path: root/arch/arm/mach-omap2/board-3430sdp.c
2013-08-28ARM: OMAP: 3430SDP: use new display driversTomi Valkeinen
Use new display drivers for 3430SDP board. The new OMAP display drivers were merged for 3.11, and we can now change the board files to use the new ones and phase out the old ones. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2013-05-06Merge branch 'late/clksrc' into late/cleanupArnd Bergmann
There is no reason to keep the clksrc cleanups separate from the other cleanups, and this resolves some merge conflicts. Conflicts: arch/arm/mach-spear/spear13xx.c drivers/irqchip/Makefile
2013-04-04arm: omap boards: Remove unnecessary platform_enable/disable callbacks for ↵Archit Taneja
VENC devices The omap_dss_device's platform_enable/disable callbacks don't do anything for any of the boards. The platform calls from the VENC driver will also be removed in the future. Remove these calls from the board which have a VENC device. Signed-off-by: Archit Taneja <archit@ti.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-04-04arm: omap: board-sdp3430: use sharp panel's gpio handlingArchit Taneja
The omap3430sdp board file currently requests gpios required by the sharp_ls dpi panel, and provides platform_enable/disable callbacks to configure them. These tasks have been moved to the sharp_ls panel driver itself and shouldn't be done in the board files. Remove the gpio requests and the platform callbacks from the board file. Add the gpio information to panel_sharp_ls037v7dw01_data so that it's passed to the panel driver. Out of sharp panel's configurable pins, all apart from resb_gpio are managed by a CPLD on the display and set to a default value. Only the configurable pin is passed to platform data. The backlight GPIO doesn't go directly to the sharp panel, it is used to set up a voltage supply which goes to the LED+ pin of the panel, hence it isn't passed to panel as platform data, and configured in the board file itself. The backlight used to previously toggle through the platform_enable/disable callbacks, but now it is always on. This needs to be revisited. Signed-off-by: Archit Taneja <archit@ti.com> Cc: Tony Lindgren <tony@atomide.com>
2013-04-03OMAPDSS: panels: keep platform data of all panels in a single headerArchit Taneja
Structs for platform data of omapdss panels are found in headers in the 'include/video/' path. Board files populate these structs with platform specific values, and the panel driver uses these to configure the panel. Currently, each panel has it's own header in the above path. Move all the omapdss panel platform data structs to a single header omap-panel-data.h. This is useful because: - All other omapdss panel drivers will be modified to use platform data. This would lead to a lot of panel headers usable only by omapdss. A lot of these platform data structs are trivial, and don't really need a separate header. - Platform data would be eventually removed, and platform information would be passed via device tree. Therefore, omapdss panel platform data structs are temporary, and will be easier to remove if they are all in the same header. - All board files will have to include the same header to configure a panel's platform data, that makes the board files more consistent. Signed-off-by: Archit Taneja <archit@ti.com>
2013-04-02ARM: OMAP3: 3430SDP: Adapt to ehci-omap changesRoger Quadros
Use usbhs_init_phys() to register the PHY's RESET regulators and the NOP PHY devices. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-02-21Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC board specific changes from Arnd Bergmann: "These updates are all for board specific code, including - defconfig updates for shmobile, davinci, bcm2835, imx, omap and tegra - SD/MMC and I2C support on bcm2835 (Raspberry PI) - minor updates for PXA - shmobile updates to GPIO usage in board files - More things in OMAP board files are moved over to device tree probing - Better support for audio devices on some OMAP platforms" * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (55 commits) ARM: imx_v4_v5_defconfig: Add VPU support ARM: imx: configs: enable netfilter support ARM: OMAP2+: Fix twl section warnings related to omap_twl4030_audio_init ARM: OMAP2+: omap2plus_defconfig: enable omap1 rtc RX-51: Register twl4030-madc device RX-51: Add leds lp5523 names from Maemo 5 2.6.28 kernel ARM: OMAP2+: AM33XX: omap2plus_defconfig: Add support for few drivers ARM: OMAP1: nokia770: enable CBUS/Retu ARM: OMAP2+: omap2plus_defconfig: enable CMA allocator ARM: OMAP2+: omap2plus_defconfig: enable TFP410 chip support ARM: OMAP3: igep0020: simplify GPIO LEDs dependencies ARM: OMAP2+: craneboard: support the TPS65910 PMU ARM: OMAP2+: craneboard: support NAND device ARM: OMAP3: cm-t3517: add MMC support ARM: OMAP2+: Remove apollon board support ARM: shmobile: armadillo800eva: set clock rates before timer init ARM: tegra: defconfig updates ARM: shmobile: mackerel: Use gpio_request_one() ARM: shmobile: kzm9g: Use gpio_request_one() ARM: shmobile: bonito: Use gpio_request_one() ...
