path: root/arch/arm/mach-omap2/board-apollon.c
2010-02-15omap2/3/4: Fix omap2_map_common_io for multi-omapTony Lindgren
Fix omap2_map_common_io for multi-omap Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: use smc91x_platdata to setup smc91xLadislav Michl
Use smc91x_platdata to setup smc91x, so we can get rid of OMAP specific stuff in smc91x driver Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-19omap: Fix DEBUG_LL UART io addressSantosh Shilimkar
This patch fixes the low level debug UART io address as per this series. The change is essential to have CONFIG_DEBUG_LL working. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-20Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/mtdcore.c Merged in order that I can apply the Nomadik nand/onenand support patches.
2009-09-19mtd: onenand: make onenand/generic.c more genericMagnus Damm
Remove the ARM dependency from the generic "onenand" platform device driver. This change makes the driver useful for other architectures as well. Needed for the SuperH kfr2r09 board. Apart from the obvious Kconfig bits, the most important change is the move away from ARM specific includes and platform data. Together with this change the only in-tree board code gets an update, and the driver name is also changed gracefully break potential out of tree drivers. The driver is also updated to allow NULL as platform data together with a few changes to make use of resource_size() and dev_name(). Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Kyungmin Park <kmpark@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-03OMAP2/3 board-*.c files: read bootloader configuration earlierPaul Walmsley
Most board-*.c files read configuration data from the bootloader in their .init_machine() function. This needs to happen earlier, at some point before omap2_init_common_hw() is called. This is because a future patch will use the bootloader serial console port information to enable the UART clocks earlier, immediately after omap2_clk_init(). This is in turn necessary since otherwise clock tree usecounts on clocks like dpll4_m2x2_ck will be bogus, which can cause the currently-active console UART clock to be disabled during boot. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-08-28OMAP: UART: drop OMAP_TAG_UART, enable all UARTs, auto-disabled on idleKalle Valo
OMAP tags are deprecrated so drop them. Drop UART config data which decides which UARTs to enable during boot. This is no longer necessary since serial core code disables clocks after inactivity. Background: with new UART idle code, all on-chip UARTs are idled using a configurable inactivity timer (default 5 seconds.) After the inactivity timer, UART clocks are disabled automatically. Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-07-24OMAP3 SDRC: add support for 2 SDRAM chip selectsJean Pihet
Some OMAP3 boards (Beagle Cx, Overo, RX51, Pandora) have 2 SDRAM parts connected to the SDRC. This patch adds the following: - add a new argument of type omap_sdrc_params struct* to omap2_init_common_hw and omap2_sdrc_init for the 2nd CS params - adapted the OMAP boards files to the new prototype of omap2_init_common_hw - add the SDRC 2nd CS registers offsets defines - adapt the sram sleep code to configure the SDRC for the 2nd CS Note: If the 2nd param to omap2_init_common_hw is NULL, then the parameters are not programmed into the SDRC CS1 registers Tested on 3430 SDP and Beagleboard rev C2 and B5, with suspend/resume and frequency changes (cpufreq). Signed-off-by: Jean Pihet <jpihet@mvista.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-03-25Merge branch 'for-next' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
2009-03-23ARM: OMAP: get rid of OMAP_TAG_USB, v2Felipe Balbi
OMAP_TAGS should vanish soon since they're not generic arm tags. Most of them can be converted to a platform_data or parsed from a command line like e.g. serial tag. For OMAP_TAG_USB we just let boards call omap_usb_init() passing a pointer to omap_usb_config. Patch updated by Tony for mainline, basically make n770 and h4 compile. Also folded in a fix for OSK by David Brownell <dbrownell@users.sourceforge.net>. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23ARM: OMAP: No need to include board-apollon.h from hardware.hTony Lindgren
Move the defines to the associated board file and remove the now unnecessary header file. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-02-08[ARM] OMAP2 SDRC: add SDRAM timing parameter infrastructurePaul Walmsley
For a given SDRAM clock rate, SDRAM chips require memory controllers to use a specific set of timing minimums and maximums to transfer data reliably. These parameters can be different for different memory chips and can also potentially vary by board. This patch adds the infrastructure for board-*.c files to pass this timing data to the SDRAM controller init function. The timing data is specified in an 'omap_sdrc_params' structure, in terms of SDRC controller register values. An array of these structs, one per SDRC target clock rate, is passed by the board-*.c file to omap2_init_common_hw(). This patch does not define the values for different memory chips, nor does it use the values for anything; those will come in subsequent patches. linux-omap source commit is bc84ecfc795c2d1c5cda8da4127cf972f488a696. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-15ARM: OMAP: Fix gpio by switching to generic gpio calls, v2Jarkko Nikula
Fix compile by removing remaining omap specific gpio calls. Based on earlier patches by Jarkko Nikula. Also remove old GPIO key code, there is already a patch to do this with gpio_keys. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10omap mmc: Remove broken MMC init codeTony Lindgren
Most of the omap1 MMC boards got broken by an earlier patch 138ab9f8321f67c71984ca43222efa71b0a0a0a9. If you look closely, the MMC init funtions are pretty much just stubs. Remove broken init code to make room for cleaner MMC init code. Cc: Pierre Ossman <drzeus-mmc@drzeus.cx> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10ARM: OMAP: Switch to gpio_request/free callsJarkko Nikula
Switch to gpio_request/free calls Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10ARM: OMAP: switch to gpio_direction_outputDavid Brownell
