path: root/arch/arm/mach-omap2/board-h4.c
2011-03-10omap: Fix H4 init_irq to not call h4_init_flashTony Lindgren
There should be no reason to call h4_init_flash this early. It causes problems as things are not yet initialized. Tested-by: Tarun Kanti DebBarma <tarun.kanti@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-25omap2+: Minimize board specific init_early callsTony Lindgren
We should only call init_common_infrastructure and init_common_devices from init_early. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-14ARM: OMAP2: use early init hookRussell King - ARM Linux
Move non-mapping and non-irq initialization code out of .map_io and .init_irq respectively into the new init_early hook. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-22Merge branch 'integration-2.6.38-for-tony' of git://git.pwsan.com/linux-2.6 ↵Tony Lindgren
into omap-for-linus
2010-12-22Keyboard: omap-keypad: use matrix_keypad.hJanusz Krzysztofik
Most keypad drivers make use of the <linux/input/matrix_keypad.h> defined macros, structures and inline functions. Convert omap-keypad driver to use those as well, as suggested by a compile time warning, hardcoded into the OMAP <palt/keypad.h>. Created against linux-2.6.37-rc5. Tested on Amstrad Delta. Compile tested with omap1_defconfig and omap2plus_defconfig shrinked to board-h4. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Reviewed-by: Aaro Koskinen <aaro.koskinen@nokia.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-21OMAP2+: io: split omap2_init_common_hw()Paul Walmsley
Split omap2_init_common_hw() into two functions. The first, omap2_init_common_infrastructure(), initializes the hwmod code and data, the OMAP PM code, and the clock code and data. The second, omap2_init_common_devices(), handles any other early device initialization that, for whatever reason, has not been or cannot be moved to initcalls or early platform devices. This patch is required for the hwmod postsetup patch, which allows board files to change the state that hwmods should be placed into at the conclusion of the hwmod _setup() function. For example, for a board whose creators wish to ensure watchdog coverage across the entire kernel boot process, code to change the watchdog's postsetup state will be added in the board-*.c file between the omap2_init_common_infrastructure() and omap2_init_common_devices() function calls. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com>
2010-12-17omap: kill all section mismatch warning for omap2plus_defconfigBryan Wu
This patch will kill following section mismatch warnings: WARNING: vmlinux.o(.text+0x24a00): Section mismatch in reference from the function zoom_twl_gpio_setup() to the (unknown reference) .init.data:(unknown) The function zoom_twl_gpio_setup() references the (unknown reference) __initdata (unknown). This is often because zoom_twl_gpio_setup lacks a __initdata annotation or the annotation of (unknown) is wrong. WARNING: vmlinux.o(.text+0x24bfc): Section mismatch in reference from the function cm_t35_twl_gpio_setup() to the (unknown reference) .init.data:(unknown) The function cm_t35_twl_gpio_setup() references the (unknown reference) __initdata (unknown). This is often because cm_t35_twl_gpio_setup lacks a __initdata annotation or the annotation of (unknown) is wrong. WARNING: vmlinux.o(.data+0x1d3e0): Section mismatch in reference from the variable h4_config to the (unknown reference) .init.data:(unknown) The variable h4_config references the (unknown reference) __initdata (unknown) If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, WARNING: vmlinux.o(.data+0x1dc08): Section mismatch in reference from the variable sdp2430_config to the (unknown reference) .init.data:(unknown) The variable sdp2430_config references the (unknown reference) __initdata (unknown) If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, WARNING: vmlinux.o(.data+0x1e1d8): Section mismatch in reference from the variable apollon_config to the (unknown reference) .init.data:(unknown) The variable apollon_config references the (unknown reference) __initdata (unknown) If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, Signed-off-by: Bryan Wu <bryan.wu@canonical.com> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-10Merge branch 'devel-gpio' into omap-for-linusTony Lindgren
2010-12-07OMAP: GPIO: Implement GPIO as a platform deviceVaradarajan, Charulatha
Implement GPIO as a platform device. GPIO APIs are used in machine_init functions. Hence it is required to complete GPIO probe before board_init. Therefore GPIO device register and driver register are implemented as postcore_initcalls. omap_gpio_init() does nothing now and this function would be removed in the next patch as it's usage is spread across most of the board files. Inorder to convert GPIO as platform device, modifications are required in clockxxxx_data.c file for OMAP1 so that device names can be used to obtain clock instead of getting clocks by name/NULL ptr. Use runtime pm APIs (pm_runtime_put*/pm_runtime_get*) for enabling or disabling the clocks, modify sysconfig settings and remove usage of clock FW APIs. Note 1: Converting GPIO driver to use runtime PM APIs is not done as a separate patch because GPIO clock names are different for various OMAPs and are different for some of the banks in the same CPU. This would need