Some regulator config can be moved out from board files,
since they are close to identical.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Reduce the amount of duplicated code by moving the common
configuration for twl4030/5030/tpsxx to the twl-common file.
Use the omap3_pmic_get_config function from board files to
properly configure the PMIC with the common fields.
This is needed for the following patches so we can initialize the
rest of the hardware timers later on.
As with the init_irq calls, there's no need to do cpu_is_omap calls
during the timer init as we only care about the major omap generation.
This means that we can initialize the sys_timer with the .timer
entries alone.
Note that for now we just set stubs for the various sys_timer entries
that will get populated in a later patch. The following patches will
also remove the omap_dm_timer_init calls and change the init for the
rest of the hardware timers to happen with an arch_initcall.
Reviewed-by: Kevin Hilman <khilman@ti.com>
This allows us to remove cpu_is_omap calls from init_irq functions.
There should not be any need for cpu_is_omap calls as at this point.
During the timer init we only care about SoC generation, and not about
subrevisions.
The main reason for the patch is that we want to initialize only
minimal omap specific code from the init_early call.
The serial*_data should have been marked as __initdata as per
it's usage in the board files. Fix the same to remove the
section mismatch warnings caused by it.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Silesh C V <silesh@ti.com>
[tony@atomide.com: updated with additional fixes from Silesh]
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (33 commits)
OMAP3: PM: Boot message is not an error, and not helpful, remove it
OMAP3: cpuidle: change the power domains modes determination logic
OMAP3: cpuidle: code rework for improved readability
OMAP3: cpuidle: re-organize the C-states data
OMAP3: clean-up mach specific cpuidle data structures
OMAP3 cpuidle: remove useless SDP specific timings
usb: otg: OMAP4430: Powerdown the internal PHY when USB is disabled
usb: otg: OMAP4430: Fixing the omap4430_phy_init function
usb: musb: am35x: fix compile error when building am35x
usb: musb: OMAP4430: Power down the PHY during board init
omap: drop board-igep0030.c
omap: igep0020: add support for IGEP3
omap: igep0020: minor refactoring
omap: igep0020: name refactoring for future merge with IGEP3
omap: Remove support for omap2evm
arm: omap2plus: GPIO cleanup
omap: musb: introduce default board config
omap: move detection of NAND CS to common-board-devices
omap: use common initialization for PMIC i2c bus
omap: consolidate touch screen initialization among different boards
ssh://master.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-linus
The cpuidle states settings can be overriden by some board-
specific settings, by calling omap3_pm_init_cpuidle.
Remove the 3430SDP specific states settings registration
since the figures are identical to the default ones (in cpuidle34xx.c).
Signed-off-by: Jean Pihet <j-pihet@ti.com>
Signed-off-by: Kevin Hilman <khilman@ti.com>
use gpio_request_<one|array>() instead of multiple gpiolib calls,
remove unneeded variables, etc.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
arch/arm/plat-omap/include/plat/panel-generic-dpi.h is an include for
the OMAP DSS panel driver for generic DPI displays. A more logical place
for it is in include/video.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
arch/arm/plat-omap/include/plat/display.h is an include for the OMAP DSS
driver. A more logical place for it is in include/video.
Most boards use exactly the same configuration for musb initialization.
Create a default that can be shared amount different boards.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Felipe Balbi <balbi@ti.com>
Introduce omap_pmic_init that registers i2c bus and PMIC device on that
bus and add omap2/3/4 wrappers for common cases.
Add common-board-devices.c that will contain the code for peripheral
devices initializatoin shared between multiple boards.
Start small with touchscreen initialization.
arch/arm/mach-omap2/board-overo.c
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits)
omap: zoom: host should not pull up wl1271's irq line
arm: plat-omap: iommu: fix request_mem_region() error path
OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430
omap4: mux: Remove duplicate mux modes
omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag
omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set
omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected
omap4: board-omap4panda: Initialise the serial pads
omap3: board-3430sdp: Initialise the serial pads
omap4: board-4430sdp: Initialise the serial pads
omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init
omap2+: mux: Remove the use of IDLE flag
omap2+: Add separate list for dynamic pads to mux
perf: add OMAP support for the new power events
OMAP4: Add IVA OPP enteries.
OMAP4: Update Voltage Rail Values for MPU, IVA and CORE
OMAP4: Enable 800 MHz and 1 GHz MPU-OPP
OMAP3+: OPP: Replace voltage values with Macros
OMAP3: wdtimer: Fix CORE idle transition
Watchdog: omap_wdt: add fine grain runtime-pm
Fix up various conflicts in
- arch/arm/mach-omap2/board-omap3evm.c
- arch/arm/mach-omap2/clock3xxx_data.c
- arch/arm/mach-omap2/usb-musb.c
- arch/arm/plat-omap/include/plat/usb.h
- drivers/usb/musb/musb_core.h
Use the mux framework to initialise the serial pads.
