path: root/arch/arm/mach-msm/gpio-v2.c
2011-08-01gpio_msm: Move Qualcomm MSM v2 gpio driver into driversDavid Brown
Migrate the driver for the v7-based MSM chips into drivers/gpio. The driver is unchanged, only moved. Change-Id: I810db5b50b71cdca4e869aa0d0310f7f48781a55 Signed-off-by: David Brown <davidb@codeaurora.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-05-11ARM: msm: update GPIO chained IRQ handler to use entry/exit functionsWill Deacon
This patch updates the MSM gpio chained IRQ handler to use the chained IRQ enter/exit functions in order to function correctly on primary controllers with different methods of flow control. Tested-and-reviewed-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: msm: Use proper irq accessor functionsThomas Gleixner
2011-03-29arm: msm: Convert to new irq chip functionsThomas Gleixner
2010-11-30msm: gpio: Add irq support to v2 gpiolib.Gregory Bean
Complete the MSM v2 gpio subsystem by adding irq_chip. Signed-off-by: Gregory Bean <gbean@codeaurora.org> Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2010-11-30msm: gpio: Add v2 gpio support to MSM SoCs.Gregory Bean
Beginning with the MSM8x60, the hardware block responsible for gpio support changes. Provide gpiolib support for the new v2 architecture. Cc: Baruch Siach <baruch@tkos.co.il> Cc: Pavan Kondeti <pkondeti@codeaurora.org> Signed-off-by: Gregory Bean <gbean@codeaurora.org> Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
