path: root/arch/arm/mach-omap1/i2c.c
2015-05-20ARM: OMAP1: Change interrupt numbering for sparse IRQTony Lindgren
Change interrupt numbering for sparse IRQ. We do this using a fixed offset until we can drop irqs.h once all it's users have been updated. Note that this depends on the GPIO fix for the MPUIO IRQs "gpio: omap: Fix regression for MPUIO interrupts". Also note that this patch adds some extra irq alloc warnings that will go away when we stop calling irq_alloc_descs in gpio-omap.c with a follow-up patch. Cc: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-01-11ARM: OMAP: Fix i2c cmdline initcall for multiplatformTony Lindgren
We only want this initcall to run when the kernel is booted on omap SoCs. Fix the issue by initializing the the initcall from separately for omap1 and omap2+. This fixes the issue for omap2+ multiplatform configs as we are using omap_subsys_initcall there. Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-31ARM: OMAP: Fix relative includes for shared i2c.h fileTony Lindgren
As discussed on linux-arm-kernel, we want to avoid relative includes for the arch/arm/*omap* shared code: http://www.spinics.net/lists/linux-omap/msg80520.html To fix this for the shared i2c.h, let's re-introduce a minimal plat/i2c.h. Note that drivers must not use this header as it will break build for omap2+ CONFIG_MULTIPLATFORM builds. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-31ARM: OMAP: Make plat-omap/i2c.c port checks localTony Lindgren
The common code should not have any omap1 or omap2+ specific code, and should not need to call the cpu_is_omap macros. The only remaining user for cpu_is_omap macros is omap_i2c_nr_ports(). Let's make those checks in the omap specific implementation of omap_i2c_add_bus() instead in order to remove cpu_is_omap usage from the common code. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-18ARM: OMAP: Split plat/cpu.h into local soc.h for mach-omap1 and mach-omap2Tony Lindgren
We want to remove plat/cpu.h. To do this, let's first split it to private soc.h to mach-omap1 and mach-omap2. We have to keep plat/cpu.h around until the remaining drivers are fixed, so let's include the local soc.h in plat/cpu.h and for drivers still including plat/cpu.h. Once the drivers are fixed not to include plat/cpu.h, we can remove the file. This is needed for the ARM common zImage support. [tony@atomide.com: updated to not print a warning] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-17ARM: OMAP: Split plat-omap/i2c.c into mach-omap1 and mach-omap2Tony Lindgren
There's no need to keep the device related things in the common i2c.c as omap2+ is using hwmod. Split the code to mach-omap1 and mach-omap2 parts and only leave common code to plat-omap/i2c.c. Note that as omap1 only has one i2c controller, we can now remove the old device related macros. Reviewed-by: Shubhrajyoti D <shubhrajyoti@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-20ARM: OMAP1: Make plat/mux.h omap1 onlyTony Lindgren
We are moving omap2+ to use the device tree based pinctrl-single.c and will be removing the old mux framework. This will remove the omap1 specific parts from plat-omap. Acked-by: Felipe Balbi <balbi@ti.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: linux-usb@vger.kernel.org Cc: linux-pcmcia@lists.infradead.org Cc: spi-devel-general@lists.sourceforge.net Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-25omap: i2c: Fix muxing for command line enabled busJarkko Nikula
The commit b63128e81214cc2db2995d690438055c26d213a5 broke the pin muxing for I2C busses that are enabled from the kernel command line. Fix this by defining the board registration function omap_register_i2c_bus in common platform code as it was before but keep the muxing in architecture dependent files. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap1: I2C mux and clocks for omap7xxCory Maccarrone
This change adds MUX pin configuration and clocks for I2C support to OMAP 730 and 850-based devices. Signed-off-by: Cory Maccarrone <darkstar6262@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: Split i2c platform init for mach-omap1 and mach-omap2Tony Lindgren
Otherwise we cannot limit new mux code to mach-omap2. The same signal names should eventually work for other omaps under mach-omap2. Note that these pins don't need to be OMAP_PIN_INPUT_PULLUP, just OMAP_PIN_INPUT is enough. Cc: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