2013-02-21Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC-specific updates from Arnd Bergmann: "This is a larger set of new functionality for the existing SoC families, including: - vt8500 gains support for new CPU cores, notably the Cortex-A9 based wm8850 - prima2 gains support for the "marco" SoC family, its SMP based cousin - tegra gains support for the new Tegra4 (Tegra114) family - socfpga now supports a newer version of the hardware including SMP - i.mx31 and bcm2835 are now using DT probing for their clocks - lots of updates for sh-mobile - OMAP updates for clocks, power management and USB - i.mx6q and tegra now support cpuidle - kirkwood now supports PCIe hot plugging - tegra clock support is updated - tegra USB PHY probing gets implemented diffently" * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (148 commits) ARM: prima2: remove duplicate v7_invalidate_l1 ARM: shmobile: r8a7779: Correct TMU clock support again ARM: prima2: fix __init section for cpu hotplug ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3) ARM: OMAP: Consolidate OMAP USB-HS platform data (part 1/3) arm: socfpga: Add SMP support for actual socfpga harware arm: Add v7_invalidate_l1 to cache-v7.S arm: socfpga: Add entries to enable make dtbs socfpga arm: socfpga: Add new device tree source for actual socfpga HW ARM: tegra: sort Kconfig selects for Tegra114 ARM: tegra: enable ARCH_REQUIRE_GPIOLIB for Tegra114 ARM: tegra: Fix build error w/ ARCH_TEGRA_114_SOC w/o ARCH_TEGRA_3x_SOC ARM: tegra: Fix build error for gic update ARM: tegra: remove empty tegra_smp_init_cpus() ARM: shmobile: Register ARM architected timer ARM: MARCO: fix the build issue due to gic-vic-to-irqchip move ARM: shmobile: r8a7779: Correct TMU clock support ARM: mxs_defconfig: Select CONFIG_DEVTMPFS_MOUNT ARM: mxs: decrease mxs_clockevent_device.min_delta_ns to 2 clock cycles ARM: mxs: use apbx bus clock to drive the timers on timrotv2 ...
2013-02-21Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups from Arnd Bergmann: "A large number of cleanups, all over the platforms. This is dominated largely by the Samsung platforms (s3c, s5p, exynos) and a few of the others moving code out of arch/arm into more appropriate subsystems. The clocksource and irqchip drivers are now abstracted to the point where platforms that are already cleaned up do not need to even specify the driver they use, it can all get configured from the device tree as we do for normal device drivers. The clocksource changes basically touch every single platform in the process. We further clean up the use of platform specific header files here, with the goal of turning more of the platforms over to being "multiplatform" enabled, which implies that they cannot expose their headers to architecture independent code any more. It is expected that no functional changes are part of the cleanup. The overall reduction in total code lines is mostly the result of removing broken and obsolete code." * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits) ARM: mvebu: correct gated clock documentation ARM: kirkwood: add missing include for nsa310 ARM: exynos: move exynos4210-combiner to drivers/irqchip mfd: db8500-prcmu: update resource passing drivers/db8500-cpufreq: delete dangling include ARM: at91: remove NEOCORE 926 board sunxi: Cleanup the reset code and add meaningful registers defines ARM: S3C24XX: header mach/regs-mem.h local ARM: S3C24XX: header mach/regs-power.h local ARM: S3C24XX: header mach/regs-s3c2412-mem.h local ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/ ARM: S3C24XX: transform s3c2443 subirqs into new structure ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs ARM: S3C24XX: move s3c2443 irq code to irq.c ARM: S3C24XX: transform s3c2416 irqs into new structure ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs ARM: S3C24XX: move s3c2416 irq init to common irq code ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property ARM: S3C24XX: Move irq syscore-ops to irq-pm clocksource: always define CLOCKSOURCE_OF_DECLARE ...
