC: Steve Sakoman <steve@sakoman.com> CC: Felipe Balbi <balbi@ti.com> Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-06-14cleanup regulator supply definitions in mach-omap2Oleg Drokin
to use REGULATOR_SUPPLY arrays. CC: Mark Brown <broonie@opensource.wolfsonmicro.com> CC: Mike Rapoport <mike@compulab.co.il> CC: Nishant Kamat <nskamat@ti.com> CC: Steve Sakoman <steve@sakoman.com> CC: Felipe Balbi <balbi@ti.com> CC: Santosh Shilimkar <santosh.shilimkar@ti.com> CC: peter.barada@logicpd.com Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-03omap: use common initialization for PMIC i2c busMike Rapoport
Introduce omap_pmic_init that registers i2c bus and PMIC device on that bus and add omap2/3/4 wrappers for common cases. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-04-20omap: gpmc-smsc911x: always set irq flags to IORESOURCE_IRQ_LOWLEVELMike Rapoport
SMSC911x devices attached to OMAP GPMC always use low level irqs. Setting the appropriate flag in the irq resourse strucure allows using .flags field in the omap_smsc911x_platform_data for driver specific flags Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-14ARM: OMAP2: use early init hookRussell King - ARM Linux
Move non-mapping and non-irq initialization code out of .map_io and .init_irq respectively into the new init_early hook. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-21OMAP2+: io: split omap2_init_common_hw()Paul Walmsley
Split omap2_init_common_hw() into two functions. The first, omap2_init_common_infrastructure(), initializes the hwmod code and data, the OMAP PM code, and the clock code and data. The second, omap2_init_common_devices(), handles any other early device initialization that, for whatever reason, has not been or cannot be moved to initcalls or early platform devices. This patch is required for the hwmod postsetup patch, which allows board files to change the state that hwmods should be placed into at the conclusion of the hwmod _setup() function. For example, for a board whose creators wish to ensure watchdog coverage across the entire kernel boot process, code to change the watchdog's postsetup state will be added in the board-*.c file between the omap2_init_common_infrastructure() and omap2_init_common_devices() function calls. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com>
2010-12-10Merge branch 'devel-gpio' into omap-for-linusTony Lindgren
2010-12-07OMAP: GPIO: Implement GPIO as a platform deviceVaradarajan, Charulatha
Implement GPIO as a platform device. GPIO APIs are used in machine_init functions. Hence it is required to complete GPIO probe before board_init. Therefore GPIO device register and driver register are implemented as postcore_initcalls. omap_gpio_init() does nothing now and this function would be removed in the next patch as it's usage is spread across most of the board files. Inorder to convert GPIO as platform device, modifications are required in clockxxxx_data.c file for OMAP1 so that device names can be used to obtain clock instead of getting clocks by name/NULL ptr. Use runtime pm APIs (pm_runtime_put*/pm_runtime_get*) for enabling or disabling the clocks, modify sysconfig settings and remove usage of clock FW APIs. Note 1: Converting GPIO driver to use runtime PM APIs is not done as a separate patch because GPIO clock names are different for various OMAPs and are different for some of the banks in the same CPU. This would need usage of cpu_is checks and bank id checks while using clock FW APIs in the gpio driver. Hence while making GPIO a platform driver framework, PM runtime APIs are used directly. Note 2: While implementing GPIO as a platform device, pm runtime APIs are used as mentioned above and modification is not done in gpio's prepare for idle/ resume after idle functions. This would be done in the next patch series and GPIO driver would be made to use dev_pm_ops instead of sysdev_class in that series only. Due to the above, the GPIO driver implicitly relies on CM_AUTOIDLE = 1 on its iclk for power management to work, since the driver never disables its iclk. This would be taken care in the next patch series (see Note 3 below). Refer to http://www.mail-archive.com/linux-omap@vger.kernel.org/msg39112.html for more details. Note 3: only pm_runtime_get_sync is called in gpio's probe() and pm_runtime_put* is never called. This is to make the implementation similar to the existing GPIO code. Another patch series would be sent to correct this. In OMAP3 and OMAP4 gpio's debounce clocks are optional clocks. They are enabled/ disabled whenever required using clock framework APIs TODO: 1. Cleanup the GPIO driver. Use function pointers and register offest pointers instead of using hardcoded values 2. Remove all cpu_is_ checks and OMAP specific macros 3. Remove usage of gpio_bank array so that only instance specific information is used in driver code 4. Rename 'method'/ avoid it's usage 5. Fix the non-wakeup gpios handling for OMAP2430, OMAP3 & OMAP4 6. Modify gpio's prepare for idle/ resume after idle functions to use runtime pm implentation. Signed-off-by: Charulatha V <charu@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Reviewed-by: Basak, Partha <p-basak2@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> [tony@atomide.com: updated for bank specific revision and updated boards] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-02arm: mach-omap2: remove NULL board_mux from board filesAaro Koskinen