usage of cpu_is checks and bank id checks while using clock FW APIs in the gpio driver. Hence while making GPIO a platform driver framework, PM runtime APIs are used directly. Note 2: While implementing GPIO as a platform device, pm runtime APIs are used as mentioned above and modification is not done in gpio's prepare for idle/ resume after idle functions. This would be done in the next patch series and GPIO driver would be made to use dev_pm_ops instead of sysdev_class in that series only. Due to the above, the GPIO driver implicitly relies on CM_AUTOIDLE = 1 on its iclk for power management to work, since the driver never disables its iclk. This would be taken care in the next patch series (see Note 3 below). Refer to http://www.mail-archive.com/linux-omap@vger.kernel.org/msg39112.html for more details. Note 3: only pm_runtime_get_sync is called in gpio's probe() and pm_runtime_put* is never called. This is to make the implementation similar to the existing GPIO code. Another patch series would be sent to correct this. In OMAP3 and OMAP4 gpio's debounce clocks are optional clocks. They are enabled/ disabled whenever required using clock framework APIs TODO: 1. Cleanup the GPIO driver. Use function pointers and register offest pointers instead of using hardcoded values 2. Remove all cpu_is_ checks and OMAP specific macros 3. Remove usage of gpio_bank array so that only instance specific information is used in driver code 4. Rename 'method'/ avoid it's usage 5. Fix the non-wakeup gpios handling for OMAP2430, OMAP3 & OMAP4 6. Modify gpio's prepare for idle/ resume after idle functions to use runtime pm implentation. Signed-off-by: Charulatha V <charu@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Reviewed-by: Basak, Partha <p-basak2@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> [tony@atomide.com: updated for bank specific revision and updated boards] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-02arm: mach-omap2: remove NULL board_mux from board filesAaro Koskinen
If CONFIG_OMAP_MUX is not enabled, we can define board_mux in the header file instead of forcing every single board to define it. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> [tony@atomide.com: updated for combined board-zoom files] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-10-25Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits) omap: complete removal of machine_desc.io_pg_offst and .phys_io omap: UART: fix wakeup registers for OMAP24xx UART2 omap: Fix spotty MMC voltages ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h serial: omap-serial: fix signess error OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish omap: dma: Fix buffering disable bit setting for omap24xx omap: serial: Fix the boot-up crash/reboot without CONFIG_PM OMAP3: PM: fix scratchpad memory accesses for off-mode omap4: pandaboard: enable the ehci port on pandaboard omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set omap4: pandaboard: remove unused hsmmc definition OMAP: McBSP: Remove null omap44xx ops comment OMAP: McBSP: Swap CLKS source definition OMAP: McBSP: Fix CLKR and FSR signal muxing OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks OMAP: control: move plat-omap/control.h to mach-omap2/control.h OMAP: split plat-omap/common.c OMAP: McBSP: implement functional clock switching via clock framework OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c ... Fixed up trivial conflicts in arch/arm/mach-omap2/ {board-zoom-peripherals.c,devices.c} as per Tony
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-08OMAP: control: move plat-omap/control.h to mach-omap2/control.hPaul Walmsley
Only OMAP2+ platforms have the System Control Module (SCM) IP block. In the past, we've kept the SCM header file in plat-omap. This has led to abuse - device drivers including it; includes being added that create implicit dependencies on OMAP2+ builds; etc. In response, move the SCM headers into mach-omap2/. As part of this, remove the direct SCM access from the OMAP UDC driver. It was clearly broken. The UDC code needs an indepth review for use on OMAP2+ chips. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Cory Maccarrone <darkstar6262@gmail.com> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-04Merge branch 'devel-map-io' into omap-for-linusTony Lindgren
2010-07-16ARM: OMAP: Convert to use ->reserve method to reserve boot time memoryRussell King
2010-07-05Removing dead MACH_OMAP2_H4_USB1Christoph Egger
MACH_OMAP2_H4_USB1 doesn't exist in Kconfig, therefore removing all references for it from the source code. Signed-off-by: Christoph Egger <siccegge@cs.fau.de> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05Removing dead MACH_OMAP_H4_OTGChristoph Egger
MACH_OMAP_H4_OTG doesn't exist in Kconfig, therefore removing all references for it from the source code. Signed-off-by: Christoph Egger <siccegge@cs.fau.de> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05Removing dead OMAP_IRChristoph Egger
OMAP_IR doesn't exist in Kconfig, therefore removing all references for it from the source code. Signed-off-by: Christoph Egger <siccegge@cs.fau.de> [tony@atomide.com: updated for new mux code] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05omap: mux: Convert 2420 platform init code to use new mux codeTony Lindgren
