path: root/arch/arm/mach-omap1
2007-08-22ARM: OMAP: H3 workqueue fixesDirk Behme
Signed-off-by: Dirk Behme <dirk.behme@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-08-22ARM: OMAP: OSK led fixesDavid Brownell
Bugfixes for the OSK led support: - Fix Kconfig merge glitches: Mistral handles idle and timer leds just fine - Fix pm_suspend() runtime botch: can't sleep, so can't touch tps65010 leds Improvements: - Switch sense of Mistral idle led, so idle == off Probably the TPS65010 leds should be handled only by the "new led" API. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-07-21clockevents: fix resume logicThomas Gleixner
We need to make sure, that the clockevent devices are resumed, before the tick is resumed. The current resume logic does not guarantee this. Add CLOCK_EVT_MODE_RESUME and call the set mode functions of the clock event devices before resuming the tick / oneshot functionality. Fixup the existing users. Thanks to Nigel Cunningham for tracking down a long standing thinko, which affected the jinxed VAIO. [akpm@linux-foundation.org: xen build fix] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-16[ARM] Silence OMAP kernel configuration warningRussell King
arch/arm/mach-omap1/Kconfig:41:warning: 'select' used by config symbol 'MACH_OMAP_H3' refers to undefined symbol 'GPIOEXPANDER_OMAP' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-10ARM: OMAP: Fix section mismatch warningTony Lindgren
Fix section mismatch warning Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-05-10ARM: OMAP: Remove old PM_SUSPEND_DISKTony Lindgren
Remove old PM_SUSPEND_DISK. Also some minor cosmetic clean-up. Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-05-09Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (28 commits) ARM: OMAP: Fix GCC-reported compile time bug ARM: OMAP: restore CONFIG_GENERIC_TIME ARM: OMAP: partial LED fixes ARM: OMAP: add SoSSI clock (call propagate_rate for childrens) ARM: OMAP: FB sync with N800 tree (support for dynamic SRAM allocations) ARM: OMAP: Sync framebuffer headers with N800 tree ARM: OMAP: Mostly cosmetic to sync up with linux-omap tree ARM: OMAP: Fix gpmc header ARM: OMAP: Add mailbox support for IVA [ARM] armv7: add Makefile and Kconfig entries [ARM] armv7: add support for asid-tagged VIVT I-cache [ARM] armv7: add dedicated ARMv7 barrier instructions [ARM] armv7: Add ARMv7 cacheid macros [ARM] armv7: add support for ARMv7 cores. [ARM] Fix ARM branch relocation range [ARM] 4363/1: AT91: Remove legacy PIO definitions [ARM] 4361/1: AT91: Build error ARM: OMAP: Sync core code with linux-omap ARM: OMAP: Sync headers with linux-omap ARM: OMAP: h4 must have blinky leds!! ...
2007-05-09Merge branches 'armv7', 'at91', 'misc' and 'omap' into develRussell King
2007-05-09ARM: OMAP: FB sync with N800 tree (support for dynamic SRAM allocations)Imre Deak
- in addition to fixed FB regions - as passed by the bootloader - allow dynamic allocations - do some more checking against overlapping / reserved regions - move the FB specific parts out from sram.c to fb.c Signed-off-by: Imre Deak <imre.deak@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-09ARM: OMAP: Mostly cosmetic to sync up with linux-omap treeTony Lindgren
Mostly cosmetic to sync up with linux-omap tree Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-09ARM: OMAP: Add mailbox support for IVAHiroshi DOYU
This patch adds a generic mailbox interface for for DSP and IVA (Image Video Accelerator). This patch itself doesn't contain any IVA driver. Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-09misc doc and kconfig typosMatt LaPlante
Fix various typos in kernel docs and Kconfigs, 2.6.21-rc4. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08ARM: OMAP: Sync core code with linux-omapTony Lindgren
This patch syncs omap specific core code with linux-omap. Most of the changes are needed to fix bitrot caused by driver updates in linux-omap tree. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08ARM: OMAP: gpio init section cleanupsDavid Brownell
Minor GPIO cleanups: remove needless #include, and omap_gpio_init() should be __init, as well as all the board init code calling it. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-06Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (82 commits) [ARM] Add comments marking in-use ptrace numbers [ARM] Move syscall saving out of the way of utrace [ARM] 4360/1: S3C24XX: regs-udc.h remove unused macro [ARM] 4358/1: S3C24XX: mach-qt2410.c: remove linux/mmc/protocol.h header [ARM] mm 10: allow memory type to be specified with ioremap [ARM] mm 9: add additional device memory types [ARM] mm 8: define mem_types table L1 bit 4 to be for ARMv6 [ARM] iop: add missing parens in macro [ARM] mm 7: remove duplicated __ioremap() prototypes ARM: OMAP: fix OMAP1 mpuio suspend/resume oops ARM: OMAP: MPUIO wake updates ARM: OMAP: speed up gpio irq handling ARM: OMAP: plat-omap changes for 2430 SDP ARM: OMAP: gpio object shrinkage, cleanup ARM: OMAP: /sys/kernel/debug/omap_gpio ARM: OMAP: Implement workaround for GPIO wakeup bug in OMAP2420 silicon ARM: OMAP: Enable 24xx GPIO autoidling [ARM] 4318/2: DSM-G600 Board Support [ARM] 4227/1: minor head.S fixups [ARM] 4328/1: Move i.MX UART regs to driver ...
