Pull arm-soc board specific changes from Olof Johansson:
"While we generally attempt to get rid of board specific files and
replace them with device tree based descriptions, a lot of platforms
have not come that far:
In shmobile, we add two new board files because their recently started
effort to add DT support has not proceeded enough to use it for all of
the important hardware.
In Kirkwood, we are adding support for new boards with a combination
of DT and board file contents in multiple cases.
pxa/mmp and imx are extending support for existing board files but not
adding new ones."
Fix up trivial conflicts in arch/arm/mach-{mmp/ttc_dkb.c,shmobile/{Kconfig,Makefile}}
* tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits)
ARM: shmobile: fix smp build
ARM: kirkwood: Add support for RaidSonic IB-NAS6210/6220 using devicetree
kirkwood: Add iconnect support
orion/kirkwood: create a generic function for gpio led blinking
kirkwood/orion: fix orion_gpio_set_blink
ARM: kirkwood: Define DNS-320/DNS-325 NAND in fdt
kirkwood: Allow nand to be configured via. devicetree
mtd: Add orion_nand devicetree bindings
ARM: kirkwood: Basic support for DNS-320 and DNS-325
ARM: mach-shmobile: Use DT_MACHINE for armadillo 800 eva
ARM: mach-shmobile: Use DT_MACHINE for KZM9G
ARM: pxa: hx4700: Add Synaptics NavPoint touchpad
ARM: pxa: Use REGULATOR_SUPPLY macro
ARM: mach-shmobile: kzm9g: enable SMP boot
ARM: mach-shmobile: kzm9g: defconfig update
ARM: mach-shmobile: kzm9g: add PCF8757 gpio-key
ARM: mach-shmobile: kzm9g: add SDHI support
ARM: mach-shmobile: kzm9g: add MMCIF support
ARM: mach-shmobile: kzm9g: correct screen direction
ARM: mach-shmobile: sh73a0.h: add GPIO_NR
On Beagleboard-xM (all revisions) only MMC1_DAT0-MMC1_DAT3 are wired up.
Tested on Beagleboard-xM Rev C1 and Beagleboard Rev B4.
Signed-off-by: Russ Dill <Russ.Dill@ti.com>
Now that the tfp410 driver has been renamed in the code, this patch
finishes the renaming by renaming the files.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
The driver for the TFP410 DPI-to-DVI chip was named quite badly as "DVI
panel driver". This patch renames the code to use tfp410 name for the
driver.
Now that the panel-dvi driver handles the PD (power-down) GPIO, we can
remove the custom PD handling from the board files.
Now that omap hsmmc init is split into two functions, it's safe
to mark omap_hsmmc_init and omap_mux related functions to __init.
This basically reverts the following fixes for the case where
TWL was compiled as a module:
a98f77b (ARM: omap: fix section mismatch warning for sdp3430_twl_gpio_setup())
8930b4e (ARM: omap: fix section mismatch warnings in mux.c caused by hsmmc.c)
Additionally it fixes up the remaining section warnings for
all callers of omap_mux functions.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Otherwise omap_device_build() and omap_mux related functions
can't be marked as __init when twl is build as a module.
If a board is using GPIO pins or regulators configured by an
external chip, such as TWL PMIC on I2C bus, the board must
mark those MMC controllers as deferred. Additionally both
omap_hsmmc_init() and omap_hsmmc_late_init() must be called
by the board.
For MMC controllers using internal GPIO pins for card
detect and regulators the slots don't need to be marked
deferred. In this case calling omap_hsmmc_init() is sufficient.
Only mark the MMC slots using gpio_cd or gpio_wd as deferred
as noted by Igor Grinberg <grinberg@compulab.co.il>.
Note that this patch does not change the behaviour for
board-4430sdp.c board-omap4panda.c. These boards wrongly
rely on the omap_hsmmc.c init function callback to configure
the PMIC GPIO interrupt lines on external chip. If the PMIC
interrupt lines are not configured during init, they will
fail.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
arch/arm/mach-exynos/cpu.c
The changes to arch/arm/mach-exynos/cpu.c were moved to
mach-exynos/common.c.
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into devel-stable
arch/arm/mach-omap2/board-4430sdp.c
arch/arm/mach-omap2/board-omap4panda.c
arch/arm/mach-omap2/include/mach/omap4-common.h
arch/arm/plat-omap/include/plat/irqs.h
The changes to omap4-common.h were moved to arch/arm/mach-omap2/common.h
and the other trivial conflicts resolved. The now empty ifdef in irqs.h
was also eliminated.
