path: root/arch/arm/mach-mx2/pcm970-baseboard.c
2009-08-07pcm038: Add support for SJA1000 on baseboardSascha Hauer
2009-08-07imxfb: Add support for multiple displaysSascha Hauer
2009-05-07PCM038: Remove unnecessary ifdefs, reorder includes alphabeticallySascha Hauer
2009-05-07pcm038: Setup all iomux pins at onceSascha Hauer
Also, remove usage of set_irq_type after request_irq. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-05-07imx: exit functions can/should be voidHolger Schurig
Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-13pcm970 baseboard: Add SDHC supportSascha Hauer
2009-03-13[ARM] pcm038: Add framebuffer supportSascha Hauer
Add framebuffer support for PCM038 Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Eliminate useless includes of asm/mach-types.hRussell King
There are 43 includes of asm/mach-types.h by files that don't reference anything from that file. Remove these unnecessary includes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-05i.MX27 family: Add the Phytec PCM970 evaluation boardJuergen Beisert
The Phytec phyCORE-i.MX27 CPU module is delivered with the PCM970 baseboard by default. This patch adds support for the hardware. This code is only an empty stub; it is filled up with functionality in a later patch series. Signed-off-by: Juergen Beisert <j.beisert@pengutronix.de>