Convert 2420 platform init code to use new mux code Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05omap: mux: Do keypad muxing in board-*.c filesTony Lindgren
This way we get pin muxing out of plat-omap and can convert H4 to use the new mux functions. Note that it should be safe to assume we can mux all the keypad pins except on H4 which may have Menelaus connected. Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05omap: mux: Select SIP package for H4Tony Lindgren
Select SIP package for H4 Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05omap: Move omap2 FS USB platform init code into mach-omap2/usb-fs.cTony Lindgren
Move omap2 FS USB platform init code into mach-omap2/usb-fs.c. This will allow further work later on to use omap hwmod for initializing the device. Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap: convert boards to use physmap-flashLadislav Michl
Convert OMAP based boards to use physmap-flash. Refreshed against today's Linux omap kernel tree Cc: linux-mtd@lists.infradead.org Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap2/3/4: Fix omap2_map_common_io for multi-omapTony Lindgren
Fix omap2_map_common_io for multi-omap Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-19omap: Fix DEBUG_LL UART io addressSantosh Shilimkar
This patch fixes the low level debug UART io address as per this series. The change is essential to have CONFIG_DEBUG_LL working. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-03OMAP2/3 board-*.c files: read bootloader configuration earlierPaul Walmsley
Most board-*.c files read configuration data from the bootloader in their .init_machine() function. This needs to happen earlier, at some point before omap2_init_common_hw() is called. This is because a future patch will use the bootloader serial console port information to enable the UART clocks earlier, immediately after omap2_clk_init(). This is in turn necessary since otherwise clock tree usecounts on clocks like dpll4_m2x2_ck will be bogus, which can cause the currently-active console UART clock to be disabled during boot. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-08-28OMAP: UART: drop OMAP_TAG_UART, enable all UARTs, auto-disabled on idleKalle Valo
OMAP tags are deprecrated so drop them. Drop UART config data which decides which UARTs to enable during boot. This is no longer necessary since serial core code disables clocks after inactivity. Background: with new UART idle code, all on-chip UARTs are idled using a configurable inactivity timer (default 5 seconds.) After the inactivity timer, UART clocks are disabled automatically. Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-07-24OMAP3 SDRC: add support for 2 SDRAM chip selectsJean Pihet
Some OMAP3 boards (Beagle Cx, Overo, RX51, Pandora) have 2 SDRAM parts connected to the SDRC. This patch adds the following: - add a new argument of type omap_sdrc_params struct* to omap2_init_common_hw and omap2_sdrc_init for the 2nd CS params - adapted the OMAP boards files to the new prototype of omap2_init_common_hw - add the SDRC 2nd CS registers offsets defines - adapt the sram sleep code to configure the SDRC for the 2nd CS Note: If the 2nd param to omap2_init_common_hw is NULL, then the parameters are not programmed into the SDRC CS1 registers Tested on 3430 SDP and Beagleboard rev C2 and B5, with suspend/resume and frequency changes (cpufreq). Signed-off-by: Jean Pihet <jpihet@mvista.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-04-23ARM: OMAP: Remove old dead gpio expander codeTony Lindgren
This should be done with GPIO calls. Patches against the mainline tree welcome to add the necessary working functionality back. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-25Merge branch 'for-next' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
2009-03-23ARM: OMAP: get rid of OMAP_TAG_USB, v2Felipe Balbi
OMAP_TAGS should vanish soon since they're not generic arm tags. Most of them can be converted to a platform_data or parsed from a command line like e.g. serial tag. For OMAP_TAG_USB we just let boards call omap_usb_init() passing a pointer to omap_usb_config. Patch updated by Tony for mainline, basically make n770 and h4 compile. Also folded in a fix for OSK by David Brownell <dbrownell@users.sourceforge.net>. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23ARM: OMAP: No need to include board-h4.h from hardware.hTony Lindgren
Move the defines to the associated board file and remove the now unnecessary header file. Also rename OMAP24XX_ETHR_GPIO_IRQ to H4_ETHR_GPIO_IRQ. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-02-08[ARM] OMAP2 SDRC: add SDRAM timing parameter infrastructurePaul Walmsley
For a given SDRAM clock rate, SDRAM chips require memory controllers to use a specific set of timing minimums and maximums to transfer data reliably. These parameters can be different for different memory chips and can also potentially vary by board. This patch adds the infrastructure for board-*.c files to pass this timing data to the SDRAM controller init function. The timing data is specified in an 'omap_sdrc_params' structure, in terms of SDRC controller register values. An array of these structs, one per SDRC target clock rate, is passed by the board-*.c file to omap2_init_common_hw(). This patch does not define the values for different memory chips, nor does it use the values for anything; those will come in subsequent patches. linux-omap source commit is bc84ecfc795c2d1c5cda8da4127cf972f488a696. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-10omap mmc: Remove broken MMC init codeTony Lindgren