As suggested by Russell King - ARM Linux <linux@arm.linux.org.uk>,
there's no need to keep local prototypes in non-local headers.
Add mach-omap1/common.h and mach-omap2/common.h and move the
local prototypes there from plat/common.h and mach/omap4-common.h.
Convert the omap2plus platforms to be using CONFIG_MULTI_IRQ_HANDLER.
Each machine is modified to provide either omap2_intc_handle_irq(),
omap3_intc_handle_irq() or gic_handle_irq().
This allows for a major cleanup, removing the MULTI_OMAP setup
from the interrupt path.
Tested on both Panda and IGEPv2 (single kernel image)
Tested-by: Tony Lindgren <tony@atomide.com>
* 'for-next' of git://git.infradead.org/users/sameo/mfd-2.6: (80 commits)
mfd: Fix missing abx500 header file updates
mfd: Add missing <linux/io.h> include to intel_msic
x86, mrst: add platform support for MSIC MFD driver
mfd: Expose TurnOnStatus in ab8500 sysfs
mfd: Remove support for early drop ab8500 chip
mfd: Add support for ab8500 v3.3
mfd: Add ab8500 interrupt disable hook
mfd: Convert db8500-prcmu panic() into pr_crit()
mfd: Refactor db8500-prcmu request_clock() function
mfd: Rename db8500-prcmu init function
mfd: Fix db5500-prcmu defines
mfd: db8500-prcmu voltage domain consumers additions
mfd: db8500-prcmu reset code retrieval
mfd: db8500-prcmu tweak for modem wakeup
mfd: Add db8500-pcmu watchdog accessor functions for watchdog
mfd: hwacc power state db8500-prcmu accessor
mfd: Add db8500-prcmu accessors for PLL and SGA clock
mfd: Move to the new db500 PRCMU API
mfd: Create a common interface for dbx500 PRCMU drivers
mfd: Initialize DB8500 PRCMU regs
arch/arm/mach-imx/mach-mx31moboard.c
arch/arm/mach-omap2/board-omap3beagle.c
arch/arm/mach-u300/include/mach/irqs.h
drivers/mfd/wm831x-spi.c
* 'next/cleanup2' of git://git.linaro.org/people/arnd/arm-soc: (31 commits)
ARM: OMAP: Warn if omap_ioremap is called before SoC detection
ARM: OMAP: Move set_globals initialization to happen in init_early
ARM: OMAP: Map SRAM later on with ioremap_exec()
ARM: OMAP: Remove calls to SRAM allocations for framebuffer
ARM: OMAP: Avoid cpu_is_omapxxxx usage until map_io is done
ARM: OMAP1: Use generic map_io, init_early and init_irq
arm/dts: OMAP3+: Add mpu, dsp and iva nodes
arm/dts: OMAP4: Add a main ocp entry bound to l3-noc driver
ARM: OMAP2+: l3-noc: Add support for device-tree
ARM: OMAP2+: board-generic: Add i2c static init
ARM: OMAP2+: board-generic: Add DT support to generic board
arm/dts: Add support for OMAP3 Beagle board
arm/dts: Add initial device tree support for OMAP3 SoC
arm/dts: Add support for OMAP4 SDP board
arm/dts: Add support for OMAP4 PandaBoard
arm/dts: Add initial device tree support for OMAP4 SoC
ARM: OMAP: omap_device: Add a method to build an omap_device from a DT node
ARM: OMAP: omap_device: Add omap_device_[alloc|delete] for DT integration
of: Add helpers to get one string in multiple strings property
ARM: OMAP2+: devices: Remove all omap_device_pm_latency structures
Fix up trivial header file conflicts in arch/arm/mach-omap2/board-generic.c
Theis resolves lots of simple conflicts between the omap
cleanup and the mach/memory.h removal series.
arch/arm/mach-imx/mach-cpuimx27.c
arch/arm/mach-omap1/board-ams-delta.c
arch/arm/mach-omap1/board-generic.c
arch/arm/mach-omap1/board-h2.c
arch/arm/mach-omap1/board-h3.c
arch/arm/mach-omap1/board-nokia770.c
arch/arm/mach-omap1/board-osk.c
arch/arm/mach-omap1/board-palmte.c
arch/arm/mach-omap1/board-palmtt.c
arch/arm/mach-omap1/board-palmz71.c
arch/arm/mach-omap1/board-sx1.c
arch/arm/mach-omap1/board-voiceblue.c
arch/arm/mach-omap1/io.c
arch/arm/mach-omap2/io.c
arch/arm/plat-omap/io.c
Omap cleanups conflicted with omap2_dss work in a nontrivial
way, this is the most logical fixup.