2013-02-19Merge tag 'omap-for-v3.9/usb-signed' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/soc These changes contain the OMAP USB related platform data changes that were dropped from linux next because of the merge conflicts as requested by me and Olof. The reason was that at this point we really should be able to do the arch/arm related changes separately from driver changes to avoid dependencies between branches. These patches were initially part of the USB related MFD patches. Based on our comments, Roger Quadros quickly reworked these patches into a shared branch between ARM SoC tree and the MFD tree, then separate patches for the OMAP platform data and MFD driver. Note that this branch will conflict with c1d1cd597fc7 ("ARM: OMAP2+: omap_device: remove obsolete pm_lats and early_device code"). Please see http://lkml.org/lkml/2013/2/11/16 for the merge resolution. [arnd - resolved the merge conflict] Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-02-14ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3)Roger Quadros
Let's have a single platform data structure for the OMAP's High-Speed USB host subsystem instead of having 3 separate ones i.e. one for board data, one for USB Host (UHH) module and one for USB-TLL module. This makes the code much simpler and avoids creating multiple copies of platform data. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Felipe Balbi <balbi@ti.com>
2013-02-06ARM: OMAP: USB: Add phy binding informationKishon Vijay Abraham I
This is w.r.t the changes in PHY library to support adding and getting multiple PHYs of the same type. In the new design, the binding information between the PHY and the USB controller should be specified in the platform specific initialization code. So it's been done here for OMAP platforms. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-22ARM: OMAP: sdp3430: Audio support via the common omap-twl4030 machine driverPeter Ujfalusi
Use the common omap-twl4030 ASoC machine driver for audio. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
2013-01-22ARM: OMAP: 3430sdp: Enable extmute functionality for audioPeter Ujfalusi
Enable the use of extmute on the HS path. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-14OMAP: board-files: fix i2c_bus for tfp410Tomi Valkeinen
The i2c handling in tfp410 driver, which handles converting parallel RGB to DVI, was changed in 958f2717b84e88bf833d996997fda8f73276f2af (OMAPDSS: TFP410: pdata rewrite). The patch changed what value the driver considers as invalid/undefined. Before the patch, 0 was the invalid value, but as 0 is a valid bus number, the patch changed this to -1. However, the fact was missed that many board files do not define the bus number at all, thus it's left to 0. This causes the driver to fail to get the i2c bus, exiting from the driver's probe with an error, meaning that the DVI output does not work for those boards. This patch fixes the issue by changing the i2c_bus number field in the driver's platform data from u16 to int, and setting the bus number to -1 in the board files for the boards that did not define the bus. The exception is devkit8000, for which the bus is set to 1, which is the correct bus for that board. The bug exists in v3.5+ kernels. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reported-by: Thomas Weber <thomas@tomweber.eu> Cc: Thomas Weber <thomas@tomweber.eu> Cc: <stable@vger.kernel.org> # v3.5+ Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-11-30ARM: OMAP: Move plat-omap/dma-omap.h to include/linux/omap-dma.hTony Lindgren