If CONFIG_OMAP_MUX is not enabled, we can define board_mux in the header file instead of forcing every single board to define it. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> [tony@atomide.com: updated for combined board-zoom files] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-10-22omap: complete removal of machine_desc.io_pg_offst and .phys_ioAnand Gadiyar
Commit ab69bcd66fb4be64edfc767365cb9eb084961246 (arm: remove machine_desc.io_pg_offst and .phys_io) could not update the new boards in the omap tree. This causes the build of omap2plus_defconfig to fail. Fix this. Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Eric Miao <eric.miao at canonical.com> [tony@atomide.com: updated description] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-10-08OMAP: control: move plat-omap/control.h to mach-omap2/control.hPaul Walmsley
Only OMAP2+ platforms have the System Control Module (SCM) IP block. In the past, we've kept the SCM header file in plat-omap. This has led to abuse - device drivers including it; includes being added that create implicit dependencies on OMAP2+ builds; etc. In response, move the SCM headers into mach-omap2/. As part of this, remove the direct SCM access from the OMAP UDC driver. It was clearly broken. The UDC code needs an indepth review for use on OMAP2+ chips. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Cory Maccarrone <darkstar6262@gmail.com> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2010-10-08OMAP2plus: Fix static function warningsManjunath Kondaiah G
This patch fixes sparse warnings due non declarations of static functions. arch/arm/mach-omap2/timer-gp.c:115:12: warning: symbol 'omap2_gp_clockevent_set_gptimer' was not declared. Should it be static? arch/arm/mach-omap2/powerdomain.c:993:5: warning: symbol 'pwrdm_set_lowpwrstchange' was not declared. Should it be static? arch/arm/mach-omap2/board-flash.c:141:8: warning: symbol 'board_nand_init' was not declared. Should it be static? arch/arm/mach-omap2/board-n8x0.c:416:6: warning: symbol 'n8x0_mmc_slot1_cover_handler' was not declared. Should it be static? arch/arm/mach-omap2/board-n8x0.c:544:13: warning: symbol 'n8x0_mmc_init' was not declared. Should it be static? arch/arm/mach-omap2/board-rx51-peripherals.c:902:13: warning: symbol 'rx51_peripherals_init' was not declared. Should it be static? arch/arm/mach-omap2/board-rx51-video.c:107:13: warning: symbol 'rx51_video_mem_init' was not declared. Should it be static? arch/arm/mach-omap2/board-zoom-debugboard.c:155:12: warning: symbol 'zoom_debugboard_init' was not declared. Should it be static? arch/arm/mach-omap2/board-zoom-peripherals.c:280:13: warning: symbol 'zoom_peripherals_init' was not declared. Should it be static? arch/arm/mach-omap2/board-igep0020.c:110:13: warning: symbol 'igep2_flash_init' was not declared. Should it be static? arch/arm/mach-omap2/board-am3517evm.c:109:6: warning: symbol 'am3517_evm_ethernet_init' was not declared. Should it be static? drivers/mtd/onenand/omap2.c:577:5: warning: symbol 'omap2_onenand_rephase' was not declared. Should it be static? Signed-off-by: Manjunath Kondaiah G <manjugk@ti.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-09-28ARM: OMAP3LOGIC: Added SMSC Ethernet board supportTim Nordell
Enable SMSC911x Ethernet driver for LogicPD's OMAP 3530 LV SOM and OMAP 35x Torpedo board. Signed-off-by: Tim Nordell <tim.nordell@logicpd.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-09-28ARM: OMAP3LOGIC: Adding SDMMC supportTim Nordell
Add low-level initialization for hsmmc controller for LogicPD's OMAP 3530 LV SOM and OMAP 35x Torpedo board. Signed-off-by: Tim Nordell <tim.nordell@logicpd.com> [tony@atomide.com: updated for the recent mmc platform init changes] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-09-28ARM: OMAP3LOGIC: Adding LogicPD OMAP3 board supportTim Nordell
Adding support for LogicPD's OMAP 3530 LV SOM and OMAP 35x Torpedo board. Signed-off-by: Tim Nordell <tim.nordell@logicpd.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
