path: root/arch/arm/mach-omap2/board-h4.c
2009-07-24OMAP3 SDRC: add support for 2 SDRAM chip selectsJean Pihet
Some OMAP3 boards (Beagle Cx, Overo, RX51, Pandora) have 2 SDRAM parts connected to the SDRC. This patch adds the following: - add a new argument of type omap_sdrc_params struct* to omap2_init_common_hw and omap2_sdrc_init for the 2nd CS params - adapted the OMAP boards files to the new prototype of omap2_init_common_hw - add the SDRC 2nd CS registers offsets defines - adapt the sram sleep code to configure the SDRC for the 2nd CS Note: If the 2nd param to omap2_init_common_hw is NULL, then the parameters are not programmed into the SDRC CS1 registers Tested on 3430 SDP and Beagleboard rev C2 and B5, with suspend/resume and frequency changes (cpufreq). Signed-off-by: Jean Pihet <jpihet@mvista.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-04-23ARM: OMAP: Remove old dead gpio expander codeTony Lindgren
This should be done with GPIO calls. Patches against the mainline tree welcome to add the necessary working functionality back. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-25Merge branch 'for-next' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
2009-03-23ARM: OMAP: get rid of OMAP_TAG_USB, v2Felipe Balbi
OMAP_TAGS should vanish soon since they're not generic arm tags. Most of them can be converted to a platform_data or parsed from a command line like e.g. serial tag. For OMAP_TAG_USB we just let boards call omap_usb_init() passing a pointer to omap_usb_config. Patch updated by Tony for mainline, basically make n770 and h4 compile. Also folded in a fix for OSK by David Brownell <dbrownell@users.sourceforge.net>. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23ARM: OMAP: No need to include board-h4.h from hardware.hTony Lindgren
Move the defines to the associated board file and remove the now unnecessary header file. Also rename OMAP24XX_ETHR_GPIO_IRQ to H4_ETHR_GPIO_IRQ. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-02-08[ARM] OMAP2 SDRC: add SDRAM timing parameter infrastructurePaul Walmsley
For a given SDRAM clock rate, SDRAM chips require memory controllers to use a specific set of timing minimums and maximums to transfer data reliably. These parameters can be different for different memory chips and can also potentially vary by board. This patch adds the infrastructure for board-*.c files to pass this timing data to the SDRAM controller init function. The timing data is specified in an 'omap_sdrc_params' structure, in terms of SDRC controller register values. An array of these structs, one per SDRC target clock rate, is passed by the board-*.c file to omap2_init_common_hw(). This patch does not define the values for different memory chips, nor does it use the values for anything; those will come in subsequent patches. linux-omap source commit is bc84ecfc795c2d1c5cda8da4127cf972f488a696. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-10omap mmc: Remove broken MMC init codeTony Lindgren
Most of the omap1 MMC boards got broken by an earlier patch 138ab9f8321f67c71984ca43222efa71b0a0a0a9. If you look closely, the MMC init funtions are pretty much just stubs. Remove broken init code to make room for cleaner MMC init code. Cc: Pierre Ossman <drzeus-mmc@drzeus.cx> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10ARM: OMAP2: bard-h4: list those eepromsDavid Brownell
Declare the two 1Kbit EEPROMs included in the H4 board stack. One is on the CPU card; the other is on the mainboard. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-14i2c/isp1301_omap: Convert to a new-style i2c driver, part 2Jean Delvare
Based on David Brownell's patch for tps65010 and previous work by Felipe Balbi, this patch finishes converting isp1301_omap to a new-style i2c driver. There's definitely room for further drivers cleanups, but these are out of the scope of this patch. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Tony Lindgren <tony@atomide.com>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-09ARM: OMAP: Add calls to omap2_set_globals_*()Paul Walmsley
Add the omap2_set_globals_{242x,243x,343x}() functions. These functions are called early upon boot in the map_io() functions in the board-specific init files. This patch was accidentally left out of the earlier series. This fixes omap2 booting as noted by Kyungmin Park <kmpark@infradead.org>. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kyungmin Park <kmpark@infradead.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Change 24xx to use new register accessPaul Walmsley
