path: root/arch/arm/mach-omap1/irq.c
2007-03-02ARM: OMAP: correct misc 15xx and non-15xx platform codeAndrzej Zaborowski
Disable accesses to SOFT_REQ_REG2 and ULPD_SOFT_DISABLE_REQ_REG registers for 15xx processors that don't have these registers. Enable level 2 interrupt handler for processors that identify as OMAP 15xx (e.g 310) and not 1510 specifically. Also fix the following compiler warning (only visible with CONFIG_OMAP_RESET_CLOCKS): arch/arm/mach-omap1/clock.c: In function 'omap1_clk_disable_unused': arch/arm/mach-omap1/clock.c:634: warning: 'return' with a value, in function returning void Signed-off-by: Andrzej Zaborowski <balrog@zabor.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-01[ARM] 3739/1: genirq updates: irq_chip, add and use irq_chip.nameDavid Brownell
Patch from David Brownell ARM genirq cleanups/updates: - Start switching platforms to newer APIs * use "irq_chip" name, not "irqchip" * providing irq_chip.name - Show irq_chip.name in /proc/interrupts, like on x86. This update a bit more than half of the ARM code. The irq_chip.name values were chosen to match docs (if I have them) or be otherwise obvious ("FPGA", "CPLD", or matching the code). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-02[ARM] 3455/1: ARM: OMAP: 7/8 Misc updates, take 2Tony Lindgren
Patch from Tony Lindgren Update misc OMAP core code from linux-omap tree: - McBSP updates by Samuel Ortiz, Andrzej Zaborowski - Whitespace cleanups by Ladislav Michl - Other fixes by various linux-omap developers Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3141/1: OMAP 1/5: Update omap1 specific filesTony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Omap1 serial pport and framebuffer init updates by Imre Deak - Add support for omap310 processor and Palm Tungsten E PDA by Laurent Gonzales, Romain Goyet, et al. Omap310 and omap1510 processors are now handled as omap15xx. - Omap1 specific changes to shared omap clock framework by Tony Lindgren - Omap1 specific changes to shared omap pin mux framework by Tony Lindgren - Other misc fixes, such as update memory timings for smc91x, omap1 specific device initialization etc. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[ARM] 2890/1: OMAP 1/4: Update omap1 specific files, take 2Tony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Convert more drivers to register resources in board-*.c to take advantage of the driver model by David Brownell and Ladislav Michl - Use set_irq_type() for GPIO interrupts instead of omap_set_gpio_edge_ctrl() by David Brownell - Add minimal support for handling optional add-on boards, such as OSK Mistral board with LCD and keypad, by David Brownell - Minimal support for loading functions to SRAM by Tony Lindgren - Wake up from serial port by muxing RX lines temporarily into GPIO interrupts by Tony Lindgren - 32KHz sched_clock by Tony Lindgren and Juha Yrjola Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-06[ARM] Fix missed initialisers/missing commaRussell King
Fix the broken initialisers missed by the recent IRQ patch. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-10[PATCH] ARM: 2800/1: OMAP update 3/11: Move OMAP1 core code into mach-omap1 ↵Tony Lindgren
directory Patch from Tony Lindgren This patch by Paul Mundt and other OMAP developers moves OMAP1 specific IRQ, time, and FPGA code into mach-omap1 directory. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