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-30power management: implement pm_ops.valid for everybodyJohannes Berg
Almost all users of pm_ops only support mem sleep, don't check in .valid and don't reject any others in .prepare so users can be confused if they check /sys/power/state, especially when new states are added (these would then result in s-t-r although they're supposed to be something different). This patch implements a generic pm_valid_only_mem function that is then exported for users and puts it to use in almost all existing pm_ops. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: David Brownell <david-b@pacbell.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: linux-pm@lists.linux-foundation.org Cc: Len Brown <lenb@kernel.org> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30rework pm_ops pm_disk_mode, kill misuseJohannes Berg
This patch series cleans up some misconceptions about pm_ops. Some users of the pm_ops structure attempt to use it to stop the user from entering suspend to disk, this, however, is not possible since the user can always use "shutdown" in /sys/power/disk and then the pm_ops are never invoked. Also, platforms that don't support suspend to disk simply should not allow configuring SOFTWARE_SUSPEND (read the help text on it, it only selects suspend to disk and nothing else, all the other stuff depends on PM). The pm_ops structure is actually intended to provide a way to enter platform-defined sleep states (currently supported states are "standby" and "mem" (suspend to ram)) and additionally (if SOFTWARE_SUSPEND is configured) allows a platform to support a platform specific way to enter low-power mode once everything has been saved to disk. This is currently only used by ACPI (S4). This patch: The pm_ops.pm_disk_mode is used in totally bogus ways since nobody really seems to understand what it actually does. This patch clarifies the pm_disk_mode description. It also removes all the arm and sh users that think they can veto suspend to disk via pm_ops; not so since the user can always do echo shutdown > /sys/power/disk, they need to find a better way involving Kconfig or such. ACPI is the only user left with a non-zero pm_disk_mode. The patch also sets the default mode to shutdown again, but when a new pm_ops is registered its pm_disk_mode is selected as default, that way the default stays for ACPI where it is apparently required. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: David Brownell <david-b@pacbell.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: <linux-pm@lists.linux-foundation.org> Cc: Len Brown <lenb@kernel.org> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-21[ARM] 4262/1: OMAP: clocksource and clockevent supportKevin Hilman
Update OMAP1 to enable support for hrtimers and dynticks by using new clocksource and clockevent infrastructure. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] Remove needless linux/ptrace.h includesRussell King
Lots of places in arch/arm were needlessly including linux/ptrace.h, resumably because we used to pass a struct pt_regs to interrupt handlers. Now that we don't, all these ptrace.h includes are redundant. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-07ARM: OMAP: Fix missing workqueue include in board-h2.cDirk Behme
ARM: OMAP: Fix missing #include <linux/workqueue.h> in board-h2.c resulting in In file included from arch/arm/mach-omap1/board-h2.c:40: include/asm/arch/irda.h:27: error: field 'gpio_expa' has incomplete type Signed-off-by: Dirk Behme <dirk.behme_at_gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: omap1510->15xx conversions needed for sx1Vladimir Ananiev
Convert 1510->15xx in generic omap code, so that sx1 can work. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: Add missing includes to board-nokia770Dirk Behme
Add missing includes to board-nokia770 to make it compile again. Signed-off-by: Dirk Behme <dirk.behme_at_gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: board-nokia770: correct lcd nameArnaud Patard