This patch changes 24xx to use new register access, except for clock framework. Clock framework register access will get updates in the next patch. Note that board-*.c files change GPMC (General Purpose Memory Controller) access to use gpmc_cs_write_reg() instead of accessing the registers directly. The code also uses gpmc_fck instead of it's parent clock core_l3_ck for GPMC clock. The H4 board file also adds h4_init_flash() function, which specify the flash start and end addresses. Also note that sleep.S removes some unused registers addresses. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-09-20ARM: OMAP: abstract debug card setup (smc, leds)David Brownell
Additional cleanup for debug boards on H2/P2/H3/H4: move the init code that's not board-specific into a new file where it can be easily shared between all the different boards (avoiding code duplication, and making it easier to support more devices). Make H4 use that. This should be easy to drop in to the OMAP1 boards using these debug cards; the only difference seems to be that the p2 does an extra reset of the smc using the fpga (probably all boards could do that, if it's necessary) and doesn't use the gpio mux or request APIs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-05-08ARM: OMAP: h4 must have blinky leds!!David Brownell
This adds generic support for the "debug board" LEDs used by most of TI's OMAP reference boards, and board-specific support for the H4. It's derived from the not-as-generic stuff used by OMAP1 H2/H3/P2. Those should be able to switch easily to this version, and clean up some of the omap1-specific code. In addition to H4 support, one key improvement is supporting not just the "old" ARM debug LED API (with timer and idle LEDs, plus four that can be handy for kernel debugging), but it also supports the "new" generic LED API (most useful for usermode stuff IMO). Either or both APIs can be enabled. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-02ARM: OMAP: Use linux/delay.h not asm/delay.hTony Lindgren
Use linux/delay.h not asm/delay.h Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: Workqueue changes for board-h4.cDirk Behme
Workqueue changes for board-h4.c Signed-off-by: Dirk Behme <dirk.behme_at_gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-12-05WorkQueue: Fix up arch-specific work items where possibleDavid Howells
Fix up arch-specific work items where possible to use the new work_struct and delayed_work structs. Three places that enqueue bits of their stack and then return have been marked with #error as this is not permitted. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-29[PATCH] OMAP: Update OMAP1/2 boards to give keymapsize and other pdataKomal Shah
This patch adds keymapsize, delay and debounce flag in the keypad platform data for various TI OMAP1/2 based boards like F-sample, H2, H3, Innovator, Nokia770, OSK, Perseus and H4. Signed-off-by: Komal Shah <komal_shah802003@yahoo.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02[ARM] 3433/1: ARM: OMAP: 8/8 Update board filesTony Lindgren
Patch from Tony Lindgren This patch syncs OMAP board support with linux-omap tree. The highlights of the patch are: - Add support for Nokia 770 by Juha Yrjola - Add support for Samsung Apollon by Kyungmin Park - Add support for Amstrad E3 videophone by Jonathan McDowell - Remove board-netstar.c board support as requested by Ladislav Michl - Do platform_device registration in board files by Komal Shah et al. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-08[ARM] 3278/1: OMAP: 3/3 Fix low-level io init for omap2 boardsTony Lindgren
Patch from Tony Lindgren This patch fixes the low-level IO init for omap2 boards. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3145/1: OMAP 3a/5: Add support for omap24xxTony Lindgren
Patch from Tony Lindgren This patch adds support for omap24xx series of processors. The files live in arch/arm/mach-omap2, and share common files with omap15xx and omap16xx processors in arch/arm/plat-omap. Omap24xx support was originally added for 2.6.9 by TI. This code was then improved and integrated to share common code with omap15xx and omap16xx processors by various omap developers, such as Paul Mundt, Juha Yrjola, Imre Deak, Tony Lindgren, Richard Woodruff, Nishant Menon, Komal Shah et al. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