Signed-off-by: sricharan <r.sricharan@ti.com>
Hwmod adaptation design requires each of the DSS HW IP to be a platform driver.
So a platform_driver for DSI is created and init exit methods are moved from core.c
to its driver probe,remove. pdev member has to be maintained by its own drivers.
Also, vdds_dsi regulator handling is copied to dsi.c, since vdds_dsi regulator is
needed by dpi_init() too. Board files are updated accordingly to add 2 instances of
vdds_dsi regulator.
DSI platform driver is registered from inside omap_dss_probe, in the order desired.
Signed-off-by: Senthilvadivu Guruswamy <svadivu@ti.com>
Signed-off-by: Sumit Semwal <sumit.semwal@ti.com>
So a platform_driver for VENC is created and init exit methods are moved from core.c
Also, venc_vdda_dac reading is moved to venc.c.
VENC platform driver is registered from inside omap_dss_probe, in the order desired.
Remove extra vdda_dac supply definition. It was a leftover from conflict
resolution.
'devel-hsmmc' into omap-for-linus
arch/arm/mach-omap2/omap_hwmod_44xx_data.c
twl4030_codec_audio and twl4030_codec_vibra_data has unused field.
In order to remove it, corresponding settings needs to be removed
from board files.
Signed-off-by: Ilkka Koskinen <ilkka.koskinen@nokia.com>
Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Modifying the device & driver name from "mmci-omap-hs" to
"omap_hsmmc".
Signed-off-by: Kishore Kadiyala <kishore.kadiyala@ti.com>
Acked-by: Benoit Cousson<b-cousson@ti.com>
The usbhs intialization is invoked by all omap3 and omap4
variant board files.
Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Create the ehci and ohci specific platform data structures.
The port enum values are made common for both ehci and ohci.
We should only call init_common_infrastructure and
init_common_devices from init_early.
omap-for-linus
arch/arm/mach-omap2/board-3430sdp.c
'devel-nand' into omap-for-linus
omap_display_init()
This patch updated board files to replace platform_device_register or
platform_add_devices of DSS with omap_display_init(). This moves away
registration of DSS from board files into a common place.
Tested-by: Kevin Hilman <khilman@ti.com>
Use driver name in regulator inits needed for display instead of using device
structure name.
clean the regulator supply mapping data in the 3430sdp
board file (which is spread all over) by moving all
of them together.
Also use the REGULATOR_SUPPLY macro and remove instances
of mapping dev pointers at run time.
Additonally define all regulator_consumer_supply as
array's and use ARRAY_SIZE macro to define
num_consumer_supplies.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
On the OMAP3430SDP board, the ads7846 touchscreen controller
is powered by VAUX3 regulator (supplying 2.8v).
Fix this mapping in the board file, and hence prevent
the ads7846 driver init to fail with the below error..
ads7846 spi1.0: unable to get regulator: -19
zoom3 and 3630-sdp having the x16 nand device.
This patch configure gpmc as x16 and select the currect function in driver
for polled mode (without prefetch enable) transfer.
Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com>
Move non-mapping and non-irq initialization code out of .map_io and
.init_irq respectively into the new init_early hook.
Still keep sharp_ls_panel, since the sharp_ls_panel driver contains blacklight
control driver code which will be moved out later. Then we can use generic DPI
driver for sharp_ls_panel.
Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
Acked-by: Archit Taneja <archit@ti.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
Split omap2_init_common_hw() into two functions. The first,
omap2_init_common_infrastructure(), initializes the hwmod code and
data, the OMAP PM code, and the clock code and data. The second,
omap2_init_common_devices(), handles any other early device
initialization that, for whatever reason, has not been or cannot be
moved to initcalls or early platform devices.
This patch is required for the hwmod postsetup patch, which allows
board files to change the state that hwmods should be placed into at
the conclusion of the hwmod _setup() function. For example, for a
board whose creators wish to ensure watchdog coverage across the
entire kernel boot process, code to change the watchdog's postsetup
state will be added in the board-*.c file between the
omap2_init_common_infrastructure() and omap2_init_common_devices() function
calls.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Tony Lindgren <tony@atomide.com>
Implement GPIO as a platform device.
GPIO APIs are used in machine_init functions. Hence it is
required to complete GPIO probe before board_init. Therefore
GPIO device register and driver register are implemented as
postcore_initcalls.
omap_gpio_init() does nothing now and this function would be
removed in the next patch as it's usage is spread across most
of the board files.
Inorder to convert GPIO as platform device, modifications are
required in clockxxxx_data.c file for OMAP1 so that device names
can be used to obtain clock instead of getting clocks by
name/NULL ptr.