Some time ago, the 'lcd_lph8923' device was renamed to 'lcd_mipid' but the board-nokia770.c file was not updated accordingly, leading to not working lcd. This one-liner fixe the trouble. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: Fix warning in mach-omap1Dirk Behme
Fix warning arch/arm/mach-omap1/pm.c: In function 'omap_pm_init': arch/arm/mach-omap1/pm.c:765: warning: ignoring return value of 'subsys_create_file', declared with attribute warn_unused_result Signed-off-by: Dirk Behme <dirk.behme_at_gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: Fix CONFIG_DEBUG_LLDirk Behme
Fix broken CONFIG_DEBUG_LL. In case of low level debugging reconfigure some clocks early. See http://source.mvista.com/git/gitweb.cgi?p=linux-omap-2.6.git;a=commitdiff;h=3bfb289ccc6c4624fd5ff0381546935e105f4093 too. Signed-off-by: Dirk Behme <dirk.behme_at_gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: OMAP310 SerialMarek Vašut
This makes serial usable also on omap310, not only 1510. (changing 1510->15xx) Signed-off-by: Marek Vašut <marek.vasut@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: Fix warning in clock.cDirk Behme
Fix warning: arch/arm/mach-omap1/clock.c: In function 'omap1_clk_enable_generic': arch/arm/mach-omap1/clock.c:499: warning: 'return' with no value, in function returning non-void Signed-off-by: Dirk Behme <dirk.behme_at_gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: correct misc 15xx and non-15xx platform codeAndrzej Zaborowski
Disable accesses to SOFT_REQ_REG2 and ULPD_SOFT_DISABLE_REQ_REG registers for 15xx processors that don't have these registers. Enable level 2 interrupt handler for processors that identify as OMAP 15xx (e.g 310) and not 1510 specifically. Also fix the following compiler warning (only visible with CONFIG_OMAP_RESET_CLOCKS): arch/arm/mach-omap1/clock.c: In function 'omap1_clk_disable_unused': arch/arm/mach-omap1/clock.c:634: warning: 'return' with a value, in function returning void Signed-off-by: Andrzej Zaborowski <balrog@zabor.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-12-13[PATCH] another build fix, header rearrangements (OSK)David Brownell
Some of the header file rearrangements broke the build for board-osk. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: <tony@atomide.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] fix more workqueue build breakage (tps65010)David Brownell
More fixes to build breakage from the work_struct changes ... this updates the tps65010 driver. Plus, fix some dependencies related to the way it's used on the OMAP OSK: force static linking there, since the resulting kernel can't link. NOTE that until the i2c core gets fixed to work without SMBUS_QUICK, kernels needing this driver must still use "tps65010.force=0,0x48" on the command line. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (76 commits) [ARM] 4002/1: S3C24XX: leave parent IRQs unmasked [ARM] 4001/1: S3C24XX: shorten reboot time [ARM] 3983/2: remove unused argument to __bug() [ARM] 4000/1: Osiris: add third serial port in [ARM] 3999/1: RX3715: suspend to RAM support [ARM] 3998/1: VR1000: LED platform devices [ARM] 3995/1: iop13xx: add iop13xx support [ARM] 3968/1: iop13xx: add iop13xx_defconfig [ARM] Update mach-types [ARM] Allow gcc to optimise arm_add_memory a little more [ARM] 3991/1: i.MX/MX1 high resolution time source [ARM] 3990/1: i.MX/MX1 more precise PLL decode [ARM] 3986/1: H1940: suspend to RAM support [ARM] 3985/1: ixp4xx clocksource cleanup [ARM] 3984/1: ixp4xx/nslu2: Fix disk LED numbering (take 2) [ARM] 3994/1: ixp23xx: fix handling of pci master aborts [ARM] 3981/1: sched_clock for PXA2xx [ARM] 3980/1: extend the ARM Versatile sched_clock implementation from 32 to 63 bit [ARM] 3979/1: extend the SA11x0 sched_clock implementation from 32 to 63 bit period [ARM] 3978/1: macro to provide a 63-bit value from a 32-bit hardware counter ...