arch/arm/mach-omap2/board-2430sdp.c
arch/arm/mach-omap2/board-apollon.c
arch/arm/mach-omap2/board-h4.c
arch/arm/mach-omap2/board-ldp.c
arch/arm/mach-omap2/board-rx51.c
Signed-off-by: Kyle Manna <kyle@kylemanna.com>
This way we don't need to initialize SoC detection early
and can start using generic map_io.
Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Replace the multiple omap2_get_XXX_device APIs with the new
omap_hwmod_name_get_dev that uses the hwmod name to get the proper
device.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Cc: Nishanth Menon <nm@ti.com>
Signed-off-by: Kevin Hilman <khilman@ti.com>
Add i2c bus number for DVI output for boards with DVI output where the
i2c bus has been confirmed to be connected and working. The driver uses
this to detect if a panel is connected and to read EDID.
Multiple OMAP3/4 boards have a DVI framer output. This patch makes the
boards use the new panel-dvi driver, instead of the panel-generic-dpi
driver.
Separate drivers for fixed size panels and DVI framer gives us cleaner
driver code.
With SoC specific timers, board specific init_irq is
no longer needed. Earlier this was still needed to
initialize the gptimer12 on Beagle based boards.
Also convert board-h4.c to use omap2_init_irq accidentally
did not get converted earlier.
There's no need to call omap2_init_common_devices from init_early.
It no longer does anything else except reprogram the memory timings
for some boards, so it's better to do it later so we have a chance
to get console messages if something goes wrong.
Move it to happen after omap_serial_init gets called. And while
patching it anyways, rename it to omap_sdrc_init as suggested by
Benoit Cousson <b-cousson@ti.com>.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Board code should not touch omap_device internals. To get the MPU/IVA devices,
use existing APIs: omap2_get_mpu_device(), omap2_get_iva_device().
arch/arm/mach-omap2/board-rx51-peripherals.c
OMAP3: beagle: add support for beagleboard xM revision C
The USB enable GPIO has been in beagleboard xM revision C.
The USER button has been moved since beagleboard xM.
Also, board specific initialization has been moved to beagle_config struct
and initialized in omap3_beagle_init_rev. Default values in struct are for xMC.
Signed-off-by: Joel A Fernandes <joelagnel@ti.com>
Signed-off-by: Koen Kooi <koen@dominion.thruhere.net>
Acked-by: Jason Kridner <jkridner@beagleboard.org>
Some regulator config can be moved out from board files,
since they are close to identical.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Reduce the amount of duplicated code by moving the common
configuration for twl4030/5030/tpsxx to the twl-common file.
Use the omap3_pmic_get_config function from board files to
properly configure the PMIC with the common fields.
This is no longer needed as we now just set the desired
.timer in MACHINE_START. We can now also remove timer-gp.h.
Reviewed-by: Kevin Hilman <khilman@ti.com>
This is needed for the following patches so we can initialize the
rest of the hardware timers later on.
As with the init_irq calls, there's no need to do cpu_is_omap calls
during the timer init as we only care about the major omap generation.
This means that we can initialize the sys_timer with the .timer
entries alone.
Note that for now we just set stubs for the various sys_timer entries
that will get populated in a later patch. The following patches will
also remove the omap_dm_timer_init calls and change the init for the
rest of the hardware timers to happen with an arch_initcall.
This allows us to remove cpu_is_omap calls from init_irq functions.
There should not be any need for cpu_is_omap calls as at this point.
During the timer init we only care about SoC generation, and not about
subrevisions.
The main reason for the patch is that we want to initialize only
minimal omap specific code from the init_early call.
CC: Mark Brown <broonie@opensource.wolfsonmicro.com>
CC: Mike Rapoport <mike@compulab.co.il>
CC: Nishant Kamat <nskamat@ti.com>
CC: Steve Sakoman <steve@sakoman.com>
CC: Felipe Balbi <balbi@ti.com>
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
Acked-by: Felipe Balbi <balbi@ti.com>
to use REGULATOR_SUPPLY arrays.