Use runtime pm APIs (pm_runtime_put*/pm_runtime_get*) for enabling
or disabling the clocks, modify sysconfig settings and remove usage
of clock FW APIs.
Note 1: Converting GPIO driver to use runtime PM APIs is not done as a
separate patch because GPIO clock names are different for various OMAPs
and are different for some of the banks in the same CPU. This would need
usage of cpu_is checks and bank id checks while using clock FW APIs in
the gpio driver. Hence while making GPIO a platform driver framework,
PM runtime APIs are used directly.
Note 2: While implementing GPIO as a platform device, pm runtime APIs
are used as mentioned above and modification is not done in gpio's
prepare for idle/ resume after idle functions. This would be done
in the next patch series and GPIO driver would be made to use dev_pm_ops
instead of sysdev_class in that series only.
Due to the above, the GPIO driver implicitly relies on
CM_AUTOIDLE = 1 on its iclk for power management to work, since the
driver never disables its iclk.
This would be taken care in the next patch series (see Note 3 below).
Refer to
http://www.mail-archive.com/linux-omap@vger.kernel.org/msg39112.html
for more details.
Note 3: only pm_runtime_get_sync is called in gpio's probe() and
pm_runtime_put* is never called. This is to make the implementation
similar to the existing GPIO code. Another patch series would be sent
to correct this.
In OMAP3 and OMAP4 gpio's debounce clocks are optional clocks. They
are enabled/ disabled whenever required using clock framework APIs
TODO:
1. Cleanup the GPIO driver. Use function pointers and register
offest pointers instead of using hardcoded values
2. Remove all cpu_is_ checks and OMAP specific macros
3. Remove usage of gpio_bank array so that only
instance specific information is used in driver code
4. Rename 'method'/ avoid it's usage
5. Fix the non-wakeup gpios handling for OMAP2430, OMAP3 & OMAP4
6. Modify gpio's prepare for idle/ resume after idle functions
to use runtime pm implentation.
Signed-off-by: Charulatha V <charu@ti.com>
Reviewed-by: Basak, Partha <p-basak2@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
[tony@atomide.com: updated for bank specific revision and updated boards]
If CONFIG_OMAP_MUX is not enabled, we can define board_mux in the header
file instead of forcing every single board to define it.
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
[tony@atomide.com: updated for combined board-zoom files]
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits)
omap: complete removal of machine_desc.io_pg_offst and .phys_io
omap: UART: fix wakeup registers for OMAP24xx UART2
omap: Fix spotty MMC voltages
ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h
serial: omap-serial: fix signess error
OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish
omap: dma: Fix buffering disable bit setting for omap24xx
omap: serial: Fix the boot-up crash/reboot without CONFIG_PM
OMAP3: PM: fix scratchpad memory accesses for off-mode
omap4: pandaboard: enable the ehci port on pandaboard
omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set
omap4: pandaboard: remove unused hsmmc definition
OMAP: McBSP: Remove null omap44xx ops comment
OMAP: McBSP: Swap CLKS source definition
OMAP: McBSP: Fix CLKR and FSR signal muxing
OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks
OMAP: control: move plat-omap/control.h to mach-omap2/control.h
OMAP: split plat-omap/common.c
OMAP: McBSP: implement functional clock switching via clock framework
OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c
Fixed up trivial conflicts in arch/arm/mach-omap2/
{board-zoom-peripherals.c,devices.c} as per Tony
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
Only OMAP2+ platforms have the System Control Module (SCM) IP block.
In the past, we've kept the SCM header file in plat-omap. This has
led to abuse - device drivers including it; includes being added that
create implicit dependencies on OMAP2+ builds; etc.
In response, move the SCM headers into mach-omap2/.
As part of this, remove the direct SCM access from the OMAP UDC
driver. It was clearly broken. The UDC code needs an indepth review for
use on OMAP2+ chips.
Cc: Cory Maccarrone <darkstar6262@gmail.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
The keypad matrix variable declaration is not matching
with structure variable keymap declared in keypad_matrix.h.
Due to this, following sparse warnings are generated with omap3_defconfig.