2006-12-07[PATCH] add rtc-omap driverDavid Brownell
This creates a new RTC-framework driver for the RTC/calendar module found in various OMAP1 chips. (OMAP2 and OMAP3 use external RTCs, like those in TI's multifunction PM companion chips.) It's been in the Linux-OMAP tree for several months now, and other trees before that, so it's quite stable. The most notable issue is that the OMAP IRQ code doesn't yet support the RTC IRQ as a wakeup event. Once that's fixed, a patch will be needed. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05WorkQueue: Fix up arch-specific work items where possibleDavid Howells
Fix up arch-specific work items where possible to use the new work_struct and delayed_work structs. Three places that enqueue bits of their stack and then return have been marked with #error as this is not permitted. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-29[PATCH] OMAP: Update OMAP1/2 boards to give keymapsize and other pdataKomal Shah
This patch adds keymapsize, delay and debounce flag in the keypad platform data for various TI OMAP1/2 based boards like F-sample, H2, H3, Innovator, Nokia770, OSK, Perseus and H4. Signed-off-by: Komal Shah <komal_shah802003@yahoo.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25ARM: OMAP: Sync clocks with linux-omap treeTony Lindgren
Mostly clean up CONFIG_OMAP_RESET_CLOCKS. Also includes a patch from Imre Deak to make McSPI clocks use id. Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-09-25ARM: OMAP: mux: add config for 16xx SPI pinsMark Howell
This patch adds pin mux info for the SPI master/slave interface on OMAP16xx. Data from OMAP 1611/1612 TRM and errata. Works for me on my 1611/H2 with current git kernel. Signed-off-by: Mark Howell <mhowell@northlink.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-08-01[ARM] 3739/1: genirq updates: irq_chip, add and use irq_chip.nameDavid Brownell
Patch from David Brownell ARM genirq cleanups/updates: - Start switching platforms to newer APIs * use "irq_chip" name, not "irqchip" * providing irq_chip.name - Show irq_chip.name in /proc/interrupts, like on x86. This update a bit more than half of the ARM code. The irq_chip.name values were chosen to match docs (if I have them) or be otherwise obvious ("FPGA", "CPLD", or matching the code). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02Merge branch 'genirq' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'genirq' of master.kernel.org:/home/rmk/linux-2.6-arm: (24 commits) [ARM] 3683/2: ARM: Convert at91rm9200 to generic irq handling [ARM] 3682/2: ARM: Convert ixp4xx to generic irq handling [ARM] 3702/1: ARM: Convert ixp23xx to generic irq handling [ARM] 3701/1: ARM: Convert plat-omap to generic irq handling [ARM] 3700/1: ARM: Convert lh7a40x to generic irq handling [ARM] 3699/1: ARM: Convert s3c2410 to generic irq handling [ARM] 3698/1: ARM: Convert sa1100 to generic irq handling [ARM] 3697/1: ARM: Convert shark to generic irq handling [ARM] 3696/1: ARM: Convert clps711x to generic irq handling [ARM] 3694/1: ARM: Convert ecard driver to generic irq handling [ARM] 3693/1: ARM: Convert omap1 to generic irq handling [ARM] 3691/1: ARM: Convert imx to generic irq handling [ARM] 3688/1: ARM: Convert clps7500 to generic irq handling [ARM] 3687/1: ARM: Convert integrator to generic irq handling [ARM] 3685/1: ARM: Convert pxa to generic irq handling [ARM] 3684/1: ARM: Convert l7200 to generic irq handling [ARM] 3681/1: ARM: Convert ixp2000 to generic irq handling [ARM] 3680/1: ARM: Convert footbridge to generic irq handling [ARM] 3695/1: ARM drivers/pcmcia: Fixup includes [ARM] 3689/1: ARM drivers/input/touchscreen: Fixup includes ... Manual conflict resolved in kernel/irq/handle.c (butt-ugly ARM tickless code).
2006-07-02Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (44 commits) [ARM] 3541/2: workaround for PXA27x erratum E7 [ARM] nommu: provide a way for correct control register value selection [ARM] 3705/1: add supersection support to ioremap() [ARM] 3707/1: iwmmxt: use the generic thread notifier infrastructure [ARM] 3706/2: ep93xx: add cirrus logic edb9315a support [ARM] 3704/1: format IOP Kconfig with tabs, create more consistency [ARM] 3703/1: Add help description for ARCH_EP80219 [ARM] 3678/1: MMC: Make OMAP MMC work [ARM] 3677/1: OMAP: Update H2 defconfig [ARM] 3676/1: ARM: OMAP: Fix dmtimers and timer32k to compile on OMAP1 [ARM] Add section support to ioremap [ARM] Fix sa11x0 SDRAM selection [ARM] Set bit 4 on section mappings correctly depending on CPU [ARM] 3666/1: TRIZEPS4 [1/5] core ARM: OMAP: Multiplexing for 24xx GPMC wait pin monitoring ARM: OMAP: Fix SRAM to use MT_MEMORY instead of MT_DEVICE ARM: OMAP: Update dmtimers ARM: OMAP: Make clock variables static ARM: OMAP: Fix GPMC compilation when DEBUG is defined ARM: OMAP: Mux updates for external DMA and GPIO ...
2006-07-01[ARM] 3693/1: ARM: Convert omap1 to generic irq handlingThomas Gleixner
Patch from Thomas Gleixner From: Thomas Gleixner <tglx@linutronix.de> Fixup the conversion to generic irq subsystem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-26ARM: OMAP: Add bitbank SPI driver for Innovator 1510 touchscreenDavid Brownell
Add bitbang SPI driver for Innovator 1510 touchscreen, using the new framework. Compile-tested only. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-06-26ARM: OMAP: Aic23 alsa platform driver code for board-innovatorlamikr
Add platform driver init-code required by the aic23-alsa driver to omap-innovator. Signed-off-by: Mika Laitio <lamikr@cc.jyu.fi> Signed-off-by: Tony Lindgren <tony@atomide.com>