Based on earlier discussions[1] we attempted to find a suitable location for the omap DMA header in commit 2b6c4e73 (ARM: OMAP: DMA: Move plat/dma.h to plat-omap/dma-omap.h) until the conversion to dmaengine is complete. Unfortunately that was before I was able to try to test compile of the ARM multiplatform builds for omap2+, and the end result was not very good. So I'm creating yet another all over the place patch to cut the last dependency for building omap2+ for ARM multiplatform. After this, we have finally removed the driver dependencies to the arch/arm code, except for few drivers that are being worked on. The other option was to make the <plat-omap/dma-omap.h> path to work, but we'd have to add some new header directory to for multiplatform builds. Or we would have to manually include arch/arm/plat-omap/include again from arch/arm/Makefile for omap2+. Neither of these alternatives sound appealing as they will likely lead addition of various other headers exposed to the drivers, which we want to avoid for the multiplatform kernels. Since we already have a minimal include/linux/omap-dma.h, let's just use that instead and add a note to it to not use the custom omap DMA functions any longer where possible. Note that converting omap DMA to dmaengine depends on dmaengine supporting automatically incrementing the FIFO address at the device end, and converting all the remaining legacy drivers. So it's going to be few more merge windows. [1] https://patchwork.kernel.org/patch/1519591/# cc: Russell King <linux@arm.linux.org.uk> cc: Kevin Hilman <khilman@ti.com> cc: "Benoît Cousson" <b-cousson@ti.com> cc: Herbert Xu <herbert@gondor.apana.org.au> cc: "David S. Miller" <davem@davemloft.net> cc: Vinod Koul <vinod.koul@intel.com> cc: Dan Williams <djbw@fb.com> cc: Mauro Carvalho Chehab <mchehab@infradead.org> cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> cc: David Woodhouse <dwmw2@infradead.org> cc: Kyungmin Park <kyungmin.park@samsung.com> cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> cc: Tomi Valkeinen <tomi.valkeinen@ti.com> cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> cc: Hans Verkuil <hans.verkuil@cisco.com> cc: Vaibhav Hiremath <hvaibhav@ti.com> cc: Lokesh Vutla <lokeshvutla@ti.com> cc: Rusty Russell <rusty@rustcorp.com.au> cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> cc: Afzal Mohammed <afzal@ti.com> cc: linux-crypto@vger.kernel.org cc: linux-media@vger.kernel.org cc: linux-mtd@lists.infradead.org cc: linux-usb@vger.kernel.org cc: linux-fbdev@vger.kernel.org Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-11-08ARM: OMAP2+: board files: use SoC-specific system restart functionsPaul Walmsley
Modify the board files to use the SoC-specific system restart functions. At this point it's possible to remove omap_prcm_restart() from mach-omap2/prcm.c. While removing the prototypes for the now-unused restart functions, clean up a few more obsolete prototypes in mach-omap2/clock.h. Signed-off-by: Paul Walmsley <paul@pwsan.com> Tested-by: Vaibhav Hiremath <hvaibhav@ti.com>
2012-10-24Merge branch 'omap-for-v3.8/cleanup-headers-usb' into ↵Tony Lindgren
omap-for-v3.8/cleanup-headers Conflicts: arch/arm/mach-omap1/clock.c arch/arm/mach-omap2/board-2430sdp.c arch/arm/mach-omap2/board-4430sdp.c arch/arm/mach-omap2/board-cm-t35.c arch/arm/mach-omap2/board-igep0020.c arch/arm/mach-omap2/board-ldp.c arch/arm/mach-omap2/board-omap3beagle.c arch/arm/mach-omap2/board-omap3logic.c arch/arm/mach-omap2/board-omap4panda.c arch/arm/mach-omap2/board-overo.c arch/arm/mach-omap2/board-rm680.c arch/arm/mach-omap2/board-rx51.c arch/arm/mach-omap2/twl-common.c arch/arm/mach-omap2/usb-host.c arch/arm/mach-omap2/usb-musb.c
2012-10-24ARM: OMAP2+: Introduce local usb.hTony Lindgren
Let's move what we can from plat/usb.h to the local usb.h for ARM common zImage support. This is needed so we can remove plat/usb.h for ARM common zImage support. Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Partha Basak <parthab@india.ti.com> Cc: Keshava Munegowda <keshava_mgowda@ti.com> Cc: linux-usb@vger.kernel.org Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-18ARM: OMAP: Split plat/cpu.h into local soc.h for mach-omap1 and mach-omap2Tony Lindgren
We want to remove plat/cpu.h. To do this, let's first split it to private soc.h to mach-omap1 and mach-omap2. We have to keep plat/cpu.h around until the remaining drivers are fixed, so let's include the local soc.h in plat/cpu.h and for drivers still including plat/cpu.h. Once the drivers are fixed not to include plat/cpu.h, we can remove the file. This is needed for the ARM common zImage support. [tony@atomide.com: updated to not print a warning] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-17Merge branch 'omap-for-v3.8/cleanup-headers-gpmc' into ↵Tony Lindgren