arch/arm/mach-omap2/board-devkit8000.c:223:14: warning: incorrect type in initializer (different signedness)
arch/arm/mach-omap2/board-devkit8000.c:223:14: expected unsigned int const [usertype] *keymap
arch/arm/mach-omap2/board-devkit8000.c:223:14: got int static [toplevel] *<noident>
arch/arm/mach-omap2/board-ldp.c:107:14: warning: incorrect type in initializer (different signedness)
arch/arm/mach-omap2/board-ldp.c:107:14: expected unsigned int const [usertype] *keymap
arch/arm/mach-omap2/board-ldp.c:107:14: got int static [toplevel] *<noident>
arch/arm/mach-omap2/board-omap3evm.c:472:14: warning: incorrect type in initializer (different signedness)
arch/arm/mach-omap2/board-omap3evm.c:472:14: expected unsigned int const [usertype] *keymap
arch/arm/mach-omap2/board-omap3evm.c:472:14: got int static [toplevel] *<noident>
arch/arm/mach-omap2/board-3430sdp.c:114:14: warning: incorrect type in initializer (different signedness)
arch/arm/mach-omap2/board-3430sdp.c:114:14: expected unsigned int const [usertype] *keymap
arch/arm/mach-omap2/board-3430sdp.c:114:14: got int static [toplevel] *<noident>
arch/arm/mach-omap2/board-rx51-peripherals.c:248:14: warning: incorrect type in initializer (different signedness)
arch/arm/mach-omap2/board-rx51-peripherals.c:248:14: expected unsigned int const [usertype] *keymap
arch/arm/mach-omap2/board-rx51-peripherals.c:248:14: got int static [toplevel] *<noident>
arch/arm/mach-omap2/board-zoom-peripherals.c:88:14: warning: incorrect type in initializer (different signedness)
arch/arm/mach-omap2/board-zoom-peripherals.c:88:14: expected unsigned int const [usertype] *keymap
arch/arm/mach-omap2/board-zoom-peripherals.c:88:14: got int static [toplevel] *<noident>
arch/arm/mach-omap2/board-cm-t35.c:568:14: warning: incorrect type in initializer (different signedness)
arch/arm/mach-omap2/board-cm-t35.c:568:14: expected unsigned int const [usertype] *keymap
arch/arm/mach-omap2/board-cm-t35.c:568:14: got int static [toplevel] *<noident>
arch/arm/mach-omap2/board-omap3stalker.c:415:13: warning: incorrect type in initializer (different signedness)
arch/arm/mach-omap2/board-omap3stalker.c:415:13: expected unsigned int const [usertype] *keymap
arch/arm/mach-omap2/board-omap3stalker.c:415:13: got int static [toplevel] *<noident>
This patch modifies the variable keymap declaration as per declaration in matrix_keymap structure.
Signed-off-by: Manjunath Kondaiah G <manjugk@ti.com>
Cc: linux-input@vger.kernel.org
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Nishanth Menon <nm@ti.com>
This patch fixes sparse warnings due non declarations of static functions.
arch/arm/mach-omap2/timer-gp.c:115:12: warning: symbol 'omap2_gp_clockevent_set_gptimer' was not declared. Should it be static?
arch/arm/mach-omap2/powerdomain.c:993:5: warning: symbol 'pwrdm_set_lowpwrstchange' was not declared. Should it be static?
arch/arm/mach-omap2/board-flash.c:141:8: warning: symbol 'board_nand_init' was not declared. Should it be static?
arch/arm/mach-omap2/board-n8x0.c:416:6: warning: symbol 'n8x0_mmc_slot1_cover_handler' was not declared. Should it be static?
arch/arm/mach-omap2/board-n8x0.c:544:13: warning: symbol 'n8x0_mmc_init' was not declared. Should it be static?
arch/arm/mach-omap2/board-rx51-peripherals.c:902:13: warning: symbol 'rx51_peripherals_init' was not declared. Should it be static?
arch/arm/mach-omap2/board-rx51-video.c:107:13: warning: symbol 'rx51_video_mem_init' was not declared. Should it be static?
arch/arm/mach-omap2/board-zoom-debugboard.c:155:12: warning: symbol 'zoom_debugboard_init' was not declared. Should it be static?
arch/arm/mach-omap2/board-zoom-peripherals.c:280:13: warning: symbol 'zoom_peripherals_init' was not declared. Should it be static?
arch/arm/mach-omap2/board-igep0020.c:110:13: warning: symbol 'igep2_flash_init' was not declared. Should it be static?
arch/arm/mach-omap2/board-am3517evm.c:109:6: warning: symbol 'am3517_evm_ethernet_init' was not declared. Should it be static?
drivers/mtd/onenand/omap2.c:577:5: warning: symbol 'omap2_onenand_rephase' was not declared. Should it be static?
wires variable is renamed, extended and this single variable to be used to
pass the platform capabilities, e.g DDR mode. Also removed the hardcoded
value was using as bus-width.
Most OMAP3-based boards use exactly the same code for .map_io method in
the machine_desc structure.
This patch introduces omap3_map_io and updates board-* files to use it
as .map_io method.
The only difference between them is the physical address of the
uart4 port, which is only present in 36xx chips.
We don't really need to care about keeping these 2 functions, since
the decision to use uart4 is more cleanly done later when we do have
access to omap_revision variable.
Signed-off-by: Sergio Aguirre <saaguirre@ti.com>
[tony@atomide.com: added comment for the uart4_phys]
rename board-sdp-flash.c(board-flash.c) and board-sdp.h(board-flash.h) to
used by other board e.g. zoom