CC: Santosh Shilimkar <santosh.shilimkar@ti.com>
CC: peter.barada@logicpd.com
Several boards defining mtd partitions also defined NAND_BLOCK_SIZE as
SZ_128K. Move the define to common-board-devices.h
This removes multiple defines of NAND_BLOCK_SIZE.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
[tony@atomide.com: updated comments]
Free Beagle rev gpios when they are read, so others can read them later
Signed-off-by: Tasslehoff Kjappfot <tasskjapp@gmail.com>
Without msecure beeing high it isn't possible to set (or start)
the RTC.
Tested with a BeagleBoard C4.
Signed-off-by: Alexander Holler <holler@ahsoftware.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (33 commits)
OMAP3: PM: Boot message is not an error, and not helpful, remove it
OMAP3: cpuidle: change the power domains modes determination logic
OMAP3: cpuidle: code rework for improved readability
OMAP3: cpuidle: re-organize the C-states data
OMAP3: clean-up mach specific cpuidle data structures
OMAP3 cpuidle: remove useless SDP specific timings
usb: otg: OMAP4430: Powerdown the internal PHY when USB is disabled
usb: otg: OMAP4430: Fixing the omap4430_phy_init function
usb: musb: am35x: fix compile error when building am35x
usb: musb: OMAP4430: Power down the PHY during board init
omap: drop board-igep0030.c
omap: igep0020: add support for IGEP3
omap: igep0020: minor refactoring
omap: igep0020: name refactoring for future merge with IGEP3
omap: Remove support for omap2evm
arm: omap2plus: GPIO cleanup
omap: musb: introduce default board config
omap: move detection of NAND CS to common-board-devices
omap: use common initialization for PMIC i2c bus
omap: consolidate touch screen initialization among different boards
use gpio_request_<one|array>() instead of multiple gpiolib calls,
remove unneeded variables, etc.
arch/arm/plat-omap/include/plat/panel-generic-dpi.h is an include for
the OMAP DSS panel driver for generic DPI displays. A more logical place
for it is in include/video.
arch/arm/plat-omap/include/plat/display.h is an include for the OMAP DSS
driver. A more logical place for it is in include/video.
Most boards use exactly the same configuration for musb initialization.
Create a default that can be shared amount different boards.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
and reduce amount of copy/paste
CC: Oleg Drokin <green@linuxhacker.ru>
Introduce omap_pmic_init that registers i2c bus and PMIC device on that
bus and add omap2/3/4 wrappers for common cases.
arch/arm/mach-omap2/board-overo.c
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits)
omap: zoom: host should not pull up wl1271's irq line
arm: plat-omap: iommu: fix request_mem_region() error path
OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430
omap4: mux: Remove duplicate mux modes
omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag
omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set
omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected
omap4: board-omap4panda: Initialise the serial pads
omap3: board-3430sdp: Initialise the serial pads
omap4: board-4430sdp: Initialise the serial pads
omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init
omap2+: mux: Remove the use of IDLE flag
omap2+: Add separate list for dynamic pads to mux
perf: add OMAP support for the new power events
OMAP4: Add IVA OPP enteries.
OMAP4: Update Voltage Rail Values for MPU, IVA and CORE
OMAP4: Enable 800 MHz and 1 GHz MPU-OPP
OMAP3+: OPP: Replace voltage values with Macros
OMAP3: wdtimer: Fix CORE idle transition
Watchdog: omap_wdt: add fine grain runtime-pm
Fix up various conflicts in
- arch/arm/mach-omap2/board-omap3evm.c
- arch/arm/mach-omap2/clock3xxx_data.c
- arch/arm/mach-omap2/usb-musb.c
- arch/arm/plat-omap/include/plat/usb.h
- drivers/usb/musb/musb_core.h
Hwmod adaptation design requires each of the DSS HW IP to be a platform driver.
So a platform_driver for DSI is created and init exit methods are moved from core.c
to its driver probe,remove. pdev member has to be maintained by its own drivers.
Also, vdds_dsi regulator handling is copied to dsi.c, since vdds_dsi regulator is
needed by dpi_init() too. Board files are updated accordingly to add 2 instances of
vdds_dsi regulator.
DSI platform driver is registered from inside omap_dss_probe, in the order desired.
Signed-off-by: Senthilvadivu Guruswamy <svadivu@ti.com>
Signed-off-by: Sumit Semwal <sumit.semwal@ti.com>
So a platform_driver for VENC is created and init exit methods are moved from core.c
Also, venc_vdda_dac reading is moved to venc.c.
VENC platform driver is registered from inside omap_dss_probe, in the order desired.