More conversion to the standard GPIO interfaces: stop using omap_set_gpio_direction() entirely, and switch over to the gpio_direction_output() call. Note that because gpio_direction_output() includes the initial value, this change isn't quite transparent. - For the call sites which defined an initial value either before or after setting the direction, that value was used. When that value was previously assigned afterwards, this could eliminate a brief output glitch ... and possibly change behavior. In a few cases (LCDs) several values were assigned together ... those were re-arranged to match the explicit sequence provided. - Some call sites didn't define such a value; so I chose an initial "off/reset" value that seemed to default to "off". In short, files touched by this patch might notice some small changes in startup behavior (with trivial fixes). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10ARM: OMAP: switch to gpio_direction_inputDavid Brownell
More switchover to the cross-platform GPIO interface: use gpio_direction_input(), not an OMAP-specific call. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10ARM: OMAP: switch to standard gpio get/set callsDavid Brownell
This patch replaces some legacy OMAP GPIO calls with the "new" (not really, any more!) calls that work on most platforms. The calls addressed by this patch are the simple ones to get and set values ... for code that's in mainline, including the implementations of those calls. Except for the declarations and definitions of those calls, all of these changes were performed by a simple SED script. Plus, a few "if() set() else set()" branches were merged by hand. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-09ARM: OMAP: Add calls to omap2_set_globals_*()Paul Walmsley
Add the omap2_set_globals_{242x,243x,343x}() functions. These functions are called early upon boot in the map_io() functions in the board-specific init files. This patch was accidentally left out of the earlier series. This fixes omap2 booting as noted by Kyungmin Park <kmpark@infradead.org>. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kyungmin Park <kmpark@infradead.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Change 24xx to use new register accessPaul Walmsley
This patch changes 24xx to use new register access, except for clock framework. Clock framework register access will get updates in the next patch. Note that board-*.c files change GPMC (General Purpose Memory Controller) access to use gpmc_cs_write_reg() instead of accessing the registers directly. The code also uses gpmc_fck instead of it's parent clock core_l3_ck for GPMC clock. The H4 board file also adds h4_init_flash() function, which specify the flash start and end addresses. Also note that sleep.S removes some unused registers addresses. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-01-28Merge branch 'pxa-plat' into develRussell King
* pxa-plat: (53 commits) [ARM] 4762/1: Basic support for Toradex Colibri module [ARM] pxa: fix mci_init functions returning -1 [ARM] 4737/1: Refactor corgi_lcd to improve readability + bugfix [ARM] 4747/1: pcm027: support for pcm990 baseboard for phyCORE-PXA270 [ARM] 4746/1: pcm027: network support for phyCORE-PXA270 [ARM] 4745/1: pcm027: default configuration [ARM] 4744/1: pcm027: add support for phyCORE-PXA270 CPU module [NET] smc91x: Make smc91x use IRQ resource trigger flags [ARM] pxa: add default config for littleton [ARM] pxa: add basic support for Littleton (PXA3xx Form Factor Platform) [ARM] 4664/1: Add basic support for HTC Magician PDA phones [ARM] 4649/1: Base support for pxa-based Toshiba e-series PDAs. [ARM] pxa: skip registers saving/restoring if entering standby mode [ARM] pxa: fix PXA27x resume [ARM] pxa: Avoid fiddling with CKEN register on suspend [ARM] pxa: Add PXA3 standby code hooked into the IRQ wake scheme [ARM] pxa: Add zylonite MFP wakeup configurations [ARM] pxa: program MFPs for low power mode when suspending [ARM] pxa: make MFP configuration processor independent [ARM] pxa: remove un-used pxa3xx_mfp_set_xxx() functions ... Conflicts: arch/arm/mach-pxa/ssp.c Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[NET] smc91x: Make smc91x use IRQ resource trigger flagsRussell King
smc91x is shared between many different platforms. Each platform needs to specify the interrupt type, and in some cases the irq type depends on more than just the build configuration - it depends on runtime checks. Rather than throwing this code into the SMC_IRQ_FLAGS definition, provide a way for these flags to be passed via the IRQ resource itself. Note that IRQF_TRIGGER_* constants are intentionally defined to correspond with the IORESOURCE_IRQ_* interrupt type flags, in much the same way that the low bits of PCI iomem resources correspond with the BAR flag bits. Also provide a way to configure smc91x to read the IRQ flags from the resource. Once all platforms have been converted over (signified by all definitions of SMC_IRQ_FLAGS being -1) SMC_IRQ_FLAGS should be removed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-26[ARM] remove duplicate includesLucas Woods
Signed-off-by: Lucas Woods <woodzy@gmail.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-09-20ARM: OMAP: Board Apollon update, fix bootKyungmin Park
Update Apollon board init to initialize NAND, USB, and LEDs. Also configure GPMC memory for smc91x Ethernet. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-12-30[PATCH] ARM: OMAP: fix missing header on apollon boardKyungmin Park
Fix apollon board compiler error Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-25ARM: OMAP: Apollon MMC supportKyungmin Park
Apollon board MMC supports on OMAP2 TODO: We have to check MMC on H4 Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02[ARM] 3433/1: ARM: OMAP: 8/8 Update board filesTony Lindgren
Patch from Tony Lindgren This patch syncs OMAP board support with linux-omap tree. The highlights of the patch are: - Add support for Nokia 770 by Juha Yrjola - Add support for Samsung Apollon by Kyungmin Park - Add support for Amstrad E3 videophone by Jonathan McDowell - Remove board-netstar.c board support as requested by Ladislav Michl - Do platform_device registration in board files by Komal Shah et al. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