omap-for-v3.8/cleanup-headers Conflicts: arch/arm/mach-omap2/board-3430sdp.c arch/arm/mach-omap2/board-h4.c arch/arm/mach-omap2/board-rx51-peripherals.c arch/arm/mach-omap2/board-rx51.c arch/arm/mach-omap2/pm34xx.c drivers/mtd/nand/omap2.c drivers/mtd/onenand/omap2.c
2012-10-15ARM: OMAP: DMA: Move plat/dma.h to plat-omap/dma-omap.hLokesh Vutla
Move plat/dma.h to plat-omap/dma-omap.h as part of single zImage work Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-15ARM: OMAP2+: gpmc: localize gpmc headerAfzal Mohammed
Requirement of gpmc header outside of mach-omap2 has been cutoff, move gpmc header file in plat-omap folder to local mach-omap2 folder Objective - common zImage participation of omap Signed-off-by: Afzal Mohammed <afzal@ti.com>
2012-09-20ARM: OMAP2+: Make gpmc-smc91x.h localTony Lindgren
This can be local to mach-omap2. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-19ARM: omap: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the omap include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Kevin Hilman <khilman@ti.com> Cc: "Benoît Cousson" <b-cousson@ti.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Jean Pihet <j-pihet@ti.com> Cc: J Keerthy <j-keerthy@ti.com> Cc: linux-omap@vger.kernel.org
2012-09-12ARM: OMAP: Split plat/hardware.h, use local soc.h for omap2+Tony Lindgren
As the plat and mach includes need to disappear for single zImage work, we need to remove plat/hardware.h. Do this by splitting plat/hardware.h into omap1 and omap2+ specific files. The old plat/hardware.h already has omap1 only defines, so it gets moved to mach/hardware.h for omap1. For omap2+, we use the local soc.h that for now just includes the related SoC headers to keep this patch more readable. Note that the local soc.h still includes plat/cpu.h that can be dealt with in later patches. Let's also include plat/serial.h from common.h for all the board-*.c files. This allows making the include files local later on without patching these files again. Note that only minimal changes are done in this patch for the drivers/watchdog/omap_wdt.c driver to keep things compiling. Further patches are needed to eventually remove cpu_is_omap usage in the drivers. Also only minimal changes are done to sound/soc/omap/* to remove the unneeded includes and to define OMAP44XX_MCPDM_L3_BASE locally so there's no need to include omap44xx.h. While at it, also sort some of the includes in the standard way. Cc: linux-watchdog@vger.kernel.org Cc: alsa-devel@alsa-project.org Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Liam Girdwood <lrg@ti.com> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-12ARM: OMAP2+: Remove hardcoded twl4030 gpio_base, irq_base and irq_endTony Lindgren
We can't use hardcoded interrupts for SPARSE_IRQ, and can replace the hardcoded gpio_base with twl_gpiochip.base after it's been allocated. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-10ARM: OMAP: cleanup struct omap_board_config_kernelIgor Grinberg
struct omap_board_config_kernel defined in the board files is always empty and does not bring any added value. Remove the struct omap_board_config_kernel instances from the board files. Also remove the omap_get_nr_config() macro and the omap_get_var_config() function as both are not used for quite a long time (if ever). Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-05-26Merge tag 'cleanup-initcall' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull sweeping late_initcall cleanup for arm-soc from Olof Johansson: "This is a patch series from Shawn Guo that moves from individual late_initcalls() to using a member in the machine structure to invoke a platform's late initcalls. This cleanup is a step in the move towards multiplatform kernels since it would reduce the need to check for compatible platforms in each and every initcall." Fix up trivial conflicts in arch/arm/mach-{exynos/mach-universal_c210.c, imx/mach-cpuimx51.c, omap2/board-generic.c} due to changes nearby (and, in the case of cpuimx51.c the board support being deleted) * tag 'cleanup-initcall' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: ux500: use machine specific hook for late init ARM: tegra: use