Most of the omap1 MMC boards got broken by an earlier patch 138ab9f8321f67c71984ca43222efa71b0a0a0a9. If you look closely, the MMC init funtions are pretty much just stubs. Remove broken init code to make room for cleaner MMC init code. Cc: Pierre Ossman <drzeus-mmc@drzeus.cx> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10ARM: OMAP2: bard-h4: list those eepromsDavid Brownell
Declare the two 1Kbit EEPROMs included in the H4 board stack. One is on the CPU card; the other is on the mainboard. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-14i2c/isp1301_omap: Convert to a new-style i2c driver, part 2Jean Delvare
Based on David Brownell's patch for tps65010 and previous work by Felipe Balbi, this patch finishes converting isp1301_omap to a new-style i2c driver. There's definitely room for further drivers cleanups, but these are out of the scope of this patch. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Tony Lindgren <tony@atomide.com>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-09ARM: OMAP: Add calls to omap2_set_globals_*()Paul Walmsley
Add the omap2_set_globals_{242x,243x,343x}() functions. These functions are called early upon boot in the map_io() functions in the board-specific init files. This patch was accidentally left out of the earlier series. This fixes omap2 booting as noted by Kyungmin Park <kmpark@infradead.org>. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kyungmin Park <kmpark@infradead.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Change 24xx to use new register accessPaul Walmsley
This patch changes 24xx to use new register access, except for clock framework. Clock framework register access will get updates in the next patch. Note that board-*.c files change GPMC (General Purpose Memory Controller) access to use gpmc_cs_write_reg() instead of accessing the registers directly. The code also uses gpmc_fck instead of it's parent clock core_l3_ck for GPMC clock. The H4 board file also adds h4_init_flash() function, which specify the flash start and end addresses. Also note that sleep.S removes some unused registers addresses. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-09-20ARM: OMAP: abstract debug card setup (smc, leds)David Brownell
Additional cleanup for debug boards on H2/P2/H3/H4: move the init code that's not board-specific into a new file where it can be easily shared between all the different boards (avoiding code duplication, and making it easier to support more devices). Make H4 use that. This should be easy to drop in to the OMAP1 boards using these debug cards; the only difference seems to be that the p2 does an extra reset of the smc using the fpga (probably all boards could do that, if it's necessary) and doesn't use the gpio mux or request APIs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-05-08ARM: OMAP: h4 must have blinky leds!!David Brownell
This adds generic support for the "debug board" LEDs used by most of TI's OMAP reference boards, and board-specific support for the H4. It's derived from the not-as-generic stuff used by OMAP1 H2/H3/P2. Those should be able to switch easily to this version, and clean up some of the omap1-specific code. In addition to H4 support, one key improvement is supporting not just the "old" ARM debug LED API (with timer and idle LEDs, plus four that can be handy for kernel debugging), but it also supports the "new" generic LED API (most useful for usermode stuff IMO). Either or both APIs can be enabled. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-02ARM: OMAP: Use linux/delay.h not asm/delay.hTony Lindgren
Use linux/delay.h not asm/delay.h Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: Workqueue changes for board-h4.cDirk Behme
Workqueue changes for board-h4.c Signed-off-by: Dirk Behme <dirk.behme_at_gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-12-05WorkQueue: Fix up arch-specific work items where possibleDavid Howells
Fix up arch-specific work items where possible to use the new work_struct and delayed_work structs. Three places that enqueue bits of their stack and then return have been marked with #error as this is not permitted. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-29[PATCH] OMAP: Update OMAP1/2 boards to give keymapsize and other pdataKomal Shah
This patch adds keymapsize, delay and debounce flag in the keypad platform data for various TI OMAP1/2 based boards like F-sample, H2, H3, Innovator, Nokia770, OSK, Perseus and H4. Signed-off-by: Komal Shah <komal_shah802003@yahoo.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02[ARM] 3433/1: ARM: OMAP: 8/8 Update board filesTony Lindgren
Patch from Tony Lindgren This patch syncs OMAP board support with linux-omap tree. The highlights of the patch are: - Add support for Nokia 770 by Juha Yrjola - Add support for Samsung Apollon by Kyungmin Park - Add support for Amstrad E3 videophone by Jonathan McDowell - Remove board-netstar.c board support as requested by Ladislav Michl - Do platform_device registration in board files by Komal Shah et al. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