machine specific hook for late init ARM: shmobile: use machine specific hook for late init ARM: sa1100: use machine specific hook for late init ARM: s3c64xx: use machine specific hook for late init ARM: prima2: use machine specific hook for late init ARM: pnx4008: use machine specific hook for late init ARM: omap2: use machine specific hook for late init ARM: omap1: use machine specific hook for late init ARM: msm: use machine specific hook for late init ARM: imx: use machine specific hook for late init ARM: exynos: use machine specific hook for late init ARM: ep93xx: use machine specific hook for late init ARM: davinci: use machine specific hook for late init ARM: provide a late_initcall hook for platform initialization
2012-05-09OMAPDSS: TFP410: rename dvi files to tfp410Tomi Valkeinen
Now that the tfp410 driver has been renamed in the code, this patch finishes the renaming by renaming the files. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-05-09OMAPDSS: TFP410: rename dvi -> tfp410Tomi Valkeinen
The driver for the TFP410 DPI-to-DVI chip was named quite badly as "DVI panel driver". This patch renames the code to use tfp410 name for the driver. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-05-09OMAP: board-files: remove custom PD GPIO handling for DVI outputTomi Valkeinen
Now that the panel-dvi driver handles the PD (power-down) GPIO, we can remove the custom PD handling from the board files. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-05-08ARM: omap2: use machine specific hook for late initShawn Guo
Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com>
2012-02-20ARM: OMAP2+: Split omap2_hsmmc_init() to properly support I2C GPIO pinsTony Lindgren
Otherwise omap_device_build() and omap_mux related functions can't be marked as __init when twl is build as a module. If a board is using GPIO pins or regulators configured by an external chip, such as TWL PMIC on I2C bus, the board must mark those MMC controllers as deferred. Additionally both omap_hsmmc_init() and omap_hsmmc_late_init() must be called by the board. For MMC controllers using internal GPIO pins for card detect and regulators the slots don't need to be marked deferred. In this case calling omap_hsmmc_init() is sufficient. Only mark the MMC slots using gpio_cd or gpio_wd as deferred as noted by Igor Grinberg <grinberg@compulab.co.il>. Note that this patch does not change the behaviour for board-4430sdp.c board-omap4panda.c. These boards wrongly rely on the omap_hsmmc.c init function callback to configure the PMIC GPIO interrupt lines on external chip. If the PMIC interrupt lines are not configured during init, they will fail. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-01-09Merge tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
power management changes for omap and imx A significant part of the changes for these two platforms went into power management, so they are split out into a separate branch. * tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (65 commits) ARM: imx6: remove __CPUINIT annotation from v7_invalidate_l1 ARM: imx6: fix v7_invalidate_l1 by adding I-Cache invalidation ARM: imx6q: resume PL310 only when CACHE_L2X0 defined ARM: imx6q: build pm code only when CONFIG_PM selected ARM: mx5: use generic irq chip pm interface for pm functions on ARM: omap: pass minimal SoC/board data for UART from dt arm/dts: Add minimal device tree support for omap2420 and omap2430 omap-serial: Add minimal device tree support omap-serial: Use default clock speed (48Mhz) if not specified omap-serial: Get rid of all pdev->id usage ARM: OMAP2+: hwmod: Add a new flag to handle hwmods left enabled at init ARM: OMAP4: PRM: use PRCM interrupt handler ARM: OMAP3: pm: use prcm chain handler ARM: OMAP: hwmod: add support for selecting mpu_irq for each wakeup pad ARM: OMAP2+: mux: add support for PAD wakeup interrupts ARM: OMAP: PRCM: add suspend prepare / finish support ARM: OMAP: PRCM: add support for chain interrupt handler ARM: OMAP3/4: PRM: add functions to read pending IRQs, PRM barrier ARM: OMAP2+: hwmod: Add API to enable IO ring wakeup ARM: OMAP2+: mux: add wakeup-capable hwmod mux entries to dynamic list ...
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: restart: omap: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-14ARM: OMAP2+: UART: Add default mux for all uarts.Govindraj.R
Padconf wakeup is used to wakeup uart after uart fclks/iclks are gated. Rx-Pad wakeup was done by writing to rx-pad offset value populated in serial.c idle_init. Remove the direct reading and writing into rx pad. Remove the padconf field part of omap_uart_state struct and pad offsets populated. Now with mux framework support we can use mux_utilities along with hmwod framework to handle io-pad configuration and enable rx-pad wake-up mechanism. To avoid breaking any board support add default mux data for all uart's if mux info is not passed from board file. With the default pads populated in serial.c wakeup capability for rx pads is set, this can be used to enable uart_rx io-pad wakeup from hwmod framework. The pad values in 3430sdp/4430sdp/omap4panda board file are same as the default pad values populated in serial.c. Remove pad values from 3430sdp/4430sdp/omap4panda board file and use the default pads from serial.c file. Signed-off-by: Govindraj.R <govindraj.raja@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-11-21Merge branch 'irqchip-consolidation' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into devel-stable Conflicts: arch/arm/mach-omap2/board-4430sdp.c arch/arm/mach-omap2/board-omap4panda.c arch/arm/mach-omap2/include/mach/omap4-common.h arch/arm/plat-omap/include/plat/irqs.h The changes to omap4-common.h were moved to arch/arm/mach-omap2/common.h and the other trivial conflicts resolved. The now empty ifdef in irqs.h was also eliminated.
2011-11-17ARM: 7159/1: OMAP: Introduce local common.h filesTony Lindgren
As suggested by Russell King - ARM Linux <linux@arm.linux.org.uk>, there's no need to keep local prototypes in non-local headers. Add mach-omap1/common.h and mach-omap2/common.h and move the local prototypes there from plat/common.h and mach/omap4-common.h. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-15ARM: omap2plus: convert to CONFIG_MULTI_IRQ_HANDLERMarc Zyngier
Convert the omap2plus platforms to be using CONFIG_MULTI_IRQ_HANDLER. Each machine is modified to provide either omap2_intc_handle_irq(), omap3_intc_handle_irq() or gic_handle_irq(). This allows for a major cleanup, removing the MULTI_OMAP setup from the interrupt path. Tested on both Panda and IGEPv2 (single kernel image) Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2011-10-31Merge branch 'depends/omap2_dss' into next/cleanupArnd Bergmann
Omap cleanups conflicted with omap2_dss work in a nontrivial way, this is the most logical fixup. Conflicts: arch/arm/mach-omap2/board-2430sdp.c arch/arm/mach-omap2/board-4430sdp.c arch/arm/mach-omap2/board-apollon.c arch/arm/mach-omap2/board-h4.c arch/arm/mach-omap2/board-ldp.c arch/arm/mach-omap2/board-rx51.c Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-08Merge branch 'depends/rmk/devel-stable' into next/cleanupArnd Bergmann
2011-09-30OMAP: use dvi panel driver instead of generic-dpiTomi Valkeinen
Multiple OMAP3/4 boards have a DVI framer output. This patch makes the boards use the new panel-dvi driver, instead of the panel-generic-dpi driver. Separate drivers for fixed size panels and DVI framer gives us cleaner driver code. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-08-24ARM: OMAP: Introduce SoC specific early_initTony Lindgren
Introduce them for each omap variant and just make them all call omap2_init_common_infrastructure for now. Do this for each board-*.c file except for board-generic and board-omap3beagle as they use the same machine ID for multiple SoCs. No functional changes. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-24ARM: OMAP: Move omap2_init_common_devices out of init_earlyTony Lindgren
There's no need to call omap2_init_common_devices from init_early. It no longer does anything else except reprogram the memory timings for some boards, so it's better to do it later so we have a chance to get console messages if something goes wrong. Move it to happen after omap_serial_init gets called. And while patching it anyways, rename it to omap_sdrc_init as suggested by Benoit Cousson <b-cousson@ti.com>. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-21ARM: mach-omap2: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-07-04OMAP3: Move common regulator configuration to twl-commonPeter Ujfalusi
Some regulator config can be moved out from board files, since they are close to identical. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2011-07-04OMAP3: Move common twl configuration to twl-commonPeter Ujfalusi
Reduce the amount of duplicated code by moving the common configuration for twl4030/5030/tpsxx to the twl-common file. Use the omap3_pmic_get_config function from board files to properly configure the PMIC with the common fields. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
